  3. nRF5 action!
nRF5 action!
1.9k Posts 49 Posters 2.1m Views 44 Watching
    I received the Linx parts today. I like them more than any other battery holders I've yet seen, because they elevate the sides just a smidge, which eliminates any risk of short-circuiting to nearby through-holes. For instance, the ones from Aliexpress (linked above by Omemtani) don't do that. Nor do any of the other ones I've tried so far.
    On Tuesday I should receive PCB's specifically designed to use the Linx holders. I can hardly wait.
    @neverdie said in nRF5 Bluetooth action!:
    I received the PCB's a day early. Unfortunately, it's almost total fiction to say that the Linx holder is designed to hold two CR2032's. Instead, it can hold one CR2032 comfortably, or, with finessing, it can hold two CR2025's. With extreme finessing I did get it to hold two CR2032's, but it will be touch-and-go as to whether the solder joints will hold long-term under the strain. Aside from the small footprint, I'm not happy with it. :(
      I guess for now, until something better can be found, I'll simply make do with either 1x CR2032 (240mah) or 2x CR2016 (effectively 100mah).
        #1334
        Here's my latest remote control:
        It has a pa-lna nRF52832 which can draw up to 250ma during Tx. It's powered by two CR2032's but draws absolutely zero current unless one of the buttons is pressed.
        If powered through the connector, however, it can run continuously, without either button being pressed. In that case, it could also serve as a transceiver, sending serial output over the connector.
        It's small and has a nice feel to it. I'm happy with it. :)
          In the next version I'm going to use a somewhat unusual shaped solder jumper, in case I want to use just a single coin cell battery (not two) and therefore bypass the LDO (well, not install an LDO at all).
          • nagelcN
            nagelcN
            nagelc
            @NeverDie I'm thinking about making the jump from NRF24s and RFM69s to the NRF5 eco system. I see you have tried quite a few different modules. If you had to pick now, would you go with the Fanstel BT832X for a gateway and BT832 for most modules?
            • nagelcN nagelc
              #1337
              @nagelc said in nRF5 Bluetooth action!:
              Yes. If cost and space were no issue, I'd probably use the BT832X on everything, because it also has the best antenna. For nRF52's, for what I'm doing I like Fanstel's stuff the best. If I needed a module with more exposed pins, then the EByte would be my choice. But nothing I'm doing requires that many exposed pins, and I think the Fanstel will likely be drop-in upgradeable to the final nRF52840 modules when final silicon for that becomes available. Of course, there's no guarantee of that, but it seems very likely.
              Also important, at least to me, is that the Fanstel modules have FCC approval, and being based in the US, I don't think they're lying about it (unlike random stuff from China).
              That said, the nRF51822-04's are a lot of fun, because they're small and relatively cheap.
              • nagelcN
                nagelcN
                nagelc
                Great. I have some on order. Can't wait go start playing around with them.
                • nagelcN nagelc
                  Great! I invite you to start making posts to this thread when you do, as fresh perspectives are always welcome.
                  • A
                    Alexey Strelnikov
                    wrote on last edited by Alexey Strelnikov
                    #1340
                    Hello, I want to build battery powered modules (with sleep). I found on Ebay NRF51822 round module with case (https://www.ebay.com/itm/hello/112650665753) - only $6.50 with shipping. Is this module is good choice? Any pitfalls?
                    I planning to use water leak sensor, BME280 (I2C), ds18b20(1-wire), maybe MH-Z19 later.
                    I don't have enough experience, I have only used ESP8266 NodeMcu V3 and Arduino before.
                    I can see one I2C (for programator and sensors?) and one GPIO as button for water leak (right?) + LED pin. Does this module have more pins? Shall I connect to chip legs to obtain more pins (GPIO) (does I need to connect resistors?) for 1-wire or better use some sort of I2C GPIO expander?
                    NeverDieN Nca78N 2 Replies Last reply
                    • A Alexey Strelnikov
                      @alexey-strelnikov
                      Looks nice, but any hardware mods and it probably won't fit the case anymore.
                        @alexey-strelnikov I have one and there are pads to program it but nothing more, it's not really a "module" but a Bluetooth beacon, the only 2 I/Os available are those from the button and the led, there's a footprint for an accelerometer also but the pads are too tiny to solder any wire.
                        If you're planning to use other sensors don't buy that one. It's great as a button sensor but any other use will need soldering to LGA-sized pads...
                        • Nca78N
                          I received the "holyiot" modules and they are really, really tiny. 2 attached together are exactly the same size than the 51822-04 module. WL-CSP package is very impressive: small, very thin and with a cool shinny surface.
                          This module has inductors for DC/DC mode, and pins .00 and .01 are mapped so it's possible to add low frequency crystal for Bluetooth mode.
                          • Nca78N Nca78
                            #1344
                            @nca78
                            Nice!
                            I'll be very interested to know how the range compares. At least so far, in my own comparisons, smaller has meant less range. Not necessarily a deal killer though, as you only need range that's "good enough," and you can compensate with a better antenna on the gateway.
                            Nca78N 1 Reply Last reply
                              @nca78
                              Nice!
                              @nca78
                              Nice!
                              Yes I'll try to test next week to have an idea of the range, if it's "good enough" to be usable at least with a central pa/lna gateway or if it's better to stick with bigger PCB antennas.
                              nrf51822-04 is small enough but this one has a better chip and 11 I/Os available, that's precious for a multisensor board.
                              • Nca78N Nca78
                                @nca78
                                Nice!
                                @nca78 said in nRF5 Bluetooth action!:
                                nrf51822-04
                                What I've noticed is that Rx range was much more compromised with a reduction in size than the Tx range is. Or, to put it differently, Tx range isn't as dramatically compromised. That's potentially good news for a sensor, which may Tx only anyway (i.e. "passive" in the mysensors jargon). But even if it does Rx, your gateway can be much more powerful on its Tx. So, it potentially works out rather nicely, if you know what I mean.
                                • nagelcN
                                  nagelcN
                                  nagelc
                                  Just received my Fanstell modules. Yikes! 1.1mm pin pitch didn't look that small in the pictures. Do you solder these by hand? I thought my soldering skills were getting pretty good, but I can see I'm going to have to up my game.
                                  • nagelcN nagelc
                                    @nagelc Yes, I solder it by hand. It's easier than it looks. Just use a narrow tip and maybe extra flux if you need it.
                                      Here's my latest gateway sheild for the Wemos D1 Mini:
                                      In the interest of both belt and suspenders, I gave it its own 300ma LDO so that it won't be competing with the Wemos D1 Mini for current. Earlier measurements of this Fanstel ldo-pa nRF52832 shows that it can draw up to 250ma.
                                      It's designed to work well with ESP-LINK, which can also be used to remotely reset the nRF52832 if that's ever needed. Presently, I'm using ESP-LINK's built-in MQTT to send MQTT to a Mosquito MQTT broker. This offloads that task from the nRF52832, which just inputs/outputs serial.
                                      By the way, I soldered the entire thing using a wide chisel point solder tip, so it turns out you don't really need a narrow solder tip after all. I do use Rosin flux, though, and it does a great job. The only inconvenience is that the excess Rosin flux should be cleaned off afterward, but, meh, I don't find that to be much of a bother.
                                      • Nca78N Nca78
                                        @nca78
                                        Nice!
                                        #1350
                                        @nca78
                                        Nice!
                                        Any update?
                                        Also, what is the size of the pads? The only info I've found is what appears on the aliexpress website, which only seems to express the distance (center to center) between the pads. I just received some of these modules, so I'd like to maybe do a prototype PCB using my CNC machine. ;)
                                        BTW, I notice that the price went up from $3.20/module to $4/module. :( And something tells me it will probably go higher still.
                                          @nca78
                                          Nice!
                                          Any update?
                                          @nca78
                                          Nice!
                                          Any update?
                                          Sorry I was busy with other things. Now my switch seems to work I will quickly finish other atmega projects and make the switch to nrf5x.
                                          For pad sizes, I believe from the pictures below it's 1mm width (grid size is obviously 0.5mm)
