  3. CNC PCB milling
CNC PCB milling
933 Posts 28 Posters 823.4k Views 27 Watching
    #193
    I applied it to the motor set screws first and let it set:
    Note: I used rare earth magnets to help secure the set screw to the allen wrench. That insures that the set screw doesn't drop off and disappear somewhere on the floor. Works great.
    The couplers are made from anodized aluminum, so I'm not sure how well the loctite will work on them. However, I think it will still work, as the set screws themselves are steel.
      #194
      I found an intro to bCNC:
      https://www.youtube.com/watch?v=c-2k48TwU-8
      It looks easy and intuitive, so I'll probably go with that.
      As usual, it's the software that has the best tutorial that wins.
        zboblamontZ
        zboblamontZ
        zboblamont
        @neverdie I used to use nail varnish on threads as it was just as effective, even though it annoyed the partner whose nail varnish it was. It is not the bond between the metals which is that important, it is adding resistance between the threads to prevent unscrewing, were it to completely bond, you would shear the bolt before it was removed, which is a whole lot of trouble....
        • zboblamontZ zboblamont
          #196
          Does nail varnish cure anaerobically in the presence of metal ions? That seems to be much of the theory behind thread lockers.
          I thought nail varnish cured by evaporation.
          In any case, I wiped off the excess loctite, because it might never dry (or, at least, take a long while to do so).
          I think the loctite is likely to work, since Andrew had success without anything but torquing it down hard. On the other hand, maybe his is threaded differently than what came in my kit.
            you should use A5 connector
            Does using A5 somehow automagically just work, or does it require additional software configuration?
            andrewA
            andrewA
            andrew
            it should work by default
              zboblamontZ
              zboblamontZ
              zboblamont
              @neverdie Torquing down correctly normally prevents threads unwinding, but have seen bolts come loose with vibration on occasion. Only ever used loctite or equivalent on cylinder head bolts, particularly alloy heads, it never actually sets solid and is oil etc resistant.
              Although lacquer or plastic paints do harden, as a plastic filler between the threads, it increases contact friction, yet will shear to permit removal of the bolt when necessary. Typical threads do not fully engage metal to metal, the clearance is essential to allow the nut to be run on the bolt.
              Loctite is fine if you have it already, nail varnish works fine for me in non oily scenarios.
                #199
                I've retried it now, and so far it's not coming lose. :)
                I added some machine oil on the rods and screws, and that seems to have helped. Before that, there were some areas where the screw rod on the y-axis was binding, but not now.
                  Are you guys running bCNC under Linux? Because installing it under Windows is proving to be challenging....
                  andrewA rmtuckerR 2 Replies Last reply
                    andrewA
                    andrewA
                    andrew
                    @neverdie yep, I've a linux vm for flatcam and bcnc.
                      rmtuckerR
                      rmtuckerR
                      rmtucker
                      @neverdie
                      Linux for me too.Never used windows in years:relaxed:
                        #203
                        Here's the machine oil I'm using. As you can tell from the manufacturer, it's meant for sewing machines and similar:
                          Well, now that I found this pulldown in Chilipeppr, I might stick with it a while longer:
                            #205
                            The strange thing is that the Chilipeppr demo seems to mill at z=0.000. So, if I were to try to etch the pattern for real, I would have to "zero" z at an actual z value of, say, z=-0.5 or something (whatever depth I wanted it to etch at).
                            Is that normal?
                            Anyhow, I've been through multiple trial iterations with no bit installed and with the spindle disabled, and during all that the X and Y couplers have not come loose. So, I think that the Locktite has lived up to its name and solved the problem I was having earlier. :)
                            andrewA 1 Reply Last reply
                              Is that normal?
                              andrewA
                              andrewA
                              andrew
                              Is that normal?
                              yes, the chilipeppr demo works like this. but keep in mind, that for "real" isolation milling, the milling depth which you used during the g code generation will be calculate from the relative z zero, so in that case you really have to set z0 to the pcb surface.
                                #207
                                Disaster. Out of the blue, it suddenly just stopped working. Now I can't get it to spin the spindle or move in any x, y, or z direction. Gcode appears to be sent to it, and it does respond to me if I send it a '$" through the Chilipeppr console window. Just no movement whatsoever.
                                I removed the heatsinks, as a possible culprit, but still no go.
                                Suggestions on how to diagnose it?
                                  #208
                                  I found the problem: bad power supply brick. It is supplying no voltage at all. :(
                                  The power brick that came as part of the kit says it is rated at 24v dc 5.62amp. Is that enough, or should I get something that can do more amps?
                                  andrewA 2 Replies Last reply
                                    andrewA
                                    andrewA
                                    andrew
                                    @neverdie oh :( if you have a chance to power the cnc from a variable current power supply, then check the current it drains by starting from low to higher current. if it eats lot, maybe there is a short somewhere. you could also try to open the power supply and find a fuse.
                                    good luck!
                                      andrewA
                                      andrewA
                                      andrew
                                      @neverdie I've a PS with the same parameters. it is enough.
                                        #211
                                        I don't have much optimism that the cheap-ass power supply that came with the kit can be repaired (well, not by me anyway).
                                        I ordered a 6amp one as a replacement, just to have a little more headroom:
                                        https://www.amazon.com/gp/product/B01AJQ9G2C/ref=oh_aui_detailpage_o01_s00?ie=UTF8&psc=1
                                        It may turn out to be cheap-ass also, but I can get it tomorrow, so I'm rolling the dice.
                                        If that burns out too, then there's this one, which looks more beefy and would be my first choice, but will take a week to receive it:
                                        https://www.amazon.com/gp/product/B01J19G00E/ref=oh_aui_detailpage_o00_s00?ie=UTF8&psc=1
                                          #212
                                          Dang. I cancelled the order, as I'm not sure whether its 5.5mmx2.1mm barrel jack will fit or whether a 5.5mm x2.5mm is required.
                                          Looks as though the barrel on the woodpeck is 2.5mm inside diameter....
