  3. CNC PCB milling
CNC PCB milling
933 Posts 28 Posters 823.4k Views 27 Watching
    one of them just came loose again
    And now the other one did too. Is anyone using a threadlocker on the set screws to keep this from happening?
    I think I'll put on some locktite and let it dry overnight and then see if it still happens tomorrow. I'll start with just the threaded rods.
    Anyhow, the good news is that the heat sinks plainly did not short out the GRBL controller boards. I guess the adhesive must act as an electrical insulator.
    sundberg84S
    sundberg84S
    For one that will probably buy the same CNC could you document how you solve this with a picture?
      @rmtucker Which g-code sender is it that you like best?
      rmtuckerR
      rmtuckerR
      rmtucker
      I am not using a g-code sender,i am using mach3.
      But i have just started playing with grbl and bCNC seems to do most things.
        Probably a committee decision. Half liked red, and the other half liked blue. They were deadlocked, and this was their compromise decision. :laughing:
        andrewA
        andrewA
        andrew
        @neverdie one more think I forgot to mention: after I assembled the cnc, I used a little wd40 across each axis and moved each from one end to another. it helped for smooth and "barrier-free" movements.
        • andrewA andrew
          @neverdie for the touch sensing you should use A5 connector from the headers, connecting it to the actual tool (bit), then a gnd (header's bottom row) connecting to the pcb's surface.
          for the tool connection I use crocodile clamps.
          screws: you did not fasten them enough. at the beginning I also missed some endpoints, but since I put the cnc together, I had no issue with any of my screws.
          Does using A5 somehow automagically just work, or does it require additional software configuration?
          andrewA 1 Reply Last reply
          • sundberg84S sundberg84
            #192
            @sundberg84 said in CNC PCB milling:
            OK, here is what I'm doing in pictures. I'm applying blue 242 Loctite:
            to the threads of the 4 set screws on the coupler:
            That should keep them from loosening up after they are screwed into position. Note, you have at most 10 minutes of working time before it sets.
              #193
              I applied it to the motor set screws first and let it set:
              Note: I used rare earth magnets to help secure the set screw to the allen wrench. That insures that the set screw doesn't drop off and disappear somewhere on the floor. Works great.
              The couplers are made from anodized aluminum, so I'm not sure how well the loctite will work on them. However, I think it will still work, as the set screws themselves are steel.
                #194
                I found an intro to bCNC:
                https://www.youtube.com/watch?v=c-2k48TwU-8
                It looks easy and intuitive, so I'll probably go with that.
                As usual, it's the software that has the best tutorial that wins.
                  zboblamontZ
                  zboblamontZ
                  zboblamont
                  @neverdie I used to use nail varnish on threads as it was just as effective, even though it annoyed the partner whose nail varnish it was. It is not the bond between the metals which is that important, it is adding resistance between the threads to prevent unscrewing, were it to completely bond, you would shear the bolt before it was removed, which is a whole lot of trouble....
                  • zboblamontZ zboblamont
                    #196
                    Does nail varnish cure anaerobically in the presence of metal ions? That seems to be much of the theory behind thread lockers.
                    I thought nail varnish cured by evaporation.
                    In any case, I wiped off the excess loctite, because it might never dry (or, at least, take a long while to do so).
                    I think the loctite is likely to work, since Andrew had success without anything but torquing it down hard. On the other hand, maybe his is threaded differently than what came in my kit.
                      andrewA
                      andrewA
                      andrew
                      it should work by default
                        zboblamontZ
                        zboblamontZ
                        zboblamont
                        @neverdie Torquing down correctly normally prevents threads unwinding, but have seen bolts come loose with vibration on occasion. Only ever used loctite or equivalent on cylinder head bolts, particularly alloy heads, it never actually sets solid and is oil etc resistant.
                        Although lacquer or plastic paints do harden, as a plastic filler between the threads, it increases contact friction, yet will shear to permit removal of the bolt when necessary. Typical threads do not fully engage metal to metal, the clearance is essential to allow the nut to be run on the bolt.
                        Loctite is fine if you have it already, nail varnish works fine for me in non oily scenarios.
                          #199
                          I've retried it now, and so far it's not coming lose. :)
                          I added some machine oil on the rods and screws, and that seems to have helped. Before that, there were some areas where the screw rod on the y-axis was binding, but not now.
                            Are you guys running bCNC under Linux? Because installing it under Windows is proving to be challenging....
                            andrewA rmtuckerR 2 Replies Last reply
                              andrewA
                              andrewA
                              andrew
                              @neverdie yep, I've a linux vm for flatcam and bcnc.
                                rmtuckerR
                                rmtuckerR
                                rmtucker
                                @neverdie
                                Linux for me too.Never used windows in years:relaxed:
                                  #203
                                  Here's the machine oil I'm using. As you can tell from the manufacturer, it's meant for sewing machines and similar:
                                    Well, now that I found this pulldown in Chilipeppr, I might stick with it a while longer:
                                      #205
                                      The strange thing is that the Chilipeppr demo seems to mill at z=0.000. So, if I were to try to etch the pattern for real, I would have to "zero" z at an actual z value of, say, z=-0.5 or something (whatever depth I wanted it to etch at).
                                      Is that normal?
                                      Anyhow, I've been through multiple trial iterations with no bit installed and with the spindle disabled, and during all that the X and Y couplers have not come loose. So, I think that the Locktite has lived up to its name and solved the problem I was having earlier. :)
                                        Is that normal?
                                        andrewA
                                        andrewA
                                        andrew
                                        Is that normal?
                                        yes, the chilipeppr demo works like this. but keep in mind, that for "real" isolation milling, the milling depth which you used during the g code generation will be calculate from the relative z zero, so in that case you really have to set z0 to the pcb surface.
                                          #207
                                          Disaster. Out of the blue, it suddenly just stopped working. Now I can't get it to spin the spindle or move in any x, y, or z direction. Gcode appears to be sent to it, and it does respond to me if I send it a '$" through the Chilipeppr console window. Just no movement whatsoever.
                                          I removed the heatsinks, as a possible culprit, but still no go.
                                          Suggestions on how to diagnose it?
