  3. MYSBootloader 1.3.0-beta.3
182 Posts 44 Posters 94.5k Views 42 Watching
  • tekkaT tekka
    @Mark-Swift Hmm, that's odd - just tested it here with the latest dev and all is ok. Can you post the logs + node sketch?
    Mark SwiftM
    Mark SwiftM
    Mark Swift
    @tekka said in MYSBootloader 1.3.0-beta.3:
    @tekka, just tried again, perhaps I'm missing something obvious?
    I have the gateway and node using the latest dev branch, I click the node in MYS and then request a signal report - I see a tx in the log but nothing further? Do I need anything in the node sketch or the gateway? Does this work with the NRF's?
    tekkaT 1 Reply Last reply
    • Mark SwiftM Mark Swift
      tekkaT
      tekkaT
      tekka
      wrote on last edited by tekka
      #140
      • J
        J
        jacikaas
        wrote on last edited by jacikaas
        #141
        Q1: Does anybody was able to succesfully use 8MHz MYSBootloader 1.3.0-beta.3 on standalone Atmega328p?
        All bootloaders I testing with Arduino BLINK example.
        Arduino 1.8.5
        I was testing 8MHz internal oscilator MYSBootloader 1.3.0-beta.3 with fuses on 2 different Atmega328p standalone but I can't upload sketch to it and test it. Arduino avrdude says that:
        avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0x4a
        Used fuses:
        proMYSBL8.bootloader.extended_fuses=0x06 / 07
        proMYSBL8.bootloader.lock_bits=0x3F / 0F
        Before that, I was burned my Atmega328p with 1MHz internal oscilator MYSBootloader 1.3.0-beta.3 bootloader and it was working.
        Also I was testing 8MHz internal oscilator MYSBootloader 1.3pre2 with fuses on 2 different Atmega328p standalone and I can upload sketch to it and test it.
        Used fuses:
        Q2: I noticed that with 8MHz internal oscilator MYSBootloader 1.3pre2 LED blinks not continuosly it like (* led ON; - led OFF):
        *** --- *** --- *** --- ** - * - * - * - [cycle ends, then repeats again] *** --- *** --- *** --- ** - * - * - * - ...
        And this one cycle of *** --- *** --- *** --- ** - * - * - * - takes ~8 seconds. Could it be something with watchdog timer? I not very know about this setting.
        Thank You for help!
        • J jacikaas
          Arduino 1.8.5
          Used fuses:
          Used fuses:
          Thank You for help!
          tekkaT
          tekkaT
          tekka
          @Mark-Swift said in MYSBootloader 1.3.0-beta.3:
          Did you try with 1.3.0-beta.4? https://github.com/mysensors/MySensorsBootloaderRF24/tree/development
          Mark SwiftM J V 3 Replies Last reply
          • tekkaT tekka
            Mark SwiftM
            Mark SwiftM
            Mark Swift
            @tekka that did it, it's now working... now to figure out what the returned signal report numbers mean :)
            • tekkaT tekka
              J
              J
              jacikaas
              @tekka thank You for the answer. I'm not sure is answer was dedicated for me or for Mark, but I tested 1.3.0-beta.4 in the same way I described before:
              • Tested with 2 different Atmega328p
              • First try was with 1MHz - working on both Atmega328p
              • Second try with 8MHz - same situation as with beta 3, skecth won't upload and I get answer from Arduino Avrdude (this time I post full log after uploading):
              avrdude: Version 6.3, compiled on Jan 17 2017 at 12:00:53
                       Overriding Baud Rate          : 38400
              avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0xf1
              avrdude: stk500_getsync() attempt 10 of 10: not in sync: resp=0xf1
              avrdude done.  Thank you.
              It would be best if someone also could try to burn same bootloader on standalone Atmega328p and post results to be sure all wiring and steps I did is without mistakes.
              Strange if I I burn 1.3pre2 8MHz bootloader - it works.
              What troubleshooting I could make?
              J 1 Reply Last reply
              • tekkaT tekka
                V
                V
                vikasjee
                wrote on last edited by vikasjee
                #145
                @tekka, Thanks for the link to the beta.4. bootloader. I have tried burning nodes using these and tested them by uploading the FW using MySController 1.0beta_b3316 (latest update meant for MySensors2.2.0) with SerialGatewaySketches using both MySensors2.2.0_rc1 and MySensrs2.2.0_pre1 libraries.
                MysController doesn't seem to even recognize the Beta.4 bootloaded Nodes (Promini 5V16Mhz with default provided fuse settings from Makefile). The extra nRF chip wiring checks and precautions (0.01uF and 100uF Caps) have been taken. What might be the problem? How to debug when SerialMontitor cant be used? Any Network Sniffer link if that helps...
                I guess the MySensors library version of the SerialGateway sketch may be posing a problem. Can you please help me with a link of the correct MySensors library version to use with beta.4 bootloaded nodes?
                Any help will be appreciated...
                V 1 Reply Last reply
                • W
                  W
                  wanvo
                  Hi @tekka!
                  Do you plan to add support for the RFM69 module in MYSBootloader?
                  • V vikasjee
                    V
                    V
                    vikasjee
                    No help from the community! Sad!!!
                    • W wanvo
                      Hi @tekka!
                      tekkaT
                      tekkaT
                      tekka
                      #148
                      @wanvo This would certainly be a great addition to MYSBootloader - but very limited dev time atm. Community contributions on that topic are welcome ;)
                      • V vikasjee
                        tekkaT
                        tekkaT
                        tekka
                        #149
                        @vikasjee Apologies for the late reply - I have no idea what's the issue with your setup - my guess is that something is wrong with the fuses and/or wrong .hex used: Can you post the MYSController log, used fuse settings and any other important information?
                        • W
                          W
                          wanvo
                          @tekka thanks for the answer. I'm still a newbie.
                          Now I can not make a contribution to the development due to my incompetence.
                          I can help as a tester :)
                          • J jacikaas
                            J
                            J
                            jacikaas
                            @jacikaas
                            Hello, maybe someone was trying 8MHz bootloader for standlaone Atmega328p?
                            • C
                              C
                              cdr
                              Anyone seen this error on latest 1.3 release? It seems a define is not done for F_CPU, what am I missing here?
                              Generating function prototypes...
                              In file included from C:\Program Files (x86)\Arduino\portable\sketchbook\libraries\MySensors/MySensors.h:371:0,
                              from C:\Program Files (x86)\Arduino\portable\sketchbook\libraries\MySensors\examples\GatewayW5100MQTTClient\GatewayW5100MQTTClient.ino:138:
                              C:\Program Files (x86)\Arduino\portable\sketchbook\libraries\MySensors/core/MyTransport.cpp:777:42: error: operator '>' has no left operand
                               #if defined(MY_GATEWAY_FEATURE) && (F_CPU>16000000)
                              In file included from C:\Program Files (x86)\Arduino\portable\sketchbook\libraries\MySensors/MySensors.h:396:0,
                              C:\Program Files (x86)\Arduino\portable\sketchbook\libraries\MySensors/core/MySensorsCore.cpp:479:11: error: operator '>' has no left operand
                               #if (F_CPU>16000000)
                              exit status 1
                              Error compiling for board ATmega328 with MYSBootloader 1.3.0.
                              Regards
                              H T 2 Replies Last reply
                              • C cdr
                                exit status 1
                                Regards
                                H
                                H
                                Henry
                                @cdr Same Problem here!
                                Greetz Henry
                                • C cdr
                                  exit status 1
                                  Regards
                                  tsjoender
                                  @cdr @Henry I ran into the same issue. Turned out to be a syntax issue in the boards.txt file. If you change:
                                  MYSBL.menu.frequency.MYSBL16.f_cpu=16000000L
                                  into
                                  MYSBL.menu.frequency.MYSBL16.build.f_cpu=16000000L
                                  Then it works again. Adding build. needs to be done for the other menu entries as well.
                                  H C 2 Replies Last reply
                                  • T tsjoender
                                    into
                                    H
                                    H
                                    Henry
                                    @tsjoender
                                    PERFEKT!!! thx!!!
                                    • T tsjoender
                                      into
                                      C
                                      C
                                      cdr
                                      @tsjoender said in MYSBootloader 1.3.0-beta.3:
                                      into
                                      thanks a lot!
                                      • tekkaT
                                        tekkaT
                                        tekka
                                        Fix: https://github.com/mysensors/MySensorsBootloaderRF24/pull/24
                                        Thanks for reporting.
                                        • thmT
                                          thmT
                                          thm
                                          I am currently testing the OTA features with a "My Slim 2AA Battery Node", MYSBootloader 1.3.0-rc.1, MYSController Build 3316 and the original example sketch "PassiveNode" (MySensors 2.2.0). Unfortunately, no reboot will be performed if I want to execute it via the MYSController. Even with a firmware update, no reboot is performed. If I disconnect the sensor from the battery and reconnect, the firmware update will be executed. Am I doing something wrong or is this a software bug?
                                          Regards
                                          Thomas
