  3. MYSBootloader 1.3.0-beta.3
182 Posts 44 Posters 94.9k Views 42 Watching
  • N nagurao.basude
    @tekka, I am planning to move from MySensors v2.0.0 to v2.1.1, do I need to use the updated MYSBootloader? Currently I am using MYSBootloader 1.3 pre-relase (https://forum.mysensors.org/topic/3453/mysbootloader-1-3-pre-release-myscontroller-1-0-0beta).
    Can you please also help me understand the differences in the low_fuses and high_fuses values in the older version of bootloader and the latest version?
    tekkaT
    tekkaT
    tekka
    wrote on last edited by tekka
    #131
    @nagurao.basude no, you don't need to but the new version has some stability improvements. The fuse differences are to better match HW (osc type) & clearing eeprom.
    AVR fuse calculator: http://www.engbedded.com/fusecalc/
    N 1 Reply Last reply
    • Nca78N
      Hello, has someone used the 1MHz precompiled bootloader ? If yes what baud rate did you use to communicate via serial ?
      I flashed it on a node but I can't upload any script ("not in sync" error). If I believe HW.h it should be 9600 bauds but I have tried hat and nearly every baudrate with no luck.
      I had no problem using the 8MHz version.
      The only way I could use the 1MHz bootloader at the moment is to flash the hex file containing both bootloader and script.
      Sorry to ask this stupid question, I wanted to compile the bootloader but Internet connection is nearly down and I can't even download Atmel Studio :(
      • tekkaT tekka
        N
        N
        nagurao.basude
        @tekka Thank you very much for the response. I will just start migrating my existing nodes to MySensors v2.1.1library.
        • Mark SwiftM
          Mark SwiftM
          Mark Swift
          @tekka try as I might, I can't get the nodes to respond to the new 'signal report' option in MYS Controller, any ideas why?
          tekkaT 1 Reply Last reply
          • Mark SwiftM Mark Swift
            tekkaT
            tekkaT
            tekka
            @Mark-Swift This feature only works on MySensors >=2.2.0
            Mark SwiftM 1 Reply Last reply
            • tekkaT tekka
              Mark SwiftM
              Mark SwiftM
              Mark Swift
              @tekka said in MYSBootloader 1.3.0-beta.3:
              @tekka I'm using the latest dev branch on all my nodes and gateway...
                tekkaT
                tekkaT
                tekka
                @Mark-Swift Hmm, that's odd - just tested it here with the latest dev and all is ok. Can you post the logs + node sketch?
                • J
                  J
                  jacikaas
                  wrote on last edited by jacikaas
                  #138
                  I have notice strange behavior with MYSBootloaderV13pre.hex 8MHz internal bootloader.
                  Problem: When I burn MYSBootloaderV13pre.hex 8MHz internal bootloader to my Standalone Atmega328p i testing it with Arduino Blink and Fade sketches. Problem is that theese sketches doesn't work on this bootloader. LED is just always ON.
                  I also tested the same sketches, same wiring, same Arduino Uno (5V when programming), same FTDI programmer (3.3V), same PC with Win 10 with same drivers, same Atmega328p with Nick Gammon Atmega Board Programmer when I burn Lilypad bootloader and then upload Blink and Fade sketches, they perfectly working.
                  I tried same uploading with Arduino IDE 1.6.5 and also with the newest version 1.8.5.
                  As a programmer I using Arduino as ISP. I theese tests when burning bootloader I don't connect external oscilator.
                  With Nick Gammon software I also checked fuses for both Lilypad and MYSBootloader settings, becose i was thought it is becose of them. Once I configure wrong fuses and it had a lot of time to reset it to default value.
                  Question: So now before changing fuses I want to ask maybe someone have been faced with similar problem?
                  I paste below info about Lilipad and MYSBootloader 8MHz internal oscilator boards fuse settings:
                  Lilypad bootloader
                  Atmega fuse calculator.
                  Written by Nick Gammon.
                  Version 1.11
                  Compiled on Nov 30 2017 at 17:36:58 with Arduino IDE 10805.
                  Attempting to enter programming mode ...
                  Entered programming mode OK.
                  Signature = 0x1E 0x95 0x0F
                  Processor = ATmega328P
                  Flash memory size = 32768
                  LFuse = 0xE2
                  HFuse = 0xDA
                  EFuse = 0xFD
                  Lock byte = 0xEF
                  Clock calibration = 0x8E
                  External Reset Disable.................. [ ]
                  Debug Wire Enable....................... [ ]
                  Enable Serial (ICSP) Programming........ [X]
                  Watchdog Timer Always On................ [ ]
                  Preserve EEPROM through chip erase...... [ ]
                  Boot into bootloader.................... [X]
                  Divide clock by 8....................... [ ]
                  Clock output............................ [ ]
                  Bootloader size: 2048 bytes.
                  Start-up time: SUT0: [X]  SUT1: [ ] (see datasheet)
                  Clock source: calibrated internal oscillator.
                  Brownout detection at: 2.7V.
                  MYSBootloaderV13pre bootloader
                  Version 1.11
                  Compiled on Nov 30 2017 at 19:48:16 with Arduino IDE 10805.
                  LFuse = 0xE2
                  HFuse = 0xD2
                  EFuse = 0xFE
                  Lock byte = 0xFF
                  Preserve EEPROM through chip erase...... [X]
                  Brownout detection at: 1.8V.
                  I appreciate any helpful info!
                  EDIT: I think I already found that there is newer MYSBootloader files of development version which working without problems. I will test it if I write good fuses :)
                  • tekkaT tekka
                    Mark SwiftM
                    Mark SwiftM
                    Mark Swift
                    @tekka, just tried again, perhaps I'm missing something obvious?
                    I have the gateway and node using the latest dev branch, I click the node in MYS and then request a signal report - I see a tx in the log but nothing further? Do I need anything in the node sketch or the gateway? Does this work with the NRF's?
                      tekkaT
                      tekkaT
                      tekka
                      #140
                      • J
                        J
                        jacikaas
                        #141
                        Q1: Does anybody was able to succesfully use 8MHz MYSBootloader 1.3.0-beta.3 on standalone Atmega328p?
                        All bootloaders I testing with Arduino BLINK example.
                        Arduino 1.8.5
                        I was testing 8MHz internal oscilator MYSBootloader 1.3.0-beta.3 with fuses on 2 different Atmega328p standalone but I can't upload sketch to it and test it. Arduino avrdude says that:
                        avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0x4a
                        Used fuses:
                        proMYSBL8.bootloader.extended_fuses=0x06 / 07
                        proMYSBL8.bootloader.lock_bits=0x3F / 0F
                        Before that, I was burned my Atmega328p with 1MHz internal oscilator MYSBootloader 1.3.0-beta.3 bootloader and it was working.
                        Also I was testing 8MHz internal oscilator MYSBootloader 1.3pre2 with fuses on 2 different Atmega328p standalone and I can upload sketch to it and test it.
                        Used fuses:
                        Q2: I noticed that with 8MHz internal oscilator MYSBootloader 1.3pre2 LED blinks not continuosly it like (* led ON; - led OFF):
                        *** --- *** --- *** --- ** - * - * - * - [cycle ends, then repeats again] *** --- *** --- *** --- ** - * - * - * - ...
                        And this one cycle of *** --- *** --- *** --- ** - * - * - * - takes ~8 seconds. Could it be something with watchdog timer? I not very know about this setting.
                        Thank You for help!
                        • J jacikaas
                          Arduino 1.8.5
                          Used fuses:
                          Used fuses:
                          Thank You for help!
                          tekkaT
                          tekkaT
                          tekka
                          @Mark-Swift said in MYSBootloader 1.3.0-beta.3:
                          Did you try with 1.3.0-beta.4? https://github.com/mysensors/MySensorsBootloaderRF24/tree/development
                          Mark SwiftM J V 3 Replies Last reply
                          • tekkaT tekka
                            Mark SwiftM
                            Mark SwiftM
                            Mark Swift
                            @tekka that did it, it's now working... now to figure out what the returned signal report numbers mean :)
                            • tekkaT tekka
                              J
                              J
                              jacikaas
                              @tekka thank You for the answer. I'm not sure is answer was dedicated for me or for Mark, but I tested 1.3.0-beta.4 in the same way I described before:
                              • Tested with 2 different Atmega328p
                              • First try was with 1MHz - working on both Atmega328p
                              • Second try with 8MHz - same situation as with beta 3, skecth won't upload and I get answer from Arduino Avrdude (this time I post full log after uploading):
                              avrdude: Version 6.3, compiled on Jan 17 2017 at 12:00:53
                                       Overriding Baud Rate          : 38400
                              avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0xf1
                              avrdude: stk500_getsync() attempt 10 of 10: not in sync: resp=0xf1
                              avrdude done.  Thank you.
                              It would be best if someone also could try to burn same bootloader on standalone Atmega328p and post results to be sure all wiring and steps I did is without mistakes.
                              Strange if I I burn 1.3pre2 8MHz bootloader - it works.
                              What troubleshooting I could make?
                              J 1 Reply Last reply
                              • tekkaT tekka
                                V
                                V
                                vikasjee
                                wrote on last edited by vikasjee
                                #145
                                @tekka, Thanks for the link to the beta.4. bootloader. I have tried burning nodes using these and tested them by uploading the FW using MySController 1.0beta_b3316 (latest update meant for MySensors2.2.0) with SerialGatewaySketches using both MySensors2.2.0_rc1 and MySensrs2.2.0_pre1 libraries.
                                MysController doesn't seem to even recognize the Beta.4 bootloaded Nodes (Promini 5V16Mhz with default provided fuse settings from Makefile). The extra nRF chip wiring checks and precautions (0.01uF and 100uF Caps) have been taken. What might be the problem? How to debug when SerialMontitor cant be used? Any Network Sniffer link if that helps...
                                I guess the MySensors library version of the SerialGateway sketch may be posing a problem. Can you please help me with a link of the correct MySensors library version to use with beta.4 bootloaded nodes?
                                Any help will be appreciated...
                                V 1 Reply Last reply
                                • W
                                  W
                                  wanvo
                                  Hi @tekka!
                                  Do you plan to add support for the RFM69 module in MYSBootloader?
                                  • V vikasjee
                                    V
                                    V
                                    vikasjee
                                    No help from the community! Sad!!!
                                    • W wanvo
                                      Hi @tekka!
                                      tekkaT
                                      tekkaT
                                      tekka
                                      #148
                                      @wanvo This would certainly be a great addition to MYSBootloader - but very limited dev time atm. Community contributions on that topic are welcome ;)
                                      • V vikasjee
                                        tekkaT
                                        tekkaT
                                        tekka
                                        #149
                                        @vikasjee Apologies for the late reply - I have no idea what's the issue with your setup - my guess is that something is wrong with the fuses and/or wrong .hex used: Can you post the MYSController log, used fuse settings and any other important information?
                                        • W
                                          W
                                          wanvo
                                          @tekka thanks for the answer. I'm still a newbie.
                                          Now I can not make a contribution to the development due to my incompetence.
                                          I can help as a tester :)
