  3. CNC PCB milling
CNC PCB milling
933 Posts 28 Posters 823.4k Views 27 Watching
    #248
    Judging from the looks of the photo directly above though, it looks like quite a bit of copper wasn't removed where it needed to be. I'm guessing I will need to:
    1. etch to a deeper depth; and/or,
    2. use a finer mesh for auto-leveling; and/or
    3. ???
    • E
      E
      executivul
      Etch 0.1mm. The groove between tracks also helps with soldering. I currently use 0.1mm and even 0.15 when in a hurry.
        So, I re-ran the job over the same area with the g-code modified by auto-leveling, and this time I got a better result:
        So, now I'll try it on a fresh area of the PCB, after doing a new auto-leveling.
        rmtuckerR
        rmtuckerR
        rmtucker
        @neverdie
        The last photo looks like the tip is missing from the cutter?
        • rmtuckerR rmtucker
          @neverdie
          @rmtucker Good catch! Here it is in contrast to a new one:
          I'll replace it with the new one.
          rmtuckerR 1 Reply Last reply
            rmtuckerR
            rmtuckerR
            rmtucker
            @neverdie
            Just for future reference i would use a duff cutter for autolevelling then change to a good cutter to cut the job after resetting the z0.
            It is so easy to smash the front of an engraving cutter when using this method for autolevelling as the machine takes a little time to stop after touching the pcb.
            Just my advice anyway:relaxed:
              @neverdie
              #253
              What's a "duff cutter"? Did you mean "dull cutter"?
                rmtuckerR
                rmtuckerR
                rmtucker
                @neverdie
                Yes sorry a used one:wink:
                  @neverdie
                  @rmtucker Thanks! Makes sense to me. I'll do it that way.
                    Argh. I ran the job, and the first cut went great. All subsequent cuts though didn't penetrate the surface:
                    Afterward, when I checked the zero on z, I found that it was off by 0.049. That explains it, since the cut-depth was 0.05.
                    I'll re-zero and try running the same job again.
                      That made a much better result:
                      It corresponds to this as the actual PCB:
                        #258
                        However, what's telling is that it obliterated the traces on either side of a 6 mil separation:
                        This is how it should look instead:
                        So, what happened?
                        My current hypothesis: the first cutting sheared 0.049mm off the tip of the blade, making it wider than it should be. Then, after re-zeroing, the wider blade cut too wide as it cut the traces for the solder jumper.
                        Is that reasonable, or is there a better hypothesis?
                        If it's true, then what do I do about it? Perhaps use a higher quality bit than the freebie that came with the kit?
                        Actually, I'm not even sure what the dimensions were on the freebie. It wasn't labeled. Perhaps it was too wide to begin with.
                          Well, to explore this more, I think I'll create a test board consisting purely of a few solder jumpers. That way I can put the focus directly on the 6 mil issue and won't be wasting time on etching that's unrelated to that.
                            #260
                            Doing just a single solder jumper, with the same bit, and autoleveling every 1mm, the result is:
                            which is pretty close, actually. Looks like maybe the bit is a little too wide, or else there's runout which is making it appear wider than it actually is.
                            I'll try it with a fresh bit next and see if it improves.
                              Well, that went horribly:
                              and I have no idea why:
                                I tried again with the same bit, after removing and re-inserting it. Got a better result this time:
                                Unless someone has suggestions on how to tweak this, I think that may represent approximately the best this CNC can do.
                                  #263
                                  In truth, though, I think it may be a flawed gcode algorithm:
                                  Instead of two separate cutting passes through the center section, one would do, and would produce a better result.
                                  How to tweak flatcam to do that? I probably haven't configured flatcam correctly. i.e. user error.
                                    So, what happened?
                                    rmtuckerR
                                    rmtuckerR
                                    rmtucker
                                    Maybe this is where your problem lies.
                                    How did you write the g-code without knowing?
                                    Too many variables here wich could give you these results.
                                    The bigger tracks,Are they measuring the correct width with a vernier after you have cut them?
                                      I assumed the width on the freebies was 0.1mm, because that's what was advertised on Jack's posting for the machine. However, I don't know how to verify that, so the uncertainty comes in whether Jack actually delivered what was advertised or slipped in something else. I chose to give Jack the benefit of the doubt.
                                        #266
                                        If I were to enter a wider tool diameter of 0.155mm (instead of 0.1mm) into flatcam, I think I can coax flatcam into generating better g-code for this situation. I'll do that and then post the results.
                                          @neverdie have you verified isolation between the parts? The cut is good?
