  2. Bug Reports
  3. Raspberry Pi stability problem
18 Posts 3 Posters 5.9k Views 2 Watching
  • A
    alterfritz
    I will try out the version for the ESP8266 (GatewayESP8266MQTTClient.ino), however this seems really strange to me. Any hint?
    • A alterfritz
      @alterfritz said in Raspberry Pi stability problem:
      Could you be a bit more specific? What seems strange? The esp8266 gateway sketch? In what way does the sketch seem strange?
      • A
        alterfritz
        The gateway basically stops with a segmentation fault after working ok for a few minutes... let me try it...give me a minute...
        • A alterfritz
          running a raspi 3 with raspbian
          pi@pi:~ $ uname -a
          Linux pi 4.9.35-v7+ #1014 SMP Fri Jun 30 14:47:43 BST 2017 armv7l GNU/Linux
          Have updated the system to latest status but I still have lots of stability issues with the gateway.
          I build it with
          git clone https://github.com/mysensors/MySensors.git --branch development
          cd MySensors/
          ./configure --my-gateway=mqtt --my-controller-ip-address=127.0.0.1 --my-mqtt-publish-topic-prefix=mysensors-out --my-mqtt-subscribe-topic-prefix=mysensors-in --my-mqtt-client-id=mygateway1 --my-rf24-ce-pin=22 --my-rf24-cs-pin=24
          make
          cd MySensors/bin/
          sudo ./mysgw -d
          It works but very very unstable - if new sensor come online the gateway goes down with a segmentation fault.
          Its basically not usable. As mysensors have such a great reputation plus I already placed lots of sensors in my place - how I can get a mqtt gateway stable? What version? maybe some configure switches I forgot.
          I tried different pi's, different NRF24L01 modules, they have an extra capacitor etc.
          I really get frustrated and I can not believe its that unstable, so there must be something I must do wrong.
          Who has run it on a pi with out issues?
          Many thanks!
          Regards
          Joerg
          @alterfritz the troubleshooting instructions in https://forum.mysensors.org/post/82711 could give valuable input regarding the raspberry pi gateway.
          • A alterfritz
            @alterfritz that's not what I was asking about. See the text I quoted.
            • A
              alterfritz
              Ok - thanks will do that...
              • A
                alterfritz
                pi@pi:~ $ sudo gdb /home/pi/mysensors_dev/MySensors/bin/mysgw
                GNU gdb (Raspbian 7.7.1+dfsg-5+rpi1) 7.7.1
                Copyright (C) 2014 Free Software Foundation, Inc.
                License GPLv3+: GNU GPL version 3 or later http://gnu.org/licenses/gpl.html
                This is free software: you are free to change and redistribute it.
                There is NO WARRANTY, to the extent permitted by law. Type "show copying"
                and "show warranty" for details.
                This GDB was configured as "arm-linux-gnueabihf".
                Type "show configuration" for configuration details.
                For bug reporting instructions, please see:
                http://www.gnu.org/software/gdb/bugs/.
                Find the GDB manual and other documentation resources online at:
                http://www.gnu.org/software/gdb/documentation/.
                For help, type "help".
                Type "apropos word" to search for commands related to "word"...
                Reading symbols from /home/pi/mysensors_dev/MySensors/bin/mysgw...done.
                (gdb) run -d
                Starting program: /home/pi/mysensors_dev/MySensors/bin/mysgw -d
                [Thread debugging using libthread_db enabled]
                Using host libthread_db library "/lib/arm-linux-gnueabihf/libthread_db.so.1".
                mysgw: Starting gateway...
                mysgw: Protocol version - 2.2.0-rc.2
                mysgw: MCO:BGN:INIT GW,CP=RNNGL-Q-,VER=2.2.0-rc.2
                mysgw: TSF:LRT:OK
                mysgw: TSM:INIT
                mysgw: TSF:WUR:MS=0
                [New Thread 0x75cc8450 (LWP 4703)]
                mysgw: TSM:INIT:TSP OK
                mysgw: TSM:INIT:GW MODE
                mysgw: MCO:REG:NOT NEEDED
                mysgw: MCO:BGN:STP
                mysgw: MCO:BGN:INIT OK,TSP=1
                mysgw: GWT:RMQ:MQTT RECONNECT
                mysgw: connected to 127.0.0.1
                mysgw: GWT:RMQ:MQTT CONNECTED
                mysgw: GWT:TPS:TOPIC=mysensors-out/0/255/0/0/18,MSG SENT
                mysgw: TSF:MSG:READ,3-3-255,s=255,c=3,t=7,pt=0,l=0,sg=0:
                mysgw: TSF:MSG:BC
                mysgw: TSF:MSG:FPAR REQ,ID=3
                mysgw: TSF:PNG:SEND,TO=0
                mysgw: TSF:CKU:OK
                mysgw: TSF:MSG:GWL OK
                Program received signal SIGSEGV, Segmentation fault.
                [Switching to Thread 0x75cc8450 (LWP 4703)]
                0x0001ac74 in RF24_spiMultiByteTransfer (readMode=true, len=6 '\006', buf=0x1 <error: Cannot access memory at address 0x1>, cmd=97 'a') at ./drivers/RF24/RF24.cpp:87
                87 *buf++ = *prx++;
                (gdb)
                • A
                  alterfritz
                  Here is another screenshot - seems that sometimes it works... for some time...
                  mysgw: TSF:MSG:READ,1-1-0,s=255,c=3,t=6,pt=1,l=1,sg=0:0
                  mysgw: GWT:TPS:TOPIC=mysensors-out/1/255/3/0/6,MSG SENT
                  mysgw: TSF:MSG:READ,6-6-0,s=255,c=3,t=24,pt=1,l=1,sg=0:1
                  mysgw: TSF:MSG:PINGED,ID=6,HP=1
                  mysgw: TSF:MSG:SEND,0-0-6-6,s=255,c=3,t=25,pt=1,l=1,sg=0,ft=0,st=OK:1
                  mysgw: TSF:MSG:READ,6-6-0,s=255,c=3,t=15,pt=6,l=2,sg=0:0100
                  mysgw: TSF:MSG:SEND,0-0-6-6,s=255,c=3,t=15,pt=6,l=2,sg=0,ft=0,st=OK:0100
                  mysgw: TSF:MSG:READ,6-6-0,s=255,c=0,t=17,pt=0,l=10,sg=0:2.2.0-beta
                  mysgw: GWT:TPS:TOPIC=mysensors-out/6/255/0/0/17,MSG SENT
                  mysgw: TSF:MSG:READ,6-6-0,s=255,c=3,t=6,pt=1,l=1,sg=0:0
                  mysgw: GWT:TPS:TOPIC=mysensors-out/6/255/3/0/6,MSG SENT
                  mysgw: TSF:MSG:READ,5-5-0,s=255,c=0,t=17,pt=0,l=10,sg=0:2.2.0-beta
                  mysgw: GWT:TPS:TOPIC=mysensors-out/5/255/0/0/17,MSG SENT
                  mysgw: TSF:MSG:READ,5-5-0,s=255,c=3,t=6,pt=1,l=1,sg=0:0
                  mysgw: GWT:TPS:TOPIC=mysensors-out/5/255/3/0/6,MSG SENT
                  mysgw: TSF:MSG:READ,1-1-0,s=255,c=3,t=11,pt=0,l=10,sg=0:WallLight1
                  mysgw: GWT:TPS:TOPIC=mysensors-out/1/255/3/0/11,MSG SENT
                  mysgw: TSF:MSG:READ,1-1-0,s=255,c=3,t=12,pt=0,l=3,sg=0:1.0
                  mysgw: GWT:TPS:TOPIC=mysensors-out/1/255/3/0/12,MSG SENT
                  mysgw: TSF:MSG:READ,1-1-0,s=1,c=0,t=4,pt=0,l=0,sg=0:
                  mysgw: GWT:TPS:TOPIC=mysensors-out/1/1/0/0/4,MSG SENT
                  mysgw: TSF:MSG:READ,1-1-0,s=255,c=3,t=26,pt=1,l=1,sg=0:2
                  mysgw: TSF:MSG:SEND,0-0-1-1,s=255,c=3,t=27,pt=1,l=1,sg=0,ft=0,st=OK:1
                  mysgw: TSF:MSG:READ,1-1-0,s=1,c=1,t=3,pt=2,l=2,sg=0:100
                  mysgw: GWT:TPS:TOPIC=mysensors-out/1/1/1/0/3,MSG SENT
                  mysgw: TSF:MSG:BC
                  mysgw: TSF:CKU:OK,FCTRL
                  mysgw: TSF:MSG:SEND,0-0-3-3,s=255,c=3,t=8,pt=1,l=1,sg=0,ft=0,st=OK:0
                  mysgw: TSF:MSG:READ,4-4-255,s=255,c=3,t=7,pt=0,l=0,sg=0:
                  mysgw: TSF:MSG:BC
                  mysgw: TSF:MSG:FPAR REQ,ID=4
                  mysgw: TSF:MSG:SEND,0-0-4-4,s=255,c=3,t=8,pt=1,l=1,sg=0,ft=0,st=OK:0
                  mysgw: TSF:MSG:READ,6-6-0,s=255,c=3,t=11,pt=0,l=10,sg=0:WallLight6
                  mysgw: GWT:TPS:TOPIC=mysensors-out/6/255/3/0/11,MSG SENT
                  mysgw: TSF:MSG:READ,6-6-0,s=255,c=3,t=12,pt=0,l=3,sg=0:1.0
                  mysgw: GWT:TPS:TOPIC=mysensors-out/6/255/3/0/12,MSG SENT
                  mysgw: TSF:MSG:READ,6-6-0,s=1,c=0,t=4,pt=0,l=0,sg=0:
                  mysgw: GWT:TPS:TOPIC=mysensors-out/6/1/0/0/4,MSG SENT
                  mysgw: TSF:MSG:READ,6-6-0,s=255,c=3,t=26,pt=1,l=1,sg=0:2
                  mysgw: !TSF:MSG:SEND,0-0-6-6,s=255,c=3,t=27,pt=1,l=1,sg=0,ft=0,st=NACK:1
                  mysgw: TSF:MSG:READ,5-5-0,s=255,c=3,t=11,pt=0,l=10,sg=0:WallLight5
                  mysgw: GWT:TPS:TOPIC=mysensors-out/5/255/3/0/11,MSG SENT
                  mysgw: TSF:MSG:READ,5-5-0,s=255,c=3,t=12,pt=0,l=3,sg=0:1.0
                  mysgw: GWT:TPS:TOPIC=mysensors-out/5/255/3/0/12,MSG SENT
                  mysgw: TSF:MSG:READ,5-5-0,s=1,c=0,t=4,pt=0,l=0,sg=0:
                  mysgw: GWT:TPS:TOPIC=mysensors-out/5/1/0/0/4,MSG SENT
                  mysgw: TSF:MSG:READ,5-5-0,s=255,c=3,t=26,pt=1,l=1,sg=0:2
                  mysgw: TSF:MSG:SEND,0-0-5-5,s=255,c=3,t=27,pt=1,l=1,sg=0,ft=0,st=OK:1
                  mysgw: TSF:MSG:READ,5-5-0,s=1,c=1,t=3,pt=2,l=2,sg=0:100
                  mysgw: GWT:TPS:TOPIC=mysensors-out/5/1/1/0/3,MSG SENT
                  mysgw: TSF:MSG:READ,3-3-0,s=255,c=3,t=24,pt=1,l=1,sg=0:1
                  mysgw: TSF:MSG:PINGED,ID=3,HP=1
                  mysgw: TSF:MSG:SEND,0-0-3-3,s=255,c=3,t=25,pt=1,l=1,sg=0,ft=0,st=OK:1
                  mysgw: TSF:MSG:READ,3-3-0,s=255,c=3,t=15,pt=6,l=2,sg=0:0100
                  mysgw: TSF:MSG:SEND,0-0-3-3,s=255,c=3,t=15,pt=6,l=2,sg=0,ft=0,st=OK:0100
                  mysgw: TSF:MSG:READ,3-3-0,s=255,c=0,t=17,pt=0,l=10,sg=0:2.2.0-beta
                  mysgw: GWT:TPS:TOPIC=mysensors-out/3/255/0/0/17,MSG SENT
                  mysgw: TSF:MSG:READ,3-3-0,s=255,c=3,t=6,pt=1,l=1,sg=0:0
                  mysgw: GWT:TPS:TOPIC=mysensors-out/3/255/3/0/6,MSG SENT
                  mysgw: TSF:MSG:READ,4-4-0,s=255,c=3,t=24,pt=1,l=1,sg=0:1
                  mysgw: TSF:MSG:PINGED,ID=4,HP=1
                  mysgw: TSF:MSG:SEND,0-0-4-4,s=255,c=3,t=25,pt=1,l=1,sg=0,ft=0,st=OK:1
                  mysgw: TSF:MSG:READ,4-4-0,s=255,c=3,t=15,pt=6,l=2,sg=0:0100
                  mysgw: TSF:MSG:SEND,0-0-4-4,s=255,c=3,t=15,pt=6,l=2,sg=0,ft=0,st=OK:0100
                  mysgw: TSF:MSG:READ,3-3-0,s=255,c=3,t=11,pt=0,l=10,sg=0:WallLight3
                  mysgw: GWT:TPS:TOPIC=mysensors-out/3/255/3/0/11,MSG SENT
                  mysgw: TSF:MSG:READ,3-3-0,s=255,c=3,t=12,pt=0,l=3,sg=0:1.0
                  mysgw: GWT:TPS:TOPIC=mysensors-out/3/255/3/0/12,MSG SENT
                  mysgw: TSF:MSG:READ,3-3-0,s=1,c=0,t=4,pt=0,l=0,sg=0:
                  mysgw: GWT:TPS:TOPIC=mysensors-out/3/1/0/0/4,MSG SENT
                  mysgw: TSF:MSG:READ,3-3-0,s=255,c=3,t=26,pt=1,l=1,sg=0:2
                  mysgw: TSF:MSG:SEND,0-0-3-3,s=255,c=3,t=27,pt=1,l=1,sg=0,ft=0,st=OK:1
                  mysgw: TSF:MSG:READ,4-4-0,s=255,c=0,t=17,pt=0,l=10,sg=0:2.2.0-beta
                  mysgw: GWT:TPS:TOPIC=mysensors-out/4/255/0/0/17,MSG SENT
                  mysgw: TSF:MSG:READ,3-3-0,s=1,c=1,t=3,pt=2,l=2,sg=0:100
                  mysgw: GWT:TPS:TOPIC=mysensors-out/3/1/1/0/3,MSG SENT
                  mysgw: TSF:MSG:READ,4-4-0,s=255,c=3,t=6,pt=1,l=1,sg=0:0
                  mysgw: GWT:TPS:TOPIC=mysensors-out/4/255/3/0/6,MSG SENT
                  mysgw: TSF:MSG:READ,4-4-0,s=255,c=3,t=11,pt=0,l=10,sg=0:WallLight4
                  mysgw: GWT:TPS:TOPIC=mysensors-out/4/255/3/0/11,MSG SENT
                  mysgw: TSF:MSG:READ,4-4-0,s=255,c=3,t=12,pt=0,l=3,sg=0:1.0
                  mysgw: GWT:TPS:TOPIC=mysensors-out/4/255/3/0/12,MSG SENT
                  mysgw: TSF:MSG:READ,4-4-0,s=1,c=0,t=4,pt=0,l=0,sg=0:
                  mysgw: GWT:TPS:TOPIC=mysensors-out/4/1/0/0/4,MSG SENT
                  mysgw: TSF:MSG:READ,4-4-0,s=255,c=3,t=26,pt=1,l=1,sg=0:2
                  mysgw: TSF:MSG:SEND,0-0-4-4,s=255,c=3,t=27,pt=1,l=1,sg=0,ft=0,st=OK:1
                  mysgw: TSF:MSG:READ,4-4-0,s=1,c=1,t=3,pt=2,l=2,sg=0:100
                  mysgw: GWT:TPS:TOPIC=mysensors-out/4/1/1/0/3,MSG SENT
                  • A
                    alterfritz
                    until it crashes...
                    mysgw: TSF:MSG:BC
                    mysgw: TSF:CKU:OK
                    [Switching to Thread 0x75cc8450 (LWP 4759)]
                    87 *buf++ = *prx++;
                    • A alterfritz
                      until it crashes...
                      mysgw: TSF:MSG:BC
                      mysgw: TSF:CKU:OK
                      87 *buf++ = *prx++;
                      @alterfritz thanks. Now we know where in the code the crash occurs. Hopefully @marceloaqno can figure out what's wrong. I'll take a look as well, but I am not familiar with that code so I am not sure I will understand it.
                      • A
                        alterfritz
                        Thanks a lot. Looking forward to any update... have a nice weekend, I will try the version for ESP8266 in the meantime, however run it on the pi would be preferred.
                        Thanks again!
                        • A
                          alterfritz
                          Just to let you know - I have uploaded the ESP8266 sketch (from 2.1.1) via Arduino IDE, seems to run stable with the same NRF24L01 module.
                          But if possible I would like to go back to have all run on the raspi.
                          Again thanks for all that support here!
                          tekkaT 1 Reply Last reply
                          • A alterfritz
                            tekkaT
                            tekkaT
                            tekka
                            @alterfritz I've prepared a PR that should fix the segmentation fault: https://github.com/tekka007/MySensors/tree/nullptr - can you test this PR?
                            • A
                              alterfritz
                              Many thanks - yes, will do today. Let you know results.
                              • A
                                alterfritz
                                Seems this does the trick. Thanks!
                                • A alterfritz
                                  tekkaT
                                  tekkaT
                                  tekka
                                  @alterfritz Thanks for the feedback, PR merged to 2.2.0-rc.2
                                  • mfalkviddM
                                    Excellent work. Thanks everyone!
