  2. Bug Reports
  3. Raspberry Pi stability problem
18 Posts 3 Posters 5.9k Views 2 Watching
  • A alterfritz
    The gateway basically stops with a segmentation fault after working ok for a few minutes... let me try it...give me a minute...
    @alterfritz that's not what I was asking about. See the text I quoted.
    • A
      alterfritz
      Ok - thanks will do that...
      • A
        alterfritz
        pi@pi:~ $ sudo gdb /home/pi/mysensors_dev/MySensors/bin/mysgw
        GNU gdb (Raspbian 7.7.1+dfsg-5+rpi1) 7.7.1
        Copyright (C) 2014 Free Software Foundation, Inc.
        License GPLv3+: GNU GPL version 3 or later http://gnu.org/licenses/gpl.html
        This is free software: you are free to change and redistribute it.
        There is NO WARRANTY, to the extent permitted by law. Type "show copying"
        and "show warranty" for details.
        This GDB was configured as "arm-linux-gnueabihf".
        Type "show configuration" for configuration details.
        For bug reporting instructions, please see:
        http://www.gnu.org/software/gdb/bugs/.
        Find the GDB manual and other documentation resources online at:
        http://www.gnu.org/software/gdb/documentation/.
        For help, type "help".
        Type "apropos word" to search for commands related to "word"...
        Reading symbols from /home/pi/mysensors_dev/MySensors/bin/mysgw...done.
        (gdb) run -d
        Starting program: /home/pi/mysensors_dev/MySensors/bin/mysgw -d
        [Thread debugging using libthread_db enabled]
        Using host libthread_db library "/lib/arm-linux-gnueabihf/libthread_db.so.1".
        mysgw: Starting gateway...
        mysgw: Protocol version - 2.2.0-rc.2
        mysgw: MCO:BGN:INIT GW,CP=RNNGL-Q-,VER=2.2.0-rc.2
        mysgw: TSF:LRT:OK
        mysgw: TSM:INIT
        mysgw: TSF:WUR:MS=0
        [New Thread 0x75cc8450 (LWP 4703)]
        mysgw: TSM:INIT:TSP OK
        mysgw: TSM:INIT:GW MODE
        mysgw: MCO:REG:NOT NEEDED
        mysgw: MCO:BGN:STP
        mysgw: MCO:BGN:INIT OK,TSP=1
        mysgw: GWT:RMQ:MQTT RECONNECT
        mysgw: connected to 127.0.0.1
        mysgw: GWT:RMQ:MQTT CONNECTED
        mysgw: GWT:TPS:TOPIC=mysensors-out/0/255/0/0/18,MSG SENT
        mysgw: TSF:MSG:READ,3-3-255,s=255,c=3,t=7,pt=0,l=0,sg=0:
        mysgw: TSF:MSG:BC
        mysgw: TSF:MSG:FPAR REQ,ID=3
        mysgw: TSF:PNG:SEND,TO=0
        mysgw: TSF:CKU:OK
        mysgw: TSF:MSG:GWL OK
        Program received signal SIGSEGV, Segmentation fault.
        [Switching to Thread 0x75cc8450 (LWP 4703)]
        0x0001ac74 in RF24_spiMultiByteTransfer (readMode=true, len=6 '\006', buf=0x1 <error: Cannot access memory at address 0x1>, cmd=97 'a') at ./drivers/RF24/RF24.cpp:87
        87 *buf++ = *prx++;
        (gdb)
        • A
          alterfritz
          Here is another screenshot - seems that sometimes it works... for some time...
          mysgw: TSF:MSG:READ,1-1-0,s=255,c=3,t=6,pt=1,l=1,sg=0:0
          mysgw: GWT:TPS:TOPIC=mysensors-out/1/255/3/0/6,MSG SENT
          mysgw: TSF:MSG:READ,6-6-0,s=255,c=3,t=24,pt=1,l=1,sg=0:1
          mysgw: TSF:MSG:PINGED,ID=6,HP=1
          mysgw: TSF:MSG:SEND,0-0-6-6,s=255,c=3,t=25,pt=1,l=1,sg=0,ft=0,st=OK:1
          mysgw: TSF:MSG:READ,6-6-0,s=255,c=3,t=15,pt=6,l=2,sg=0:0100
          mysgw: TSF:MSG:SEND,0-0-6-6,s=255,c=3,t=15,pt=6,l=2,sg=0,ft=0,st=OK:0100
          mysgw: TSF:MSG:READ,6-6-0,s=255,c=0,t=17,pt=0,l=10,sg=0:2.2.0-beta
          mysgw: GWT:TPS:TOPIC=mysensors-out/6/255/0/0/17,MSG SENT
          mysgw: TSF:MSG:READ,6-6-0,s=255,c=3,t=6,pt=1,l=1,sg=0:0
          mysgw: GWT:TPS:TOPIC=mysensors-out/6/255/3/0/6,MSG SENT
          mysgw: TSF:MSG:READ,5-5-0,s=255,c=0,t=17,pt=0,l=10,sg=0:2.2.0-beta
          mysgw: GWT:TPS:TOPIC=mysensors-out/5/255/0/0/17,MSG SENT
          mysgw: TSF:MSG:READ,5-5-0,s=255,c=3,t=6,pt=1,l=1,sg=0:0
          mysgw: GWT:TPS:TOPIC=mysensors-out/5/255/3/0/6,MSG SENT
          mysgw: TSF:MSG:READ,1-1-0,s=255,c=3,t=11,pt=0,l=10,sg=0:WallLight1
          mysgw: GWT:TPS:TOPIC=mysensors-out/1/255/3/0/11,MSG SENT
          mysgw: TSF:MSG:READ,1-1-0,s=255,c=3,t=12,pt=0,l=3,sg=0:1.0
          mysgw: GWT:TPS:TOPIC=mysensors-out/1/255/3/0/12,MSG SENT
          mysgw: TSF:MSG:READ,1-1-0,s=1,c=0,t=4,pt=0,l=0,sg=0:
          mysgw: GWT:TPS:TOPIC=mysensors-out/1/1/0/0/4,MSG SENT
          mysgw: TSF:MSG:READ,1-1-0,s=255,c=3,t=26,pt=1,l=1,sg=0:2
          mysgw: TSF:MSG:SEND,0-0-1-1,s=255,c=3,t=27,pt=1,l=1,sg=0,ft=0,st=OK:1
          mysgw: TSF:MSG:READ,1-1-0,s=1,c=1,t=3,pt=2,l=2,sg=0:100
          mysgw: GWT:TPS:TOPIC=mysensors-out/1/1/1/0/3,MSG SENT
          mysgw: TSF:MSG:BC
          mysgw: TSF:CKU:OK,FCTRL
          mysgw: TSF:MSG:SEND,0-0-3-3,s=255,c=3,t=8,pt=1,l=1,sg=0,ft=0,st=OK:0
          mysgw: TSF:MSG:READ,4-4-255,s=255,c=3,t=7,pt=0,l=0,sg=0:
          mysgw: TSF:MSG:BC
          mysgw: TSF:MSG:FPAR REQ,ID=4
          mysgw: TSF:MSG:SEND,0-0-4-4,s=255,c=3,t=8,pt=1,l=1,sg=0,ft=0,st=OK:0
          mysgw: TSF:MSG:READ,6-6-0,s=255,c=3,t=11,pt=0,l=10,sg=0:WallLight6
          mysgw: GWT:TPS:TOPIC=mysensors-out/6/255/3/0/11,MSG SENT
          mysgw: TSF:MSG:READ,6-6-0,s=255,c=3,t=12,pt=0,l=3,sg=0:1.0
          mysgw: GWT:TPS:TOPIC=mysensors-out/6/255/3/0/12,MSG SENT
          mysgw: TSF:MSG:READ,6-6-0,s=1,c=0,t=4,pt=0,l=0,sg=0:
          mysgw: GWT:TPS:TOPIC=mysensors-out/6/1/0/0/4,MSG SENT
          mysgw: TSF:MSG:READ,6-6-0,s=255,c=3,t=26,pt=1,l=1,sg=0:2
          mysgw: !TSF:MSG:SEND,0-0-6-6,s=255,c=3,t=27,pt=1,l=1,sg=0,ft=0,st=NACK:1
          mysgw: TSF:MSG:READ,5-5-0,s=255,c=3,t=11,pt=0,l=10,sg=0:WallLight5
          mysgw: GWT:TPS:TOPIC=mysensors-out/5/255/3/0/11,MSG SENT
          mysgw: TSF:MSG:READ,5-5-0,s=255,c=3,t=12,pt=0,l=3,sg=0:1.0
          mysgw: GWT:TPS:TOPIC=mysensors-out/5/255/3/0/12,MSG SENT
          mysgw: TSF:MSG:READ,5-5-0,s=1,c=0,t=4,pt=0,l=0,sg=0:
          mysgw: GWT:TPS:TOPIC=mysensors-out/5/1/0/0/4,MSG SENT
          mysgw: TSF:MSG:READ,5-5-0,s=255,c=3,t=26,pt=1,l=1,sg=0:2
          mysgw: TSF:MSG:SEND,0-0-5-5,s=255,c=3,t=27,pt=1,l=1,sg=0,ft=0,st=OK:1
          mysgw: TSF:MSG:READ,5-5-0,s=1,c=1,t=3,pt=2,l=2,sg=0:100
          mysgw: GWT:TPS:TOPIC=mysensors-out/5/1/1/0/3,MSG SENT
          mysgw: TSF:MSG:READ,3-3-0,s=255,c=3,t=24,pt=1,l=1,sg=0:1
          mysgw: TSF:MSG:PINGED,ID=3,HP=1
          mysgw: TSF:MSG:SEND,0-0-3-3,s=255,c=3,t=25,pt=1,l=1,sg=0,ft=0,st=OK:1
          mysgw: TSF:MSG:READ,3-3-0,s=255,c=3,t=15,pt=6,l=2,sg=0:0100
          mysgw: TSF:MSG:SEND,0-0-3-3,s=255,c=3,t=15,pt=6,l=2,sg=0,ft=0,st=OK:0100
          mysgw: TSF:MSG:READ,3-3-0,s=255,c=0,t=17,pt=0,l=10,sg=0:2.2.0-beta
          mysgw: GWT:TPS:TOPIC=mysensors-out/3/255/0/0/17,MSG SENT
          mysgw: TSF:MSG:READ,3-3-0,s=255,c=3,t=6,pt=1,l=1,sg=0:0
          mysgw: GWT:TPS:TOPIC=mysensors-out/3/255/3/0/6,MSG SENT
          mysgw: TSF:MSG:READ,4-4-0,s=255,c=3,t=24,pt=1,l=1,sg=0:1
          mysgw: TSF:MSG:PINGED,ID=4,HP=1
          mysgw: TSF:MSG:SEND,0-0-4-4,s=255,c=3,t=25,pt=1,l=1,sg=0,ft=0,st=OK:1
          mysgw: TSF:MSG:READ,4-4-0,s=255,c=3,t=15,pt=6,l=2,sg=0:0100
          mysgw: TSF:MSG:SEND,0-0-4-4,s=255,c=3,t=15,pt=6,l=2,sg=0,ft=0,st=OK:0100
          mysgw: TSF:MSG:READ,3-3-0,s=255,c=3,t=11,pt=0,l=10,sg=0:WallLight3
          mysgw: GWT:TPS:TOPIC=mysensors-out/3/255/3/0/11,MSG SENT
          mysgw: TSF:MSG:READ,3-3-0,s=255,c=3,t=12,pt=0,l=3,sg=0:1.0
          mysgw: GWT:TPS:TOPIC=mysensors-out/3/255/3/0/12,MSG SENT
          mysgw: TSF:MSG:READ,3-3-0,s=1,c=0,t=4,pt=0,l=0,sg=0:
          mysgw: GWT:TPS:TOPIC=mysensors-out/3/1/0/0/4,MSG SENT
          mysgw: TSF:MSG:READ,3-3-0,s=255,c=3,t=26,pt=1,l=1,sg=0:2
          mysgw: TSF:MSG:SEND,0-0-3-3,s=255,c=3,t=27,pt=1,l=1,sg=0,ft=0,st=OK:1
          mysgw: TSF:MSG:READ,4-4-0,s=255,c=0,t=17,pt=0,l=10,sg=0:2.2.0-beta
          mysgw: GWT:TPS:TOPIC=mysensors-out/4/255/0/0/17,MSG SENT
          mysgw: TSF:MSG:READ,3-3-0,s=1,c=1,t=3,pt=2,l=2,sg=0:100
          mysgw: GWT:TPS:TOPIC=mysensors-out/3/1/1/0/3,MSG SENT
          mysgw: TSF:MSG:READ,4-4-0,s=255,c=3,t=6,pt=1,l=1,sg=0:0
          mysgw: GWT:TPS:TOPIC=mysensors-out/4/255/3/0/6,MSG SENT
          mysgw: TSF:MSG:READ,4-4-0,s=255,c=3,t=11,pt=0,l=10,sg=0:WallLight4
          mysgw: GWT:TPS:TOPIC=mysensors-out/4/255/3/0/11,MSG SENT
          mysgw: TSF:MSG:READ,4-4-0,s=255,c=3,t=12,pt=0,l=3,sg=0:1.0
          mysgw: GWT:TPS:TOPIC=mysensors-out/4/255/3/0/12,MSG SENT
          mysgw: TSF:MSG:READ,4-4-0,s=1,c=0,t=4,pt=0,l=0,sg=0:
          mysgw: GWT:TPS:TOPIC=mysensors-out/4/1/0/0/4,MSG SENT
          mysgw: TSF:MSG:READ,4-4-0,s=255,c=3,t=26,pt=1,l=1,sg=0:2
          mysgw: TSF:MSG:SEND,0-0-4-4,s=255,c=3,t=27,pt=1,l=1,sg=0,ft=0,st=OK:1
          mysgw: TSF:MSG:READ,4-4-0,s=1,c=1,t=3,pt=2,l=2,sg=0:100
          mysgw: GWT:TPS:TOPIC=mysensors-out/4/1/1/0/3,MSG SENT
          • A
            alterfritz
            until it crashes...
            mysgw: TSF:MSG:BC
            mysgw: TSF:CKU:OK
            [Switching to Thread 0x75cc8450 (LWP 4759)]
            87 *buf++ = *prx++;
            • A alterfritz
              until it crashes...
              mysgw: TSF:MSG:BC
              mysgw: TSF:CKU:OK
              87 *buf++ = *prx++;
              @alterfritz thanks. Now we know where in the code the crash occurs. Hopefully @marceloaqno can figure out what's wrong. I'll take a look as well, but I am not familiar with that code so I am not sure I will understand it.
              • A
                alterfritz
                Thanks a lot. Looking forward to any update... have a nice weekend, I will try the version for ESP8266 in the meantime, however run it on the pi would be preferred.
                Thanks again!
                • A
                  alterfritz
                  Just to let you know - I have uploaded the ESP8266 sketch (from 2.1.1) via Arduino IDE, seems to run stable with the same NRF24L01 module.
                  But if possible I would like to go back to have all run on the raspi.
                  Again thanks for all that support here!
                  tekkaT 1 Reply Last reply
                  • A alterfritz
                    tekkaT
                    tekkaT
                    tekka
                    @alterfritz I've prepared a PR that should fix the segmentation fault: https://github.com/tekka007/MySensors/tree/nullptr - can you test this PR?
                    • A
                      alterfritz
                      Many thanks - yes, will do today. Let you know results.
                      • A
                        alterfritz
                        Seems this does the trick. Thanks!
                        • A alterfritz
                          tekkaT
                          tekkaT
                          tekka
                          @alterfritz Thanks for the feedback, PR merged to 2.2.0-rc.2
                          • mfalkviddM
                            Excellent work. Thanks everyone!
