  3. Door sensor make USB disconnect while reading serial output?
19 Posts 4 Posters 2.2k Views 3 Watching
  • G Offline
    G Offline
    Guilou
    I have two Arduino Nano and I just want to build a domotic system with Home Assistant and MySensors.
    So, I build a serial gateway with one Arduino, just by copy/pasting the documentation example. By reading the debug, I think it's quite good.
    For the sensor, my code is:
    #define MY_BAUD_RATE 9600
    #define MY_NODE_ID 10
    #define CHILD_ID 3
    const int buttonPin = 3;    // the number of the pushbutton pin
    const int ledPin = 13;      // the number of the LED pin
    // Variables will change:
    int ledState = HIGH;         // the current state of the output pin
    int buttonState;             // the current reading from the input pin
    int lastButtonState = LOW;   // the previous reading from the input pin
    // the following variables are unsigned longs because the time, measured in
    // milliseconds, will quickly become a bigger number than can be stored in an int.
    unsigned long lastDebounceTime = 0;  // the last time the output pin was toggled
    unsigned long debounceDelay = 50;    // the debounce time; increase if the output flickers
      pinMode(buttonPin, INPUT);
      pinMode(ledPin, OUTPUT);
      // set initial LED state
      digitalWrite(ledPin, ledState);
      Serial.begin(MY_BAUD_RATE);
      //sendSketchInfo("TestSketch",  "1.0");
      present(CHILD_ID, S_DOOR);
      // read the state of the switch into a local variable:
      int reading = digitalRead(buttonPin);
      // check to see if you just pressed the button
      // (i.e. the input went from LOW to HIGH), and you've waited long enough
      // since the last press to ignore any noise:
      // If the switch changed, due to noise or pressing:
      if (reading != lastButtonState) {
        // reset the debouncing timer
        lastDebounceTime = millis();
      if ((millis() - lastDebounceTime) > debounceDelay) {
        // whatever the reading is at, it's been there for longer than the debounce
        // delay, so take it as the actual current state:
        // if the button state has changed:
        if (reading != buttonState) {
          buttonState = reading;
          // only toggle the LED if the new button state is HIGH
          if (buttonState == HIGH) {
            //send(msg.set(buttonState == HIGH ? 1 : 0));
            delay(1000);
            ledState = !ledState;
            Serial.print("State = ");
            Serial.println(ledState);
            send(msg.set(ledState));
      // set the LED:
      // save the reading. Next time through the loop, it'll be the lastButtonState:
      lastButtonState = reading;
    The serial output is like this.
    But something weird happens just after this serial reading. The USB seems to be disconnected and then reconnect to another ttyUSB. So I can't read all the serial at once. I tried to lower the baud rate, as you can see, but there is still the bug.
    I tried to swap Arduino, change USB port, change USB cable and there is still this strange behaviour.
    Do you know why?
    rejoe2R 1 Reply Last reply
    • G Guilou
      #define CHILD_ID 3
              delay(1000);
        // set the LED:
      Do you know why?
      rejoe2R Offline
      rejoe2R Offline
      rejoe2
      @guilou First, I can not see the serial output you tried to link, the log parser page remains blank.
      Do you also see this kind of rebooting behaviour, if you diconnect the arduino and then reconnect it without reflashing the sketch? If it then works and the Nano is equipped with a FTDI USB-serial-chip, it could be a not connected PIN of the FTDI.
      Otherwise this could be a powering issue (not enough juice for sending).
      In case this doesn't help, you might add info about IDE Version and Board Definition Version (IDE: Board Manager) of the Nano you use.
      • G Offline
        G Offline
        Guilou
        @rejoe2 said in Door sensor make USB disconnect while reading serial output?:
        That is weird, on my computer all links are ok.
        Anyway, I tried to disconnect/reconnect the Arduino without reflashing the sketch, and I have still the same behaviour: the output stops, and at the same time the Arduino change its port…
        26773 TSF:MSG:SEND,10-10-255-2550 MCO:BGN:INIT NODE,CP=RNNNA--,VER=2.1.1
        41 TSM:INIT
        55 TSF:WUR:MS=0
        76 TSM:INIT:TSP OK
        97 TSM:INIT:STATID=10
        119 TSF:SID:OK,ID=10
        The "14" on a single like lets me think the serial communication is interrupted at this exact point.
        I tried other cables and power source without any success.
        • G Guilou
          41 TSM:INIT
          55 TSF:WUR:MS=0
          76 TSM:INIT:TSP OK
          sundberg84S Offline
          sundberg84S Offline
          @guilou I would suspect a power issue, when the node draws to much current (ie. radio transmits) there is a voltage drop and reboot/freeze. Do you have capacitors installed on the radio and/or voltage regulator? What kind of hardware do you use?
          The Nano is also 5v so you need to regulate voltage down for VCC and datalines if you use a nrf or rfm radio.
          G 1 Reply Last reply
          • rejoe2R Offline
            rejoe2R Offline
            rejoe2
            Also this is version 2.1.1.
            Afaik RFM69 is more stable in the dev Version. You may try if things get better there...
            • sundberg84S sundberg84
              G Offline
              G Offline
              Guilou
              @sundberg84 I use Arduino Nano V3, breadboards and NRF24L01+ with a 4.7 µF capacitor. For debugging, a use USB port from my computer or RaspberryPI. I tried with a USB charger for cellphones, and nothing seems to change (but I am blind without serial :smile: )
              About software, I use Arduino IDE v1.8.5 and MySensors v2.1.1.
              sundberg84S 2 Replies Last reply
              • G Guilou
                sundberg84S Offline
                sundberg84S Offline
                @guilou - everything seems fine except that nrf24l01+ is not 5v tolerant (according to specs - sometimes it works!). I recommend to exclude this problem by using a logic level converter for the datalines since the nano sends 5v over all datalines and the nrf accepts 3.3 this could be a problem.
                • G Guilou
                  sundberg84S Offline
                  sundberg84S Offline
                  Sorry, brainfreeze - 5v dataline should be fine... confused with the RFM radio...
                  • G Offline
                    G Offline
                    Guilou
                    I use the 3v3 output of the Arduino to power the radio module :)
                    • G Guilou
                      sundberg84S Offline
                      sundberg84S Offline
                      @guilou - should work just fine..!
                      But still the behaviour smells like a power issue if you use the standard sketch... did you try another radio and or nano?
                        G Offline
                        G Offline
                        Guilou
                        @sundberg84 I swapped Nano between the gateway and the sensor and this bug always occurs with the sensor sketch. I have spare radio modules, so I will try with another one, thank you for this suggestion ;)
                        • G Offline
                          G Offline
                          Guilou
                          I tried with two spares modules and I am still stuck with this curious behaviour.
                          • hekH Offline
                            hekH Offline
                            Did you try adding a larger capacitor on the radio?
                              G Offline
                              G Offline
                              Guilou
                              @hek said in Door sensor make USB disconnect while reading serial output?:
                              Yes, but still the same.
                              I grab another Arduino Nano (not sure it's a guenuine one) and the serial output is correct! The sensor can not find the gateway, but this is another story :)
                              Do you know why some Arduino Nano V3 "compatible" will not work?
                              • G Offline
                                G Offline
                                Guilou
                                Hey there,
                                How can I know which Arduino Nano are good for MySensors?
                                Mine are from Banggood and the serial output seems to be chaotic.
                                I have one from Gravitech and it seems to be ok…
                                How to choose? In the MySensors store, this is clone form Asia like mine from Banggood…
                                • rejoe2R Offline
                                  rejoe2R Offline
                                  rejoe2
                                  So far, most of the cheap clones I use (or used) seemed to work fine on USB side, so most likely there is no real "rule".
                                  In case your problem is related to powering, you may replace the nano by a combination of CP2102 USB-to-serial converter and a pro mini or use a Pro Micro. The CP2102 also provides more current@3.3V (up to 100mA) and (similar to original FTDI's) allows programming of serial numbers and Product ID's to uniquely identify them in /dev/serial/by-id.
                                  Your problem report also reminds me to problems other users had with their LAN-GW's. For them afaik downgrading the board definition for the nanos (not the IDE) to version <=1.6.11 helped a lot. You might give that a try...
                                  • rejoe2R rejoe2
                                    G Offline
                                    G Offline
                                    Guilou
                                    Ok, I don't really understand yet what is the board definition version, but I will try. Thank you :)
                                    • G Guilou
                                      rejoe2R Offline
                                      rejoe2R Offline
                                      rejoe2
                                      @guilou said in Door sensor make USB disconnect while reading serial output?:
                                      See Tools - Board - Boards Manager. If you click on the Board Definitions listed (here: for Arduino Nano), a dropdown with all the versions available will appear - the function is similar to the Library Manager.
                                      • G Offline
                                        G Offline
                                        Guilou
                                        Hey,
                                        Just for information: I solved all my problem ny soldering. Don't know if this is the breadboard or the Dupont wire jumpers, but with wires soldered, everything is working now :)
