  3. Door sensor make USB disconnect while reading serial output?
19 Posts 4 Posters 3.7k Views 3 Watching
  • G Guilou
    I use the 3v3 output of the Arduino to power the radio module :)
    sundberg84S
    sundberg84S
    @guilou - should work just fine..!
    But still the behaviour smells like a power issue if you use the standard sketch... did you try another radio and or nano?
    G 1 Reply Last reply
    • sundberg84S sundberg84
      G
      G
      Guilou
      @sundberg84 I swapped Nano between the gateway and the sensor and this bug always occurs with the sensor sketch. I have spare radio modules, so I will try with another one, thank you for this suggestion ;)
      • G
        G
        Guilou
        I tried with two spares modules and I am still stuck with this curious behaviour.
          Did you try adding a larger capacitor on the radio?
            G
            G
            Guilou
            @hek said in Door sensor make USB disconnect while reading serial output?:
            Yes, but still the same.
            I grab another Arduino Nano (not sure it's a guenuine one) and the serial output is correct! The sensor can not find the gateway, but this is another story :)
            Do you know why some Arduino Nano V3 "compatible" will not work?
            • G
              G
              Guilou
              Hey there,
              How can I know which Arduino Nano are good for MySensors?
              Mine are from Banggood and the serial output seems to be chaotic.
              I have one from Gravitech and it seems to be ok…
              How to choose? In the MySensors store, this is clone form Asia like mine from Banggood…
              • rejoe2R
                rejoe2R
                rejoe2
                So far, most of the cheap clones I use (or used) seemed to work fine on USB side, so most likely there is no real "rule".
                In case your problem is related to powering, you may replace the nano by a combination of CP2102 USB-to-serial converter and a pro mini or use a Pro Micro. The CP2102 also provides more current@3.3V (up to 100mA) and (similar to original FTDI's) allows programming of serial numbers and Product ID's to uniquely identify them in /dev/serial/by-id.
                Your problem report also reminds me to problems other users had with their LAN-GW's. For them afaik downgrading the board definition for the nanos (not the IDE) to version <=1.6.11 helped a lot. You might give that a try...
                • rejoe2R rejoe2
                  G
                  G
                  Guilou
                  @rejoe2 said in Door sensor make USB disconnect while reading serial output?:
                  Ok, I don't really understand yet what is the board definition version, but I will try. Thank you :)
                  rejoe2R 1 Reply Last reply
                  • G Guilou
                    rejoe2R
                    rejoe2R
                    rejoe2
                    @guilou said in Door sensor make USB disconnect while reading serial output?:
                    See Tools - Board - Boards Manager. If you click on the Board Definitions listed (here: for Arduino Nano), a dropdown with all the versions available will appear - the function is similar to the Library Manager.
                    • G
                      G
                      Guilou
                      Hey,
                      Just for information: I solved all my problem ny soldering. Don't know if this is the breadboard or the Dupont wire jumpers, but with wires soldered, everything is working now :)
