  3. CNC PCB milling
CNC PCB milling
933 Posts 28 Posters 823.4k Views 27 Watching
    I found a place which sells a very similar looking board with epacket delivery, so I ordered from them: https://www.aliexpress.com/item/GRBL-0-9J-USB-port-cnc-engraving-machine-control-board-3-axis-control-laser-engraving-machine/32800881096.html?spm=2114.search0104.3.234.rCVwg2&ws_ab_test=searchweb0_0,searchweb201602_5_10152_10151_10065_10344_10130_10068_10324_10342_10547_10325_10546_10343_10340_10548_10341_10545_10084_10083_10613_10615_10307_10614_10059_10314_10534_100031_10604_10103_10142,searchweb201603_36,ppcSwitch_5&algo_expid=fda46a77-2501-458a-bcbb-474154a6fced-34&algo_pvid=fda46a77-2501-458a-bcbb-474154a6fced&transAbTest=ae803_5&priceBeautifyAB=0
    E 1 Reply Last reply
      #415
        E
        E
        executivul
        wrote on last edited by executivul
        #416
        @neverdie I believe the boards with a removable Arduino Nano are better, if the uC fries you can replace it without replacing the whole board.
        dbemowskD NeverDieN 2 Replies Last reply
        • E executivul
          dbemowskD
          dbemowskD
          @executivul similar to the RAMPS boards for 3D printers. It's all modular so if your uC or a stepper driver dies, you can just replace that one part.
          • E executivul
            I agree that seems like a far better design, for exactly that reason. I'm hoping this isn't something that happens regularly. If the replacement dies too, then I'll make the switch.
              E
              E
              executivul
              @neverdie or you could just mill your own board since now you have the tools :ok_hand:
              dbemowskD 1 Reply Last reply
                I've read from one of the sellers of the nano based grbl boards that they're typically hardwired against microstepping, but that the shields for the arduino uno don't typically have that problem. So, with that in mind, I'll probably order this as a backup in case of future failures: https://www.aliexpress.com/item/A4988-Driver-CNC-Qunqi-Shield-Expansion-Board-for-Arduino-V3-Engraver/32639790781.html?ws_ab_test=searchweb0_0,searchweb201602_4_10152_10151_10065_10344_10130_10068_10324_10342_10547_10325_10546_10343_10340_10548_10341_10545_10084_10083_10613_10615_10307_10614_10059_10314_10534_100031_10604_10103_10142,searchweb201603_2,ppcSwitch_4&algo_expid=14eaf328-95a3-442a-be93-ac1ee33f07f5-4&algo_pvid=14eaf328-95a3-442a-be93-ac1ee33f07f5&priceBeautifyAB=0
                • scalzS scalz
                  #421
                  andrewA 1 Reply Last reply
                  • E executivul
                    dbemowskD
                    dbemowskD
                    Not if it's broke he doesn't.
                    • ben999B
                      ben999B
                      ben999
                      That's the original designer of that shield :
                        andrewA
                        andrewA
                        andrew
                        @neverdie interesting.
                          #425
                            andrewA
                            andrewA
                            andrew
                            wrote on last edited by andrew
                            #426
                            @neverdie don't stick to you missing dragon programmer. use an arduino as an isp programmer instead. also, if you burn the bootloader, next time you can use the usb connector for update.
                            • andrewA andrew
                              #427
                                  #429
                                  BODLEVEL = 2V7
                                  RSTDISBL = [ ]
                                  DWEN = [ ]
                                  SPIEN = [X]
                                  WDTON = [ ]
                                  EESAVE = [ ]
                                  BOOTSZ = 1024W_3C00
                                  BOOTRST = [X]
                                  CKDIV8 = [ ]
                                  CKOUT = [ ]
                                  EXTENDED = 0x05 (valid)
                                  HIGH = 0xDA (valid)
                                  LOW = 0xFF (valid)
                                    #430
                                    Grbl 1.1f ['$' for help]
                                    Because of the upgraded firmware, I'm actually better off now than I was before. :)
                                    • andrewA andrew
                                      @neverdie I still use my default settings (see below). I re-applied these settings after I flashed the board to grbl 1.1f.
                                      $0=10 (step pulse, usec)
                                      $1=25 (step idle delay, msec)
                                      $6=0 (probe pin invert, bool)
                                      $12=0.002 (arc tolerance, mm)
                                      $13=0 (report inches, bool)
                                      $20=0 (soft limits, bool)
                                      $21=0 (hard limits, bool)
                                      $22=0 (homing cycle, bool)
                                      $100=800.000 (x, step/mm)
                                      $101=800.000 (y, step/mm)
                                      $102=800.000 (z, step/mm)
                                      #431
                                      $0=10
                                      $1=25
                                      $2=0
                                      $3=5
                                      $4=0
                                      $5=0
                                      $6=0
                                      $10=3
                                      $11=0.010
                                      $12=0.002
                                      $13=0
                                      $20=0
                                      $21=0
                                      $22=0
                                      $23=0
                                      $24=25.000
                                      $25=500.000
                                      $26=250
                                      $27=1.000
                                      $30=1000
                                      $31=0
                                      $32=0
                                      $100=800.000
                                      $101=800.000
                                      $102=800.000
                                      $110=800.000
                                      $111=800.000
                                      $112=500.000
                                      $120=10.000
                                      $121=10.000
                                      $122=10.000
                                      $130=200.000
                                      $131=200.000
                                      $132=200.000
                                        rmtuckerR 1 Reply Last reply
                                          rmtuckerR
                                          rmtuckerR
                                          rmtucker
                                          wrote on last edited by rmtucker
                                          #433
                                          @neverdie
