  3. CNC PCB milling
CNC PCB milling
933 Posts 28 Posters 823.4k Views 27 Watching
  • E executivul
    @neverdie or you could just mill your own board since now you have the tools :ok_hand:
    dbemowskD
    dbemowskD
    Not if it's broke he doesn't.
    • ben999B
      ben999B
      ben999
      That's the original designer of that shield :
        andrewA
        andrewA
        andrew
        @neverdie interesting.
          #425
          andrewA 1 Reply Last reply
            andrewA
            andrewA
            andrew
            wrote on last edited by andrew
            #426
            @neverdie don't stick to you missing dragon programmer. use an arduino as an isp programmer instead. also, if you burn the bootloader, next time you can use the usb connector for update.
            • andrewA andrew
              #427
                  #429
                  BODLEVEL = 2V7
                  RSTDISBL = [ ]
                  DWEN = [ ]
                  SPIEN = [X]
                  WDTON = [ ]
                  EESAVE = [ ]
                  BOOTSZ = 1024W_3C00
                  BOOTRST = [X]
                  CKDIV8 = [ ]
                  CKOUT = [ ]
                  EXTENDED = 0x05 (valid)
                  HIGH = 0xDA (valid)
                  LOW = 0xFF (valid)
                    #430
                    Grbl 1.1f ['$' for help]
                    Because of the upgraded firmware, I'm actually better off now than I was before. :)
                    • andrewA andrew
                      @neverdie I still use my default settings (see below). I re-applied these settings after I flashed the board to grbl 1.1f.
                      $0=10 (step pulse, usec)
                      $1=25 (step idle delay, msec)
                      $6=0 (probe pin invert, bool)
                      $12=0.002 (arc tolerance, mm)
                      $13=0 (report inches, bool)
                      $20=0 (soft limits, bool)
                      $21=0 (hard limits, bool)
                      $22=0 (homing cycle, bool)
                      $100=800.000 (x, step/mm)
                      $101=800.000 (y, step/mm)
                      $102=800.000 (z, step/mm)
                      #431
                      $0=10
                      $1=25
                      $2=0
                      $3=5
                      $4=0
                      $5=0
                      $6=0
                      $10=3
                      $11=0.010
                      $12=0.002
                      $13=0
                      $20=0
                      $21=0
                      $22=0
                      $23=0
                      $24=25.000
                      $25=500.000
                      $26=250
                      $27=1.000
                      $30=1000
                      $31=0
                      $32=0
                      $100=800.000
                      $101=800.000
                      $102=800.000
                      $110=800.000
                      $111=800.000
                      $112=500.000
                      $120=10.000
                      $121=10.000
                      $122=10.000
                      $130=200.000
                      $131=200.000
                      $132=200.000
                        rmtuckerR 1 Reply Last reply
                          rmtuckerR
                          rmtuckerR
                          rmtucker
                          wrote on last edited by rmtucker
                          #433
                          @neverdie
                            $0=10
                            $1=25
                            $2=0
                            $3=5
                            $4=0
                            $5=0
                            $6=0
                            $10=3
                            $11=0.010
                            $12=0.002
                            $13=0
                            $20=0
                            $21=0
                            $22=0
                            $23=0
                            $24=25.000
                            $25=500.000
                            $26=250
                            $27=1.000
                            $30=1000
                            $31=0
                            $32=0
                            $100=800.000
                            $101=800.000
                            $102=800.000
                            $110=800.000
                            $111=800.000
                            $112=500.000
                            $120=10.000
                            $121=10.000
                            $122=10.000
                            $130=200.000
                            $131=200.000
                            $132=200.000
                            I found out what they mean:
                            $31=0.	Min spindle speed, RPM
                            $32=0	Laser mode, boolean
                            • rmtuckerR rmtucker
                              @neverdie
                              yes
                                yes
                                andrewA
                                andrewA
                                andrew
                                @neverdie sorry, I'm abroad, with very limited availability, so cannot answer too quickly.
                                • andrewA andrew
                                  Thanks! You nailed it. It turns out the solder connection on the atmega328p pin corresponding to D5 just wasn't good enough. I resoldered it, and now the X-axis works in both directions. :)
                                        #440
                                        There's a huge difference between being able to evolve a single PCB design to perfect it rather than having to work on a "dumbed down" design (for a CNC or some other DIY etching process) before being able to get "the real deal" from a PCB fabricator. So, I'm very relieved that the first option now seems possible. :)
                                        andrewA 2 Replies Last reply
                                          andrewA
                                          andrewA
                                          andrew
                                          @neverdie I told you since the very beginning to make the firmware upgrade! ;)
