  3. CNC PCB milling
CNC PCB milling
933 Posts 28 Posters 823.4k Views 27 Watching
  • ben999B
    ben999B
    ben999
    That's the original designer of that shield :
      andrewA
      andrewA
      andrew
      @neverdie interesting.
        #425
        andrewA 1 Reply Last reply
          andrewA
          andrewA
          andrew
          wrote on last edited by andrew
          #426
          @neverdie don't stick to you missing dragon programmer. use an arduino as an isp programmer instead. also, if you burn the bootloader, next time you can use the usb connector for update.
          • andrewA andrew
            #427
                #429
                BODLEVEL = 2V7
                RSTDISBL = [ ]
                DWEN = [ ]
                SPIEN = [X]
                WDTON = [ ]
                EESAVE = [ ]
                BOOTSZ = 1024W_3C00
                BOOTRST = [X]
                CKDIV8 = [ ]
                CKOUT = [ ]
                EXTENDED = 0x05 (valid)
                HIGH = 0xDA (valid)
                LOW = 0xFF (valid)
                  #430
                  Grbl 1.1f ['$' for help]
                  Because of the upgraded firmware, I'm actually better off now than I was before. :)
                  • andrewA andrew
                    @neverdie I still use my default settings (see below). I re-applied these settings after I flashed the board to grbl 1.1f.
                    $0=10 (step pulse, usec)
                    $1=25 (step idle delay, msec)
                    $6=0 (probe pin invert, bool)
                    $12=0.002 (arc tolerance, mm)
                    $13=0 (report inches, bool)
                    $20=0 (soft limits, bool)
                    $21=0 (hard limits, bool)
                    $22=0 (homing cycle, bool)
                    $100=800.000 (x, step/mm)
                    $101=800.000 (y, step/mm)
                    $102=800.000 (z, step/mm)
                    #431
                    $0=10
                    $1=25
                    $2=0
                    $3=5
                    $4=0
                    $5=0
                    $6=0
                    $10=3
                    $11=0.010
                    $12=0.002
                    $13=0
                    $20=0
                    $21=0
                    $22=0
                    $23=0
                    $24=25.000
                    $25=500.000
                    $26=250
                    $27=1.000
                    $30=1000
                    $31=0
                    $32=0
                    $100=800.000
                    $101=800.000
                    $102=800.000
                    $110=800.000
                    $111=800.000
                    $112=500.000
                    $120=10.000
                    $121=10.000
                    $122=10.000
                    $130=200.000
                    $131=200.000
                    $132=200.000
                      rmtuckerR 1 Reply Last reply
                        rmtuckerR
                        rmtuckerR
                        rmtucker
                        wrote on last edited by rmtucker
                        #433
                        @neverdie
                          $0=10
                          $1=25
                          $2=0
                          $3=5
                          $4=0
                          $5=0
                          $6=0
                          $10=3
                          $11=0.010
                          $12=0.002
                          $13=0
                          $20=0
                          $21=0
                          $22=0
                          $23=0
                          $24=25.000
                          $25=500.000
                          $26=250
                          $27=1.000
                          $30=1000
                          $31=0
                          $32=0
                          $100=800.000
                          $101=800.000
                          $102=800.000
                          $110=800.000
                          $111=800.000
                          $112=500.000
                          $120=10.000
                          $121=10.000
                          $122=10.000
                          $130=200.000
                          $131=200.000
                          $132=200.000
                          I found out what they mean:
                          $31=0.	Min spindle speed, RPM
                          $32=0	Laser mode, boolean
                          • rmtuckerR rmtucker
                            @neverdie
                            yes
                              yes
                              andrewA
                              andrewA
                              andrew
                              @neverdie sorry, I'm abroad, with very limited availability, so cannot answer too quickly.
                              • andrewA andrew
                                Thanks! You nailed it. It turns out the solder connection on the atmega328p pin corresponding to D5 just wasn't good enough. I resoldered it, and now the X-axis works in both directions. :)
                                      #440
                                      There's a huge difference between being able to evolve a single PCB design to perfect it rather than having to work on a "dumbed down" design (for a CNC or some other DIY etching process) before being able to get "the real deal" from a PCB fabricator. So, I'm very relieved that the first option now seems possible. :)
                                      andrewA 2 Replies Last reply
                                        andrewA
                                        andrewA
                                        andrew
                                        @neverdie I told you since the very beginning to make the firmware upgrade! ;)
                                          andrewA
                                          andrewA
                                          andrew
                                          @neverdie as I see from the picture, you can decrease the cutting depth. this could help you to soften the force against the carving bits and it could also help you to use faster feed rates without risking a missing step or bit damage.
