  3. nRF5 action!
nRF5 action!
1.9k Posts 49 Posters 2.1m Views 44 Watching
  • T Toyman
    @korttoma thx. Do they have a CR2032 slot? Sorry, it's not clear from the pictures
    korttomaK
    korttomaK
    korttoma
    @toyman yes
    • Tomas
      It would probably do well as a "one button scene controller," but is it good for anything else I wonder?
      korttomaK 1 Reply Last reply
        korttomaK
        korttomaK
        korttoma
        @neverdie does not seem to be any easy way to get access to any of the pins on the board but who does not need a bunch of "one button scene controllers"?
        • Tomas
        • Nca78N
          I was tempted to try adding the missing accelerometer too, but in the end it's easier and cheaper to make a board with the 2$ module.
            #1369
            Speaking of which, I shrunk the HolyIOT board a bit and added the small buzzer:
            Hopefully this is small enough that it can be used as a locator beacon.
            It turns out this is pretty nearly the minimum size, even if the HolyIOT were smaller, because of the CR2032 battery underneath it. Anyway, that's an interesting result, because the BC182 is smaller than the HolyIOT, but I wouldn't get the benefit of it.
            Nca78N 1 Reply Last reply
              @neverdie said in nRF5 Bluetooth action!:
              small buzzer:
              CR2032 battery
              If I'm not wrong this buzzer needs over 100mA, not sure it's a good match for a CR2032 ?
              • MiKaM MiKa
                Working without problem with mysensors, I use STLink v2 from Aliexpress. LED and Button are mapped on pins 28 and 29 :)
                MiKaM
                MiKaM
                MiKa
                @mika said in nRF5 Bluetooth action!:
                Im just reporting sketch from NeverDie ;)
                https://www.openhardware.io/view/510/Multi-Sensor-TempHumidityPIR-LeakMagnetLightAccel
                • Nca78N Nca78
                  small buzzer:
                  CR2032 battery
                  @nca78 said in nRF5 Bluetooth action!:
                  small buzzer:
                  CR2032 battery
                  I like how nothing slips past you! Yes, it's a pretty severe trade-off in exchange for its small size. So, I'll be using two CR2032's and make it run only in very short bursts. I honestly don't know how well or badly it will turn out.
                    small buzzer:
                    CR2032 battery
                    I don't see anything to co trim such a high current on your board ? Maybe it's the reason the sound level is low on your other board, max current of the MCU pin is much lower than what the buzzer needs ?
                    • Nca78N Nca78
                      #1374
                      What does "co trim" mean?
                        Sorry phone rewriting what I type.
                        "Control".
                        MCU pins can't source that much current and I see no transistor on your board to do it ?
                        If you put a reserve capacitor big enough to supply 100+mA long enough to make some sound on the buzzer, will you not fry the pin ?
                        • Nca78N Nca78
                          "Control".
                          @nca78
                          The present design uses a TPS22860 load switch to turn on and off the buzzer. I'm not trying to power the buzzer directly from one of the nRF52832 pins, because the current would be outside the maximum limits for the nRF52832 pin. I'm hoping the two CR2032's will give enough headroom that the voltage (after the LDO) will be stable.
                            @nca78
                            @neverdie didn't now this chip, nice one thank you I've added it to my next order.
                            Seems I should have a better look at your designs :)
                            • Nca78N Nca78
                              I received the "holyiot" modules and they are really, really tiny. 2 attached together are exactly the same size than the 51822-04 module. WL-CSP package is very impressive: small, very thin and with a cool shinny surface.
                              This module has inductors for DC/DC mode, and pins .00 and .01 are mapped so it's possible to add low frequency crystal for Bluetooth mode.
                              #1378
                              Have you tried uploading anything to the HolyIOT modules? I've now tried on two different HolyIOT modules, both without success. :(
                                Sorry not yet, I've just re-plugged my NRF5 board and I'm figuring out how to program external board. I'll do it with a board I know works, then try the holyiot module;
                                • Nca78N Nca78
                                  @nca78 It's a tricky module to solder (probably the most tricky of them all that I've tried so far), so to eliminate that concern on the second module I flipped it over and soldered wires directly to the four essential pads. That way I could visually confirm that it was soldered correctly. Still fails. So, just FYI.
                                    I think I see the problem. These pinouts are inconsistent:
                                    I had been basing it on the first one, whereas I'm now guessing that the second one is probably the correct one.
                                      Confirmed. That was the problem. Using the second pinout, it now uploads.
                                        #1383
                                        I have the HolyIOT blinking an LED and receiving packets now. Range, as I suspected, is rather mediocre, but that's probably an inherent trade-off for its small size. For my purposes I don't think it will matter.
                                          #1384
                                          @neverdie was the difference that they were mirrored along vertical axis? Or am I missing a difference in labelling?
