  3. OpenHAB
  4. openHAB 2.2 binding MQTT support
37 Posts 9 Posters 24.4k Views 12 Watching
  • cgrfC
    cgrfC
    cgrf
    First of all, I'd like to thank you for your contribution, it is greatly appreciated!
    Unfortunately, I could not get the binding to talk to my Mosquitto server, yet. I have installed the addon and configured my MySensors MQTT Gateway as described above. But when I start OpenHAB (the Docker container instantiated from "openhab/openhab:2.2.0-amd64-alpine" to be precise), this is what I get in the openhab.log file:
    2018-01-09 15:45:29.710 [INFO ] [penhab.io.transport.mqtt.MqttService] - MQTT Service initialization completed.
    2018-01-09 15:45:29.711 [INFO ] [t.mqtt.internal.MqttBrokerConnection] - Starting MQTT broker connection 'ineluki'
    2018-01-09 15:45:30.420 [ERROR] [rotocol.mqtt.MySensorsMqttConnection] - No connection to broker: ineluki
    2018-01-09 15:45:30.471 [ERROR] [rotocol.mqtt.MySensorsMqttConnection] - Failed connecting to bridge...next retry in 10 seconds (Retry No.:0)
    And there is no "retry" after 10 seconds. At the same time this is and only this logged by Mosquitto:
    1515512709: Socket error on client openhab, disconnecting.
    1515512729: New connection from 172.19.0.5 on port 1883.
    Do you have any clue or hint what I might be doing wrong? I'm entirely new to OpenHAB, so please excuse if I'm missing something obvious.
    • cgrfC cgrf
      TimO
      Hi @cgrf !
      Please post the content of "org.eclipse.smarthome.mqtt.cfg".
      My guess is: there is no connection between OpenHAB2 and Mosquitto. The binding is only using the connection, it is not in charge for establishment or reconnects.
      Please check that in org.eclipse.smarthome.mqtt.cfg :
      mosquitto.url=tcp://192.168.2.3:1883
      mosquitto.user=user
      mosquitto.pwd=secret
      mosquitto.retain=false
      and in the MQTT GW configuration (in OH2) the names are matching.
      In your case it should look like (or similar to):
      ineluki.url=tcp://172.19.0.5:1883
      ineluki.user=user
      ineluki.pwd=secret
      ineluki.retain=false
      • cgrfC
        cgrfC
        cgrf
        Hi @TimO,
        Thanks for your response! There is an incoming connection from OpenHAB to Mosquitto, I can see as much in the Mosquitto log. But that connection does not seem to succeed.
        This is the content of my mqtt.cfg:
        ineluki.url=tcp://192.168.5.2:1883
        ineluki.clientId=openhab
        ineluki.qos=2
        ineluki.retain=true
        That Mosquitto instance currently does not require users to authenticate.
        • cgrfC cgrf
          Hi @TimO,
          ineluki.qos=2
          ineluki.retain=true
          TimO
          @cgrf
          Is there a log entry in OpenHAB that looks like this?
          [DEBUG] [.io.transport.mqtt.MqttService:155  ] - Starting MQTT Service...
          [INFO ] [.i.t.mqtt.MqttBrokerConnection:576  ] - Starting MQTT broker connection 'mosquitto' to 'tcp://192.168.2.3:1883' with clientid paho6110733874326 and file store '/tmp/mosquitto'
          [INFO ] [.i.t.mqtt.MqttBrokerConnection:576  ] - Starting MQTT broker connection 'mosquitto' to 'tcp://192.168.2.3:1883' with clientid paho6110762725063 and file store '/tmp/mosquitto'
          Depending on your log level there only may be the INFO line.
          • cgrfC
            cgrfC
            cgrf
            wrote on last edited by cgrf
            @TimO
            I have this INFO line, as included in my first post, that looks similar but not quite the same:
            The four lines from my first post are actually all lines I have in that log after the UI start-up messages.
            • T
              TimO
              wrote on last edited by TimO
              @cgrf said in openHAB 2.2 binding MQTT support:
              You're using the mqtt1 (openhab1-addon) to connect to the broker. The OpenHAB2 binding is based on the current (/upcoming) mqtt-transport implementation of ESH.
              My guess: the file org.eclipse.smarthome.mqtt.cfg is missing in /etc/openhab2/services and there only is a mqtt.cfg file. Just copy the mqtt.cfg file to org.eclipse.smarthome.mqtt.cfg (Same content, different name, different use).
              mqtt.cfg: mqtt1 binding, mqtt-transport, owntracks ...
              org.eclipse.smarthome.mqtt.cfg: ESH-MQTT and I'm only aware of my binding using it yet. But there are a few upcoming (mqtt generic, mqtt2 binding ..)
              cgrfC 1 Reply Last reply
              • T TimO
                cgrfC
                cgrfC
                cgrf
                @timo said in openHAB 2.2 binding MQTT support:
                Excellent guess, that was my problem! My gateway is "online" now. It would have taken me forever to figure that out on my own, so thank you very much! (And yes, reading your first post now I realize that you said so.)
                Should OpenHAB be able to discover the sensors behind the gateway? Or do I need to configure them manually?
                • cgrfC cgrf
                  TimO
                  @cgrf
                  If you restart the node they should represent themself and will show up in the Inbox in PaperUI.
                  • cgrfC
                    cgrfC
                    cgrf
                    @TimO
                    Ok, I've restarted the sensor multiple times now and I assume that it presents itself properly as it is discovered by other controllers (mycontroller.org, that is). But in OpenHAB's PaperUI it doesn't show up at all. There is a trace of it in the openhab.log though:
                    2018-01-10 09:29:39.268 [WARN ] [al.sensors.child.MySensorsChildSTemp] - Overwrite variable: V_VAR1
                    2018-01-10 09:29:39.269 [WARN ] [al.sensors.child.MySensorsChildSTemp] - Overwrite variable: V_VAR2
                    2018-01-10 09:29:39.277 [WARN ] [al.sensors.child.MySensorsChildSTemp] - Overwrite variable: V_VAR3
                    2018-01-10 09:29:39.289 [WARN ] [al.sensors.child.MySensorsChildSTemp] - Overwrite variable: V_VAR4
                    2018-01-10 09:29:39.289 [WARN ] [al.sensors.child.MySensorsChildSTemp] - Overwrite variable: V_VAR5
                    2018-01-10 20:38:26.959 [WARN ] [nal.sensors.child.MySensorsChildSHum] - Overwrite variable: V_VAR1
                    2018-01-10 20:38:26.980 [WARN ] [nal.sensors.child.MySensorsChildSHum] - Overwrite variable: V_VAR2
                    2018-01-10 20:38:26.980 [WARN ] [nal.sensors.child.MySensorsChildSHum] - Overwrite variable: V_VAR3
                    2018-01-10 20:38:26.980 [WARN ] [nal.sensors.child.MySensorsChildSHum] - Overwrite variable: V_VAR4
                    2018-01-10 20:38:26.981 [WARN ] [nal.sensors.child.MySensorsChildSHum] - Overwrite variable: V_VAR5
                    2018-01-10 20:38:27.084 [WARN ] [sors.child.MySensorsChildSMultimeter] - Overwrite variable: V_VAR1
                    2018-01-10 20:38:27.086 [WARN ] [sors.child.MySensorsChildSMultimeter] - Overwrite variable: V_VAR2
                    2018-01-10 20:38:27.086 [WARN ] [sors.child.MySensorsChildSMultimeter] - Overwrite variable: V_VAR3
                    2018-01-10 20:38:27.088 [WARN ] [sors.child.MySensorsChildSMultimeter] - Overwrite variable: V_VAR4
                    2018-01-10 20:38:27.089 [WARN ] [sors.child.MySensorsChildSMultimeter] - Overwrite variable: V_VAR5
                    2018-01-10 20:39:10.530 [WARN ] [rs.internal.gateway.MySensorsGateway] - Presented child is alredy present in gateway
                    2018-01-10 20:39:11.529 [WARN ] [rs.internal.gateway.MySensorsGateway] - Presented child is alredy present in gateway
                    2018-01-10 20:39:11.660 [WARN ] [rs.internal.gateway.MySensorsGateway] - Presented child is alredy present in gateway
                    2018-01-10 20:40:58.584 [WARN ] [rs.internal.gateway.MySensorsGateway] - Presented child is alredy present in gateway
                    2018-01-10 20:40:59.461 [WARN ] [rs.internal.gateway.MySensorsGateway] - Presented child is alredy present in gateway
                    2018-01-10 20:40:59.592 [WARN ] [rs.internal.gateway.MySensorsGateway] - Presented child is alredy present in gateway
                    While this is happening on MQTT:
                    gateway1-out/3/255/0/0/17 2.1.1
                    gateway1-out/3/255/3/0/6 0
                    gateway1-out/3/255/3/0/11 Combined Climate Sensor
                    gateway1-out/3/255/3/0/12 1.0.16
                    gateway1-out/3/0/0/0/7 (null)
                    gateway1-out/3/7/0/0/30 (null)
                    gateway1-out/3/10/2/0/15 (null)
                    gateway1-out/3/1/1/0/0 21.9
                    gateway1-out/3/0/1/0/1 42
                    gateway1-out/3/7/1/0/38 3.98
                    gateway1-out/3/255/3/0/0 56
                    Have you got another hint for me, maybe? It would be greatly appreciated.
                    • cgrfC
                      cgrfC
                      cgrf
                      Unfortunately, I'm still making no progress here. In the meantime I deleted the MQTT Gateway in the Paper UI and restarted the device to see what would happen. Now I'm seeing an error in openhab.log:
                      2018-01-16 19:45:23.419 [INFO ] [.transport.mqtt.MqttBrokerConnection] - Starting MQTT broker connection 'ineluki' to 'tcp://192.168.5.2:1883' with clientid openhab2 and file store '/openhab/userdata/tmp/ineluki'
                      2018-01-16 19:45:29.680 [INFO ] [.transport.mqtt.MqttBrokerConnection] - MQTT connection to 'ineluki' was lost: MqttException
                      2018-01-16 19:45:29.681 [ERROR] [rotocol.mqtt.MySensorsMqttConnection] - MQTT connection offline - {}
                      org.eclipse.paho.client.mqttv3.MqttException: MqttException
                              at org.eclipse.paho.client.mqttv3.internal.CommsCallback.run(CommsCallback.java:176) [211:org.eclipse.paho.client.mqttv3:1.0.2]
                              at java.lang.Thread.run(Thread.java:748) [?:?]
                      Caused by: java.lang.NullPointerException
                              at org.openhab.binding.mysensors.internal.protocol.mqtt.MySensorsMqttConnection$MySensorsMqttSubscriber.processMessage(MySensorsMqttConnection.java:142) ~[?:?]
                              at org.eclipse.smarthome.io.transport.mqtt.MqttBrokerConnection$ClientCallbacks.messageArrived(MqttBrokerConnection.java:121) ~[?:?]
                              at org.eclipse.paho.client.mqttv3.internal.CommsCallback.handleMessage(CommsCallback.java:354) ~[?:?]
                              at org.eclipse.paho.client.mqttv3.internal.CommsCallback.run(CommsCallback.java:162) ~[?:?]
                              ... 1 more
                      2018-01-16 19:45:29.709 [INFO ] [.reconnect.PeriodicReconnectStrategy] - Try to restore connection to 'ineluki' every 10000ms
                      Does this give any clue on what's going wrong?
                      • cgrfC
                        cgrfC
                        cgrf
                        Ok, now I'm seeing items in my Inbox, after I changed my org.eclipse.smarthome.mqtt.cfg from
                        ineluki.qos=2
                        ineluki.retain=true
                        to
                        #ineluki.qos=2
                        • MasMatM
                          MasMatM
                          MasMat
                          OK, n00b questions again:
                          1. where to place the binding-jar and do I have to do something with the jar-file?
                          2. no services directory exists in /etc. Create it?
                          3. any other things to install? Fresh PaperUI-OpenHab installation so far.
                            My system:RpiZero/Scratch+Mosquitto.
                          • MasMatM MasMat
                            TimO
                            @masmat
                            1. /usr/share/openhab2/addons/
                            2. Thank you for the hint, I've pointed to the wrong directory, it's: /etc/openhab2/services
                            3. For additional Informations please have a look at the wiki: https://github.com/tobof/openhab2-addons/wiki
                            MasMatM 1 Reply Last reply
                            • cgrfC cgrf
                              ineluki.qos=2
                              ineluki.retain=true
                              to
                              #ineluki.qos=2
                              TimO
                              @cgrf Thank you for the hint! At the moment I don't have an explanation for that behaviour.
                              • T TimO
                                @masmat
                                MasMatM
                                MasMatM
                                MasMat
                                @timo I still cant find mqtt.cfg OR org.eclipse.smarthome.mqtt.cfg. I looked thru the Github stuff but didn't see it.
                                Any ideas where to locate either of these files? I assume they have more lines than those four on display in the example.
                                Thanks. Sorry I'm still a tool with OH2
                                L 1 Reply Last reply
                                • MasMatM MasMat
                                  L
                                  L
                                  LastSamurai
                                  @masmat As far as I know .cfg files are only the config files fpr your installed addons and are located in the service directory (see TimO's post above). And they indeed only contain the settings you want to use, which can be 4 lines only. Depends on the addon
                                  • L LastSamurai
                                    MasMatM
                                    MasMatM
                                    MasMat
                                    @lastsamurai I kinda figured that. From the first post I understood that the MQTT binding (binding-mqtt1 - 1.11.0) did not need to be installed. mqtt.cfg -file does come from that. So far I haven't installed it, but if that's where the mqtt.cfg file should come from then I'll do that next.
                                    Just dont want to have addon on top of addon if they're redundant.
                                    • MasMatM MasMat
                                      TimO
                                      @masmat Just create the org.eclipse.smarthome.mqtt.cfg file. It's not created automatically. mqtt.cfg is not needed for the binding.
                                      • T TimO
                                        MasMatM
                                        MasMatM
                                        MasMat
                                        @timo Alright!! MQTT Gateway Online. Thanks for your patience. Hopefully this thread will help future hopefuls.
                                        Now, I'm gonna activate some nodes and see what happens.
                                        • MasMatM
                                          MasMatM
                                          MasMat
                                          Well, this joy lasted almost 24h...until I unplugged and moved the set-up.
                                          Now Mosquitto-service wont start "Status 11/SEGV"...went nuts looking for that.
                                          Moved Mosquitto to another machine, but now mysgw-service "failed to connect".
                                          Any ideas why Mosquitto went status11 after reboot?
                                          Why wont mysgw connect to another Mosquitto IP? does the port 1883 need to be configured as well?
                                          My configure-line: --my-transport=nrf24 --my-gateway=mqtt --my-controller-ip-address=192.168.0.52 --my-mqtt-publish-topic-prefix=mysensors-out --my-mqtt-subscribe-topic-prefix=mysensors-in --my-mqtt-client-id=mygateway1 --my-rf24-irq-pin=15 --my-leds-err-pin=12 --my-leds-rx-pin=16 --my-leds-tx-pin=18 --my-mqtt-user=????? —-my-mqtt-password=???????
