  3. OpenHAB
  4. openHAB 2.2 binding MQTT support
37 Posts 9 Posters 24.4k Views 12 Watching
  • cgrfC
    cgrfC
    cgrf
    Unfortunately, I'm still making no progress here. In the meantime I deleted the MQTT Gateway in the Paper UI and restarted the device to see what would happen. Now I'm seeing an error in openhab.log:
    2018-01-16 19:45:23.419 [INFO ] [.transport.mqtt.MqttBrokerConnection] - Starting MQTT broker connection 'ineluki' to 'tcp://192.168.5.2:1883' with clientid openhab2 and file store '/openhab/userdata/tmp/ineluki'
    2018-01-16 19:45:29.680 [INFO ] [.transport.mqtt.MqttBrokerConnection] - MQTT connection to 'ineluki' was lost: MqttException
    2018-01-16 19:45:29.681 [ERROR] [rotocol.mqtt.MySensorsMqttConnection] - MQTT connection offline - {}
    org.eclipse.paho.client.mqttv3.MqttException: MqttException
            at org.eclipse.paho.client.mqttv3.internal.CommsCallback.run(CommsCallback.java:176) [211:org.eclipse.paho.client.mqttv3:1.0.2]
            at java.lang.Thread.run(Thread.java:748) [?:?]
    Caused by: java.lang.NullPointerException
            at org.openhab.binding.mysensors.internal.protocol.mqtt.MySensorsMqttConnection$MySensorsMqttSubscriber.processMessage(MySensorsMqttConnection.java:142) ~[?:?]
            at org.eclipse.smarthome.io.transport.mqtt.MqttBrokerConnection$ClientCallbacks.messageArrived(MqttBrokerConnection.java:121) ~[?:?]
            at org.eclipse.paho.client.mqttv3.internal.CommsCallback.handleMessage(CommsCallback.java:354) ~[?:?]
            at org.eclipse.paho.client.mqttv3.internal.CommsCallback.run(CommsCallback.java:162) ~[?:?]
            ... 1 more
    2018-01-16 19:45:29.709 [INFO ] [.reconnect.PeriodicReconnectStrategy] - Try to restore connection to 'ineluki' every 10000ms
    Does this give any clue on what's going wrong?
    • cgrfC
      cgrfC
      cgrf
      Ok, now I'm seeing items in my Inbox, after I changed my org.eclipse.smarthome.mqtt.cfg from
      ineluki.qos=2
      ineluki.retain=true
      to
      #ineluki.qos=2
      ineluki.retain=false
      • MasMatM
        MasMatM
        MasMat
        OK, n00b questions again:
        1. where to place the binding-jar and do I have to do something with the jar-file?
        2. no services directory exists in /etc. Create it?
        3. any other things to install? Fresh PaperUI-OpenHab installation so far.
          My system:RpiZero/Scratch+Mosquitto.
        • MasMatM MasMat
          TimO
          @masmat
          1. /usr/share/openhab2/addons/
          2. Thank you for the hint, I've pointed to the wrong directory, it's: /etc/openhab2/services
          3. For additional Informations please have a look at the wiki: https://github.com/tobof/openhab2-addons/wiki
          MasMatM 1 Reply Last reply
          • cgrfC cgrf
            ineluki.qos=2
            ineluki.retain=true
            to
            #ineluki.qos=2
            TimO
            @cgrf Thank you for the hint! At the moment I don't have an explanation for that behaviour.
            • T TimO
              @masmat
              MasMatM
              MasMatM
              MasMat
              @timo I still cant find mqtt.cfg OR org.eclipse.smarthome.mqtt.cfg. I looked thru the Github stuff but didn't see it.
              Any ideas where to locate either of these files? I assume they have more lines than those four on display in the example.
              Thanks. Sorry I'm still a tool with OH2
              L 1 Reply Last reply
              • MasMatM MasMat
                L
                L
                LastSamurai
                @masmat As far as I know .cfg files are only the config files fpr your installed addons and are located in the service directory (see TimO's post above). And they indeed only contain the settings you want to use, which can be 4 lines only. Depends on the addon
                • L LastSamurai
                  MasMatM
                  MasMatM
                  MasMat
                  @lastsamurai I kinda figured that. From the first post I understood that the MQTT binding (binding-mqtt1 - 1.11.0) did not need to be installed. mqtt.cfg -file does come from that. So far I haven't installed it, but if that's where the mqtt.cfg file should come from then I'll do that next.
                  Just dont want to have addon on top of addon if they're redundant.
                  • MasMatM MasMat
                    TimO
                    @masmat Just create the org.eclipse.smarthome.mqtt.cfg file. It's not created automatically. mqtt.cfg is not needed for the binding.
                    • T TimO
                      MasMatM
                      MasMatM
                      MasMat
                      @timo Alright!! MQTT Gateway Online. Thanks for your patience. Hopefully this thread will help future hopefuls.
                      Now, I'm gonna activate some nodes and see what happens.
                      • MasMatM
                        MasMatM
                        MasMat
                        Well, this joy lasted almost 24h...until I unplugged and moved the set-up.
                        Now Mosquitto-service wont start "Status 11/SEGV"...went nuts looking for that.
                        Moved Mosquitto to another machine, but now mysgw-service "failed to connect".
                        Any ideas why Mosquitto went status11 after reboot?
                        Why wont mysgw connect to another Mosquitto IP? does the port 1883 need to be configured as well?
                        My configure-line: --my-transport=nrf24 --my-gateway=mqtt --my-controller-ip-address=192.168.0.52 --my-mqtt-publish-topic-prefix=mysensors-out --my-mqtt-subscribe-topic-prefix=mysensors-in --my-mqtt-client-id=mygateway1 --my-rf24-irq-pin=15 --my-leds-err-pin=12 --my-leds-rx-pin=16 --my-leds-tx-pin=18 --my-mqtt-user=????? —-my-mqtt-password=???????
                        • B
                          B
                          BenPr
                          @TimO The MySonsors Binding didn't find any things for me. :-/
                          My /etc/openhab2/services/org.eclipse.smarthome.mqtt.cfg
                          broker.url=tcp://localhost:1883
                          broker.clientId=openhabianpi
                          broker.user=*private*
                          broker.pwd=*private*
                          My /etc/mosquitto/mosquitto.conf
                          persistence true
                          password_file /etc/mosquitto/passwd
                          allow_anonymous false
                          My /var/log/mosquitto/mosquitto.log
                          1516918990: mosquitto version 1.4.10 (build date Mon, 29 May 2017 13:43:29 +0100) starting
                          1516918990: Config loaded from /etc/mosquitto/mosquitto.conf.
                          1516918990: Opening ipv4 listen socket on port 1883.
                          1516918990: Opening ipv6 listen socket on port 1883.
                          1516919015: New connection from x.x.x.29 on port 1883.
                          1516919015: New client connected from x.x.x.29 as MQTT_Terrassen_Beleuchtung (c1, k15, u'openhabian').
                          1516919044: New connection from 127.0.0.1 on port 1883.
                          1516919044: New client connected from 127.0.0.1 as openhabianpi (c1, k60, u'openhabian').
                          1516920798: Saving in-memory database to /var/lib/mosquitto/mosquitto.db.
                          MQTT_Terrassen_Beleuchtung is the thing to find.
                          My /var/log/openhab2/openhab.log
                          2018-01-26 00:15:23.079 [INFO ] [.internal.GenericScriptEngineFactory] - Activated scripting support for ECMAScript
                          2018-01-26 00:15:25.437 [INFO ] [er.internal.HomeBuilderDashboardTile] - Started Home Builder at /homebuilder
                          2018-01-26 00:15:28.660 [INFO ] [.core.internal.i18n.I18nProviderImpl] - Locale set to de_DE, Location set to 51.5032,7.0073, Time zone set to Europe/Berlin
                          2018-01-26 00:15:31.505 [INFO ] [.transport.mqtt.MqttBrokerConnection] - Starting MQTT broker connection 'broker' to 'tcp://localhost:1883' with clientid openhabianpi and file store '/var/lib/openhab2/tmp/broker'
                          2018-01-26 00:15:31.642 [WARN ] [rthome.io.transport.mqtt.MqttService] - MqttBroker start failed: Persistenz wird bereits verwendet
                          org.eclipse.smarthome.io.transport.mqtt.MqttException: Persistenz wird bereits verwendet
                                  at org.eclipse.smarthome.io.transport.mqtt.MqttBrokerConnection.start(MqttBrokerConnection.java:572) [289:org.eclipse.smarthome.io.transport.mqtt:0.10.0.b1]
                                  at org.eclipse.smarthome.io.transport.mqtt.MqttService.modified(MqttService.java:145) [289:org.eclipse.smarthome.io.transport.mqtt:0.10.0.b1]
                                  at org.eclipse.smarthome.io.transport.mqtt.MqttService.activate(MqttService.java:157) [289:org.eclipse.smarthome.io.transport.mqtt:0.10.0.b1]
                                  at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method) ~[?:?]
                                  at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62) ~[?:?]
                                  at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43) ~[?:?]
                                  at java.lang.reflect.Method.invoke(Method.java:498) ~[?:?]
                                  at org.apache.felix.scr.impl.inject.BaseMethod.invokeMethod(BaseMethod.java:229) [42:org.apache.felix.scr:2.0.12]
                                  at org.apache.felix.scr.impl.inject.BaseMethod.access$500(BaseMethod.java:39) [42:org.apache.felix.scr:2.0.12]
                                  at org.apache.felix.scr.impl.inject.BaseMethod$Resolved.invoke(BaseMethod.java:650) [42:org.apache.felix.scr:2.0.12]
                                  at org.apache.felix.scr.impl.inject.BaseMethod.invoke(BaseMethod.java:506) [42:org.apache.felix.scr:2.0.12]
                                  at org.apache.felix.scr.impl.inject.ActivateMethod.invoke(ActivateMethod.java:307) [42:org.apache.felix.scr:2.0.12]
                                  at org.apache.felix.scr.impl.inject.ActivateMethod.invoke(ActivateMethod.java:299) [42:org.apache.felix.scr:2.0.12]
                                  at org.apache.felix.scr.impl.manager.SingleComponentManager.createImplementationObject(SingleComponentManager.java:298) [42:org.apache.felix.scr:2.0.12]
                                  at org.apache.felix.scr.impl.manager.SingleComponentManager.createComponent(SingleComponentManager.java:109) [42:org.apache.felix.scr:2.0.12]
                                  at org.apache.felix.scr.impl.manager.SingleComponentManager.getService(SingleComponentManager.java:906) [42:org.apache.felix.scr:2.0.12]
                                  at org.apache.felix.scr.impl.manager.SingleComponentManager.getServiceInternal(SingleComponentManager.java:879) [42:org.apache.felix.scr:2.0.12]
                                  at org.apache.felix.scr.impl.manager.SingleComponentManager.getService(SingleComponentManager.java:823) [42:org.apache.felix.scr:2.0.12]
                                  at org.eclipse.osgi.internal.serviceregistry.ServiceFactoryUse$1.run(ServiceFactoryUse.java:212) [?:?]
                                  at java.security.AccessController.doPrivileged(Native Method) ~[?:?]
                                  at org.eclipse.osgi.internal.serviceregistry.ServiceFactoryUse.factoryGetService(ServiceFactoryUse.java:210) [?:?]
                                  at org.eclipse.osgi.internal.serviceregistry.ServiceFactoryUse.getService(ServiceFactoryUse.java:111) [?:?]
                                  at org.eclipse.osgi.internal.serviceregistry.ServiceConsumer$2.getService(ServiceConsumer.java:45) [?:?]
                                  at org.eclipse.osgi.internal.serviceregistry.ServiceRegistrationImpl.getService(ServiceRegistrationImpl.java:496) [?:?]
                                  at org.eclipse.osgi.internal.serviceregistry.ServiceRegistry.getService(ServiceRegistry.java:461) [?:?]
                                  at org.eclipse.osgi.internal.framework.BundleContextImpl.getService(BundleContextImpl.java:619) [?:?]
                                  at com.eclipsesource.jaxrs.publisher.internal.ResourceTracker.addingService(ResourceTracker.java:39) [15:com.eclipsesource.jaxrs.publisher:5.3.1.201602281253]
                                  at org.osgi.util.tracker.ServiceTracker$Tracked.customizerAdding(ServiceTracker.java:941) [?:?]
                                  at org.osgi.util.tracker.ServiceTracker$Tracked.customizerAdding(ServiceTracker.java:870) [?:?]
                                  at org.osgi.util.tracker.AbstractTracked.trackAdding(AbstractTracked.java:256) [?:?]
                                  at org.osgi.util.tracker.AbstractTracked.track(AbstractTracked.java:229) [?:?]
                                  at org.osgi.util.tracker.ServiceTracker$Tracked.serviceChanged(ServiceTracker.java:901) [?:?]
                                  at org.eclipse.osgi.internal.serviceregistry.FilteredServiceListener.serviceChanged(FilteredServiceListener.java:109) [?:?]
                                  at org.eclipse.osgi.internal.framework.BundleContextImpl.dispatchEvent(BundleContextImpl.java:915) [?:?]
                                  at org.eclipse.osgi.framework.eventmgr.EventManager.dispatchEvent(EventManager.java:230) [?:?]
                                  at org.eclipse.osgi.framework.eventmgr.ListenerQueue.dispatchEventSynchronous(ListenerQueue.java:148) [?:?]
                                  at org.eclipse.osgi.internal.serviceregistry.ServiceRegistry.publishServiceEventPrivileged(ServiceRegistry.java:862) [?:?]
                                  at org.eclipse.osgi.internal.serviceregistry.ServiceRegistry.publishServiceEvent(ServiceRegistry.java:801) [?:?]
                                  at org.eclipse.osgi.internal.serviceregistry.ServiceRegistrationImpl.register(ServiceRegistrationImpl.java:127) [?:?]
                                  at org.eclipse.osgi.internal.serviceregistry.ServiceRegistry.registerService(ServiceRegistry.java:225) [?:?]
                                  at org.eclipse.osgi.internal.framework.BundleContextImpl.registerService(BundleContextImpl.java:464) [?:?]
                                  at org.apache.felix.scr.impl.manager.AbstractComponentManager$3.register(AbstractComponentManager.java:887) [42:org.apache.felix.scr:2.0.12]
                                  at org.apache.felix.scr.impl.manager.AbstractComponentManager$3.register(AbstractComponentManager.java:874) [42:org.apache.felix.scr:2.0.12]
                                  at org.apache.felix.scr.impl.manager.RegistrationManager.changeRegistration(RegistrationManager.java:132) [42:org.apache.felix.scr:2.0.12]
                                  at org.apache.felix.scr.impl.manager.AbstractComponentManager.registerService(AbstractComponentManager.java:941) [42:org.apache.felix.scr:2.0.12]
                                  at org.apache.felix.scr.impl.manager.AbstractComponentManager.activateInternal(AbstractComponentManager.java:741) [42:org.apache.felix.scr:2.0.12]
                                  at org.apache.felix.scr.impl.manager.DependencyManager$SingleDynamicCustomizer.addedService(DependencyManager.java:799) [42:org.apache.felix.scr:2.0.12]
                                  at org.apache.felix.scr.impl.manager.DependencyManager$SingleDynamicCustomizer.addedService(DependencyManager.java:743) [42:org.apache.felix.scr:2.0.12]
                                  at org.apache.felix.scr.impl.manager.ServiceTracker$Tracked.customizerAdded(ServiceTracker.java:1215) [42:org.apache.felix.scr:2.0.12]
                                  at org.apache.felix.scr.impl.manager.ServiceTracker$Tracked.customizerAdded(ServiceTracker.java:1136) [42:org.apache.felix.scr:2.0.12]
                                  at org.apache.felix.scr.impl.manager.ServiceTracker$AbstractTracked.trackAdding(ServiceTracker.java:945) [42:org.apache.felix.scr:2.0.12]
                                  at org.apache.felix.scr.impl.manager.ServiceTracker$AbstractTracked.track(ServiceTracker.java:881) [42:org.apache.felix.scr:2.0.12]
                                  at org.apache.felix.scr.impl.manager.ServiceTracker$Tracked.serviceChanged(ServiceTracker.java:1167) [42:org.apache.felix.scr:2.0.12]
                                  at org.apache.felix.scr.impl.BundleComponentActivator$ListenerInfo.serviceChanged(BundleComponentActivator.java:127) [42:org.apache.felix.scr:2.0.12]
                                  at org.apache.felix.scr.impl.manager.DependencyManager$SingleStaticCustomizer.addedService(DependencyManager.java:1012) [42:org.apache.felix.scr:2.0.12]
                                  at org.apache.felix.scr.impl.manager.DependencyManager$SingleStaticCustomizer.addedService(DependencyManager.java:968) [42:org.apache.felix.scr:2.0.12]
                                  at org.apache.felix.scr.impl.manager.AbstractComponentManager.enableInternal(AbstractComponentManager.java:675) [42:org.apache.felix.scr:2.0.12]
                                  at org.apache.felix.scr.impl.manager.AbstractComponentManager.enable(AbstractComponentManager.java:430) [42:org.apache.felix.scr:2.0.12]
                                  at org.apache.felix.scr.impl.manager.ConfigurableComponentHolder.enableComponents(ConfigurableComponentHolder.java:657) [42:org.apache.felix.scr:2.0.12]
                                  at org.apache.felix.scr.impl.BundleComponentActivator.initialEnable(BundleComponentActivator.java:341) [42:org.apache.felix.scr:2.0.12]
                                  at org.apache.felix.scr.impl.Activator.loadComponents(Activator.java:390) [42:org.apache.felix.scr:2.0.12]
                                  at org.apache.felix.scr.impl.Activator.access$200(Activator.java:54) [42:org.apache.felix.scr:2.0.12]
                                  at org.apache.felix.scr.impl.Activator$ScrExtension.start(Activator.java:265) [42:org.apache.felix.scr:2.0.12]
                                  at org.apache.felix.utils.extender.AbstractExtender.createExtension(AbstractExtender.java:254) [42:org.apache.felix.scr:2.0.12]
                                  at org.apache.felix.utils.extender.AbstractExtender.modifiedBundle(AbstractExtender.java:227) [42:org.apache.felix.scr:2.0.12]
                                  at org.osgi.util.tracker.BundleTracker$Tracked.customizerModified(BundleTracker.java:482) [?:?]
                                  at org.osgi.util.tracker.BundleTracker$Tracked.customizerModified(BundleTracker.java:415) [?:?]
                                  at org.osgi.util.tracker.AbstractTracked.track(AbstractTracked.java:232) [?:?]
                                  at org.osgi.util.tracker.BundleTracker$Tracked.bundleChanged(BundleTracker.java:444) [?:?]
                                  at org.eclipse.osgi.internal.framework.BundleContextImpl.dispatchEvent(BundleContextImpl.java:903) [?:?]
                                  at org.eclipse.osgi.internal.framework.EquinoxEventPublisher.publishBundleEventPrivileged(EquinoxEventPublisher.java:213) [?:?]
                                  at org.eclipse.osgi.internal.framework.EquinoxEventPublisher.publishBundleEvent(EquinoxEventPublisher.java:120) [?:?]
                                  at org.eclipse.osgi.internal.framework.EquinoxEventPublisher.publishBundleEvent(EquinoxEventPublisher.java:112) [?:?]
                                  at org.eclipse.osgi.internal.framework.EquinoxContainerAdaptor.publishModuleEvent(EquinoxContainerAdaptor.java:156) [?:?]
                                  at org.eclipse.osgi.container.Module.publishEvent(Module.java:476) [?:?]
                                  at org.eclipse.osgi.container.Module.start(Module.java:467) [?:?]
                                  at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.incStartLevel(ModuleContainer.java:1620) [?:?]
                                  at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.incStartLevel(ModuleContainer.java:1600) [?:?]
                                  at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.doContainerStartLevel(ModuleContainer.java:1571) [?:?]
                                  at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.dispatchEvent(ModuleContainer.java:1514) [?:?]
                                  at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.dispatchEvent(ModuleContainer.java:1) [?:?]
                                  at org.eclipse.osgi.framework.eventmgr.EventManager$EventThread.run(EventManager.java:340) [?:?]
                          Caused by: org.eclipse.paho.client.mqttv3.MqttPersistenceException: Persistenz wird bereits verwendet
                                  at org.eclipse.paho.client.mqttv3.persist.MqttDefaultFilePersistence.open(MqttDefaultFilePersistence.java:112) ~[?:?]
                                  at org.eclipse.paho.client.mqttv3.MqttAsyncClient.<init>(MqttAsyncClient.java:286) ~[?:?]
                                  at org.eclipse.paho.client.mqttv3.MqttAsyncClient.<init>(MqttAsyncClient.java:167) ~[?:?]
                                  at org.eclipse.smarthome.io.transport.mqtt.MqttBrokerConnection.start(MqttBrokerConnection.java:570) ~[?:?]
                                  ... 118 more
                          2018-01-26 00:15:32.456 [INFO ] [.dashboard.internal.DashboardService] - Started dashboard at http://x.x.x.30:8080
                          2018-01-26 00:15:32.465 [INFO ] [.dashboard.internal.DashboardService] - Started dashboard at https://x.x.x.30:8443
                          2018-01-26 00:15:52.506 [INFO ] [thome.model.lsp.internal.ModelServer] - Started Language Server Protocol (LSP) service on port 5007
                          2018-01-26 00:16:01.849 [INFO ] [basic.internal.servlet.WebAppServlet] - Started Basic UI at /basicui/app
                          2018-01-26 00:16:01.999 [INFO ] [arthome.ui.paper.internal.PaperUIApp] - Started Paper UI at /paperui
                          2018-01-26 00:16:02.291 [INFO ] [panel.internal.HABPanelDashboardTile] - Started HABPanel at /habpanel
                          2018-01-26 00:16:02.816 [WARN ] [mqtt.internal.MqttPersistenceService] - mqtt-persistence:broker
                          2018-01-26 00:16:02.819 [WARN ] [mqtt.internal.MqttPersistenceService] - mqtt-persistence:topic
                          2018-01-26 00:16:02.822 [WARN ] [mqtt.internal.MqttPersistenceService] - mqtt-persistence:message
                          2018-01-26 00:16:05.597 [INFO ] [ui.habmin.internal.servlet.HABminApp] - Started HABmin servlet at /habmin
                          2018-01-26 00:16:06.390 [INFO ] [assic.internal.servlet.WebAppServlet] - Started Classic UI at /classicui/app
                          Have you any idea to fix this?
                          • jjkJ
                            jjkJ
                            jjk
                            jjkJ 1 Reply Last reply
                            • jjkJ jjk
                              [[topic:post-is-deleted]]
                              jjkJ
                              jjkJ
                              jjk
                              wrote on last edited by jjk
                              #27
                              Hi @TimO ,
                              after doing clean install of OH and the ESH mqtt binding per the original post above, the mqqt service ran properly (no errors in the debug log). After installing the mysensors binding, I start seing mysensors topics come in, but then following exception is thrown
                              2018-02-06 20:01:10.676 [DEBUG] [o.client.mqttv3.internal.ClientState] - paho167001634703924: received key=1 message=PUBLISH qos:1 msgId:1 retained:true dup:false topic:"mysgw-out/1/0/1/0/97" payload:[hex:33392e38 utf8:"39.8" length:4]
                              2018-02-06 20:01:10.676 [DEBUG] [o.client.mqttv3.internal.ClientState] - paho167001634703924: received key=1 token=org.eclipse.paho.client.mqttv3.MqttToken@e71260 message=SUBACK msgId 1 granted Qos 1
                              2018-02-06 20:01:10.677 [DEBUG] [client.mqttv3.internal.CommsCallback] - paho167001634703924: new msg avail, notify workAvailable
                              2018-02-06 20:01:10.678 [DEBUG] [o.client.mqttv3.internal.ClientState] - paho167001634703924: wait for new work or for space in the inflight window
                              2018-02-06 20:01:10.679 [DEBUG] [client.mqttv3.internal.CommsReceiver] - paho167001634703924: network read message
                              2018-02-06 20:01:10.679 [DEBUG] [client.mqttv3.internal.CommsCallback] - paho167001634703924: call messageArrived key=1 topic=mysgw-out/1/0/1/0/97
                              2018-02-06 20:01:10.680 [DEBUG] [o.client.mqttv3.internal.ClientState] - paho167001634703924: received bytes count=1
                              2018-02-06 20:01:10.681 [DEBUG] [o.client.mqttv3.internal.ClientState] - paho167001634703924: received bytes count=28
                              2018-02-06 20:01:10.681 [DEBUG] [client.mqttv3.internal.CommsCallback] - paho167001634703924: callback threw exception
                                      at org.openhab.binding.mysensors.internal.protocol.mqtt.MySensorsMqttConnection$MySensorsMqttSubscriber.processMessage(MySensorsMqttConnection.java:140) [233:org.openhab.binding.mysensors:2.2.0.201712141227]
                                      at org.eclipse.smarthome.io.transport.mqtt.MqttBrokerConnection$ClientCallbacks.messageArrived(MqttBrokerConnection.java:121) [232:org.eclipse.smarthome.io.transport.mqtt:0.10.0.b1]
                                      at org.eclipse.paho.client.mqttv3.internal.CommsCallback.handleMessage(CommsCallback.java:354) [231:org.eclipse.paho.client.mqttv3:1.0.2]
                                      at org.eclipse.paho.client.mqttv3.internal.CommsCallback.run(CommsCallback.java:162) [231:org.eclipse.paho.client.mqttv3:1.0.2]
                              2018-02-06 20:01:10.683 [DEBUG] [o.client.mqttv3.internal.ClientComms] - paho167001634703924: state=DISCONNECTING
                              Any idea what I'm doing wrong?
                              UPDATE:
                              For what it's worth, I found the trigger for the error. In fact, the mqtt messages the binding received were (for whatever reason) retained messages of the mosquitto broker. After removing the mosquitto presistence file
                              sudo service mosquitto stop
                              sudo rm /var/lib/mosquitto/mosquitto.db
                              sudo service mosquitto start
                              it now seems to work o.k. - Hope this might help others who come across this thread.
                              • jjkJ jjk
                                Hi @TimO ,
                                UPDATE:
                                TimO
                                @jjk Thank you for reporting back!
                                • T TimO
                                  jjkJ
                                  jjkJ
                                  jjk
                                  @timo, another effect I noticed is that the mysensor binding seems a bit sensitive to updates in the things and item files. I got new errors every time I added a thing to the things file or modified the items file. After rebooting OH those erros were gone and the things properly included. Stopping the mysensors binding (bundle:stop) before adding/changing things or items and restarting it afterwards works without a problem.
                                  • jogantJ
                                    jogantJ
                                    jogant
                                    hi,
                                    first I would say thanks for the binding. Generally I got it working, but I build a special sensor for my district heating counter. It has two sensors in one node, power and watermeter. The power sensor also sends messages for value types VAR1-5. Unfortunately these value seem to have a problem. I see them in the mosquitto broker but in openhab I can't see them. In the logging there are some warnings concerning these values.
                                    Is it a known problem?
                                    thanks and best regards
                                    Joachim
                                    • jogantJ jogant
                                      hi,
                                      Joachim
                                      TimO
                                      @jogant please enable debug output with log:set DEBUG org.openhab.binding.mysensors and post the debug output here. I'll look at it.
                                      jogantJ 1 Reply Last reply
                                      • T TimO
                                        jogantJ
                                        jogantJ
                                        jogant
                                        @timo I enabled debugging and could see that all mqtt messages are received correct. I had a problem with caching through jsondb. I deleted some things and links and now everything is fine. So nothing wrong in the binding. Thanks for your helpful hint.
                                        • MasMatM
                                          MasMatM
                                          MasMat
                                          wrote on last edited by MasMat
                                          #33
                                          Hi everyone. Since my last I reinstalled everything. I went back to Raspbian Jessie to get Mosquitto working properly. Full reinstall of MySensors mqtt gw and Openhab2 and binding.
                                          I have one sensor built that will not connect to the gw and I seem to be having problems on the gw as well.
                                          Quick specs: Rpi W, jessie, nrf24.
                                          I'm pretty new to Rpi as gateway, so I'm having little difficulty with finding debug-logs etc as well.
                                          Here's what my configuration was:
                                          ./configure --my-transport=nrf24 --my-gateway=mqtt --my-controller-ip-address=127.0.0.1 --my-mqtt-publish-topic-prefix=mysensors-out --my-mqtt-subscribe-topic-prefix=mysensors-in --my-mqtt-client-id=mygateway1 --my-rf24-irq-pin=15 --my-leds-err-pin=12 --my-leds-rx-pin=16 --my-leds-tx-pin=18 --my-mqtt-user=XXXX --my-mqtt-password=YYYYY --my-signing=password --my-signing-password=123456
                                          2018-02-19 16:56:15.280 [INFO ] [.transport.mqtt.MqttBrokerConnection] - Starting MQTT broker connection 'mosquitto' to 'tcp://127.0.0.1:1883' with clientid paho108561372416048 and file store '/var/lib/openhab2/tmp/mosquitto'
                                          2018-02-19 16:56:15.406 [INFO ] [.transport.mqtt.MqttBrokerConnection] - Starting MQTT broker connection 'mosquitto' to 'tcp://127.0.0.1:1883' with clientid paho108561583416206 and file store '/var/lib/openhab2/tmp/mosquitto'
                                          ......keeps repeating
                                          1519052215: Socket error on client <unknown>, disconnecting.
                                          1519052215: New connection from 127.0.0.1 on port 1883.
                                          1519052225: New connection from 127.0.0.1 on port 1883.
                                          ....keeps repeating
                                          systemctl status mysgw.service
                                          Feb 18 10:27:44 GwMqOH2 mysgw[359]: connect: Connection refused
                                          Feb 18 10:27:44 GwMqOH2 mysgw[359]: failed to connect
                                          ...repeating
                                          when I run mysgw -d:
                                          mysgw: Starting gateway...
                                          mysgw: Protocol version - 2.2.1-alpha
                                          mysgw: MCO:BGN:INIT GW,CP=RNNGLSQX,VER=2.2.1-alpha
                                          mysgw: TSF:LRT:OK
                                          mysgw: TSM:INIT
                                          mysgw: TSF:WUR:MS=0
                                          mysgw: TSM:INIT:TSP OK
                                          mysgw: TSM:INIT:GW MODE
                                          mysgw: MCO:REG:NOT NEEDED
                                          mysgw: MCO:BGN:STP
                                          mysgw: MCO:BGN:INIT OK,TSP=1
                                          mysgw: GWT:RMQ:MQTT RECONNECT
                                          mysgw: connected to 127.0.0.1
                                          mysgw: GWT:RMQ:MQTT CONNECTED
                                          mysgw: GWT:TPS:TOPIC=mysensors-out/0/255/0/0/18,MSG SENT
                                          Any ideas? Where should I start?
                                          Sorry for flooding, the code-block is not working for some reason....
