  3. OpenHAB
  4. openHAB 2.2 binding MQTT support
37 Posts 9 Posters 24.4k Views 12 Watching
  • cgrfC cgrf
    Hi @TimO,
    Thanks for your response! There is an incoming connection from OpenHAB to Mosquitto, I can see as much in the Mosquitto log. But that connection does not seem to succeed.
    This is the content of my mqtt.cfg:
    ineluki.url=tcp://192.168.5.2:1883
    ineluki.clientId=openhab
    ineluki.qos=2
    ineluki.retain=true
    That Mosquitto instance currently does not require users to authenticate.
    TimO
    @cgrf
    Is there a log entry in OpenHAB that looks like this?
    [DEBUG] [.io.transport.mqtt.MqttService:155  ] - Starting MQTT Service...
    [INFO ] [.i.t.mqtt.MqttBrokerConnection:576  ] - Starting MQTT broker connection 'mosquitto' to 'tcp://192.168.2.3:1883' with clientid paho6110733874326 and file store '/tmp/mosquitto'
    [INFO ] [.i.t.mqtt.MqttBrokerConnection:576  ] - Starting MQTT broker connection 'mosquitto' to 'tcp://192.168.2.3:1883' with clientid paho6110762725063 and file store '/tmp/mosquitto'
    Depending on your log level there only may be the INFO line.
    • cgrfC
      cgrfC
      cgrf
      wrote on last edited by cgrf
      @TimO
      I have this INFO line, as included in my first post, that looks similar but not quite the same:
      2018-01-09 15:45:29.711 [INFO ] [t.mqtt.internal.MqttBrokerConnection] - Starting MQTT broker connection 'ineluki'
      The four lines from my first post are actually all lines I have in that log after the UI start-up messages.
      • T
        TimO
        wrote on last edited by TimO
        @cgrf said in openHAB 2.2 binding MQTT support:
        You're using the mqtt1 (openhab1-addon) to connect to the broker. The OpenHAB2 binding is based on the current (/upcoming) mqtt-transport implementation of ESH.
        My guess: the file org.eclipse.smarthome.mqtt.cfg is missing in /etc/openhab2/services and there only is a mqtt.cfg file. Just copy the mqtt.cfg file to org.eclipse.smarthome.mqtt.cfg (Same content, different name, different use).
        mqtt.cfg: mqtt1 binding, mqtt-transport, owntracks ...
        org.eclipse.smarthome.mqtt.cfg: ESH-MQTT and I'm only aware of my binding using it yet. But there are a few upcoming (mqtt generic, mqtt2 binding ..)
        cgrfC 1 Reply Last reply
        • T TimO
          cgrfC
          cgrfC
          cgrf
          @timo said in openHAB 2.2 binding MQTT support:
          Excellent guess, that was my problem! My gateway is "online" now. It would have taken me forever to figure that out on my own, so thank you very much! (And yes, reading your first post now I realize that you said so.)
          Should OpenHAB be able to discover the sensors behind the gateway? Or do I need to configure them manually?
          • cgrfC cgrf
            TimO
            @cgrf
            If you restart the node they should represent themself and will show up in the Inbox in PaperUI.
            • cgrfC
              cgrfC
              cgrf
              @TimO
              Ok, I've restarted the sensor multiple times now and I assume that it presents itself properly as it is discovered by other controllers (mycontroller.org, that is). But in OpenHAB's PaperUI it doesn't show up at all. There is a trace of it in the openhab.log though:
              2018-01-10 09:29:39.268 [WARN ] [al.sensors.child.MySensorsChildSTemp] - Overwrite variable: V_VAR1
              2018-01-10 09:29:39.269 [WARN ] [al.sensors.child.MySensorsChildSTemp] - Overwrite variable: V_VAR2
              2018-01-10 09:29:39.277 [WARN ] [al.sensors.child.MySensorsChildSTemp] - Overwrite variable: V_VAR3
              2018-01-10 09:29:39.289 [WARN ] [al.sensors.child.MySensorsChildSTemp] - Overwrite variable: V_VAR4
              2018-01-10 09:29:39.289 [WARN ] [al.sensors.child.MySensorsChildSTemp] - Overwrite variable: V_VAR5
              2018-01-10 20:38:26.959 [WARN ] [nal.sensors.child.MySensorsChildSHum] - Overwrite variable: V_VAR1
              2018-01-10 20:38:26.980 [WARN ] [nal.sensors.child.MySensorsChildSHum] - Overwrite variable: V_VAR2
              2018-01-10 20:38:26.980 [WARN ] [nal.sensors.child.MySensorsChildSHum] - Overwrite variable: V_VAR3
              2018-01-10 20:38:26.980 [WARN ] [nal.sensors.child.MySensorsChildSHum] - Overwrite variable: V_VAR4
              2018-01-10 20:38:26.981 [WARN ] [nal.sensors.child.MySensorsChildSHum] - Overwrite variable: V_VAR5
              2018-01-10 20:38:27.084 [WARN ] [sors.child.MySensorsChildSMultimeter] - Overwrite variable: V_VAR1
              2018-01-10 20:38:27.086 [WARN ] [sors.child.MySensorsChildSMultimeter] - Overwrite variable: V_VAR2
              2018-01-10 20:38:27.086 [WARN ] [sors.child.MySensorsChildSMultimeter] - Overwrite variable: V_VAR3
              2018-01-10 20:38:27.088 [WARN ] [sors.child.MySensorsChildSMultimeter] - Overwrite variable: V_VAR4
              2018-01-10 20:38:27.089 [WARN ] [sors.child.MySensorsChildSMultimeter] - Overwrite variable: V_VAR5
              2018-01-10 20:39:10.530 [WARN ] [rs.internal.gateway.MySensorsGateway] - Presented child is alredy present in gateway
              2018-01-10 20:39:11.529 [WARN ] [rs.internal.gateway.MySensorsGateway] - Presented child is alredy present in gateway
              2018-01-10 20:39:11.660 [WARN ] [rs.internal.gateway.MySensorsGateway] - Presented child is alredy present in gateway
              2018-01-10 20:40:58.584 [WARN ] [rs.internal.gateway.MySensorsGateway] - Presented child is alredy present in gateway
              2018-01-10 20:40:59.461 [WARN ] [rs.internal.gateway.MySensorsGateway] - Presented child is alredy present in gateway
              2018-01-10 20:40:59.592 [WARN ] [rs.internal.gateway.MySensorsGateway] - Presented child is alredy present in gateway
              While this is happening on MQTT:
              gateway1-out/3/255/0/0/17 2.1.1
              gateway1-out/3/255/3/0/6 0
              gateway1-out/3/255/3/0/11 Combined Climate Sensor
              gateway1-out/3/255/3/0/12 1.0.16
              gateway1-out/3/0/0/0/7 (null)
              gateway1-out/3/7/0/0/30 (null)
              gateway1-out/3/10/2/0/15 (null)
              gateway1-out/3/1/1/0/0 21.9
              gateway1-out/3/0/1/0/1 42
              gateway1-out/3/7/1/0/38 3.98
              gateway1-out/3/255/3/0/0 56
              Have you got another hint for me, maybe? It would be greatly appreciated.
              • cgrfC
                cgrfC
                cgrf
                Unfortunately, I'm still making no progress here. In the meantime I deleted the MQTT Gateway in the Paper UI and restarted the device to see what would happen. Now I'm seeing an error in openhab.log:
                2018-01-16 19:45:23.419 [INFO ] [.transport.mqtt.MqttBrokerConnection] - Starting MQTT broker connection 'ineluki' to 'tcp://192.168.5.2:1883' with clientid openhab2 and file store '/openhab/userdata/tmp/ineluki'
                2018-01-16 19:45:29.680 [INFO ] [.transport.mqtt.MqttBrokerConnection] - MQTT connection to 'ineluki' was lost: MqttException
                2018-01-16 19:45:29.681 [ERROR] [rotocol.mqtt.MySensorsMqttConnection] - MQTT connection offline - {}
                org.eclipse.paho.client.mqttv3.MqttException: MqttException
                        at org.eclipse.paho.client.mqttv3.internal.CommsCallback.run(CommsCallback.java:176) [211:org.eclipse.paho.client.mqttv3:1.0.2]
                        at java.lang.Thread.run(Thread.java:748) [?:?]
                Caused by: java.lang.NullPointerException
                        at org.openhab.binding.mysensors.internal.protocol.mqtt.MySensorsMqttConnection$MySensorsMqttSubscriber.processMessage(MySensorsMqttConnection.java:142) ~[?:?]
                        at org.eclipse.smarthome.io.transport.mqtt.MqttBrokerConnection$ClientCallbacks.messageArrived(MqttBrokerConnection.java:121) ~[?:?]
                        at org.eclipse.paho.client.mqttv3.internal.CommsCallback.handleMessage(CommsCallback.java:354) ~[?:?]
                        at org.eclipse.paho.client.mqttv3.internal.CommsCallback.run(CommsCallback.java:162) ~[?:?]
                        ... 1 more
                2018-01-16 19:45:29.709 [INFO ] [.reconnect.PeriodicReconnectStrategy] - Try to restore connection to 'ineluki' every 10000ms
                Does this give any clue on what's going wrong?
                • cgrfC
                  cgrfC
                  cgrf
                  Ok, now I'm seeing items in my Inbox, after I changed my org.eclipse.smarthome.mqtt.cfg from
                  ineluki.qos=2
                  ineluki.retain=true
                  to
                  #ineluki.qos=2
                  ineluki.retain=false
                  • MasMatM
                    MasMatM
                    MasMat
                    OK, n00b questions again:
                    1. where to place the binding-jar and do I have to do something with the jar-file?
                    2. no services directory exists in /etc. Create it?
                    3. any other things to install? Fresh PaperUI-OpenHab installation so far.
                      My system:RpiZero/Scratch+Mosquitto.
                    • MasMatM MasMat
                      TimO
                      @masmat
                      1. /usr/share/openhab2/addons/
                      2. Thank you for the hint, I've pointed to the wrong directory, it's: /etc/openhab2/services
                      3. For additional Informations please have a look at the wiki: https://github.com/tobof/openhab2-addons/wiki
                      MasMatM 1 Reply Last reply
                      • cgrfC cgrf
                        ineluki.qos=2
                        ineluki.retain=true
                        to
                        #ineluki.qos=2
                        TimO
                        @cgrf Thank you for the hint! At the moment I don't have an explanation for that behaviour.
                        • T TimO
                          @masmat
                          MasMatM
                          MasMatM
                          MasMat
                          @timo I still cant find mqtt.cfg OR org.eclipse.smarthome.mqtt.cfg. I looked thru the Github stuff but didn't see it.
                          Any ideas where to locate either of these files? I assume they have more lines than those four on display in the example.
                          Thanks. Sorry I'm still a tool with OH2
                          L 1 Reply Last reply
                          • MasMatM MasMat
                            L
                            L
                            LastSamurai
                            @masmat As far as I know .cfg files are only the config files fpr your installed addons and are located in the service directory (see TimO's post above). And they indeed only contain the settings you want to use, which can be 4 lines only. Depends on the addon
                            • L LastSamurai
                              MasMatM
                              MasMatM
                              MasMat
                              @lastsamurai I kinda figured that. From the first post I understood that the MQTT binding (binding-mqtt1 - 1.11.0) did not need to be installed. mqtt.cfg -file does come from that. So far I haven't installed it, but if that's where the mqtt.cfg file should come from then I'll do that next.
                              Just dont want to have addon on top of addon if they're redundant.
                              • MasMatM MasMat
                                TimO
                                @masmat Just create the org.eclipse.smarthome.mqtt.cfg file. It's not created automatically. mqtt.cfg is not needed for the binding.
                                • T TimO
                                  MasMatM
                                  MasMatM
                                  MasMat
                                  @timo Alright!! MQTT Gateway Online. Thanks for your patience. Hopefully this thread will help future hopefuls.
                                  Now, I'm gonna activate some nodes and see what happens.
                                  • MasMatM
                                    MasMatM
                                    MasMat
                                    Well, this joy lasted almost 24h...until I unplugged and moved the set-up.
                                    Now Mosquitto-service wont start "Status 11/SEGV"...went nuts looking for that.
                                    Moved Mosquitto to another machine, but now mysgw-service "failed to connect".
                                    Any ideas why Mosquitto went status11 after reboot?
                                    Why wont mysgw connect to another Mosquitto IP? does the port 1883 need to be configured as well?
                                    My configure-line: --my-transport=nrf24 --my-gateway=mqtt --my-controller-ip-address=192.168.0.52 --my-mqtt-publish-topic-prefix=mysensors-out --my-mqtt-subscribe-topic-prefix=mysensors-in --my-mqtt-client-id=mygateway1 --my-rf24-irq-pin=15 --my-leds-err-pin=12 --my-leds-rx-pin=16 --my-leds-tx-pin=18 --my-mqtt-user=????? —-my-mqtt-password=???????
                                    • B
                                      B
                                      BenPr
                                      @TimO The MySonsors Binding didn't find any things for me. :-/
                                      My /etc/openhab2/services/org.eclipse.smarthome.mqtt.cfg
                                      broker.url=tcp://localhost:1883
                                      broker.clientId=openhabianpi
                                      broker.user=*private*
                                      broker.pwd=*private*
                                      My /etc/mosquitto/mosquitto.conf
                                      persistence true
                                      password_file /etc/mosquitto/passwd
                                      allow_anonymous false
                                      My /var/log/mosquitto/mosquitto.log
                                      1516918990: mosquitto version 1.4.10 (build date Mon, 29 May 2017 13:43:29 +0100) starting
                                      1516918990: Config loaded from /etc/mosquitto/mosquitto.conf.
                                      1516918990: Opening ipv4 listen socket on port 1883.
                                      1516918990: Opening ipv6 listen socket on port 1883.
                                      1516919015: New connection from x.x.x.29 on port 1883.
                                      1516919015: New client connected from x.x.x.29 as MQTT_Terrassen_Beleuchtung (c1, k15, u'openhabian').
                                      1516919044: New connection from 127.0.0.1 on port 1883.
                                      1516919044: New client connected from 127.0.0.1 as openhabianpi (c1, k60, u'openhabian').
                                      1516920798: Saving in-memory database to /var/lib/mosquitto/mosquitto.db.
                                      MQTT_Terrassen_Beleuchtung is the thing to find.
                                      My /var/log/openhab2/openhab.log
                                      2018-01-26 00:15:23.079 [INFO ] [.internal.GenericScriptEngineFactory] - Activated scripting support for ECMAScript
                                      2018-01-26 00:15:25.437 [INFO ] [er.internal.HomeBuilderDashboardTile] - Started Home Builder at /homebuilder
                                      2018-01-26 00:15:28.660 [INFO ] [.core.internal.i18n.I18nProviderImpl] - Locale set to de_DE, Location set to 51.5032,7.0073, Time zone set to Europe/Berlin
                                      2018-01-26 00:15:31.505 [INFO ] [.transport.mqtt.MqttBrokerConnection] - Starting MQTT broker connection 'broker' to 'tcp://localhost:1883' with clientid openhabianpi and file store '/var/lib/openhab2/tmp/broker'
                                      2018-01-26 00:15:31.642 [WARN ] [rthome.io.transport.mqtt.MqttService] - MqttBroker start failed: Persistenz wird bereits verwendet
                                      org.eclipse.smarthome.io.transport.mqtt.MqttException: Persistenz wird bereits verwendet
                                              at org.eclipse.smarthome.io.transport.mqtt.MqttBrokerConnection.start(MqttBrokerConnection.java:572) [289:org.eclipse.smarthome.io.transport.mqtt:0.10.0.b1]
                                              at org.eclipse.smarthome.io.transport.mqtt.MqttService.modified(MqttService.java:145) [289:org.eclipse.smarthome.io.transport.mqtt:0.10.0.b1]
                                              at org.eclipse.smarthome.io.transport.mqtt.MqttService.activate(MqttService.java:157) [289:org.eclipse.smarthome.io.transport.mqtt:0.10.0.b1]
                                              at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method) ~[?:?]
                                              at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62) ~[?:?]
                                              at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43) ~[?:?]
                                              at java.lang.reflect.Method.invoke(Method.java:498) ~[?:?]
                                              at org.apache.felix.scr.impl.inject.BaseMethod.invokeMethod(BaseMethod.java:229) [42:org.apache.felix.scr:2.0.12]
                                              at org.apache.felix.scr.impl.inject.BaseMethod.access$500(BaseMethod.java:39) [42:org.apache.felix.scr:2.0.12]
                                              at org.apache.felix.scr.impl.inject.BaseMethod$Resolved.invoke(BaseMethod.java:650) [42:org.apache.felix.scr:2.0.12]
                                              at org.apache.felix.scr.impl.inject.BaseMethod.invoke(BaseMethod.java:506) [42:org.apache.felix.scr:2.0.12]
                                              at org.apache.felix.scr.impl.inject.ActivateMethod.invoke(ActivateMethod.java:307) [42:org.apache.felix.scr:2.0.12]
                                              at org.apache.felix.scr.impl.inject.ActivateMethod.invoke(ActivateMethod.java:299) [42:org.apache.felix.scr:2.0.12]
                                              at org.apache.felix.scr.impl.manager.SingleComponentManager.createImplementationObject(SingleComponentManager.java:298) [42:org.apache.felix.scr:2.0.12]
                                              at org.apache.felix.scr.impl.manager.SingleComponentManager.createComponent(SingleComponentManager.java:109) [42:org.apache.felix.scr:2.0.12]
                                              at org.apache.felix.scr.impl.manager.SingleComponentManager.getService(SingleComponentManager.java:906) [42:org.apache.felix.scr:2.0.12]
                                              at org.apache.felix.scr.impl.manager.SingleComponentManager.getServiceInternal(SingleComponentManager.java:879) [42:org.apache.felix.scr:2.0.12]
                                              at org.apache.felix.scr.impl.manager.SingleComponentManager.getService(SingleComponentManager.java:823) [42:org.apache.felix.scr:2.0.12]
                                              at org.eclipse.osgi.internal.serviceregistry.ServiceFactoryUse$1.run(ServiceFactoryUse.java:212) [?:?]
                                              at java.security.AccessController.doPrivileged(Native Method) ~[?:?]
                                              at org.eclipse.osgi.internal.serviceregistry.ServiceFactoryUse.factoryGetService(ServiceFactoryUse.java:210) [?:?]
                                              at org.eclipse.osgi.internal.serviceregistry.ServiceFactoryUse.getService(ServiceFactoryUse.java:111) [?:?]
                                              at org.eclipse.osgi.internal.serviceregistry.ServiceConsumer$2.getService(ServiceConsumer.java:45) [?:?]
                                              at org.eclipse.osgi.internal.serviceregistry.ServiceRegistrationImpl.getService(ServiceRegistrationImpl.java:496) [?:?]
                                              at org.eclipse.osgi.internal.serviceregistry.ServiceRegistry.getService(ServiceRegistry.java:461) [?:?]
                                              at org.eclipse.osgi.internal.framework.BundleContextImpl.getService(BundleContextImpl.java:619) [?:?]
                                              at com.eclipsesource.jaxrs.publisher.internal.ResourceTracker.addingService(ResourceTracker.java:39) [15:com.eclipsesource.jaxrs.publisher:5.3.1.201602281253]
                                              at org.osgi.util.tracker.ServiceTracker$Tracked.customizerAdding(ServiceTracker.java:941) [?:?]
                                              at org.osgi.util.tracker.ServiceTracker$Tracked.customizerAdding(ServiceTracker.java:870) [?:?]
                                              at org.osgi.util.tracker.AbstractTracked.trackAdding(AbstractTracked.java:256) [?:?]
                                              at org.osgi.util.tracker.AbstractTracked.track(AbstractTracked.java:229) [?:?]
                                              at org.osgi.util.tracker.ServiceTracker$Tracked.serviceChanged(ServiceTracker.java:901) [?:?]
                                              at org.eclipse.osgi.internal.serviceregistry.FilteredServiceListener.serviceChanged(FilteredServiceListener.java:109) [?:?]
                                              at org.eclipse.osgi.internal.framework.BundleContextImpl.dispatchEvent(BundleContextImpl.java:915) [?:?]
                                              at org.eclipse.osgi.framework.eventmgr.EventManager.dispatchEvent(EventManager.java:230) [?:?]
                                              at org.eclipse.osgi.framework.eventmgr.ListenerQueue.dispatchEventSynchronous(ListenerQueue.java:148) [?:?]
                                              at org.eclipse.osgi.internal.serviceregistry.ServiceRegistry.publishServiceEventPrivileged(ServiceRegistry.java:862) [?:?]
                                              at org.eclipse.osgi.internal.serviceregistry.ServiceRegistry.publishServiceEvent(ServiceRegistry.java:801) [?:?]
                                              at org.eclipse.osgi.internal.serviceregistry.ServiceRegistrationImpl.register(ServiceRegistrationImpl.java:127) [?:?]
                                              at org.eclipse.osgi.internal.serviceregistry.ServiceRegistry.registerService(ServiceRegistry.java:225) [?:?]
                                              at org.eclipse.osgi.internal.framework.BundleContextImpl.registerService(BundleContextImpl.java:464) [?:?]
                                              at org.apache.felix.scr.impl.manager.AbstractComponentManager$3.register(AbstractComponentManager.java:887) [42:org.apache.felix.scr:2.0.12]
                                              at org.apache.felix.scr.impl.manager.AbstractComponentManager$3.register(AbstractComponentManager.java:874) [42:org.apache.felix.scr:2.0.12]
                                              at org.apache.felix.scr.impl.manager.RegistrationManager.changeRegistration(RegistrationManager.java:132) [42:org.apache.felix.scr:2.0.12]
                                              at org.apache.felix.scr.impl.manager.AbstractComponentManager.registerService(AbstractComponentManager.java:941) [42:org.apache.felix.scr:2.0.12]
                                              at org.apache.felix.scr.impl.manager.AbstractComponentManager.activateInternal(AbstractComponentManager.java:741) [42:org.apache.felix.scr:2.0.12]
                                              at org.apache.felix.scr.impl.manager.DependencyManager$SingleDynamicCustomizer.addedService(DependencyManager.java:799) [42:org.apache.felix.scr:2.0.12]
                                              at org.apache.felix.scr.impl.manager.DependencyManager$SingleDynamicCustomizer.addedService(DependencyManager.java:743) [42:org.apache.felix.scr:2.0.12]
                                              at org.apache.felix.scr.impl.manager.ServiceTracker$Tracked.customizerAdded(ServiceTracker.java:1215) [42:org.apache.felix.scr:2.0.12]
                                              at org.apache.felix.scr.impl.manager.ServiceTracker$Tracked.customizerAdded(ServiceTracker.java:1136) [42:org.apache.felix.scr:2.0.12]
                                              at org.apache.felix.scr.impl.manager.ServiceTracker$AbstractTracked.trackAdding(ServiceTracker.java:945) [42:org.apache.felix.scr:2.0.12]
                                              at org.apache.felix.scr.impl.manager.ServiceTracker$AbstractTracked.track(ServiceTracker.java:881) [42:org.apache.felix.scr:2.0.12]
                                              at org.apache.felix.scr.impl.manager.ServiceTracker$Tracked.serviceChanged(ServiceTracker.java:1167) [42:org.apache.felix.scr:2.0.12]
                                              at org.apache.felix.scr.impl.BundleComponentActivator$ListenerInfo.serviceChanged(BundleComponentActivator.java:127) [42:org.apache.felix.scr:2.0.12]
                                              at org.apache.felix.scr.impl.manager.DependencyManager$SingleStaticCustomizer.addedService(DependencyManager.java:1012) [42:org.apache.felix.scr:2.0.12]
                                              at org.apache.felix.scr.impl.manager.DependencyManager$SingleStaticCustomizer.addedService(DependencyManager.java:968) [42:org.apache.felix.scr:2.0.12]
                                              at org.apache.felix.scr.impl.manager.AbstractComponentManager.enableInternal(AbstractComponentManager.java:675) [42:org.apache.felix.scr:2.0.12]
                                              at org.apache.felix.scr.impl.manager.AbstractComponentManager.enable(AbstractComponentManager.java:430) [42:org.apache.felix.scr:2.0.12]
                                              at org.apache.felix.scr.impl.manager.ConfigurableComponentHolder.enableComponents(ConfigurableComponentHolder.java:657) [42:org.apache.felix.scr:2.0.12]
                                              at org.apache.felix.scr.impl.BundleComponentActivator.initialEnable(BundleComponentActivator.java:341) [42:org.apache.felix.scr:2.0.12]
                                              at org.apache.felix.scr.impl.Activator.loadComponents(Activator.java:390) [42:org.apache.felix.scr:2.0.12]
                                              at org.apache.felix.scr.impl.Activator.access$200(Activator.java:54) [42:org.apache.felix.scr:2.0.12]
                                              at org.apache.felix.scr.impl.Activator$ScrExtension.start(Activator.java:265) [42:org.apache.felix.scr:2.0.12]
                                              at org.apache.felix.utils.extender.AbstractExtender.createExtension(AbstractExtender.java:254) [42:org.apache.felix.scr:2.0.12]
                                              at org.apache.felix.utils.extender.AbstractExtender.modifiedBundle(AbstractExtender.java:227) [42:org.apache.felix.scr:2.0.12]
                                              at org.osgi.util.tracker.BundleTracker$Tracked.customizerModified(BundleTracker.java:482) [?:?]
                                              at org.osgi.util.tracker.BundleTracker$Tracked.customizerModified(BundleTracker.java:415) [?:?]
                                              at org.osgi.util.tracker.AbstractTracked.track(AbstractTracked.java:232) [?:?]
                                              at org.osgi.util.tracker.BundleTracker$Tracked.bundleChanged(BundleTracker.java:444) [?:?]
                                              at org.eclipse.osgi.internal.framework.BundleContextImpl.dispatchEvent(BundleContextImpl.java:903) [?:?]
                                              at org.eclipse.osgi.internal.framework.EquinoxEventPublisher.publishBundleEventPrivileged(EquinoxEventPublisher.java:213) [?:?]
                                              at org.eclipse.osgi.internal.framework.EquinoxEventPublisher.publishBundleEvent(EquinoxEventPublisher.java:120) [?:?]
                                              at org.eclipse.osgi.internal.framework.EquinoxEventPublisher.publishBundleEvent(EquinoxEventPublisher.java:112) [?:?]
                                              at org.eclipse.osgi.internal.framework.EquinoxContainerAdaptor.publishModuleEvent(EquinoxContainerAdaptor.java:156) [?:?]
                                              at org.eclipse.osgi.container.Module.publishEvent(Module.java:476) [?:?]
                                              at org.eclipse.osgi.container.Module.start(Module.java:467) [?:?]
                                              at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.incStartLevel(ModuleContainer.java:1620) [?:?]
                                              at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.incStartLevel(ModuleContainer.java:1600) [?:?]
                                              at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.doContainerStartLevel(ModuleContainer.java:1571) [?:?]
                                              at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.dispatchEvent(ModuleContainer.java:1514) [?:?]
                                              at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.dispatchEvent(ModuleContainer.java:1) [?:?]
                                              at org.eclipse.osgi.framework.eventmgr.EventManager$EventThread.run(EventManager.java:340) [?:?]
                                      Caused by: org.eclipse.paho.client.mqttv3.MqttPersistenceException: Persistenz wird bereits verwendet
                                              at org.eclipse.paho.client.mqttv3.persist.MqttDefaultFilePersistence.open(MqttDefaultFilePersistence.java:112) ~[?:?]
                                              at org.eclipse.paho.client.mqttv3.MqttAsyncClient.<init>(MqttAsyncClient.java:286) ~[?:?]
                                              at org.eclipse.paho.client.mqttv3.MqttAsyncClient.<init>(MqttAsyncClient.java:167) ~[?:?]
                                              at org.eclipse.smarthome.io.transport.mqtt.MqttBrokerConnection.start(MqttBrokerConnection.java:570) ~[?:?]
                                              ... 118 more
                                      2018-01-26 00:15:32.456 [INFO ] [.dashboard.internal.DashboardService] - Started dashboard at http://x.x.x.30:8080
                                      2018-01-26 00:15:32.465 [INFO ] [.dashboard.internal.DashboardService] - Started dashboard at https://x.x.x.30:8443
                                      2018-01-26 00:15:52.506 [INFO ] [thome.model.lsp.internal.ModelServer] - Started Language Server Protocol (LSP) service on port 5007
                                      2018-01-26 00:16:01.849 [INFO ] [basic.internal.servlet.WebAppServlet] - Started Basic UI at /basicui/app
                                      2018-01-26 00:16:01.999 [INFO ] [arthome.ui.paper.internal.PaperUIApp] - Started Paper UI at /paperui
                                      2018-01-26 00:16:02.291 [INFO ] [panel.internal.HABPanelDashboardTile] - Started HABPanel at /habpanel
                                      2018-01-26 00:16:02.816 [WARN ] [mqtt.internal.MqttPersistenceService] - mqtt-persistence:broker
                                      2018-01-26 00:16:02.819 [WARN ] [mqtt.internal.MqttPersistenceService] - mqtt-persistence:topic
                                      2018-01-26 00:16:02.822 [WARN ] [mqtt.internal.MqttPersistenceService] - mqtt-persistence:message
                                      2018-01-26 00:16:05.597 [INFO ] [ui.habmin.internal.servlet.HABminApp] - Started HABmin servlet at /habmin
                                      2018-01-26 00:16:06.390 [INFO ] [assic.internal.servlet.WebAppServlet] - Started Classic UI at /classicui/app
                                      Have you any idea to fix this?
                                      • jjkJ
                                        jjkJ
                                        jjk
                                        jjkJ 1 Reply Last reply
                                        • jjkJ jjk
                                          [[topic:post-is-deleted]]
                                          jjkJ
                                          jjkJ
                                          jjk
                                          wrote on last edited by jjk
                                          #27
                                          Hi @TimO ,
                                          after doing clean install of OH and the ESH mqtt binding per the original post above, the mqqt service ran properly (no errors in the debug log). After installing the mysensors binding, I start seing mysensors topics come in, but then following exception is thrown
                                          2018-02-06 20:01:10.676 [DEBUG] [o.client.mqttv3.internal.ClientState] - paho167001634703924: received key=1 message=PUBLISH qos:1 msgId:1 retained:true dup:false topic:"mysgw-out/1/0/1/0/97" payload:[hex:33392e38 utf8:"39.8" length:4]
                                          2018-02-06 20:01:10.676 [DEBUG] [o.client.mqttv3.internal.ClientState] - paho167001634703924: received key=1 token=org.eclipse.paho.client.mqttv3.MqttToken@e71260 message=SUBACK msgId 1 granted Qos 1
                                          2018-02-06 20:01:10.677 [DEBUG] [client.mqttv3.internal.CommsCallback] - paho167001634703924: new msg avail, notify workAvailable
                                          2018-02-06 20:01:10.678 [DEBUG] [o.client.mqttv3.internal.ClientState] - paho167001634703924: wait for new work or for space in the inflight window
                                          2018-02-06 20:01:10.679 [DEBUG] [client.mqttv3.internal.CommsReceiver] - paho167001634703924: network read message
                                          2018-02-06 20:01:10.679 [DEBUG] [client.mqttv3.internal.CommsCallback] - paho167001634703924: call messageArrived key=1 topic=mysgw-out/1/0/1/0/97
                                          2018-02-06 20:01:10.680 [DEBUG] [o.client.mqttv3.internal.ClientState] - paho167001634703924: received bytes count=1
                                          2018-02-06 20:01:10.681 [DEBUG] [o.client.mqttv3.internal.ClientState] - paho167001634703924: received bytes count=28
                                          2018-02-06 20:01:10.681 [DEBUG] [client.mqttv3.internal.CommsCallback] - paho167001634703924: callback threw exception
                                                  at org.openhab.binding.mysensors.internal.protocol.mqtt.MySensorsMqttConnection$MySensorsMqttSubscriber.processMessage(MySensorsMqttConnection.java:140) [233:org.openhab.binding.mysensors:2.2.0.201712141227]
                                                  at org.eclipse.smarthome.io.transport.mqtt.MqttBrokerConnection$ClientCallbacks.messageArrived(MqttBrokerConnection.java:121) [232:org.eclipse.smarthome.io.transport.mqtt:0.10.0.b1]
                                                  at org.eclipse.paho.client.mqttv3.internal.CommsCallback.handleMessage(CommsCallback.java:354) [231:org.eclipse.paho.client.mqttv3:1.0.2]
                                                  at org.eclipse.paho.client.mqttv3.internal.CommsCallback.run(CommsCallback.java:162) [231:org.eclipse.paho.client.mqttv3:1.0.2]
                                          2018-02-06 20:01:10.683 [DEBUG] [o.client.mqttv3.internal.ClientComms] - paho167001634703924: state=DISCONNECTING
                                          Any idea what I'm doing wrong?
                                          UPDATE:
                                          For what it's worth, I found the trigger for the error. In fact, the mqtt messages the binding received were (for whatever reason) retained messages of the mosquitto broker. After removing the mosquitto presistence file
                                          sudo service mosquitto stop
                                          sudo rm /var/lib/mosquitto/mosquitto.db
                                          sudo service mosquitto start
                                          it now seems to work o.k. - Hope this might help others who come across this thread.
