  3. OpenHAB
  4. openHAB 2.2 binding MQTT support
37 Posts 9 Posters 24.4k Views 12 Watching
  • cgrfC
    cgrfC
    cgrf
    wrote on last edited by cgrf
    @TimO
    I have this INFO line, as included in my first post, that looks similar but not quite the same:
    2018-01-09 15:45:29.711 [INFO ] [t.mqtt.internal.MqttBrokerConnection] - Starting MQTT broker connection 'ineluki'
    The four lines from my first post are actually all lines I have in that log after the UI start-up messages.
    • T
      TimO
      wrote on last edited by TimO
      @cgrf said in openHAB 2.2 binding MQTT support:
      You're using the mqtt1 (openhab1-addon) to connect to the broker. The OpenHAB2 binding is based on the current (/upcoming) mqtt-transport implementation of ESH.
      My guess: the file org.eclipse.smarthome.mqtt.cfg is missing in /etc/openhab2/services and there only is a mqtt.cfg file. Just copy the mqtt.cfg file to org.eclipse.smarthome.mqtt.cfg (Same content, different name, different use).
      mqtt.cfg: mqtt1 binding, mqtt-transport, owntracks ...
      org.eclipse.smarthome.mqtt.cfg: ESH-MQTT and I'm only aware of my binding using it yet. But there are a few upcoming (mqtt generic, mqtt2 binding ..)
      cgrfC 1 Reply Last reply
      • T TimO
        cgrfC
        cgrfC
        cgrf
        @timo said in openHAB 2.2 binding MQTT support:
        Excellent guess, that was my problem! My gateway is "online" now. It would have taken me forever to figure that out on my own, so thank you very much! (And yes, reading your first post now I realize that you said so.)
        Should OpenHAB be able to discover the sensors behind the gateway? Or do I need to configure them manually?
        • cgrfC cgrf
          TimO
          @cgrf
          If you restart the node they should represent themself and will show up in the Inbox in PaperUI.
          • cgrfC
            cgrfC
            cgrf
            @TimO
            Ok, I've restarted the sensor multiple times now and I assume that it presents itself properly as it is discovered by other controllers (mycontroller.org, that is). But in OpenHAB's PaperUI it doesn't show up at all. There is a trace of it in the openhab.log though:
            2018-01-10 09:29:39.268 [WARN ] [al.sensors.child.MySensorsChildSTemp] - Overwrite variable: V_VAR1
            2018-01-10 09:29:39.269 [WARN ] [al.sensors.child.MySensorsChildSTemp] - Overwrite variable: V_VAR2
            2018-01-10 09:29:39.277 [WARN ] [al.sensors.child.MySensorsChildSTemp] - Overwrite variable: V_VAR3
            2018-01-10 09:29:39.289 [WARN ] [al.sensors.child.MySensorsChildSTemp] - Overwrite variable: V_VAR4
            2018-01-10 09:29:39.289 [WARN ] [al.sensors.child.MySensorsChildSTemp] - Overwrite variable: V_VAR5
            2018-01-10 20:38:26.959 [WARN ] [nal.sensors.child.MySensorsChildSHum] - Overwrite variable: V_VAR1
            2018-01-10 20:38:26.980 [WARN ] [nal.sensors.child.MySensorsChildSHum] - Overwrite variable: V_VAR2
            2018-01-10 20:38:26.980 [WARN ] [nal.sensors.child.MySensorsChildSHum] - Overwrite variable: V_VAR3
            2018-01-10 20:38:26.980 [WARN ] [nal.sensors.child.MySensorsChildSHum] - Overwrite variable: V_VAR4
            2018-01-10 20:38:26.981 [WARN ] [nal.sensors.child.MySensorsChildSHum] - Overwrite variable: V_VAR5
            2018-01-10 20:38:27.084 [WARN ] [sors.child.MySensorsChildSMultimeter] - Overwrite variable: V_VAR1
            2018-01-10 20:38:27.086 [WARN ] [sors.child.MySensorsChildSMultimeter] - Overwrite variable: V_VAR2
            2018-01-10 20:38:27.086 [WARN ] [sors.child.MySensorsChildSMultimeter] - Overwrite variable: V_VAR3
            2018-01-10 20:38:27.088 [WARN ] [sors.child.MySensorsChildSMultimeter] - Overwrite variable: V_VAR4
            2018-01-10 20:38:27.089 [WARN ] [sors.child.MySensorsChildSMultimeter] - Overwrite variable: V_VAR5
            2018-01-10 20:39:10.530 [WARN ] [rs.internal.gateway.MySensorsGateway] - Presented child is alredy present in gateway
            2018-01-10 20:39:11.529 [WARN ] [rs.internal.gateway.MySensorsGateway] - Presented child is alredy present in gateway
            2018-01-10 20:39:11.660 [WARN ] [rs.internal.gateway.MySensorsGateway] - Presented child is alredy present in gateway
            2018-01-10 20:40:58.584 [WARN ] [rs.internal.gateway.MySensorsGateway] - Presented child is alredy present in gateway
            2018-01-10 20:40:59.461 [WARN ] [rs.internal.gateway.MySensorsGateway] - Presented child is alredy present in gateway
            2018-01-10 20:40:59.592 [WARN ] [rs.internal.gateway.MySensorsGateway] - Presented child is alredy present in gateway
            While this is happening on MQTT:
            gateway1-out/3/255/0/0/17 2.1.1
            gateway1-out/3/255/3/0/6 0
            gateway1-out/3/255/3/0/11 Combined Climate Sensor
            gateway1-out/3/255/3/0/12 1.0.16
            gateway1-out/3/0/0/0/7 (null)
            gateway1-out/3/7/0/0/30 (null)
            gateway1-out/3/10/2/0/15 (null)
            gateway1-out/3/1/1/0/0 21.9
            gateway1-out/3/0/1/0/1 42
            gateway1-out/3/7/1/0/38 3.98
            gateway1-out/3/255/3/0/0 56
            Have you got another hint for me, maybe? It would be greatly appreciated.
            • cgrfC
              cgrfC
              cgrf
              Unfortunately, I'm still making no progress here. In the meantime I deleted the MQTT Gateway in the Paper UI and restarted the device to see what would happen. Now I'm seeing an error in openhab.log:
              2018-01-16 19:45:23.419 [INFO ] [.transport.mqtt.MqttBrokerConnection] - Starting MQTT broker connection 'ineluki' to 'tcp://192.168.5.2:1883' with clientid openhab2 and file store '/openhab/userdata/tmp/ineluki'
              2018-01-16 19:45:29.680 [INFO ] [.transport.mqtt.MqttBrokerConnection] - MQTT connection to 'ineluki' was lost: MqttException
              2018-01-16 19:45:29.681 [ERROR] [rotocol.mqtt.MySensorsMqttConnection] - MQTT connection offline - {}
              org.eclipse.paho.client.mqttv3.MqttException: MqttException
                      at org.eclipse.paho.client.mqttv3.internal.CommsCallback.run(CommsCallback.java:176) [211:org.eclipse.paho.client.mqttv3:1.0.2]
                      at java.lang.Thread.run(Thread.java:748) [?:?]
              Caused by: java.lang.NullPointerException
                      at org.openhab.binding.mysensors.internal.protocol.mqtt.MySensorsMqttConnection$MySensorsMqttSubscriber.processMessage(MySensorsMqttConnection.java:142) ~[?:?]
                      at org.eclipse.smarthome.io.transport.mqtt.MqttBrokerConnection$ClientCallbacks.messageArrived(MqttBrokerConnection.java:121) ~[?:?]
                      at org.eclipse.paho.client.mqttv3.internal.CommsCallback.handleMessage(CommsCallback.java:354) ~[?:?]
                      at org.eclipse.paho.client.mqttv3.internal.CommsCallback.run(CommsCallback.java:162) ~[?:?]
                      ... 1 more
              2018-01-16 19:45:29.709 [INFO ] [.reconnect.PeriodicReconnectStrategy] - Try to restore connection to 'ineluki' every 10000ms
              Does this give any clue on what's going wrong?
              • cgrfC
                cgrfC
                cgrf
                Ok, now I'm seeing items in my Inbox, after I changed my org.eclipse.smarthome.mqtt.cfg from
                ineluki.qos=2
                ineluki.retain=true
                to
                #ineluki.qos=2
                ineluki.retain=false
                • MasMatM
                  MasMatM
                  MasMat
                  OK, n00b questions again:
                  1. where to place the binding-jar and do I have to do something with the jar-file?
                  2. no services directory exists in /etc. Create it?
                  3. any other things to install? Fresh PaperUI-OpenHab installation so far.
                    My system:RpiZero/Scratch+Mosquitto.
                  • MasMatM MasMat
                    TimO
                    @masmat
                    1. /usr/share/openhab2/addons/
                    2. Thank you for the hint, I've pointed to the wrong directory, it's: /etc/openhab2/services
                    3. For additional Informations please have a look at the wiki: https://github.com/tobof/openhab2-addons/wiki
                    MasMatM 1 Reply Last reply
                    • cgrfC cgrf
                      ineluki.qos=2
                      ineluki.retain=true
                      to
                      #ineluki.qos=2
                      TimO
                      @cgrf Thank you for the hint! At the moment I don't have an explanation for that behaviour.
                      • T TimO
                        @masmat
                        MasMatM
                        MasMatM
                        MasMat
                        @timo I still cant find mqtt.cfg OR org.eclipse.smarthome.mqtt.cfg. I looked thru the Github stuff but didn't see it.
                        Any ideas where to locate either of these files? I assume they have more lines than those four on display in the example.
                        Thanks. Sorry I'm still a tool with OH2
                        L 1 Reply Last reply
                        • MasMatM MasMat
                          L
                          L
                          LastSamurai
                          @masmat As far as I know .cfg files are only the config files fpr your installed addons and are located in the service directory (see TimO's post above). And they indeed only contain the settings you want to use, which can be 4 lines only. Depends on the addon
                          • L LastSamurai
                            MasMatM
                            MasMatM
                            MasMat
                            @lastsamurai I kinda figured that. From the first post I understood that the MQTT binding (binding-mqtt1 - 1.11.0) did not need to be installed. mqtt.cfg -file does come from that. So far I haven't installed it, but if that's where the mqtt.cfg file should come from then I'll do that next.
                            Just dont want to have addon on top of addon if they're redundant.
                            • MasMatM MasMat
                              TimO
                              @masmat Just create the org.eclipse.smarthome.mqtt.cfg file. It's not created automatically. mqtt.cfg is not needed for the binding.
                              • T TimO
                                MasMatM
                                MasMatM
                                MasMat
                                @timo Alright!! MQTT Gateway Online. Thanks for your patience. Hopefully this thread will help future hopefuls.
                                Now, I'm gonna activate some nodes and see what happens.
                                • MasMatM
                                  MasMatM
                                  MasMat
                                  Well, this joy lasted almost 24h...until I unplugged and moved the set-up.
                                  Now Mosquitto-service wont start "Status 11/SEGV"...went nuts looking for that.
                                  Moved Mosquitto to another machine, but now mysgw-service "failed to connect".
                                  Any ideas why Mosquitto went status11 after reboot?
                                  Why wont mysgw connect to another Mosquitto IP? does the port 1883 need to be configured as well?
                                  My configure-line: --my-transport=nrf24 --my-gateway=mqtt --my-controller-ip-address=192.168.0.52 --my-mqtt-publish-topic-prefix=mysensors-out --my-mqtt-subscribe-topic-prefix=mysensors-in --my-mqtt-client-id=mygateway1 --my-rf24-irq-pin=15 --my-leds-err-pin=12 --my-leds-rx-pin=16 --my-leds-tx-pin=18 --my-mqtt-user=????? —-my-mqtt-password=???????
                                  • B
                                    B
                                    BenPr
                                    @TimO The MySonsors Binding didn't find any things for me. :-/
                                    My /etc/openhab2/services/org.eclipse.smarthome.mqtt.cfg
                                    broker.url=tcp://localhost:1883
                                    broker.clientId=openhabianpi
                                    broker.user=*private*
                                    broker.pwd=*private*
                                    My /etc/mosquitto/mosquitto.conf
                                    persistence true
                                    password_file /etc/mosquitto/passwd
                                    allow_anonymous false
                                    My /var/log/mosquitto/mosquitto.log
                                    1516918990: mosquitto version 1.4.10 (build date Mon, 29 May 2017 13:43:29 +0100) starting
                                    1516918990: Config loaded from /etc/mosquitto/mosquitto.conf.
                                    1516918990: Opening ipv4 listen socket on port 1883.
                                    1516918990: Opening ipv6 listen socket on port 1883.
                                    1516919015: New connection from x.x.x.29 on port 1883.
                                    1516919015: New client connected from x.x.x.29 as MQTT_Terrassen_Beleuchtung (c1, k15, u'openhabian').
                                    1516919044: New connection from 127.0.0.1 on port 1883.
                                    1516919044: New client connected from 127.0.0.1 as openhabianpi (c1, k60, u'openhabian').
                                    1516920798: Saving in-memory database to /var/lib/mosquitto/mosquitto.db.
                                    MQTT_Terrassen_Beleuchtung is the thing to find.
                                    My /var/log/openhab2/openhab.log
                                    2018-01-26 00:15:23.079 [INFO ] [.internal.GenericScriptEngineFactory] - Activated scripting support for ECMAScript
                                    2018-01-26 00:15:25.437 [INFO ] [er.internal.HomeBuilderDashboardTile] - Started Home Builder at /homebuilder
                                    2018-01-26 00:15:28.660 [INFO ] [.core.internal.i18n.I18nProviderImpl] - Locale set to de_DE, Location set to 51.5032,7.0073, Time zone set to Europe/Berlin
                                    2018-01-26 00:15:31.505 [INFO ] [.transport.mqtt.MqttBrokerConnection] - Starting MQTT broker connection 'broker' to 'tcp://localhost:1883' with clientid openhabianpi and file store '/var/lib/openhab2/tmp/broker'
                                    2018-01-26 00:15:31.642 [WARN ] [rthome.io.transport.mqtt.MqttService] - MqttBroker start failed: Persistenz wird bereits verwendet
                                    org.eclipse.smarthome.io.transport.mqtt.MqttException: Persistenz wird bereits verwendet
                                            at org.eclipse.smarthome.io.transport.mqtt.MqttBrokerConnection.start(MqttBrokerConnection.java:572) [289:org.eclipse.smarthome.io.transport.mqtt:0.10.0.b1]
                                            at org.eclipse.smarthome.io.transport.mqtt.MqttService.modified(MqttService.java:145) [289:org.eclipse.smarthome.io.transport.mqtt:0.10.0.b1]
                                            at org.eclipse.smarthome.io.transport.mqtt.MqttService.activate(MqttService.java:157) [289:org.eclipse.smarthome.io.transport.mqtt:0.10.0.b1]
                                            at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method) ~[?:?]
                                            at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62) ~[?:?]
                                            at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43) ~[?:?]
                                            at java.lang.reflect.Method.invoke(Method.java:498) ~[?:?]
                                            at org.apache.felix.scr.impl.inject.BaseMethod.invokeMethod(BaseMethod.java:229) [42:org.apache.felix.scr:2.0.12]
                                            at org.apache.felix.scr.impl.inject.BaseMethod.access$500(BaseMethod.java:39) [42:org.apache.felix.scr:2.0.12]
                                            at org.apache.felix.scr.impl.inject.BaseMethod$Resolved.invoke(BaseMethod.java:650) [42:org.apache.felix.scr:2.0.12]
                                            at org.apache.felix.scr.impl.inject.BaseMethod.invoke(BaseMethod.java:506) [42:org.apache.felix.scr:2.0.12]
                                            at org.apache.felix.scr.impl.inject.ActivateMethod.invoke(ActivateMethod.java:307) [42:org.apache.felix.scr:2.0.12]
                                            at org.apache.felix.scr.impl.inject.ActivateMethod.invoke(ActivateMethod.java:299) [42:org.apache.felix.scr:2.0.12]
                                            at org.apache.felix.scr.impl.manager.SingleComponentManager.createImplementationObject(SingleComponentManager.java:298) [42:org.apache.felix.scr:2.0.12]
                                            at org.apache.felix.scr.impl.manager.SingleComponentManager.createComponent(SingleComponentManager.java:109) [42:org.apache.felix.scr:2.0.12]
                                            at org.apache.felix.scr.impl.manager.SingleComponentManager.getService(SingleComponentManager.java:906) [42:org.apache.felix.scr:2.0.12]
                                            at org.apache.felix.scr.impl.manager.SingleComponentManager.getServiceInternal(SingleComponentManager.java:879) [42:org.apache.felix.scr:2.0.12]
                                            at org.apache.felix.scr.impl.manager.SingleComponentManager.getService(SingleComponentManager.java:823) [42:org.apache.felix.scr:2.0.12]
                                            at org.eclipse.osgi.internal.serviceregistry.ServiceFactoryUse$1.run(ServiceFactoryUse.java:212) [?:?]
                                            at java.security.AccessController.doPrivileged(Native Method) ~[?:?]
                                            at org.eclipse.osgi.internal.serviceregistry.ServiceFactoryUse.factoryGetService(ServiceFactoryUse.java:210) [?:?]
                                            at org.eclipse.osgi.internal.serviceregistry.ServiceFactoryUse.getService(ServiceFactoryUse.java:111) [?:?]
                                            at org.eclipse.osgi.internal.serviceregistry.ServiceConsumer$2.getService(ServiceConsumer.java:45) [?:?]
                                            at org.eclipse.osgi.internal.serviceregistry.ServiceRegistrationImpl.getService(ServiceRegistrationImpl.java:496) [?:?]
                                            at org.eclipse.osgi.internal.serviceregistry.ServiceRegistry.getService(ServiceRegistry.java:461) [?:?]
                                            at org.eclipse.osgi.internal.framework.BundleContextImpl.getService(BundleContextImpl.java:619) [?:?]
                                            at com.eclipsesource.jaxrs.publisher.internal.ResourceTracker.addingService(ResourceTracker.java:39) [15:com.eclipsesource.jaxrs.publisher:5.3.1.201602281253]
                                            at org.osgi.util.tracker.ServiceTracker$Tracked.customizerAdding(ServiceTracker.java:941) [?:?]
                                            at org.osgi.util.tracker.ServiceTracker$Tracked.customizerAdding(ServiceTracker.java:870) [?:?]
                                            at org.osgi.util.tracker.AbstractTracked.trackAdding(AbstractTracked.java:256) [?:?]
                                            at org.osgi.util.tracker.AbstractTracked.track(AbstractTracked.java:229) [?:?]
                                            at org.osgi.util.tracker.ServiceTracker$Tracked.serviceChanged(ServiceTracker.java:901) [?:?]
                                            at org.eclipse.osgi.internal.serviceregistry.FilteredServiceListener.serviceChanged(FilteredServiceListener.java:109) [?:?]
                                            at org.eclipse.osgi.internal.framework.BundleContextImpl.dispatchEvent(BundleContextImpl.java:915) [?:?]
                                            at org.eclipse.osgi.framework.eventmgr.EventManager.dispatchEvent(EventManager.java:230) [?:?]
                                            at org.eclipse.osgi.framework.eventmgr.ListenerQueue.dispatchEventSynchronous(ListenerQueue.java:148) [?:?]
                                            at org.eclipse.osgi.internal.serviceregistry.ServiceRegistry.publishServiceEventPrivileged(ServiceRegistry.java:862) [?:?]
                                            at org.eclipse.osgi.internal.serviceregistry.ServiceRegistry.publishServiceEvent(ServiceRegistry.java:801) [?:?]
                                            at org.eclipse.osgi.internal.serviceregistry.ServiceRegistrationImpl.register(ServiceRegistrationImpl.java:127) [?:?]
                                            at org.eclipse.osgi.internal.serviceregistry.ServiceRegistry.registerService(ServiceRegistry.java:225) [?:?]
                                            at org.eclipse.osgi.internal.framework.BundleContextImpl.registerService(BundleContextImpl.java:464) [?:?]
                                            at org.apache.felix.scr.impl.manager.AbstractComponentManager$3.register(AbstractComponentManager.java:887) [42:org.apache.felix.scr:2.0.12]
                                            at org.apache.felix.scr.impl.manager.AbstractComponentManager$3.register(AbstractComponentManager.java:874) [42:org.apache.felix.scr:2.0.12]
                                            at org.apache.felix.scr.impl.manager.RegistrationManager.changeRegistration(RegistrationManager.java:132) [42:org.apache.felix.scr:2.0.12]
                                            at org.apache.felix.scr.impl.manager.AbstractComponentManager.registerService(AbstractComponentManager.java:941) [42:org.apache.felix.scr:2.0.12]
                                            at org.apache.felix.scr.impl.manager.AbstractComponentManager.activateInternal(AbstractComponentManager.java:741) [42:org.apache.felix.scr:2.0.12]
                                            at org.apache.felix.scr.impl.manager.DependencyManager$SingleDynamicCustomizer.addedService(DependencyManager.java:799) [42:org.apache.felix.scr:2.0.12]
                                            at org.apache.felix.scr.impl.manager.DependencyManager$SingleDynamicCustomizer.addedService(DependencyManager.java:743) [42:org.apache.felix.scr:2.0.12]
                                            at org.apache.felix.scr.impl.manager.ServiceTracker$Tracked.customizerAdded(ServiceTracker.java:1215) [42:org.apache.felix.scr:2.0.12]
                                            at org.apache.felix.scr.impl.manager.ServiceTracker$Tracked.customizerAdded(ServiceTracker.java:1136) [42:org.apache.felix.scr:2.0.12]
                                            at org.apache.felix.scr.impl.manager.ServiceTracker$AbstractTracked.trackAdding(ServiceTracker.java:945) [42:org.apache.felix.scr:2.0.12]
                                            at org.apache.felix.scr.impl.manager.ServiceTracker$AbstractTracked.track(ServiceTracker.java:881) [42:org.apache.felix.scr:2.0.12]
                                            at org.apache.felix.scr.impl.manager.ServiceTracker$Tracked.serviceChanged(ServiceTracker.java:1167) [42:org.apache.felix.scr:2.0.12]
                                            at org.apache.felix.scr.impl.BundleComponentActivator$ListenerInfo.serviceChanged(BundleComponentActivator.java:127) [42:org.apache.felix.scr:2.0.12]
                                            at org.apache.felix.scr.impl.manager.DependencyManager$SingleStaticCustomizer.addedService(DependencyManager.java:1012) [42:org.apache.felix.scr:2.0.12]
                                            at org.apache.felix.scr.impl.manager.DependencyManager$SingleStaticCustomizer.addedService(DependencyManager.java:968) [42:org.apache.felix.scr:2.0.12]
                                            at org.apache.felix.scr.impl.manager.AbstractComponentManager.enableInternal(AbstractComponentManager.java:675) [42:org.apache.felix.scr:2.0.12]
                                            at org.apache.felix.scr.impl.manager.AbstractComponentManager.enable(AbstractComponentManager.java:430) [42:org.apache.felix.scr:2.0.12]
                                            at org.apache.felix.scr.impl.manager.ConfigurableComponentHolder.enableComponents(ConfigurableComponentHolder.java:657) [42:org.apache.felix.scr:2.0.12]
                                            at org.apache.felix.scr.impl.BundleComponentActivator.initialEnable(BundleComponentActivator.java:341) [42:org.apache.felix.scr:2.0.12]
                                            at org.apache.felix.scr.impl.Activator.loadComponents(Activator.java:390) [42:org.apache.felix.scr:2.0.12]
                                            at org.apache.felix.scr.impl.Activator.access$200(Activator.java:54) [42:org.apache.felix.scr:2.0.12]
                                            at org.apache.felix.scr.impl.Activator$ScrExtension.start(Activator.java:265) [42:org.apache.felix.scr:2.0.12]
                                            at org.apache.felix.utils.extender.AbstractExtender.createExtension(AbstractExtender.java:254) [42:org.apache.felix.scr:2.0.12]
                                            at org.apache.felix.utils.extender.AbstractExtender.modifiedBundle(AbstractExtender.java:227) [42:org.apache.felix.scr:2.0.12]
                                            at org.osgi.util.tracker.BundleTracker$Tracked.customizerModified(BundleTracker.java:482) [?:?]
                                            at org.osgi.util.tracker.BundleTracker$Tracked.customizerModified(BundleTracker.java:415) [?:?]
                                            at org.osgi.util.tracker.AbstractTracked.track(AbstractTracked.java:232) [?:?]
                                            at org.osgi.util.tracker.BundleTracker$Tracked.bundleChanged(BundleTracker.java:444) [?:?]
                                            at org.eclipse.osgi.internal.framework.BundleContextImpl.dispatchEvent(BundleContextImpl.java:903) [?:?]
                                            at org.eclipse.osgi.internal.framework.EquinoxEventPublisher.publishBundleEventPrivileged(EquinoxEventPublisher.java:213) [?:?]
                                            at org.eclipse.osgi.internal.framework.EquinoxEventPublisher.publishBundleEvent(EquinoxEventPublisher.java:120) [?:?]
                                            at org.eclipse.osgi.internal.framework.EquinoxEventPublisher.publishBundleEvent(EquinoxEventPublisher.java:112) [?:?]
                                            at org.eclipse.osgi.internal.framework.EquinoxContainerAdaptor.publishModuleEvent(EquinoxContainerAdaptor.java:156) [?:?]
                                            at org.eclipse.osgi.container.Module.publishEvent(Module.java:476) [?:?]
                                            at org.eclipse.osgi.container.Module.start(Module.java:467) [?:?]
                                            at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.incStartLevel(ModuleContainer.java:1620) [?:?]
                                            at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.incStartLevel(ModuleContainer.java:1600) [?:?]
                                            at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.doContainerStartLevel(ModuleContainer.java:1571) [?:?]
                                            at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.dispatchEvent(ModuleContainer.java:1514) [?:?]
                                            at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.dispatchEvent(ModuleContainer.java:1) [?:?]
                                            at org.eclipse.osgi.framework.eventmgr.EventManager$EventThread.run(EventManager.java:340) [?:?]
                                    Caused by: org.eclipse.paho.client.mqttv3.MqttPersistenceException: Persistenz wird bereits verwendet
                                            at org.eclipse.paho.client.mqttv3.persist.MqttDefaultFilePersistence.open(MqttDefaultFilePersistence.java:112) ~[?:?]
                                            at org.eclipse.paho.client.mqttv3.MqttAsyncClient.<init>(MqttAsyncClient.java:286) ~[?:?]
                                            at org.eclipse.paho.client.mqttv3.MqttAsyncClient.<init>(MqttAsyncClient.java:167) ~[?:?]
                                            at org.eclipse.smarthome.io.transport.mqtt.MqttBrokerConnection.start(MqttBrokerConnection.java:570) ~[?:?]
                                            ... 118 more
                                    2018-01-26 00:15:32.456 [INFO ] [.dashboard.internal.DashboardService] - Started dashboard at http://x.x.x.30:8080
                                    2018-01-26 00:15:32.465 [INFO ] [.dashboard.internal.DashboardService] - Started dashboard at https://x.x.x.30:8443
                                    2018-01-26 00:15:52.506 [INFO ] [thome.model.lsp.internal.ModelServer] - Started Language Server Protocol (LSP) service on port 5007
                                    2018-01-26 00:16:01.849 [INFO ] [basic.internal.servlet.WebAppServlet] - Started Basic UI at /basicui/app
                                    2018-01-26 00:16:01.999 [INFO ] [arthome.ui.paper.internal.PaperUIApp] - Started Paper UI at /paperui
                                    2018-01-26 00:16:02.291 [INFO ] [panel.internal.HABPanelDashboardTile] - Started HABPanel at /habpanel
                                    2018-01-26 00:16:02.816 [WARN ] [mqtt.internal.MqttPersistenceService] - mqtt-persistence:broker
                                    2018-01-26 00:16:02.819 [WARN ] [mqtt.internal.MqttPersistenceService] - mqtt-persistence:topic
                                    2018-01-26 00:16:02.822 [WARN ] [mqtt.internal.MqttPersistenceService] - mqtt-persistence:message
                                    2018-01-26 00:16:05.597 [INFO ] [ui.habmin.internal.servlet.HABminApp] - Started HABmin servlet at /habmin
                                    2018-01-26 00:16:06.390 [INFO ] [assic.internal.servlet.WebAppServlet] - Started Classic UI at /classicui/app
                                    Have you any idea to fix this?
                                    • jjkJ
                                      jjkJ
                                      jjk
                                      jjkJ 1 Reply Last reply
                                      • jjkJ jjk
                                        [[topic:post-is-deleted]]
                                        jjkJ
                                        jjkJ
                                        jjk
                                        wrote on last edited by jjk
                                        #27
                                        Hi @TimO ,
                                        after doing clean install of OH and the ESH mqtt binding per the original post above, the mqqt service ran properly (no errors in the debug log). After installing the mysensors binding, I start seing mysensors topics come in, but then following exception is thrown
                                        2018-02-06 20:01:10.676 [DEBUG] [o.client.mqttv3.internal.ClientState] - paho167001634703924: received key=1 message=PUBLISH qos:1 msgId:1 retained:true dup:false topic:"mysgw-out/1/0/1/0/97" payload:[hex:33392e38 utf8:"39.8" length:4]
                                        2018-02-06 20:01:10.676 [DEBUG] [o.client.mqttv3.internal.ClientState] - paho167001634703924: received key=1 token=org.eclipse.paho.client.mqttv3.MqttToken@e71260 message=SUBACK msgId 1 granted Qos 1
                                        2018-02-06 20:01:10.677 [DEBUG] [client.mqttv3.internal.CommsCallback] - paho167001634703924: new msg avail, notify workAvailable
                                        2018-02-06 20:01:10.678 [DEBUG] [o.client.mqttv3.internal.ClientState] - paho167001634703924: wait for new work or for space in the inflight window
                                        2018-02-06 20:01:10.679 [DEBUG] [client.mqttv3.internal.CommsReceiver] - paho167001634703924: network read message
                                        2018-02-06 20:01:10.679 [DEBUG] [client.mqttv3.internal.CommsCallback] - paho167001634703924: call messageArrived key=1 topic=mysgw-out/1/0/1/0/97
                                        2018-02-06 20:01:10.680 [DEBUG] [o.client.mqttv3.internal.ClientState] - paho167001634703924: received bytes count=1
                                        2018-02-06 20:01:10.681 [DEBUG] [o.client.mqttv3.internal.ClientState] - paho167001634703924: received bytes count=28
                                        2018-02-06 20:01:10.681 [DEBUG] [client.mqttv3.internal.CommsCallback] - paho167001634703924: callback threw exception
                                                at org.openhab.binding.mysensors.internal.protocol.mqtt.MySensorsMqttConnection$MySensorsMqttSubscriber.processMessage(MySensorsMqttConnection.java:140) [233:org.openhab.binding.mysensors:2.2.0.201712141227]
                                                at org.eclipse.smarthome.io.transport.mqtt.MqttBrokerConnection$ClientCallbacks.messageArrived(MqttBrokerConnection.java:121) [232:org.eclipse.smarthome.io.transport.mqtt:0.10.0.b1]
                                                at org.eclipse.paho.client.mqttv3.internal.CommsCallback.handleMessage(CommsCallback.java:354) [231:org.eclipse.paho.client.mqttv3:1.0.2]
                                                at org.eclipse.paho.client.mqttv3.internal.CommsCallback.run(CommsCallback.java:162) [231:org.eclipse.paho.client.mqttv3:1.0.2]
                                        2018-02-06 20:01:10.683 [DEBUG] [o.client.mqttv3.internal.ClientComms] - paho167001634703924: state=DISCONNECTING
                                        Any idea what I'm doing wrong?
                                        UPDATE:
                                        For what it's worth, I found the trigger for the error. In fact, the mqtt messages the binding received were (for whatever reason) retained messages of the mosquitto broker. After removing the mosquitto presistence file
                                        sudo service mosquitto stop
                                        sudo rm /var/lib/mosquitto/mosquitto.db
                                        sudo service mosquitto start
                                        it now seems to work o.k. - Hope this might help others who come across this thread.
                                        • jjkJ jjk
                                          Hi @TimO ,
                                          UPDATE:
                                          TimO
                                          @jjk Thank you for reporting back!
