  3. OpenHAB
  4. openHAB 2.2 binding MQTT support
37 Posts 9 Posters 24.4k Views 12 Watching
  • cgrfC cgrf
    First of all, I'd like to thank you for your contribution, it is greatly appreciated!
    Unfortunately, I could not get the binding to talk to my Mosquitto server, yet. I have installed the addon and configured my MySensors MQTT Gateway as described above. But when I start OpenHAB (the Docker container instantiated from "openhab/openhab:2.2.0-amd64-alpine" to be precise), this is what I get in the openhab.log file:
    2018-01-09 15:45:29.710 [INFO ] [penhab.io.transport.mqtt.MqttService] - MQTT Service initialization completed.
    2018-01-09 15:45:29.711 [INFO ] [t.mqtt.internal.MqttBrokerConnection] - Starting MQTT broker connection 'ineluki'
    2018-01-09 15:45:30.420 [ERROR] [rotocol.mqtt.MySensorsMqttConnection] - No connection to broker: ineluki
    2018-01-09 15:45:30.471 [ERROR] [rotocol.mqtt.MySensorsMqttConnection] - Failed connecting to bridge...next retry in 10 seconds (Retry No.:0)
    And there is no "retry" after 10 seconds. At the same time this is and only this logged by Mosquitto:
    1515512709: Socket error on client openhab, disconnecting.
    1515512729: New connection from 172.19.0.5 on port 1883.
    Do you have any clue or hint what I might be doing wrong? I'm entirely new to OpenHAB, so please excuse if I'm missing something obvious.
    TimO
    Hi @cgrf !
    Please post the content of "org.eclipse.smarthome.mqtt.cfg".
    My guess is: there is no connection between OpenHAB2 and Mosquitto. The binding is only using the connection, it is not in charge for establishment or reconnects.
    Please check that in org.eclipse.smarthome.mqtt.cfg :
    mosquitto.url=tcp://192.168.2.3:1883
    mosquitto.user=user
    mosquitto.pwd=secret
    mosquitto.retain=false
    and in the MQTT GW configuration (in OH2) the names are matching.
    In your case it should look like (or similar to):
    ineluki.url=tcp://172.19.0.5:1883
    ineluki.user=user
    ineluki.pwd=secret
    ineluki.retain=false
    • cgrfC
      cgrfC
      cgrf
      Hi @TimO,
      Thanks for your response! There is an incoming connection from OpenHAB to Mosquitto, I can see as much in the Mosquitto log. But that connection does not seem to succeed.
      This is the content of my mqtt.cfg:
      ineluki.url=tcp://192.168.5.2:1883
      ineluki.clientId=openhab
      ineluki.qos=2
      ineluki.retain=true
      That Mosquitto instance currently does not require users to authenticate.
      • cgrfC cgrf
        Hi @TimO,
        ineluki.qos=2
        ineluki.retain=true
        TimO
        @cgrf
        Is there a log entry in OpenHAB that looks like this?
        [DEBUG] [.io.transport.mqtt.MqttService:155  ] - Starting MQTT Service...
        [INFO ] [.i.t.mqtt.MqttBrokerConnection:576  ] - Starting MQTT broker connection 'mosquitto' to 'tcp://192.168.2.3:1883' with clientid paho6110733874326 and file store '/tmp/mosquitto'
        [INFO ] [.i.t.mqtt.MqttBrokerConnection:576  ] - Starting MQTT broker connection 'mosquitto' to 'tcp://192.168.2.3:1883' with clientid paho6110762725063 and file store '/tmp/mosquitto'
        Depending on your log level there only may be the INFO line.
        • cgrfC
          cgrfC
          cgrf
          wrote on last edited by cgrf
          @TimO
          I have this INFO line, as included in my first post, that looks similar but not quite the same:
          The four lines from my first post are actually all lines I have in that log after the UI start-up messages.
          • T
            TimO
            wrote on last edited by TimO
            @cgrf said in openHAB 2.2 binding MQTT support:
            You're using the mqtt1 (openhab1-addon) to connect to the broker. The OpenHAB2 binding is based on the current (/upcoming) mqtt-transport implementation of ESH.
            My guess: the file org.eclipse.smarthome.mqtt.cfg is missing in /etc/openhab2/services and there only is a mqtt.cfg file. Just copy the mqtt.cfg file to org.eclipse.smarthome.mqtt.cfg (Same content, different name, different use).
            mqtt.cfg: mqtt1 binding, mqtt-transport, owntracks ...
            org.eclipse.smarthome.mqtt.cfg: ESH-MQTT and I'm only aware of my binding using it yet. But there are a few upcoming (mqtt generic, mqtt2 binding ..)
            cgrfC 1 Reply Last reply
            • T TimO
              cgrfC
              cgrfC
              cgrf
              @timo said in openHAB 2.2 binding MQTT support:
              Excellent guess, that was my problem! My gateway is "online" now. It would have taken me forever to figure that out on my own, so thank you very much! (And yes, reading your first post now I realize that you said so.)
              Should OpenHAB be able to discover the sensors behind the gateway? Or do I need to configure them manually?
              • cgrfC cgrf
                TimO
                @cgrf
                If you restart the node they should represent themself and will show up in the Inbox in PaperUI.
                • cgrfC
                  cgrfC
                  cgrf
                  @TimO
                  Ok, I've restarted the sensor multiple times now and I assume that it presents itself properly as it is discovered by other controllers (mycontroller.org, that is). But in OpenHAB's PaperUI it doesn't show up at all. There is a trace of it in the openhab.log though:
                  2018-01-10 09:29:39.268 [WARN ] [al.sensors.child.MySensorsChildSTemp] - Overwrite variable: V_VAR1
                  2018-01-10 09:29:39.269 [WARN ] [al.sensors.child.MySensorsChildSTemp] - Overwrite variable: V_VAR2
                  2018-01-10 09:29:39.277 [WARN ] [al.sensors.child.MySensorsChildSTemp] - Overwrite variable: V_VAR3
                  2018-01-10 09:29:39.289 [WARN ] [al.sensors.child.MySensorsChildSTemp] - Overwrite variable: V_VAR4
                  2018-01-10 09:29:39.289 [WARN ] [al.sensors.child.MySensorsChildSTemp] - Overwrite variable: V_VAR5
                  2018-01-10 20:38:26.959 [WARN ] [nal.sensors.child.MySensorsChildSHum] - Overwrite variable: V_VAR1
                  2018-01-10 20:38:26.980 [WARN ] [nal.sensors.child.MySensorsChildSHum] - Overwrite variable: V_VAR2
                  2018-01-10 20:38:26.980 [WARN ] [nal.sensors.child.MySensorsChildSHum] - Overwrite variable: V_VAR3
                  2018-01-10 20:38:26.980 [WARN ] [nal.sensors.child.MySensorsChildSHum] - Overwrite variable: V_VAR4
                  2018-01-10 20:38:26.981 [WARN ] [nal.sensors.child.MySensorsChildSHum] - Overwrite variable: V_VAR5
                  2018-01-10 20:38:27.084 [WARN ] [sors.child.MySensorsChildSMultimeter] - Overwrite variable: V_VAR1
                  2018-01-10 20:38:27.086 [WARN ] [sors.child.MySensorsChildSMultimeter] - Overwrite variable: V_VAR2
                  2018-01-10 20:38:27.086 [WARN ] [sors.child.MySensorsChildSMultimeter] - Overwrite variable: V_VAR3
                  2018-01-10 20:38:27.088 [WARN ] [sors.child.MySensorsChildSMultimeter] - Overwrite variable: V_VAR4
                  2018-01-10 20:38:27.089 [WARN ] [sors.child.MySensorsChildSMultimeter] - Overwrite variable: V_VAR5
                  2018-01-10 20:39:10.530 [WARN ] [rs.internal.gateway.MySensorsGateway] - Presented child is alredy present in gateway
                  2018-01-10 20:39:11.529 [WARN ] [rs.internal.gateway.MySensorsGateway] - Presented child is alredy present in gateway
                  2018-01-10 20:39:11.660 [WARN ] [rs.internal.gateway.MySensorsGateway] - Presented child is alredy present in gateway
                  2018-01-10 20:40:58.584 [WARN ] [rs.internal.gateway.MySensorsGateway] - Presented child is alredy present in gateway
                  2018-01-10 20:40:59.461 [WARN ] [rs.internal.gateway.MySensorsGateway] - Presented child is alredy present in gateway
                  2018-01-10 20:40:59.592 [WARN ] [rs.internal.gateway.MySensorsGateway] - Presented child is alredy present in gateway
                  While this is happening on MQTT:
                  gateway1-out/3/255/0/0/17 2.1.1
                  gateway1-out/3/255/3/0/6 0
                  gateway1-out/3/255/3/0/11 Combined Climate Sensor
                  gateway1-out/3/255/3/0/12 1.0.16
                  gateway1-out/3/0/0/0/7 (null)
                  gateway1-out/3/7/0/0/30 (null)
                  gateway1-out/3/10/2/0/15 (null)
                  gateway1-out/3/1/1/0/0 21.9
                  gateway1-out/3/0/1/0/1 42
                  gateway1-out/3/7/1/0/38 3.98
                  gateway1-out/3/255/3/0/0 56
                  Have you got another hint for me, maybe? It would be greatly appreciated.
                  • cgrfC
                    cgrfC
                    cgrf
                    Unfortunately, I'm still making no progress here. In the meantime I deleted the MQTT Gateway in the Paper UI and restarted the device to see what would happen. Now I'm seeing an error in openhab.log:
                    2018-01-16 19:45:23.419 [INFO ] [.transport.mqtt.MqttBrokerConnection] - Starting MQTT broker connection 'ineluki' to 'tcp://192.168.5.2:1883' with clientid openhab2 and file store '/openhab/userdata/tmp/ineluki'
                    2018-01-16 19:45:29.680 [INFO ] [.transport.mqtt.MqttBrokerConnection] - MQTT connection to 'ineluki' was lost: MqttException
                    2018-01-16 19:45:29.681 [ERROR] [rotocol.mqtt.MySensorsMqttConnection] - MQTT connection offline - {}
                    org.eclipse.paho.client.mqttv3.MqttException: MqttException
                            at org.eclipse.paho.client.mqttv3.internal.CommsCallback.run(CommsCallback.java:176) [211:org.eclipse.paho.client.mqttv3:1.0.2]
                            at java.lang.Thread.run(Thread.java:748) [?:?]
                    Caused by: java.lang.NullPointerException
                            at org.openhab.binding.mysensors.internal.protocol.mqtt.MySensorsMqttConnection$MySensorsMqttSubscriber.processMessage(MySensorsMqttConnection.java:142) ~[?:?]
                            at org.eclipse.smarthome.io.transport.mqtt.MqttBrokerConnection$ClientCallbacks.messageArrived(MqttBrokerConnection.java:121) ~[?:?]
                            at org.eclipse.paho.client.mqttv3.internal.CommsCallback.handleMessage(CommsCallback.java:354) ~[?:?]
                            at org.eclipse.paho.client.mqttv3.internal.CommsCallback.run(CommsCallback.java:162) ~[?:?]
                            ... 1 more
                    2018-01-16 19:45:29.709 [INFO ] [.reconnect.PeriodicReconnectStrategy] - Try to restore connection to 'ineluki' every 10000ms
                    Does this give any clue on what's going wrong?
                    • cgrfC
                      cgrfC
                      cgrf
                      Ok, now I'm seeing items in my Inbox, after I changed my org.eclipse.smarthome.mqtt.cfg from
                      ineluki.qos=2
                      ineluki.retain=true
                      to
                      #ineluki.qos=2
                      • MasMatM
                        MasMatM
                        MasMat
                        OK, n00b questions again:
                        1. where to place the binding-jar and do I have to do something with the jar-file?
                        2. no services directory exists in /etc. Create it?
                        3. any other things to install? Fresh PaperUI-OpenHab installation so far.
                          My system:RpiZero/Scratch+Mosquitto.
                        • MasMatM MasMat
                          TimO
                          @masmat
                          1. /usr/share/openhab2/addons/
                          2. Thank you for the hint, I've pointed to the wrong directory, it's: /etc/openhab2/services
                          3. For additional Informations please have a look at the wiki: https://github.com/tobof/openhab2-addons/wiki
                          MasMatM 1 Reply Last reply
                          • cgrfC cgrf
                            ineluki.qos=2
                            ineluki.retain=true
                            to
                            #ineluki.qos=2
                            TimO
                            @cgrf Thank you for the hint! At the moment I don't have an explanation for that behaviour.
                            • T TimO
                              @masmat
                              MasMatM
                              MasMatM
                              MasMat
                              @timo I still cant find mqtt.cfg OR org.eclipse.smarthome.mqtt.cfg. I looked thru the Github stuff but didn't see it.
                              Any ideas where to locate either of these files? I assume they have more lines than those four on display in the example.
                              Thanks. Sorry I'm still a tool with OH2
                              L 1 Reply Last reply
                              • MasMatM MasMat
                                L
                                L
                                LastSamurai
                                @masmat As far as I know .cfg files are only the config files fpr your installed addons and are located in the service directory (see TimO's post above). And they indeed only contain the settings you want to use, which can be 4 lines only. Depends on the addon
                                • L LastSamurai
                                  MasMatM
                                  MasMatM
                                  MasMat
                                  @lastsamurai I kinda figured that. From the first post I understood that the MQTT binding (binding-mqtt1 - 1.11.0) did not need to be installed. mqtt.cfg -file does come from that. So far I haven't installed it, but if that's where the mqtt.cfg file should come from then I'll do that next.
                                  Just dont want to have addon on top of addon if they're redundant.
                                  • MasMatM MasMat
                                    TimO
                                    @masmat Just create the org.eclipse.smarthome.mqtt.cfg file. It's not created automatically. mqtt.cfg is not needed for the binding.
                                    • T TimO
                                      MasMatM
                                      MasMatM
                                      MasMat
                                      @timo Alright!! MQTT Gateway Online. Thanks for your patience. Hopefully this thread will help future hopefuls.
                                      Now, I'm gonna activate some nodes and see what happens.
                                      • MasMatM
                                        MasMatM
                                        MasMat
                                        Well, this joy lasted almost 24h...until I unplugged and moved the set-up.
                                        Now Mosquitto-service wont start "Status 11/SEGV"...went nuts looking for that.
                                        Moved Mosquitto to another machine, but now mysgw-service "failed to connect".
                                        Any ideas why Mosquitto went status11 after reboot?
                                        Why wont mysgw connect to another Mosquitto IP? does the port 1883 need to be configured as well?
                                        My configure-line: --my-transport=nrf24 --my-gateway=mqtt --my-controller-ip-address=192.168.0.52 --my-mqtt-publish-topic-prefix=mysensors-out --my-mqtt-subscribe-topic-prefix=mysensors-in --my-mqtt-client-id=mygateway1 --my-rf24-irq-pin=15 --my-leds-err-pin=12 --my-leds-rx-pin=16 --my-leds-tx-pin=18 --my-mqtt-user=????? —-my-mqtt-password=???????
                                        • B
                                          B
                                          BenPr
                                          @TimO The MySonsors Binding didn't find any things for me. :-/
                                          My /etc/openhab2/services/org.eclipse.smarthome.mqtt.cfg
                                          broker.url=tcp://localhost:1883
                                          broker.clientId=openhabianpi
                                          broker.user=*private*
                                          broker.pwd=*private*
                                          My /etc/mosquitto/mosquitto.conf
                                          persistence true
                                          password_file /etc/mosquitto/passwd
                                          allow_anonymous false
                                          My /var/log/mosquitto/mosquitto.log
                                          1516918990: mosquitto version 1.4.10 (build date Mon, 29 May 2017 13:43:29 +0100) starting
                                          1516918990: Config loaded from /etc/mosquitto/mosquitto.conf.
                                          1516918990: Opening ipv4 listen socket on port 1883.
                                          1516918990: Opening ipv6 listen socket on port 1883.
                                          1516919015: New connection from x.x.x.29 on port 1883.
                                          1516919015: New client connected from x.x.x.29 as MQTT_Terrassen_Beleuchtung (c1, k15, u'openhabian').
                                          1516919044: New connection from 127.0.0.1 on port 1883.
                                          1516919044: New client connected from 127.0.0.1 as openhabianpi (c1, k60, u'openhabian').
                                          1516920798: Saving in-memory database to /var/lib/mosquitto/mosquitto.db.
                                          MQTT_Terrassen_Beleuchtung is the thing to find.
                                          My /var/log/openhab2/openhab.log
                                          2018-01-26 00:15:23.079 [INFO ] [.internal.GenericScriptEngineFactory] - Activated scripting support for ECMAScript
                                          2018-01-26 00:15:25.437 [INFO ] [er.internal.HomeBuilderDashboardTile] - Started Home Builder at /homebuilder
                                          2018-01-26 00:15:28.660 [INFO ] [.core.internal.i18n.I18nProviderImpl] - Locale set to de_DE, Location set to 51.5032,7.0073, Time zone set to Europe/Berlin
                                          2018-01-26 00:15:31.505 [INFO ] [.transport.mqtt.MqttBrokerConnection] - Starting MQTT broker connection 'broker' to 'tcp://localhost:1883' with clientid openhabianpi and file store '/var/lib/openhab2/tmp/broker'
                                          2018-01-26 00:15:31.642 [WARN ] [rthome.io.transport.mqtt.MqttService] - MqttBroker start failed: Persistenz wird bereits verwendet
                                          org.eclipse.smarthome.io.transport.mqtt.MqttException: Persistenz wird bereits verwendet
                                                  at org.eclipse.smarthome.io.transport.mqtt.MqttBrokerConnection.start(MqttBrokerConnection.java:572) [289:org.eclipse.smarthome.io.transport.mqtt:0.10.0.b1]
                                                  at org.eclipse.smarthome.io.transport.mqtt.MqttService.modified(MqttService.java:145) [289:org.eclipse.smarthome.io.transport.mqtt:0.10.0.b1]
                                                  at org.eclipse.smarthome.io.transport.mqtt.MqttService.activate(MqttService.java:157) [289:org.eclipse.smarthome.io.transport.mqtt:0.10.0.b1]
                                                  at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method) ~[?:?]
                                                  at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62) ~[?:?]
                                                  at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43) ~[?:?]
                                                  at java.lang.reflect.Method.invoke(Method.java:498) ~[?:?]
                                                  at org.apache.felix.scr.impl.inject.BaseMethod.invokeMethod(BaseMethod.java:229) [42:org.apache.felix.scr:2.0.12]
                                                  at org.apache.felix.scr.impl.inject.BaseMethod.access$500(BaseMethod.java:39) [42:org.apache.felix.scr:2.0.12]
                                                  at org.apache.felix.scr.impl.inject.BaseMethod$Resolved.invoke(BaseMethod.java:650) [42:org.apache.felix.scr:2.0.12]
                                                  at org.apache.felix.scr.impl.inject.BaseMethod.invoke(BaseMethod.java:506) [42:org.apache.felix.scr:2.0.12]
                                                  at org.apache.felix.scr.impl.inject.ActivateMethod.invoke(ActivateMethod.java:307) [42:org.apache.felix.scr:2.0.12]
                                                  at org.apache.felix.scr.impl.inject.ActivateMethod.invoke(ActivateMethod.java:299) [42:org.apache.felix.scr:2.0.12]
                                                  at org.apache.felix.scr.impl.manager.SingleComponentManager.createImplementationObject(SingleComponentManager.java:298) [42:org.apache.felix.scr:2.0.12]
                                                  at org.apache.felix.scr.impl.manager.SingleComponentManager.createComponent(SingleComponentManager.java:109) [42:org.apache.felix.scr:2.0.12]
                                                  at org.apache.felix.scr.impl.manager.SingleComponentManager.getService(SingleComponentManager.java:906) [42:org.apache.felix.scr:2.0.12]
                                                  at org.apache.felix.scr.impl.manager.SingleComponentManager.getServiceInternal(SingleComponentManager.java:879) [42:org.apache.felix.scr:2.0.12]
                                                  at org.apache.felix.scr.impl.manager.SingleComponentManager.getService(SingleComponentManager.java:823) [42:org.apache.felix.scr:2.0.12]
                                                  at org.eclipse.osgi.internal.serviceregistry.ServiceFactoryUse$1.run(ServiceFactoryUse.java:212) [?:?]
                                                  at java.security.AccessController.doPrivileged(Native Method) ~[?:?]
                                                  at org.eclipse.osgi.internal.serviceregistry.ServiceFactoryUse.factoryGetService(ServiceFactoryUse.java:210) [?:?]
                                                  at org.eclipse.osgi.internal.serviceregistry.ServiceFactoryUse.getService(ServiceFactoryUse.java:111) [?:?]
                                                  at org.eclipse.osgi.internal.serviceregistry.ServiceConsumer$2.getService(ServiceConsumer.java:45) [?:?]
                                                  at org.eclipse.osgi.internal.serviceregistry.ServiceRegistrationImpl.getService(ServiceRegistrationImpl.java:496) [?:?]
                                                  at org.eclipse.osgi.internal.serviceregistry.ServiceRegistry.getService(ServiceRegistry.java:461) [?:?]
                                                  at org.eclipse.osgi.internal.framework.BundleContextImpl.getService(BundleContextImpl.java:619) [?:?]
                                                  at com.eclipsesource.jaxrs.publisher.internal.ResourceTracker.addingService(ResourceTracker.java:39) [15:com.eclipsesource.jaxrs.publisher:5.3.1.201602281253]
                                                  at org.osgi.util.tracker.ServiceTracker$Tracked.customizerAdding(ServiceTracker.java:941) [?:?]
                                                  at org.osgi.util.tracker.ServiceTracker$Tracked.customizerAdding(ServiceTracker.java:870) [?:?]
                                                  at org.osgi.util.tracker.AbstractTracked.trackAdding(AbstractTracked.java:256) [?:?]
                                                  at org.osgi.util.tracker.AbstractTracked.track(AbstractTracked.java:229) [?:?]
                                                  at org.osgi.util.tracker.ServiceTracker$Tracked.serviceChanged(ServiceTracker.java:901) [?:?]
                                                  at org.eclipse.osgi.internal.serviceregistry.FilteredServiceListener.serviceChanged(FilteredServiceListener.java:109) [?:?]
                                                  at org.eclipse.osgi.internal.framework.BundleContextImpl.dispatchEvent(BundleContextImpl.java:915) [?:?]
                                                  at org.eclipse.osgi.framework.eventmgr.EventManager.dispatchEvent(EventManager.java:230) [?:?]
                                                  at org.eclipse.osgi.framework.eventmgr.ListenerQueue.dispatchEventSynchronous(ListenerQueue.java:148) [?:?]
                                                  at org.eclipse.osgi.internal.serviceregistry.ServiceRegistry.publishServiceEventPrivileged(ServiceRegistry.java:862) [?:?]
                                                  at org.eclipse.osgi.internal.serviceregistry.ServiceRegistry.publishServiceEvent(ServiceRegistry.java:801) [?:?]
                                                  at org.eclipse.osgi.internal.serviceregistry.ServiceRegistrationImpl.register(ServiceRegistrationImpl.java:127) [?:?]
                                                  at org.eclipse.osgi.internal.serviceregistry.ServiceRegistry.registerService(ServiceRegistry.java:225) [?:?]
                                                  at org.eclipse.osgi.internal.framework.BundleContextImpl.registerService(BundleContextImpl.java:464) [?:?]
                                                  at org.apache.felix.scr.impl.manager.AbstractComponentManager$3.register(AbstractComponentManager.java:887) [42:org.apache.felix.scr:2.0.12]
                                                  at org.apache.felix.scr.impl.manager.AbstractComponentManager$3.register(AbstractComponentManager.java:874) [42:org.apache.felix.scr:2.0.12]
                                                  at org.apache.felix.scr.impl.manager.RegistrationManager.changeRegistration(RegistrationManager.java:132) [42:org.apache.felix.scr:2.0.12]
                                                  at org.apache.felix.scr.impl.manager.AbstractComponentManager.registerService(AbstractComponentManager.java:941) [42:org.apache.felix.scr:2.0.12]
                                                  at org.apache.felix.scr.impl.manager.AbstractComponentManager.activateInternal(AbstractComponentManager.java:741) [42:org.apache.felix.scr:2.0.12]
                                                  at org.apache.felix.scr.impl.manager.DependencyManager$SingleDynamicCustomizer.addedService(DependencyManager.java:799) [42:org.apache.felix.scr:2.0.12]
                                                  at org.apache.felix.scr.impl.manager.DependencyManager$SingleDynamicCustomizer.addedService(DependencyManager.java:743) [42:org.apache.felix.scr:2.0.12]
                                                  at org.apache.felix.scr.impl.manager.ServiceTracker$Tracked.customizerAdded(ServiceTracker.java:1215) [42:org.apache.felix.scr:2.0.12]
                                                  at org.apache.felix.scr.impl.manager.ServiceTracker$Tracked.customizerAdded(ServiceTracker.java:1136) [42:org.apache.felix.scr:2.0.12]
                                                  at org.apache.felix.scr.impl.manager.ServiceTracker$AbstractTracked.trackAdding(ServiceTracker.java:945) [42:org.apache.felix.scr:2.0.12]
                                                  at org.apache.felix.scr.impl.manager.ServiceTracker$AbstractTracked.track(ServiceTracker.java:881) [42:org.apache.felix.scr:2.0.12]
                                                  at org.apache.felix.scr.impl.manager.ServiceTracker$Tracked.serviceChanged(ServiceTracker.java:1167) [42:org.apache.felix.scr:2.0.12]
                                                  at org.apache.felix.scr.impl.BundleComponentActivator$ListenerInfo.serviceChanged(BundleComponentActivator.java:127) [42:org.apache.felix.scr:2.0.12]
                                                  at org.apache.felix.scr.impl.manager.DependencyManager$SingleStaticCustomizer.addedService(DependencyManager.java:1012) [42:org.apache.felix.scr:2.0.12]
                                                  at org.apache.felix.scr.impl.manager.DependencyManager$SingleStaticCustomizer.addedService(DependencyManager.java:968) [42:org.apache.felix.scr:2.0.12]
                                                  at org.apache.felix.scr.impl.manager.AbstractComponentManager.enableInternal(AbstractComponentManager.java:675) [42:org.apache.felix.scr:2.0.12]
                                                  at org.apache.felix.scr.impl.manager.AbstractComponentManager.enable(AbstractComponentManager.java:430) [42:org.apache.felix.scr:2.0.12]
                                                  at org.apache.felix.scr.impl.manager.ConfigurableComponentHolder.enableComponents(ConfigurableComponentHolder.java:657) [42:org.apache.felix.scr:2.0.12]
                                                  at org.apache.felix.scr.impl.BundleComponentActivator.initialEnable(BundleComponentActivator.java:341) [42:org.apache.felix.scr:2.0.12]
                                                  at org.apache.felix.scr.impl.Activator.loadComponents(Activator.java:390) [42:org.apache.felix.scr:2.0.12]
                                                  at org.apache.felix.scr.impl.Activator.access$200(Activator.java:54) [42:org.apache.felix.scr:2.0.12]
                                                  at org.apache.felix.scr.impl.Activator$ScrExtension.start(Activator.java:265) [42:org.apache.felix.scr:2.0.12]
                                                  at org.apache.felix.utils.extender.AbstractExtender.createExtension(AbstractExtender.java:254) [42:org.apache.felix.scr:2.0.12]
                                                  at org.apache.felix.utils.extender.AbstractExtender.modifiedBundle(AbstractExtender.java:227) [42:org.apache.felix.scr:2.0.12]
                                                  at org.osgi.util.tracker.BundleTracker$Tracked.customizerModified(BundleTracker.java:482) [?:?]
                                                  at org.osgi.util.tracker.BundleTracker$Tracked.customizerModified(BundleTracker.java:415) [?:?]
                                                  at org.osgi.util.tracker.AbstractTracked.track(AbstractTracked.java:232) [?:?]
                                                  at org.osgi.util.tracker.BundleTracker$Tracked.bundleChanged(BundleTracker.java:444) [?:?]
                                                  at org.eclipse.osgi.internal.framework.BundleContextImpl.dispatchEvent(BundleContextImpl.java:903) [?:?]
                                                  at org.eclipse.osgi.internal.framework.EquinoxEventPublisher.publishBundleEventPrivileged(EquinoxEventPublisher.java:213) [?:?]
                                                  at org.eclipse.osgi.internal.framework.EquinoxEventPublisher.publishBundleEvent(EquinoxEventPublisher.java:120) [?:?]
                                                  at org.eclipse.osgi.internal.framework.EquinoxEventPublisher.publishBundleEvent(EquinoxEventPublisher.java:112) [?:?]
                                                  at org.eclipse.osgi.internal.framework.EquinoxContainerAdaptor.publishModuleEvent(EquinoxContainerAdaptor.java:156) [?:?]
                                                  at org.eclipse.osgi.container.Module.publishEvent(Module.java:476) [?:?]
                                                  at org.eclipse.osgi.container.Module.start(Module.java:467) [?:?]
                                                  at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.incStartLevel(ModuleContainer.java:1620) [?:?]
                                                  at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.incStartLevel(ModuleContainer.java:1600) [?:?]
                                                  at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.doContainerStartLevel(ModuleContainer.java:1571) [?:?]
                                                  at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.dispatchEvent(ModuleContainer.java:1514) [?:?]
                                                  at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.dispatchEvent(ModuleContainer.java:1) [?:?]
                                                  at org.eclipse.osgi.framework.eventmgr.EventManager$EventThread.run(EventManager.java:340) [?:?]
                                          Caused by: org.eclipse.paho.client.mqttv3.MqttPersistenceException: Persistenz wird bereits verwendet
                                                  at org.eclipse.paho.client.mqttv3.persist.MqttDefaultFilePersistence.open(MqttDefaultFilePersistence.java:112) ~[?:?]
                                                  at org.eclipse.paho.client.mqttv3.MqttAsyncClient.<init>(MqttAsyncClient.java:286) ~[?:?]
                                                  at org.eclipse.paho.client.mqttv3.MqttAsyncClient.<init>(MqttAsyncClient.java:167) ~[?:?]
                                                  at org.eclipse.smarthome.io.transport.mqtt.MqttBrokerConnection.start(MqttBrokerConnection.java:570) ~[?:?]
                                                  ... 118 more
                                          2018-01-26 00:15:32.456 [INFO ] [.dashboard.internal.DashboardService] - Started dashboard at http://x.x.x.30:8080
                                          2018-01-26 00:15:32.465 [INFO ] [.dashboard.internal.DashboardService] - Started dashboard at https://x.x.x.30:8443
                                          2018-01-26 00:15:52.506 [INFO ] [thome.model.lsp.internal.ModelServer] - Started Language Server Protocol (LSP) service on port 5007
                                          2018-01-26 00:16:01.849 [INFO ] [basic.internal.servlet.WebAppServlet] - Started Basic UI at /basicui/app
                                          2018-01-26 00:16:01.999 [INFO ] [arthome.ui.paper.internal.PaperUIApp] - Started Paper UI at /paperui
                                          2018-01-26 00:16:02.291 [INFO ] [panel.internal.HABPanelDashboardTile] - Started HABPanel at /habpanel
                                          2018-01-26 00:16:02.816 [WARN ] [mqtt.internal.MqttPersistenceService] - mqtt-persistence:broker
                                          2018-01-26 00:16:02.819 [WARN ] [mqtt.internal.MqttPersistenceService] - mqtt-persistence:topic
                                          2018-01-26 00:16:02.822 [WARN ] [mqtt.internal.MqttPersistenceService] - mqtt-persistence:message
                                          2018-01-26 00:16:05.597 [INFO ] [ui.habmin.internal.servlet.HABminApp] - Started HABmin servlet at /habmin
                                          2018-01-26 00:16:06.390 [INFO ] [assic.internal.servlet.WebAppServlet] - Started Classic UI at /classicui/app
                                          Have you any idea to fix this?
