  2. Announcements
  • S sineverba
    Hi to all,
    I'm testing an ethernet gateway on RPI3, with nrf24 + 1 node with a relay.
    I want introduce security and signing. On Arduino gateway / node no problem at all, but, how to do on the RPI3 as gateway?
    I would get / create / set a software serial on PI itself and whitelisting it on the node, after I will introduce the AES Key and signing.
    Cannot find in documentation how do it on PI3. Thank you very much!
    G
    G
    ghiglie
    @sineverba said in 💬 Building a Raspberry Pi Gateway:
    Hi to all,
    Earlier in this forum... https://forum.mysensors.org/topic/4803/building-a-raspberry-pi-gateway/350
    atmega328p serial killer
    HomeAssistant / gateway: ESP8266 & NRF24L01+ gateway
    S 1 Reply Last reply
      @ghiglie https://lists.yoctoproject.org/pipermail/yocto/2016-January/028233.html seems to suggest that adding
      #include <asm/ioctl.h>
      would solve the problem. Could you try that?
      G
      G
      ghiglie
      wrote on last edited by ghiglie
      #741
      @mfalkvidd I'm trying today, but to compile correctly the Docker image I'll have to clone to my github account :( or at least locally. My Dockerfile for the "Alpine edition" for Hass.io is simply:
      ARG BUILD_FROM
      ARG BUILD_ARCH
      ARG BUILD_DATE
      ARG BUILD_REF
      ARG BUILD_VERSION
      FROM ${BUILD_FROM}
      ENV CONFIG_PATH=/data/options.json
      ENV APPDIR=/opt/MySensors
      RUN apt-get update && apt-get install -y --force-yes \
          make \
      	 g++ \
      	 git \
      	 && rm -rf /var/lib/apt/lists/* /tmp/* /var/tmp/* ~/.cache \
      	 && git clone https://github.com/mysensors/MySensors.git --branch development $APPDIR
      # Copy root filesystem
      COPY rootfs /
      #CMD [ "/run.sh" ]
      I deleted the LABELS 'cause... the data is still too rawly "buried" from others. :tongue:
      The Configure and Make is in run.sh.
      BTW, I still need to figure out how to start mysgw as service... Mainlyt I'd like to redirect the log: how can I do this safely?
      And... can I use the rx/tx/err led feature on Raspi too (aside being in a Docker) ?
      EDIT: the code add works!
      Another question: I'm not getting far from this... what is it trying to do?
      : Starting gateway...
      : Protocol version - 2.2.0-rc.2
      : MCO:BGN:INIT GW,CP=RNNGL---,VER=2.2.0-rc.2
      : TSF:LRT:OK
      : TSM:INIT
      : TSF:WUR:MS=0
      • G ghiglie
        Hi to all,
        sineverba
        @ghiglie Thank you, I did see that was for 2.1.1. Just playing with them!
        • alowhumA
          alowhumA
          alowhum
          Does the Pi Gateway support the MY_SIGNING_SIMPLE_PASSWD option? I couldn't find anything about that. I've been gearing up to use that feature in my network, but I've also been playing with moving my gateway onto my Pi Zero W.
          gohanG M 2 Replies Last reply
          • alowhumA alowhum
            @alowhum If you want to just encrypt data, just add the encryption key in the myconfig.h file and compile it
            MasMatM 1 Reply Last reply
              MasMatM
              MasMatM
              MasMat
              @gohan N00b question, but which steps from the step-by-step need to be redone to "compile it" after altering myconfig.h? Or can you just post the command lines? :flushed:
                As soon as you do the changes in myconfig.h before the MAKE, you are fine
                  sentur
                  Anyone tried using the new Pi Zero WH as a Raspberry Pi Gateway. Presumably by MQTT and using NRF24 radio?
                  @alowhum Have you been able to setup a gateway with your Raspberry Pi Zero?
                  • S sentur
                    MasMatM
                    MasMatM
                    MasMat
                    @sentur That's what I'm doing now. Except mine is Zero W. Soldered the pins on myself.
                    • alowhumA alowhum
                      marceloaqno
                      Code Contributor
                      @alowhum yes, to use MY_SIGNING_SIMPLE_PASSWD feature, add the following to your list of configure options:
                      ... --my-signing=password --my-signing-password=<PASSWORD>
                      • Richard van der PlasR
                        Is there anyway where i can see if i have IRQ configured ?
                        ive build it a long time ago, but now upgraded to a nrf24 PA/LNA and have more an more sensors.
                          look inside makefile.inc in mysensors folder, that should contain the parameters you set in ./configure
                          Richard van der PlasR 1 Reply Last reply
                            wrote on last edited by Richard van der Plas
                            #752
                            @gohanm, as it seems not ?, can i rebuild it easily? ```
                            SOC=BCM2837
                            CPPFLAGS=-march=armv8-a+crc -mtune=cortex-a53 -mfpu=neon-fp-armv8 -mfloat-abi=hard -DMY_RADIO_NRF24 -DMY_GATEWAY_LINUX -DMY_DEBUG -DLINUX_SPI_BCM -DLINUX_ARCH_RASPBERRYPI -DMY_PORT=5003
                            LDFLAGS=-pthread
                            PREFIX=/usr/local
                            CC=gcc
                            CXX=g++
                            BUILDDIR=build
                            BINDIR=bin
                            GATEWAY_DIR=/usr/local/bin
                            INIT_SYSTEM=systemd
                            SPI_DRIVER=BCM```
                              make a copy of it and make a ./configure with the IRQ enabled and see what you get
                                @gohan make a copy of the makefile.inc and restart the ./configure command again you mean ?
                                ill try it tomorrow, too afraid to break things late in the evening ;)
                                  as far as you don't execute the MAKE command you are ok. Also make a copy of the mysgw executable just as backup if you never did it
                                    but ill have to do it sometime , just ./configure with all the options, build , test and install ?
                                      if you only want to check if irq is enabled, otherwise you could just build it fresh with irq enabled and you can go back by replacing the mysgw executable
                                      Richard van der PlasR 2 Replies Last reply
                                        @gohan ty
