  2. Announcements
    As soon as you do the changes in myconfig.h before the MAKE, you are fine
      sentur
      Anyone tried using the new Pi Zero WH as a Raspberry Pi Gateway. Presumably by MQTT and using NRF24 radio?
      @alowhum Have you been able to setup a gateway with your Raspberry Pi Zero?
      MasMatM 1 Reply Last reply
      • S sentur
        MasMatM
        MasMatM
        MasMat
        @sentur That's what I'm doing now. Except mine is Zero W. Soldered the pins on myself.
        • alowhumA alowhum
          Does the Pi Gateway support the MY_SIGNING_SIMPLE_PASSWD option? I couldn't find anything about that. I've been gearing up to use that feature in my network, but I've also been playing with moving my gateway onto my Pi Zero W.
          marceloaqno
          Code Contributor
          @alowhum yes, to use MY_SIGNING_SIMPLE_PASSWD feature, add the following to your list of configure options:
          ... --my-signing=password --my-signing-password=<PASSWORD>
          • Richard van der PlasR
            Is there anyway where i can see if i have IRQ configured ?
            ive build it a long time ago, but now upgraded to a nrf24 PA/LNA and have more an more sensors.
              look inside makefile.inc in mysensors folder, that should contain the parameters you set in ./configure
              Richard van der PlasR 1 Reply Last reply
                wrote on last edited by Richard van der Plas
                #752
                @gohanm, as it seems not ?, can i rebuild it easily? ```
                SOC=BCM2837
                CPPFLAGS=-march=armv8-a+crc -mtune=cortex-a53 -mfpu=neon-fp-armv8 -mfloat-abi=hard -DMY_RADIO_NRF24 -DMY_GATEWAY_LINUX -DMY_DEBUG -DLINUX_SPI_BCM -DLINUX_ARCH_RASPBERRYPI -DMY_PORT=5003
                LDFLAGS=-pthread
                PREFIX=/usr/local
                CC=gcc
                CXX=g++
                BUILDDIR=build
                BINDIR=bin
                GATEWAY_DIR=/usr/local/bin
                INIT_SYSTEM=systemd
                SPI_DRIVER=BCM```
                  make a copy of it and make a ./configure with the IRQ enabled and see what you get
                    @gohan make a copy of the makefile.inc and restart the ./configure command again you mean ?
                    ill try it tomorrow, too afraid to break things late in the evening ;)
                      as far as you don't execute the MAKE command you are ok. Also make a copy of the mysgw executable just as backup if you never did it
                        but ill have to do it sometime , just ./configure with all the options, build , test and install ?
                          if you only want to check if irq is enabled, otherwise you could just build it fresh with irq enabled and you can go back by replacing the mysgw executable
                          Richard van der PlasR 2 Replies Last reply
                            @gohan ty
                                #760
                                Moved to normal troubleshooting forum
                                  • alowhumA
                                    alowhumA
                                    alowhum
                                    @MasMat Yes I was able to build it on a Pi Zero. I did a fresh install on Dietpi. It worked fine when I didn't give any configuration options.
                                    Now, however, I am still trying to run something on the PGIO pins in paralel to MySensors again, and this is not working. As I speak the Pi reboots every 5 minutes.. Not sure what to blame yet. Domoticz, PiGPIO, or MySensors.
                                    Latest DietPi Stretch, latest Domoticz beta, latest MySensors beta.
                                      PiGPIO
                                      what are you using that for?
                                      • alowhumA alowhum
                                        MasMatM
                                        MasMatM
                                        MasMat
                                        @alowhum I'm not using the GPIO for anything else.
                                        I had everything working (mysgw-MQTT, Mosquitto, Node-Red and OH2) for almost 6h. Then I moved the set-up and everything went south: cant get mosquitto to start, cant get mysgw to connect to that or another Mosquitto broker, OH2 seems to ignore everything...
                                        Spent the last 24h trying to resurrect Mosquitto but it's beyond me what's wrong.
                                        I remember reading that mysgw renders rest of the gpio unusable. Maybe that's giving you problems.
                                        alowhumA 1 Reply Last reply
                                          I am running 2 gateway instances, one nrf24 and one rfm69 so I guess you can run other things
