  2. Announcements
  • alowhumA alowhum
    Does the Pi Gateway support the MY_SIGNING_SIMPLE_PASSWD option? I couldn't find anything about that. I've been gearing up to use that feature in my network, but I've also been playing with moving my gateway onto my Pi Zero W.
    @alowhum If you want to just encrypt data, just add the encryption key in the myconfig.h file and compile it
    MasMatM 1 Reply Last reply
      MasMatM
      MasMatM
      MasMat
      @gohan N00b question, but which steps from the step-by-step need to be redone to "compile it" after altering myconfig.h? Or can you just post the command lines? :flushed:
        As soon as you do the changes in myconfig.h before the MAKE, you are fine
          sentur
          Anyone tried using the new Pi Zero WH as a Raspberry Pi Gateway. Presumably by MQTT and using NRF24 radio?
          @alowhum Have you been able to setup a gateway with your Raspberry Pi Zero?
          • S sentur
            MasMatM
            MasMatM
            MasMat
            @sentur That's what I'm doing now. Except mine is Zero W. Soldered the pins on myself.
            • alowhumA alowhum
              marceloaqno
              Code Contributor
              @alowhum yes, to use MY_SIGNING_SIMPLE_PASSWD feature, add the following to your list of configure options:
              ... --my-signing=password --my-signing-password=<PASSWORD>
              • Richard van der PlasR
                Is there anyway where i can see if i have IRQ configured ?
                ive build it a long time ago, but now upgraded to a nrf24 PA/LNA and have more an more sensors.
                  look inside makefile.inc in mysensors folder, that should contain the parameters you set in ./configure
                  Richard van der PlasR 1 Reply Last reply
                    wrote on last edited by Richard van der Plas
                    #752
                    @gohanm, as it seems not ?, can i rebuild it easily? ```
                    SOC=BCM2837
                    CPPFLAGS=-march=armv8-a+crc -mtune=cortex-a53 -mfpu=neon-fp-armv8 -mfloat-abi=hard -DMY_RADIO_NRF24 -DMY_GATEWAY_LINUX -DMY_DEBUG -DLINUX_SPI_BCM -DLINUX_ARCH_RASPBERRYPI -DMY_PORT=5003
                    LDFLAGS=-pthread
                    PREFIX=/usr/local
                    CC=gcc
                    CXX=g++
                    BUILDDIR=build
                    BINDIR=bin
                    GATEWAY_DIR=/usr/local/bin
                    INIT_SYSTEM=systemd
                    SPI_DRIVER=BCM```
                      make a copy of it and make a ./configure with the IRQ enabled and see what you get
                        @gohan make a copy of the makefile.inc and restart the ./configure command again you mean ?
                        ill try it tomorrow, too afraid to break things late in the evening ;)
                          as far as you don't execute the MAKE command you are ok. Also make a copy of the mysgw executable just as backup if you never did it
                            but ill have to do it sometime , just ./configure with all the options, build , test and install ?
                              if you only want to check if irq is enabled, otherwise you could just build it fresh with irq enabled and you can go back by replacing the mysgw executable
                              Richard van der PlasR 2 Replies Last reply
                                @gohan ty
                                    #760
                                    Moved to normal troubleshooting forum
                                      • alowhumA
                                        alowhumA
                                        alowhum
                                        @MasMat Yes I was able to build it on a Pi Zero. I did a fresh install on Dietpi. It worked fine when I didn't give any configuration options.
                                        Now, however, I am still trying to run something on the PGIO pins in paralel to MySensors again, and this is not working. As I speak the Pi reboots every 5 minutes.. Not sure what to blame yet. Domoticz, PiGPIO, or MySensors.
                                        Latest DietPi Stretch, latest Domoticz beta, latest MySensors beta.
                                          PiGPIO
                                          what are you using that for?
