  2. Announcements
  • G ghiglie
    @sineverba said in 💬 Building a Raspberry Pi Gateway:
    Hi to all,
    I'm testing an ethernet gateway on RPI3, with nrf24 + 1 node with a relay.
    I want introduce security and signing. On Arduino gateway / node no problem at all, but, how to do on the RPI3 as gateway?
    I would get / create / set a software serial on PI itself and whitelisting it on the node, after I will introduce the AES Key and signing.
    Cannot find in documentation how do it on PI3. Thank you very much!
    Earlier in this forum... https://forum.mysensors.org/topic/4803/building-a-raspberry-pi-gateway/350
    sineverba
    @ghiglie Thank you, I did see that was for 2.1.1. Just playing with them!
    • alowhumA
      alowhumA
      alowhum
      Does the Pi Gateway support the MY_SIGNING_SIMPLE_PASSWD option? I couldn't find anything about that. I've been gearing up to use that feature in my network, but I've also been playing with moving my gateway onto my Pi Zero W.
      gohanG M 2 Replies Last reply
      • alowhumA alowhum
        @alowhum If you want to just encrypt data, just add the encryption key in the myconfig.h file and compile it
        MasMatM 1 Reply Last reply
          MasMatM
          MasMatM
          MasMat
          @gohan N00b question, but which steps from the step-by-step need to be redone to "compile it" after altering myconfig.h? Or can you just post the command lines? :flushed:
            As soon as you do the changes in myconfig.h before the MAKE, you are fine
              sentur
              Anyone tried using the new Pi Zero WH as a Raspberry Pi Gateway. Presumably by MQTT and using NRF24 radio?
              @alowhum Have you been able to setup a gateway with your Raspberry Pi Zero?
              • S sentur
                MasMatM
                MasMatM
                MasMat
                @sentur That's what I'm doing now. Except mine is Zero W. Soldered the pins on myself.
                • alowhumA alowhum
                  marceloaqno
                  Code Contributor
                  @alowhum yes, to use MY_SIGNING_SIMPLE_PASSWD feature, add the following to your list of configure options:
                  ... --my-signing=password --my-signing-password=<PASSWORD>
                  • Richard van der PlasR
                    Is there anyway where i can see if i have IRQ configured ?
                    ive build it a long time ago, but now upgraded to a nrf24 PA/LNA and have more an more sensors.
                      look inside makefile.inc in mysensors folder, that should contain the parameters you set in ./configure
                      Richard van der PlasR 1 Reply Last reply
                        wrote on last edited by Richard van der Plas
                        #752
                        @gohanm, as it seems not ?, can i rebuild it easily? ```
                        SOC=BCM2837
                        CPPFLAGS=-march=armv8-a+crc -mtune=cortex-a53 -mfpu=neon-fp-armv8 -mfloat-abi=hard -DMY_RADIO_NRF24 -DMY_GATEWAY_LINUX -DMY_DEBUG -DLINUX_SPI_BCM -DLINUX_ARCH_RASPBERRYPI -DMY_PORT=5003
                        LDFLAGS=-pthread
                        PREFIX=/usr/local
                        CC=gcc
                        CXX=g++
                        BUILDDIR=build
                        BINDIR=bin
                        GATEWAY_DIR=/usr/local/bin
                        INIT_SYSTEM=systemd
                        SPI_DRIVER=BCM```
                          make a copy of it and make a ./configure with the IRQ enabled and see what you get
                            @gohan make a copy of the makefile.inc and restart the ./configure command again you mean ?
                            ill try it tomorrow, too afraid to break things late in the evening ;)
                              as far as you don't execute the MAKE command you are ok. Also make a copy of the mysgw executable just as backup if you never did it
                                but ill have to do it sometime , just ./configure with all the options, build , test and install ?
                                  if you only want to check if irq is enabled, otherwise you could just build it fresh with irq enabled and you can go back by replacing the mysgw executable
                                  Richard van der PlasR 2 Replies Last reply
                                    @gohan ty
                                        #760
                                        Moved to normal troubleshooting forum
