  3. [SOLVED] I use serial GW 2.1.1 and my sensor node won't connect
26 Posts 6 Posters 8.1k Views 4 Watching
  • tbowmoT
    tbowmoT
    tbowmo
    @bjacobse
    What does the log in domoticz tell you, when you power up gateway / nodes?
    "old" nodes (pre 2.1'ish) should be able to communicate with a new gateway (2.1), while the opposite is not true (new nodes running 2.1 is not able to connect to an old 1.5 gateway)
    Anyways, check logs on both ends (node, and gateway) to see if there is anything suspicious there..
    bjacobseB 1 Reply Last reply
    • zboblamontZ zboblamont
      @bjacobse I may be completely off the beam here as have not read through it all, and still new at all this, but... Have you enabled "#define MY_INCLUSION_MODE_FEATURE" on the Gateway?
      I read somewhere that this is needed for Domoticz after I could not get a Node to similarly connect.
      bjacobseB
      bjacobseB
      bjacobse
      @zboblamont
      I used the "original sketch and only updated the #define MY_RF24_PA_LEVEL RF24_PA_MAX
      * LEDs (OPTIONAL):
      * - To use the feature, uncomment any of the MY_DEFAULT_xx_LED_PINs
      // RF24_PA_MIN RF24_PA_LOW RF24_PA_HIGH RF24_PA_MAX
      // Enable serial gateway
      #define MY_GATEWAY_SERIAL
      #if F_CPU == 8000000L
      #define MY_BAUD_RATE 38400
      // Enable inclusion mode
      // Set blinking period
      // Flash leds on rx/tx/err
      • tbowmoT tbowmo
        @bjacobse
        bjacobseB
        bjacobseB
        bjacobse
        @tbowmo
        Thank you for the input
        the Domotics log:
        2017-11-14 20:42:04.586 MySensors: Using serial port: /dev/ttyUSB-mysensor
        2017-11-14 20:42:06.075 MySensors: Gateway Ready...
        2017-11-14 20:42:06.150 MySensors: Gateway Version: 2.1.1
        I am not sure how I also get debug/serial info out from the gateway meanwhile it's connected to the RPI that is running the Domoticz server, I will check the forum posts, as I haven't thought of this
        • bjacobseB bjacobse
          @zboblamont
          * LEDs (OPTIONAL):
          zboblamontZ
          zboblamontZ
          zboblamont
          @bjacobse Ok, not experienced enough to offer any further suggestions as still fumbling my own way,...
          In my own setup it is standardised on RFM69 radio modules, and the Nework ID is defined at the Gateway and Node, the Node ID is defined at the Node.
          • tbowmoT
            tbowmoT
            tbowmo
            @bjacobse
            As a start, you could shut down the domoticz instance, and connect a terminal program directly to your serial port instead. Then power cycle a few nodes, while recording the output from the gateway.
            at the same time, if you could capture the serial output from the power up sequence / first transmission of one of the nodes.
            • tbowmoT tbowmo
              @bjacobse
              bjacobseB
              bjacobseB
              bjacobse
              @tbowmo
              Thank you Thomas for good ideas :-) I will try this when I get time within a few days
              • bjacobseB
                bjacobseB
                bjacobse
                Gateway startup
                0;255;3;0;9;TSM:INIT
                0;255;3;0;9;TSF:WUR:MS=0
                0;255;3;0;9;TSM:INIT:TSP OK
                0;255;3;0;9;TSM:INIT:GW MODE
                0;255;0;0;18;2.1.1
                0;255;3;0;9;MCO:BGN:STP
                • bjacobseB
                  bjacobseB
                  bjacobse
                  Finally I got it, as I have used same hw configuration for ver1.5.4 as for ver 2.1.1 I did not expect any power issues...
                  a hint for debugging in consol mode linux then use screen
                  apt-get install screen
                  then use like this, note that I use udev to always get Domoticz to use correct ttyUSBx, as I have several USB devices attached attached
                  sudo screen /dev/ttyUSB-mysensor 115200
                  to kill screen CTRL-a then k and y for confirm
                  Then I realised that if I use gateway sketch un-modified it is working, and Domoticz is providing node id, (If Domotics is set to allow new sensors, in settings)
                  So when I change on the PA_LEVEL_HIGH or PA_LEVEL_MAX and use more power consumption, apparently the gateway isn't working. I do have a amplified PA RF24L01 moduleboard.
                  It's working when set as default PA_LEVEL_LOW
                  //#define MY_RF24_PA_LEVEL RF24_PA_MAX
                  I might have to look into a power USB hub ;-)
                  Thank you guys for providing input to solve my issue
                    mckvack
                    I too had problems with my GW resetting.
                    I use custom designed PCBs with Atmega328p-au using the internal oscillator. With some nodes the GW will reset when I turn them on. Sometimes changing to another NRF-module solved it but this time none of my NRF-modules worked so I searched and found this thread. Flashed the GW with v2.2.0-rc.2 and now all my problems are gone.
                      Mario64
                      I've got across similar problem. What works for you doesn't solve problem in my case.
                      Decreasing power to PA_LEVEL_LOW or switching to MySensors v2.2.0-rc.2 gives no positive result.
                      I have some experience with Arduino, but it is my first try with MySensors and Domoticz.
                      If someone could advice how to cope with, thank you in advance.
                      My Hardware:
                      Arduino Nano, NRF21+ for GW & Node,
                      the node is simple actuator: relay with button.
                      GW output on Serial monitor:
                      0;255;0;0;18;2.1.1
                      Node output on Serial Monitor:
                      0 MCO:BGN:INIT REPEATER,CP=RNNRA--,VER=2.1.1
                      3 TSM:INIT
                      4 TSF:WUR:MS=0
                      11 TSM:INIT:TSP OK
                      13 TSM:FPAR
                      15 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                      2023 !TSM:FPAR:NO REPLY
                      2025 TSM:FPAR
                      2027 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                      4035 !TSM:FPAR:NO REPLY
                      4037 TSM:FPAR
                      4039 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                      6047 !TSM:FPAR:NO REPLY
                      6049 TSM:FPAR
                      6051 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                      8060 !TSM:FPAR:FAIL
                      8061 TSM:FAIL:CNT=1
                      8064 TSM:FAIL:PDT
                      18067 TSM:FAIL:RE-INIT
                      18069 TSM:INIT
                      18076 TSM:INIT:TSP OK
                      18078 TSM:FPAR
                      18080 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                      20088 !TSM:FPAR:NO REPLY
                      20090 TSM:FPAR
                      20092 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                      22102 !TSM:FPAR:NO REPLY
                      22104 TSM:FPAR
                      22106 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                      24114 !TSM:FPAR:NO REPLY
                      24116 TSM:FPAR
                      24118 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                      26126 !TSM:FPAR:FAIL
                      26127 TSM:FAIL:CNT=2
                      26129 TSM:FAIL:PDT
                      etc...
                      Scratches:
                      //Gateway
                      #define MY_INCLUSION_MODE_DURATION 120
                      Node:
                      #define MY_REPEATER_FEATURE
                      #include <MyConfig.h>
                      #define RELAY_PIN  4  // Arduino Digital I/O pin number for relay
                      #define BUTTON_PIN  5  // Arduino Digital I/O pin number for button
                      #define CHILD_ID 10   // Id of the sensor (child)
                      #define RELAY_ON 1
                      #define RELAY_OFF 0
                      Bounce debouncer = Bounce();
                      int oldValue=0;
                      bool state;
                        // Setup the button
                        pinMode(BUTTON_PIN,INPUT);
                        // Setup debouncer
                        debouncer.attach(BUTTON_PIN);
                        debouncer.interval(5);
                        // set relay on when starting up
                        pinMode(RELAY_PIN, OUTPUT);
                        state=true;
                        digitalWrite(RELAY_PIN, RELAY_ON);
                      void presentation()  {
                        present(CHILD_ID, S_LIGHT);
                        debouncer.update();
                        // Get the update value
                        int value = debouncer.read();
                        if (value != oldValue && value==0) {
                            send(msg.set(state?false:true), true); // Send new state and request ack back
                            Serial.println("zmiana value na 0");
                            // Change relay state localy, anyway
                            state = !state;
                            Serial.print("state = ");
                            Serial.println(state);
                        oldValue = value;
                        if (message.isAck()) {
                           state = message.getBool();
                      • M Mario64
                        My Hardware:
                        0;255;0;0;18;2.1.1
                        3 TSM:INIT
                        4 TSF:WUR:MS=0
                        11 TSM:INIT:TSP OK
                        13 TSM:FPAR
                        2025 TSM:FPAR
                        4037 TSM:FPAR
                        6049 TSM:FPAR
                        8060 !TSM:FPAR:FAIL
                        8061 TSM:FAIL:CNT=1
                        8064 TSM:FAIL:PDT
                        18069 TSM:INIT
                        18078 TSM:FPAR
                        20090 TSM:FPAR
                        22104 TSM:FPAR
                        24116 TSM:FPAR
                        26129 TSM:FAIL:PDT
                        etc...
                        Scratches:
                        //Gateway
                        Node:
                        #define RELAY_ON 1
                        #define RELAY_OFF 0
                        int oldValue=0;
                        bool state;
                          // Setup the button
                          // Setup debouncer
                          state=true;
                          debouncer.update();
                              state = !state;
                          oldValue = value;
                        bjacobseB
                        bjacobseB
                        bjacobse
                        @mario64
                        Which home automation system are you using?
                        If using domoticz, then it's vital to accept new sensors, you find it setup->settings
                        Hardware/Devices:
                        Accept new Hardware Devices
                        if this is disabled, no sensors are allowed to be created
                          @mario64
                          Hardware/Devices:
                          Mario64
                          wrote on last edited by Mario64
                          Hi @bjacobse,
                          thank you for answer. I'm back to my project after e few days.
                          Actually, the "Accept new Hardware Devices" switch is on. I also used the "Alow for 5 minutes" button. Let me share more details:
                          • pls find log of Domoticz:
                           2018-01-22 09:55:34.871 MySensors: retrying in 30 seconds...
                          2018-01-22 09:56:00.874 MySensors: Serial Worker stopped...
                          2018-01-22 09:56:11.130 New sensors allowed for 5 minutes...
                          2018-01-22 09:56:43.077 MySensors: Using serial port: /dev/ttyUSB0
                          2018-01-22 10:02:38.123 MySensors: Serial Worker stopped...
                          2018-01-22 10:02:39.134 MySensors: Using serial port: /dev/ttyUSB0
                          2018-01-22 10:03:38.156 New sensors allowed for 5 minutes...
                          2018-01-22 10:04:00.048 Error: Gwx hardware (2) nothing received for more than 1 Minute!....
                          2018-01-22 10:04:01.049 Error: Restarting: Gwx
                          2018-01-22 10:04:01.146 MySensors: Serial Worker stopped...
                          2018-01-22 10:04:02.157 MySensors: Using serial port: /dev/ttyUSB0
                          2018-01-22 10:05:30.219 Error: Gwx hardware (2) nothing received for more than 1 Minute!....
                          2018-01-22 10:05:31.220 Error: Restarting: Gwx
                          2018-01-22 10:05:32.170 MySensors: Serial Worker stopped...
                          2018-01-22 10:05:33.181 MySensors: Using serial port: /dev/ttyUSB0
                          2018-01-22 10:07:00.204 Error: Gwx hardware (2) nothing received for more than 1 Minute!....
                          etc
                          • screen shots:
                          • list itemSetup->Hardware:
                            ![Gateway settings]https://drive.google.com/file/d/1NjJZMlaM98XaZ-UCY93pyeHcKbT7ZZoh/view?usp=sharing
                          • list itemSetup->Hardware Gwx setup:
                            ![Gwx Setup]https://drive.google.com/file/d/1vDVDcLGaGK_g3-uYQrl_DnlHlbvjq87Z/view?usp=sharing
                          • list itemSetup->Settings:
                            ![Domoticz Settings]https://drive.google.com/file/d/15bkfnHx6rEcqRnTvLVOydwPK63dy83xe/view?usp=sharing
                          • M Mario64
                            Hi @bjacobse,
                            etc
                            • screen shots:
                            Mario64
                            @mario64
                            one update information (Gateway)
                            when I press reset button on Arduino Nano board, I get one additional line on serial monitor:
                            0;255;3;0;2;2.1.1
                            and on domoticz HW setup screen, I get one children of node with name: S_ARDUINO_REPEATER_NODE. see screenshot:
                            ![ ]https://drive.google.com/file/d/1Pjqy7XKA5V9nZYmP90V8hR-pfDy26hc8/view?usp=sharing
                            • M Mario64
                              @mario64
                              0;255;3;0;2;2.1.1
                              zboblamontZ
                              zboblamontZ
                              zboblamont
                              @mario64
                              That is normal, if you use the Log Parser (Search) you will understand the message...
                              Domoticz does that with nodes "S_ARDUINO_REPEATER_NODE", no need to worry....
                              • bjacobseB
                                bjacobseB
                                bjacobse
                                maybe trying to use an "older" version for BOTH serial gateway and node. remember for the node to use the special sketch that erases/clear eeprom, as it contains the node id given from the gateway.
                                I
                                m out of good ideas
                                  I
                                  m out of good ideas
                                  Mario64
                                  Thanks. I will try with an older version. If you would share known "mix" of software working together, it would be good to start with. I mean" Arduino IDE/MySensors/Domoticz. ?
                                    @mario64
                                    Mario64
                                    @zboblamont
                                    So, gateway works as repeater by default? I also expected that on reset, whole initial sequence should appear, not just 0;255;3;0;2;2.1.1.
                                    • M Mario64
                                      @zboblamont
                                      zboblamontZ
                                      zboblamontZ
                                      zboblamont
                                      @mario64 It does not work as a repeater, it registers via Domoticz as a node with a child ID of 255 (Internal effectively) under Setup/Hardware/Nodes, sometimes listed as a Repeater.
                                      It baffled me originally as I have no repeaters nor a need for them, but that is what Domoticz does. Since you can activate which child sensors are active under Domoticz, you can simply ignore them anyway.
                                      Not sure if you have figured this out yet without reading back to confirm it, but until you send a sensor reading after presentation the device will not show up within Domoticz and remains in the background....
