  3. [SOLVED] I use serial GW 2.1.1 and my sensor node won't connect
26 Posts 6 Posters 8.0k Views 4 Watching
  • bjacobseB bjacobse
    @zboblamont
    I used the "original sketch and only updated the #define MY_RF24_PA_LEVEL RF24_PA_MAX
    * LEDs (OPTIONAL):
    * - To use the feature, uncomment any of the MY_DEFAULT_xx_LED_PINs
    // RF24_PA_MIN RF24_PA_LOW RF24_PA_HIGH RF24_PA_MAX
    // Enable serial gateway
    #define MY_GATEWAY_SERIAL
    #if F_CPU == 8000000L
    #define MY_BAUD_RATE 38400
    // Enable inclusion mode
    // Set blinking period
    // Flash leds on rx/tx/err
    zboblamontZ
    zboblamontZ
    zboblamont
    @bjacobse Ok, not experienced enough to offer any further suggestions as still fumbling my own way,...
    In my own setup it is standardised on RFM69 radio modules, and the Nework ID is defined at the Gateway and Node, the Node ID is defined at the Node.
    • tbowmoT
      tbowmoT
      tbowmo
      @bjacobse
      As a start, you could shut down the domoticz instance, and connect a terminal program directly to your serial port instead. Then power cycle a few nodes, while recording the output from the gateway.
      at the same time, if you could capture the serial output from the power up sequence / first transmission of one of the nodes.
      bjacobseB 1 Reply Last reply
      • tbowmoT tbowmo
        @bjacobse
        bjacobseB
        bjacobseB
        bjacobse
        @tbowmo
        Thank you Thomas for good ideas :-) I will try this when I get time within a few days
        • bjacobseB
          bjacobseB
          bjacobse
          Gateway startup
          0;255;3;0;9;TSM:INIT
          0;255;3;0;9;TSF:WUR:MS=0
          0;255;3;0;9;TSM:INIT:TSP OK
          0;255;3;0;9;TSM:INIT:GW MODE
          0;255;0;0;18;2.1.1
          0;255;3;0;9;MCO:BGN:STP
          • bjacobseB
            bjacobseB
            bjacobse
            Finally I got it, as I have used same hw configuration for ver1.5.4 as for ver 2.1.1 I did not expect any power issues...
            a hint for debugging in consol mode linux then use screen
            apt-get install screen
            then use like this, note that I use udev to always get Domoticz to use correct ttyUSBx, as I have several USB devices attached attached
            sudo screen /dev/ttyUSB-mysensor 115200
            to kill screen CTRL-a then k and y for confirm
            Then I realised that if I use gateway sketch un-modified it is working, and Domoticz is providing node id, (If Domotics is set to allow new sensors, in settings)
            So when I change on the PA_LEVEL_HIGH or PA_LEVEL_MAX and use more power consumption, apparently the gateway isn't working. I do have a amplified PA RF24L01 moduleboard.
            It's working when set as default PA_LEVEL_LOW
            //#define MY_RF24_PA_LEVEL RF24_PA_MAX
            I might have to look into a power USB hub ;-)
            Thank you guys for providing input to solve my issue
              mckvack
              I too had problems with my GW resetting.
              I use custom designed PCBs with Atmega328p-au using the internal oscillator. With some nodes the GW will reset when I turn them on. Sometimes changing to another NRF-module solved it but this time none of my NRF-modules worked so I searched and found this thread. Flashed the GW with v2.2.0-rc.2 and now all my problems are gone.
                Mario64
                I've got across similar problem. What works for you doesn't solve problem in my case.
                Decreasing power to PA_LEVEL_LOW or switching to MySensors v2.2.0-rc.2 gives no positive result.
                I have some experience with Arduino, but it is my first try with MySensors and Domoticz.
                If someone could advice how to cope with, thank you in advance.
                My Hardware:
                Arduino Nano, NRF21+ for GW & Node,
                the node is simple actuator: relay with button.
                GW output on Serial monitor:
                0;255;0;0;18;2.1.1
                Node output on Serial Monitor:
                0 MCO:BGN:INIT REPEATER,CP=RNNRA--,VER=2.1.1
                3 TSM:INIT
                4 TSF:WUR:MS=0
                11 TSM:INIT:TSP OK
                13 TSM:FPAR
                15 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                2023 !TSM:FPAR:NO REPLY
                2025 TSM:FPAR
                2027 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                4035 !TSM:FPAR:NO REPLY
                4037 TSM:FPAR
                4039 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                6047 !TSM:FPAR:NO REPLY
                6049 TSM:FPAR
                6051 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                8060 !TSM:FPAR:FAIL
                8061 TSM:FAIL:CNT=1
                8064 TSM:FAIL:PDT
                18067 TSM:FAIL:RE-INIT
                18069 TSM:INIT
                18076 TSM:INIT:TSP OK
                18078 TSM:FPAR
                18080 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                20088 !TSM:FPAR:NO REPLY
                20090 TSM:FPAR
                20092 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                22102 !TSM:FPAR:NO REPLY
                22104 TSM:FPAR
                22106 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                24114 !TSM:FPAR:NO REPLY
                24116 TSM:FPAR
                24118 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                26126 !TSM:FPAR:FAIL
                26127 TSM:FAIL:CNT=2
                26129 TSM:FAIL:PDT
                etc...
                Scratches:
                //Gateway
                #define MY_INCLUSION_MODE_DURATION 120
                Node:
                #define MY_REPEATER_FEATURE
                #include <MyConfig.h>
                #define RELAY_PIN  4  // Arduino Digital I/O pin number for relay
                #define BUTTON_PIN  5  // Arduino Digital I/O pin number for button
                #define CHILD_ID 10   // Id of the sensor (child)
                #define RELAY_ON 1
                #define RELAY_OFF 0
                Bounce debouncer = Bounce();
                int oldValue=0;
                bool state;
                  // Setup the button
                  pinMode(BUTTON_PIN,INPUT);
                  // Setup debouncer
                  debouncer.attach(BUTTON_PIN);
                  debouncer.interval(5);
                  // set relay on when starting up
                  pinMode(RELAY_PIN, OUTPUT);
                  state=true;
                  digitalWrite(RELAY_PIN, RELAY_ON);
                void presentation()  {
                  present(CHILD_ID, S_LIGHT);
                  debouncer.update();
                  // Get the update value
                  int value = debouncer.read();
                  if (value != oldValue && value==0) {
                      send(msg.set(state?false:true), true); // Send new state and request ack back
                      Serial.println("zmiana value na 0");
                      // Change relay state localy, anyway
                      state = !state;
                      Serial.print("state = ");
                      Serial.println(state);
                  oldValue = value;
                  if (message.isAck()) {
                     state = message.getBool();
                • M Mario64
                  My Hardware:
                  0;255;0;0;18;2.1.1
                  3 TSM:INIT
                  4 TSF:WUR:MS=0
                  11 TSM:INIT:TSP OK
                  13 TSM:FPAR
                  2025 TSM:FPAR
                  4037 TSM:FPAR
                  6049 TSM:FPAR
                  8060 !TSM:FPAR:FAIL
                  8061 TSM:FAIL:CNT=1
                  8064 TSM:FAIL:PDT
                  18069 TSM:INIT
                  18078 TSM:FPAR
                  20090 TSM:FPAR
                  22104 TSM:FPAR
                  24116 TSM:FPAR
                  26129 TSM:FAIL:PDT
                  etc...
                  Scratches:
                  //Gateway
                  Node:
                  #define RELAY_ON 1
                  #define RELAY_OFF 0
                  int oldValue=0;
                  bool state;
                    // Setup the button
                    // Setup debouncer
                    state=true;
                    debouncer.update();
                        state = !state;
                    oldValue = value;
                  bjacobseB
                  bjacobseB
                  bjacobse
                  @mario64
                  Which home automation system are you using?
                  If using domoticz, then it's vital to accept new sensors, you find it setup->settings
                  Hardware/Devices:
                  Accept new Hardware Devices
                  if this is disabled, no sensors are allowed to be created
                    @mario64
                    Hardware/Devices:
                    Mario64
                    wrote on last edited by Mario64
                    Hi @bjacobse,
                    thank you for answer. I'm back to my project after e few days.
                    Actually, the "Accept new Hardware Devices" switch is on. I also used the "Alow for 5 minutes" button. Let me share more details:
                    • pls find log of Domoticz:
                     2018-01-22 09:55:34.871 MySensors: retrying in 30 seconds...
                    2018-01-22 09:56:00.874 MySensors: Serial Worker stopped...
                    2018-01-22 09:56:11.130 New sensors allowed for 5 minutes...
                    2018-01-22 09:56:43.077 MySensors: Using serial port: /dev/ttyUSB0
                    2018-01-22 10:02:38.123 MySensors: Serial Worker stopped...
                    2018-01-22 10:02:39.134 MySensors: Using serial port: /dev/ttyUSB0
                    2018-01-22 10:03:38.156 New sensors allowed for 5 minutes...
                    2018-01-22 10:04:00.048 Error: Gwx hardware (2) nothing received for more than 1 Minute!....
                    2018-01-22 10:04:01.049 Error: Restarting: Gwx
                    2018-01-22 10:04:01.146 MySensors: Serial Worker stopped...
                    2018-01-22 10:04:02.157 MySensors: Using serial port: /dev/ttyUSB0
                    2018-01-22 10:05:30.219 Error: Gwx hardware (2) nothing received for more than 1 Minute!....
                    2018-01-22 10:05:31.220 Error: Restarting: Gwx
                    2018-01-22 10:05:32.170 MySensors: Serial Worker stopped...
                    2018-01-22 10:05:33.181 MySensors: Using serial port: /dev/ttyUSB0
                    2018-01-22 10:07:00.204 Error: Gwx hardware (2) nothing received for more than 1 Minute!....
                    etc
                    • screen shots:
                    • list itemSetup->Hardware:
                      ![Gateway settings]https://drive.google.com/file/d/1NjJZMlaM98XaZ-UCY93pyeHcKbT7ZZoh/view?usp=sharing
                    • list itemSetup->Hardware Gwx setup:
                      ![Gwx Setup]https://drive.google.com/file/d/1vDVDcLGaGK_g3-uYQrl_DnlHlbvjq87Z/view?usp=sharing
                    • list itemSetup->Settings:
                      ![Domoticz Settings]https://drive.google.com/file/d/15bkfnHx6rEcqRnTvLVOydwPK63dy83xe/view?usp=sharing
                    • M Mario64
                      Hi @bjacobse,
                      etc
                      • screen shots:
                      Mario64
                      @mario64
                      one update information (Gateway)
                      when I press reset button on Arduino Nano board, I get one additional line on serial monitor:
                      0;255;3;0;2;2.1.1
                      and on domoticz HW setup screen, I get one children of node with name: S_ARDUINO_REPEATER_NODE. see screenshot:
                      ![ ]https://drive.google.com/file/d/1Pjqy7XKA5V9nZYmP90V8hR-pfDy26hc8/view?usp=sharing
                      • M Mario64
                        @mario64
                        0;255;3;0;2;2.1.1
                        zboblamontZ
                        zboblamontZ
                        zboblamont
                        @mario64
                        That is normal, if you use the Log Parser (Search) you will understand the message...
                        Domoticz does that with nodes "S_ARDUINO_REPEATER_NODE", no need to worry....
                        • bjacobseB
                          bjacobseB
                          bjacobse
                          maybe trying to use an "older" version for BOTH serial gateway and node. remember for the node to use the special sketch that erases/clear eeprom, as it contains the node id given from the gateway.
                          I
                          m out of good ideas
                            I
                            m out of good ideas
                            Mario64
                            Thanks. I will try with an older version. If you would share known "mix" of software working together, it would be good to start with. I mean" Arduino IDE/MySensors/Domoticz. ?
                            • zboblamontZ zboblamont
                              @mario64
                              Mario64
                              @zboblamont
                              So, gateway works as repeater by default? I also expected that on reset, whole initial sequence should appear, not just 0;255;3;0;2;2.1.1.
                              • M Mario64
                                @zboblamont
                                zboblamontZ
                                zboblamontZ
                                zboblamont
                                @mario64 It does not work as a repeater, it registers via Domoticz as a node with a child ID of 255 (Internal effectively) under Setup/Hardware/Nodes, sometimes listed as a Repeater.
                                It baffled me originally as I have no repeaters nor a need for them, but that is what Domoticz does. Since you can activate which child sensors are active under Domoticz, you can simply ignore them anyway.
                                Not sure if you have figured this out yet without reading back to confirm it, but until you send a sensor reading after presentation the device will not show up within Domoticz and remains in the background....
