  3. Multiple interuppts: One Arduino with two door sensors?
interruptdoor sensors
28 Posts 7 Posters 23.1k Views 4 Watching
  • A Offline
    A Offline
    algoritm
    wrote on last edited by algoritm
    I've been looking around the forum for a solution, but haven't found one. I have one arduino and two door/window sensors. One sensor will be on my apartments front door, while the other sensor will sit on the mailbox-slot.
    The problem is that I don't know how to get two interrupts running at the same time. So if the door opens, one interrupt should trigger. And if I get mail (and the slot opens) the second interrupt should trigger.
    I'm using an arduino pro mini 328p.
    Here's my code:
    #define CHILD_ID_DOOR 0
    #define CHILD_ID_MAIL 1
    #define DOOR_PIN  2  // Arduino Digital I/O pin for button/reed switch
    #define MAIL_PIN  3  // Arduino Digital I/O pin for button/reed switch
    #define INTERRUPT DOOR_PIN-2
    #define INTERRUPTMAIL_PIN-3
    // For lipo gauge
    #include "Arduino.h"
    #include "Wire.h"
    #include "MAX1704.h"
    MAX1704 fuelGauge;
    int oldBatteryPcnt = 0;
    unsigned long SLEEP_TIME = 86400000; // 1 day
    Bounce debouncer_door = Bounce();
    Bounce debouncer_mail = Bounce();
    int oldValue_door = -1;
    int oldValue_mail = -1;
    MyMessage msgDoor(CHILD_ID_DOOR,V_TRIPPED);
    MyMessage msgMail(CHILD_ID_MAIL,V_TRIPPED);
      // Fuel gague
      fuelGauge.reset();
      fuelGauge.quickStart();
      fuelGauge.showConfig();
      gw.begin();
      // Setup the button
      pinMode(DOOR_PIN,INPUT);
      // Activate internal pull-up
      digitalWrite(DOOR_PIN,HIGH);
      pinMode(MAIL_PIN,INPUT);
      digitalWrite(MAIL_PIN,HIGH);
      debouncer_door.attach(DOOR_PIN);
      debouncer_door.interval(5);
      debouncer_mail.attach(DOOR_PIN);
      debouncer_mail.interval(5);
      gw.present(CHILD_ID_DOOR, S_DOOR);
      gw.present(CHILD_ID_MAIL, S_DOOR);
      // Fuel gauge
      int batteryPcnt = fuelGauge.stateOfCharge();
         // Power up radio after sleep
         oldBatteryPcnt = batteryPcnt;
      // Door
      debouncer_door.update();
      // Get the update value
      int value_door = debouncer_door.read();
      if (value_door != oldValue_door) {
         // Send in the new value
         gw.send(msgDoor.set(value_door==HIGH ? 1 : 0));
         oldValue_door = value_door;
      // Mail
      debouncer_mail.update();
      int value_mail = debouncer_mail.read();
      if (value_mail != oldValue_mail) {
         gw.send(msgMail.set(value_mail==HIGH ? 1 : 0));
         oldValue_mail = value_mail;
      gw.sleep(INTERRUPT,CHANGE, SLEEP_TIME);
    I'm a bit proud to have built this into a small enclosure. Here's a photo :)
    • E Offline
      E Offline
      ericvdb
      What is the upsidedown pcb?
      A 1 Reply Last reply
      • E ericvdb
        A Offline
        A Offline
        algoritm
        @ericvdb It's a USB charger board (TP4056). The battery is connected to it via a MAX17043 LiPo Fuel Gauge which is soldered directoly onto the usb charger board.
        B 1 Reply Last reply
        • A algoritm
          B Offline
          B Offline
          BulldogLowell
          @algoritm
          try setting up the two interrupts this way...
          Test it (I compiled but didn't test) and then add in your sleep and battery stuff...
          //USING TWO INTERRUPTS
          #define DOOR_ID 3
          #define MAILBOX_ID 2
          #define DOOR_PIN  3  // Arduino Digital I/O pin for button/reed switch
          #define MAILBOX_PIN 2
          Bounce debouncer[2];
          byte oldValue[2] = {
            -1, -1};
          MyMessage msg(DOOR_ID,V_TRIPPED);
            gw.begin();
            debouncer[0] = Bounce();
            debouncer[1] = Bounce();
            // Setup the buttons and Activate internal pull-ups
            pinMode(DOOR_PIN,INPUT_PULLUP);
            pinMode(MAILBOX_PIN, INPUT_PULLUP);
            debouncer[0].attach(DOOR_PIN);
            debouncer[1].attach(MAILBOX_PIN);
            debouncer[0].interval(5);
            debouncer[1].interval(5);
            gw.present(DOOR_ID, S_DOOR);
            delay(250);
            gw.present(MAILBOX_ID, S_DOOR);
            for (byte i = 0; i < 2; i++)
              debouncer[i].update();
              if (value != oldValue[i]);
              gw.send(msg.setSensor(i).set(value == HIGH? 1 : 0), false);
              oldValue[i] = value;
          • B BulldogLowell
            @algoritm
            #define DOOR_ID 3
              -1, -1};
              gw.begin();
              delay(250);
            A Offline
            A Offline
            algoritm
            Thanks for the help @BulldogLowell!
            I read your code, and I can see that you are setting the variables smarter than I. However, I can't seem to understand where you put the interrupts. Is the sensor going to sleep?
            The actual button/triggers were not the problem. It was how to set up the interrupts.
            • hekH Offline
              hekH Offline
              wrote on last edited by hek
              Have a look at the following provided in api
              https://github.com/mysensors/Arduino/blob/master/libraries/MySensors/MySensor.h#L235
              It lets you do what you want without much problem (including attaching both interrupts).
                A Offline
                A Offline
                algoritm
                Thank you @hek! I will try and solve it now, and then show my sketch here later.
                • A algoritm
                  B Offline
                  B Offline
                  BulldogLowell
                  @algoritm
                  OK, I couldn't compile your example so I went at the problems.
                  I added your battery library and your interrupts:
                  (compiled but not tested)
                  // For lipo gauge
                  #include "Wire.h"
                  MAX1704 fuelGauge;
                  byte oldValue[2] = { -1, -1};
                  unsigned long sleepTime = 86400000UL; // 1 day
                  MyMessage msg(DOOR_PIN,V_TRIPPED);
                    // Fuel gauge
                    fuelGauge.reset();
                    gw.begin();
                    gw.present(DOOR_PIN, S_DOOR);
                    delay(250);
                    gw.present(MAILBOX_PIN, S_DOOR);
                    // Fuel gauge
                    gw.sleep(DOOR_PIN - 2, CHANGE, MAILBOX_PIN - 2, CHANGE, sleepTime);
                  • B BulldogLowell
                    @algoritm
                    // For lipo gauge
                    #include "Wire.h"
                    MAX1704 fuelGauge;
                      // Fuel gauge
                      fuelGauge.reset();
                      gw.begin();
                      delay(250);
                      // Fuel gauge
                    A Offline
                    A Offline
                    algoritm
                    Thanks @BulldogLowell for all your help! The interrupts are working now, but there is something wrong with the MyMessage function.
                    Correct me if I am wrong, but it seems like we only instantiate it for the DOOR_PIN, but not for the MAILBOX_PIN. I tried a solution similar to how you instantiate the the bounce functions, but for some reason it does not work.
                    What happens now is only one message gets sent (for the door). And it's also saying that it is always closed.
                    I can see here that you use the setSensor method to the pin numbers 0 and 1 (interrupt pins?). But shouldn't it use the pins that we declare at the top?
                    • A algoritm
                      B Offline
                      B Offline
                      BulldogLowell
                      delay(250);
                      yeah.... the device numbers need to match the for() counting:
                      gw.present(DOOR_PIN - 2, S_DOOR);
                        delay(250);
                        gw.present(MAILBOX_PIN - 2, S_DOOR);
                      that will instead create a child device zero and one
                      I think that should do it. that's what I get for not being able to test!
                      • B BulldogLowell
                        delay(250);
                          delay(250);
                        A Offline
                        A Offline
                        algoritm
                        Thanks again @BulldogLowell :)
                        I think I'm going a bit crazy over this. The problem remains. Only the data for the door is being sent (it only sends closed), but not for the mailbox. Is it because I am defining only the door in the code below?
                        • A algoritm
                          B Offline
                          B Offline
                          BulldogLowell
                          @algoritm
                          same issue, basically.
                          try this instead... you should only need one instance of MyMessage
                          MyMessage msg(0,V_TRIPPED);
                          • B BulldogLowell
                            @algoritm
                            A Offline
                            A Offline
                            algoritm
                            The problem remains @BulldogLowell . It's like the arduino is treating the two interrupts as one.
                            The sensors react when trigger them, but it's only N2S1 (door) that shows up in my gateway (EasyIoT), and it always displays the same value (closed). I'm going to go over the wiring and the code again.
                            Reading one sensor connected to one interrupt is simple... reading two seems impossible :)
                            Here's the current state of the sketch:
                            // For lipo gauge
                            #include "Wire.h"
                            MAX1704 fuelGauge;
                              // Fuel gauge
                              fuelGauge.reset();
                              // GW
                              gw.begin();
                              delay(250);
                              // Fuel gauge
                            • hekH Offline
                              hekH Offline
                              @algoritm said:
                              MyMessage msg(<sensorId>,V_TRIPPED);
                              You must report data on on two different sensor ids.
                              DOOR_PIN and MAILBOX_PIN was used during presentation so also use them when reporting values to controller.
                              The sleep function I linked returns which interrupt that was triggered. Use it to determine which sensor to report on.
                              Debouncer will probably not work if you also sleep the node.
                                A Offline
                                A Offline
                                algoritm
                                So I need to call MyMessage twice. one for each sensor ID? How do I do that without making two instances? That is kind of what I have been trying to do, but I'm having trouble with the syntax.
                                • A algoritm
                                  B Offline
                                  B Offline
                                  BulldogLowell
                                  like this?
                                  // For lipo gauge
                                  #include "Wire.h"
                                  MAX1704 fuelGauge;
                                  MyMessage msg1(DOOR_PIN - 2,V_TRIPPED);
                                  MyMessage msg0(MAILBOX_PIN - 2,V_TRIPPED);
                                    // Fuel gauge
                                    fuelGauge.reset();
                                    gw.begin();
                                    gw.present(DOOR_PIN-2, S_DOOR);
                                    delay(250);
                                    gw.present(MAILBOX_PIN-2, S_DOOR);
                                    // Fuel gauge
                                    int value0 = digitalRead(MAILBOX_PIN);
                                    int value1 = digitalRead(DOOR_PIN);
                                    gw.send(msg0.set(value0 == HIGH? 1 : 0), false);
                                    gw.send(msg1.set(value1 == HIGH? 1 : 0), false);
                                  • B BulldogLowell
                                    like this?
                                    // For lipo gauge
                                    #include "Wire.h"
                                    MAX1704 fuelGauge;
                                      // Fuel gauge
                                      fuelGauge.reset();
                                      gw.begin();
                                      delay(250);
                                      // Fuel gauge
                                    A Offline
                                    A Offline
                                    algoritm
                                    @BulldogLowell Thank you! It finally works! I'll make a sketch with comments so other people can use it later for reference.
                                    • A algoritm
                                      B Offline
                                      B Offline
                                      BulldogLowell
                                      @algoritm
                                      OK, but we should be able to do it with the sleep/wake returning the interrupt number and executing only the pin change on one child... I have to play with that if I can get this rigged.
                                      • A Offline
                                        A Offline
                                        algoritm
                                        Here's the finished script.
                                          // For lipo gauge
                                          #include "Wire.h"
                                          #define DOOR_ID 3
                                          MAX1704 fuelGauge;
                                          //MyMessage msg(DOOR_PIN,V_TRIPPED);
                                          MyMessage msg[2];
                                            // Fuel gauge
                                            fuelGauge.reset();
                                            gw.begin();
                                            // Set sensor (pin)
                                            msg[0].setSensor(DOOR_ID);
                                            msg[1].setSensor(MAILBOX_ID);
                                            // Set sensor (type)
                                            msg[0].setType(V_TRIPPED);
                                            msg[1].setType(V_TRIPPED);
                                            // Fuel gauge
                                              //if (value != oldValue[i]);
                                              gw.send(msg[i].set(value == HIGH? 1 : 0), false);
                                        • G Offline
                                          G Offline
                                          gadu
                                          How about 3 doorsensors? Just +1 on everything?
                                          B T 2 Replies Last reply
