  3. Multiple interuppts: One Arduino with two door sensors?
interruptdoor sensors
28 Posts 7 Posters 23.4k Views 4 Watching
  • A algoritm
    Thanks @BulldogLowell for all your help! The interrupts are working now, but there is something wrong with the MyMessage function.
    MyMessage msg(DOOR_PIN,V_TRIPPED);
    Correct me if I am wrong, but it seems like we only instantiate it for the DOOR_PIN, but not for the MAILBOX_PIN. I tried a solution similar to how you instantiate the the bounce functions, but for some reason it does not work.
    What happens now is only one message gets sent (for the door). And it's also saying that it is always closed.
    gw.send(msg.setSensor(i).set(value == HIGH? 1 : 0), false);
    I can see here that you use the setSensor method to the pin numbers 0 and 1 (interrupt pins?). But shouldn't it use the pins that we declare at the top?
     #define DOOR_PIN  3  // Arduino Digital I/O pin for button/reed switch
     #define MAILBOX_PIN 2
    BulldogLowellB
    BulldogLowellB
    BulldogLowell
    @BulldogLowell said:
    gw.present(DOOR_PIN, S_DOOR);
    delay(250);
    gw.present(MAILBOX_PIN, S_DOOR);
    yeah.... the device numbers need to match the for() counting:
    gw.present(DOOR_PIN - 2, S_DOOR);
      delay(250);
      gw.present(MAILBOX_PIN - 2, S_DOOR);
    that will instead create a child device zero and one
    I think that should do it. that's what I get for not being able to test!
    A 1 Reply Last reply
      delay(250);
        delay(250);
      algoritm
      Thanks again @BulldogLowell :)
      I think I'm going a bit crazy over this. The problem remains. Only the data for the door is being sent (it only sends closed), but not for the mailbox. Is it because I am defining only the door in the code below?
      • A algoritm
        BulldogLowellB
        BulldogLowellB
        BulldogLowell
        @algoritm
        same issue, basically.
        try this instead... you should only need one instance of MyMessage
        MyMessage msg(0,V_TRIPPED);
          @algoritm
          algoritm
          wrote on last edited by algoritm
          The problem remains @BulldogLowell . It's like the arduino is treating the two interrupts as one.
          The sensors react when trigger them, but it's only N2S1 (door) that shows up in my gateway (EasyIoT), and it always displays the same value (closed). I'm going to go over the wiring and the code again.
          Reading one sensor connected to one interrupt is simple... reading two seems impossible :)
          Here's the current state of the sketch:
          //USING TWO INTERRUPTS
          // For lipo gauge
          #include "Arduino.h"
          #include "Wire.h"
          #include "MAX1704.h"
          MAX1704 fuelGauge;
          int oldBatteryPcnt = 0;
          Bounce debouncer[2];
          byte oldValue[2] = { -1, -1};
          unsigned long sleepTime = 86400000UL; // 1 day
            // Fuel gauge
            fuelGauge.reset();
            // GW
            gw.begin();
            debouncer[0] = Bounce();
            debouncer[1] = Bounce();
            // Setup the buttons and Activate internal pull-ups
            pinMode(DOOR_PIN,INPUT_PULLUP);
            pinMode(MAILBOX_PIN, INPUT_PULLUP);
            debouncer[0].attach(DOOR_PIN);
            debouncer[1].attach(MAILBOX_PIN);
            debouncer[0].interval(5);
            debouncer[1].interval(5);
            delay(250);
            // Fuel gauge
            int batteryPcnt = fuelGauge.stateOfCharge();
            if (oldBatteryPcnt != batteryPcnt)
               oldBatteryPcnt = batteryPcnt;
            for (byte i = 0; i < 2; i++)
              debouncer[i].update();
              if (value != oldValue[i]);
              oldValue[i] = value;
            gw.sleep(DOOR_PIN - 2, CHANGE, MAILBOX_PIN - 2, CHANGE, sleepTime);
            wrote on last edited by hek
            @algoritm said:
            MyMessage msg(<sensorId>,V_TRIPPED);
            You must report data on on two different sensor ids.
            DOOR_PIN and MAILBOX_PIN was used during presentation so also use them when reporting values to controller.
            The sleep function I linked returns which interrupt that was triggered. Use it to determine which sensor to report on.
            Debouncer will probably not work if you also sleep the node.
              algoritm
              So I need to call MyMessage twice. one for each sensor ID? How do I do that without making two instances? That is kind of what I have been trying to do, but I'm having trouble with the syntax.
              • A algoritm
                BulldogLowellB
                BulldogLowellB
                BulldogLowell
                like this?
                // For lipo gauge
                #include "Wire.h"
                MAX1704 fuelGauge;
                MyMessage msg1(DOOR_PIN - 2,V_TRIPPED);
                MyMessage msg0(MAILBOX_PIN - 2,V_TRIPPED);
                  // Fuel gauge
                  fuelGauge.reset();
                  fuelGauge.quickStart();
                  fuelGauge.showConfig();
                  gw.begin();
                  gw.present(DOOR_PIN-2, S_DOOR);
                  delay(250);
                  gw.present(MAILBOX_PIN-2, S_DOOR);
                  // Fuel gauge
                  int value0 = digitalRead(MAILBOX_PIN);
                  int value1 = digitalRead(DOOR_PIN);
                  gw.send(msg0.set(value0 == HIGH? 1 : 0), false);
                  gw.send(msg1.set(value1 == HIGH? 1 : 0), false);
                  like this?
                  // For lipo gauge
                  #include "Wire.h"
                  MAX1704 fuelGauge;
                    // Fuel gauge
                    fuelGauge.reset();
                    gw.begin();
                    delay(250);
                    // Fuel gauge
                  algoritm
                  @BulldogLowell Thank you! It finally works! I'll make a sketch with comments so other people can use it later for reference.
                  • A algoritm
                    BulldogLowellB
                    BulldogLowellB
                    BulldogLowell
                    @algoritm
                    OK, but we should be able to do it with the sleep/wake returning the interrupt number and executing only the pin change on one child... I have to play with that if I can get this rigged.
                    • A
                      algoritm
                      Here's the finished script.
                        // For lipo gauge
                        #include "Wire.h"
                        #define DOOR_ID 3
                        #define MAILBOX_ID 2
                        MAX1704 fuelGauge;
                        //MyMessage msg(DOOR_PIN,V_TRIPPED);
                        MyMessage msg[2];
                          // Fuel gauge
                          fuelGauge.reset();
                          gw.begin();
                          // Set sensor (pin)
                          msg[0].setSensor(DOOR_ID);
                          msg[1].setSensor(MAILBOX_ID);
                          // Set sensor (type)
                          msg[0].setType(V_TRIPPED);
                          msg[1].setType(V_TRIPPED);
                          gw.present(DOOR_ID, S_DOOR);
                          gw.present(MAILBOX_ID, S_DOOR);
                          // Fuel gauge
                            //if (value != oldValue[i]);
                            gw.send(msg[i].set(value == HIGH? 1 : 0), false);
                      • gaduG
                        gaduG
                        gadu
                        How about 3 doorsensors? Just +1 on everything?
                        BulldogLowellB tbowmoT 2 Replies Last reply
                        • gaduG gadu
                          BulldogLowellB
                          BulldogLowellB
                          BulldogLowell
                          #21
                          @gadu
                          there are two external interrupts on most Arduino... but Mega has six.
                          so yes, you can extend the code above if you have the right hardware.
                          but... @hek 's library may not support more than two.
                          • gaduG gadu
                            tbowmoT
                            tbowmoT
                            tbowmo
                            You could make an or gate, with a couple of diodes, then you only only need 1 interrupt pin. If you need to check which one of the reed switches was triggered, you could wire each of them to a separate input on the arduino as well as the input to the or gate.
                            • A
                              algoritm
                              I found this example file to work much better. The battery drained a lot slower.
                                // Interrupt driven binary switch example with dual interrupts
                                // Author: Patrick 'Anticimex' Fallberg
                                // Connect one button or door/window reed switch between
                                // digitial I/O pin 3 (BUTTON_PIN below) and GND and the other
                                // one in similar fashion on digital I/O pin 2.
                                // This example is designed to fit Arduino Nano/Pro Mini
                                // For lipo gauge
                                #include "Wire.h"
                                MAX1704 fuelGauge;
                                #define SKETCH_MAJOR_VER "1"
                                #define SKETCH_MINOR_VER "0"
                                #define PRIMARY_CHILD_ID 3
                                #define SECONDARY_CHILD_ID 4
                                MySensor sensor_node;
                                  sensor_node.begin();
                                  // Activate internal pull-ups
                                  sensor_node.present(PRIMARY_CHILD_ID, S_DOOR);
                                  sensor_node.present(SECONDARY_CHILD_ID, S_DOOR);
                                  uint8_t value;
                                  static uint8_t sentValue=2;
                                  static uint8_t sentValue2=2;
                                  sensor_node.sleep(5);
                                  if (value != sentValue) {
                                     sentValue = value;
                                  if (value != sentValue2) {
                                     sentValue2 = value;
                                  // Fuel gauge
                                     sensor_node.sendBatteryLevel(batteryPcnt);
                                @algoritm said:
                                TP4056
                                Ok, need to have one of these to play with myself.
                                We should probably have an example of using it distributed with the MySensors library. Might steal something from the code posted here.
                                  @algoritm said:
                                  TP4056
                                  algoritm
                                  @hek They are great and very cheap. Just make sure you get the latest version of the board (the one with the micro-usb). 10pcs for $7 on Ebay.
                                  hekH 1 Reply Last reply
                                  • A algoritm
                                    @algoritm
                                    But the one you linked didn't have any I2C interface. How about this?
                                    http://www.ebay.com.au/itm/Detection-Alarm-Module-A-D-Conversion-IIC-MAX17043-New-LiPo-Fuel-Gauge-Battery-/400749711661?
                                      @algoritm
                                      algoritm
                                      @hek The TP4056 is the charger module. I didn't know you meant the fuel gauge. They are two separate boards which I solder together to one part. :)
                                      • Paul AugustoP
                                        Paul AugustoP
                                        Paul Augusto
                                        2 part video showing how to tie the TP4056 and MAX17043 boards together and to an arduino pro mini.
                                        Part 1:
                                        https://www.youtube.com/watch?v=3yHRrPDczK4
                                        Part 2:
                                        https://www.youtube.com/watch?v=ZtkIDwkrc6E
