  3. 6/8 Buttons battery remote node
53 Posts 7 Posters 12.3k Views 8 Watching
    Would it still be able to trigger interrupt even with all those resistors?
    @gohan said in 6/8 Buttons battery remote node:
    Try it. I don't see a problem with it, but if it were a problem, you'd just reduce all the resistor values proportionately.
      The nice thing is that since you'd be measuring the voltage relative to the voltage powering your arduino/mcu, even if the battery voltage were to decrease, you'd still get the correct value for the button pressed.
        Well, on an arduino, you could wire it to both the IRQ pin and an analog pin (see above schematic). On an nRF52832, you'd need only one pin.
        dbemowskD
        dbemowskD
        @neverdie said in 6/8 Buttons battery remote node:
        Slightly off topic question. On the nRF5's, can any pin act as an interrupt?
        • dbemowskD dbemowsk
          @dbemowsk said in 6/8 Buttons battery remote node:
          IIRC, any GPIO can. I can't think of any exceptions. So, notionally, you would wake from the interrupt pin, then change it to be an analog pin and read the voltage from that.
            Here it is notionally for 4 buttons:
            It's a voltage divider. Structured like this, it could trigger the IRQ pin when a button is pushed, and the analog pin could read the voltage to determine which button it was.
            I made a custom PCB to test the concept:
              Tomorrow I'll try to bring out the arduino numeric keypad and an old sketch I used with it and see what I can do
                Cool! I didn't know there was an official Arduino keypad.
                Here's mine:
                  It works. Connecting the output wires to A0 and D3, and running this script:
                  #include <avr/sleep.h>
                  void wake ()
                    // cancel sleep as a precaution
                    sleep_disable();
                    // precautionary while we do other stuff
                    detachInterrupt (1);
                  }  // end of wake
                    pinMode(A0,INPUT);
                    Serial.flush();
                    uint16_t voltage;
                    set_sleep_mode (SLEEP_MODE_PWR_DOWN);
                    sleep_enable();
                    // Do not interrupt before we go to sleep, or the
                    // ISR will detach interrupts and we won't wake.
                    noInterrupts ();
                    // will be called when pin D2 goes low
                    attachInterrupt (1, wake, RISING);  //pin D3
                    EIFR = bit (INTF1);  // clear flag for interrupt 1
                    // turn off brown-out enable in software
                    // BODS must be set to one and BODSE must be set to zero within four clock cycles
                    MCUCR = bit (BODS) | bit (BODSE);
                    // The BODS bit is automatically cleared after three clock cycles
                    MCUCR = bit (BODS);
                    // We are guaranteed that the sleep_cpu call will be done
                    // as the processor executes the next instruction after
                    // interrupts are turned on.
                    interrupts ();  // one cycle
                    sleep_cpu ();   // one cycle
                    delay(100);  //debounce the button
                    voltage=analogRead(A0);
                    if (voltage>0) {
                      Serial.println(voltage);
                      Serial.flush();
                  on a 3.3v Arduino pro mini yields these values for each of the four buttons:
                  Starting...
                  1023
                  930
                  852
                  787
                  The pro mini sleeps until one of the buttons gets pressed, then it wakes up, reads the value, displays the value, and then goes back to sleep. :)
                    #21
                    It * might* get a little hairy though if running at 1.8v and you've got a lot of buttons to disambiguate and you still want to wake up on any button press. According to Table 32-2 of the atmega328p datasheet, the minimum threshold for input HIGH if running at vcc=1.8v-2.4v is 0.7Vcc. So, at the limit, that is 0.7*1.8v=1.26v. So, if n is the number of buttons, you need to disambiguate, then in a perfect world 0.54/(n-1) volts separates each button press. So, if say 12 buttons, that is 0.54/11=0.049 volts. Well, let's see: resolution is 1.8v/1023=0.0018v.
                    Hmm... Again, in a perfect world, that's 27 analog read units separating each button press. In an imperfect world, that's not a lot of headroom for disambiguation. I guess in the worst case you might have to run a one-time calibration for each button and store it in EEPROM. I would hope to avoid such a calibration step, but it might come to that.
                      I am planning to use a LiFePO4 3.4V battery anyway, so it will be difficult to go even below 2.8V as that would mean battery almost empty.
                        zboblamontZ
                        zboblamontZ
                        zboblamont
                        @neverdie Is this not an instance where a high efficiency low dropout booster supply would null this particular issue?
                        • zboblamontZ zboblamont
                          @zboblamont said in 6/8 Buttons battery remote node:
                          Yes, that trade-off would relax the constraints.
                          But so does a one-time calibration. Since writing the above, I've warmed up to the idea. At least for my purposes, it's not that big a deal.
                          Nca78N 1 Reply Last reply
                            What about resistance variation due to temperature changes ? :)
                            • Nca78N Nca78
                              @nca78 said in 6/8 Buttons battery remote node:
                              I hadn't really thought about that. Should I? In my case (12 buttons on a remote control) I'm assuming the resistors stay more or less room temperature.
                                It would depend on the quality of your resistors, and if your room temperature varies. Cheap carbon film resistors can have relatively wide temperature coefficient variation range, I see over 1000ppm/°C between min and max of range for some "branded" resistors on Arrow.com so it could be worse with cheap aliexpress versions. So if you're unlucky you could get resistors in the two opposite parts of the range. With 27 units on average on a 1024 max value you have an average 27000ppm margin, so you should be ok if your keyboard stays inside, but it could become a problem if it's outside, a 30°C variation between summer and winter could in theory give your wrong results.
                                But I suppose I'm really nitpicking here, you would need to be really unlucky with your resistors :D
                                  Since values are a bit far apart, I could make a range of values to be considered a specific key pressed.
                                    #29
                                    @gohan Exactly right.
                                    @gohan Does the Arduino keypad that you already have work on the same principle?
                                    Presently I'm doing the layout on a 3x4 matrix keypad that uses fewer resistors (using the design I referenced earlier), but which works on the same voltage dividing principle.
                                    gohanG 1 Reply Last reply
                                      @neverdie this is the one I'm talking about http://www.circuitstoday.com/interfacing-hex-keypad-to-arduino
                                      • wesW
                                        wesW
                                        wes
                                        I have the same use case (remote control with buttons to control lights/scenes).
                                        I'm planning to use some cheap RF remotes and connect a RF receiver to my RPI, which hosts both my gateway and controller.
                                        Not sure if I'll receive the codes via MySensors, or write something that talks directly to the controller (thoughts on pros/cons of each approach welcome).
                                        Of course this won't be as reliable or flexible as buttons connected to a MySensors node, but it should be enough for my needs.
                                        Further thoughts welcome :-)
                                        Blog: https://www.wes.id.au/
                                        Nodes: Arduino Pro Mini ATMega328P 3.3V 8MHz, RFM69 433MHz, Canton Power CE024 0.8-3.3V regulator & single AA battery
                                        Gateway & Controller: Raspberry Pi 3 + Home Assistant
                                        • wesW wes
                                          @wes said in 6/8 Buttons battery remote node:
                                          I think you should change the remote controls into MySensors nodes. A bit more work at the beginning but you'll probably save a lot of hair pulling, reliability etc in the long term.
