  3. 6/8 Buttons battery remote node
53 Posts 7 Posters 12.3k Views 8 Watching
    It works. Connecting the output wires to A0 and D3, and running this script:
    #include <avr/sleep.h>
    void wake ()
      // cancel sleep as a precaution
      sleep_disable();
      // precautionary while we do other stuff
      detachInterrupt (1);
    }  // end of wake
      pinMode(A0,INPUT);
      Serial.flush();
      uint16_t voltage;
      set_sleep_mode (SLEEP_MODE_PWR_DOWN);
      sleep_enable();
      // Do not interrupt before we go to sleep, or the
      // ISR will detach interrupts and we won't wake.
      noInterrupts ();
      // will be called when pin D2 goes low
      attachInterrupt (1, wake, RISING);  //pin D3
      EIFR = bit (INTF1);  // clear flag for interrupt 1
      // turn off brown-out enable in software
      // BODS must be set to one and BODSE must be set to zero within four clock cycles
      MCUCR = bit (BODS) | bit (BODSE);
      // The BODS bit is automatically cleared after three clock cycles
      MCUCR = bit (BODS);
      // We are guaranteed that the sleep_cpu call will be done
      // as the processor executes the next instruction after
      // interrupts are turned on.
      interrupts ();  // one cycle
      sleep_cpu ();   // one cycle
      delay(100);  //debounce the button
      voltage=analogRead(A0);
      if (voltage>0) {
        Serial.println(voltage);
        Serial.flush();
    on a 3.3v Arduino pro mini yields these values for each of the four buttons:
    Starting...
    1023
    930
    852
    787
    The pro mini sleeps until one of the buttons gets pressed, then it wakes up, reads the value, displays the value, and then goes back to sleep. :)
      #21
      It * might* get a little hairy though if running at 1.8v and you've got a lot of buttons to disambiguate and you still want to wake up on any button press. According to Table 32-2 of the atmega328p datasheet, the minimum threshold for input HIGH if running at vcc=1.8v-2.4v is 0.7Vcc. So, at the limit, that is 0.7*1.8v=1.26v. So, if n is the number of buttons, you need to disambiguate, then in a perfect world 0.54/(n-1) volts separates each button press. So, if say 12 buttons, that is 0.54/11=0.049 volts. Well, let's see: resolution is 1.8v/1023=0.0018v.
      Hmm... Again, in a perfect world, that's 27 analog read units separating each button press. In an imperfect world, that's not a lot of headroom for disambiguation. I guess in the worst case you might have to run a one-time calibration for each button and store it in EEPROM. I would hope to avoid such a calibration step, but it might come to that.
        I am planning to use a LiFePO4 3.4V battery anyway, so it will be difficult to go even below 2.8V as that would mean battery almost empty.
          zboblamontZ
          zboblamontZ
          zboblamont
          @neverdie Is this not an instance where a high efficiency low dropout booster supply would null this particular issue?
          • zboblamontZ zboblamont
            @zboblamont said in 6/8 Buttons battery remote node:
            Yes, that trade-off would relax the constraints.
            But so does a one-time calibration. Since writing the above, I've warmed up to the idea. At least for my purposes, it's not that big a deal.
            Nca78N 1 Reply Last reply
              @neverdie said in 6/8 Buttons battery remote node:
              What about resistance variation due to temperature changes ? :)
              • Nca78N Nca78
                @nca78 said in 6/8 Buttons battery remote node:
                I hadn't really thought about that. Should I? In my case (12 buttons on a remote control) I'm assuming the resistors stay more or less room temperature.
                  It would depend on the quality of your resistors, and if your room temperature varies. Cheap carbon film resistors can have relatively wide temperature coefficient variation range, I see over 1000ppm/°C between min and max of range for some "branded" resistors on Arrow.com so it could be worse with cheap aliexpress versions. So if you're unlucky you could get resistors in the two opposite parts of the range. With 27 units on average on a 1024 max value you have an average 27000ppm margin, so you should be ok if your keyboard stays inside, but it could become a problem if it's outside, a 30°C variation between summer and winter could in theory give your wrong results.
                  But I suppose I'm really nitpicking here, you would need to be really unlucky with your resistors :D
                    Since values are a bit far apart, I could make a range of values to be considered a specific key pressed.
                      #29
                      @gohan Exactly right.
                      @gohan Does the Arduino keypad that you already have work on the same principle?
                      Presently I'm doing the layout on a 3x4 matrix keypad that uses fewer resistors (using the design I referenced earlier), but which works on the same voltage dividing principle.
                      gohanG 1 Reply Last reply
                        @neverdie this is the one I'm talking about http://www.circuitstoday.com/interfacing-hex-keypad-to-arduino
                        • wesW
                          wesW
                          wes
                          I have the same use case (remote control with buttons to control lights/scenes).
                          I'm planning to use some cheap RF remotes and connect a RF receiver to my RPI, which hosts both my gateway and controller.
                          Not sure if I'll receive the codes via MySensors, or write something that talks directly to the controller (thoughts on pros/cons of each approach welcome).
                          Of course this won't be as reliable or flexible as buttons connected to a MySensors node, but it should be enough for my needs.
                          Further thoughts welcome :-)
                          Blog: https://www.wes.id.au/
                          Nodes: Arduino Pro Mini ATMega328P 3.3V 8MHz, RFM69 433MHz, Canton Power CE024 0.8-3.3V regulator & single AA battery
                          Gateway & Controller: Raspberry Pi 3 + Home Assistant
                          • wesW wes
                            @wes said in 6/8 Buttons battery remote node:
                            I think you should change the remote controls into MySensors nodes. A bit more work at the beginning but you'll probably save a lot of hair pulling, reliability etc in the long term.
                            • CarywinC
                              CarywinC
                              Carywin
                              You can use pin change interrupts with MySensors sleep loops with an easy hack. Here's the code I use for 4 button battery powered nodes that also report temperature and humidity using DHT a sensor. I run them from 2 AA and so far they've been running for more than 6 months without showing signs of discharge. This could be easily modified for 6 or 8 buttons.
                              // MySensors EnviroButtons
                              // Temperature and Humidity Sensor with 4 Push Buttons
                              // Battery Powered Node
                              // Don't forget to change buttons and VCC_CAL for each node
                              // Cary Wintle - July 2017
                              // MySensors configuration
                              #define SN "EnviroButtons"  // Software name
                              #define SV "0.4"            // Version number
                              #define MY_NODE_ID 6
                              #define MY_RADIO_RFM69
                              #define MY_RFM69_NETWORKID 137
                              #define MY_RFM69_ENABLE_ENCRYPTION
                              #define MY_RFM69_NEW_DRIVER
                              #define MY_RFM69_FREQUENCY RFM69_433MHZ
                              #define MY_IS_RFM69HW
                              #define EI_NOTEXTERNAL // External interrupts managed by built-in routines
                              #include <EnableInterrupt.h> // Pin-change interrupts
                              #define DHT_DATA_PIN 8
                              // Buttons
                              #define BUTTON1_PIN A1 // 5: A1 - 6: A1
                              #define BUTTON2_PIN A2 // 5: A3 - 6: A2
                              #define BUTTON3_PIN A3 // 5: A2 - 6: A3
                              #define BUTTON4_PIN A0 // 5: A0 - 6: A0
                              #define SENSOR_TEMP_OFFSET 0
                              static const uint64_t UPDATE_INTERVAL = 120000;
                              #define BAT_UPDATE_INTERVAL 720 // 24 hrs - Interval between battery updates (multiples of UPDATE_INTERVAL)
                              // VCC Calibration Values
                              // Node 5: 1128953L
                              // Node 6: 1125300L
                              #define VCC_CAL 1125300L
                              static const uint8_t FORCE_UPDATE_N_READS = 30; // After an hour
                              float lastTemp;
                              float lastHum;
                              uint8_t nNoUpdatesTemp;
                              uint8_t nNoUpdatesHum;
                              int cycleCount = BAT_UPDATE_INTERVAL; // Send battery update immediately
                              volatile byte B1Int = 0, B2Int = 0, B3Int = 0, B4Int = 0; // Interrupt button flags
                              uint32_t now;
                              MyMessage msgHum(0, V_HUM);
                              MyMessage msgTemp(0, V_TEMP);
                              MyMessage msgButtons(0, V_SCENE_ON);
                              MyMessage msgBattV(0, V_VOLTAGE);
                              DHT dht;
                                sendSketchInfo(SN,SV);
                                // Present the sensor
                                present(0, S_CUSTOM, "Temp/Humid/Buttons");
                                // Setup pins the DHT sensor is on
                                digitalWrite(6, LOW);
                                pinMode(6, OUTPUT);
                                digitalWrite(7, LOW);
                                pinMode(7, OUTPUT);
                                digitalWrite(9, HIGH);
                                pinMode(9, OUTPUT);
                                sleep(2000);
                                dht.setup(DHT_DATA_PIN); // Setup the DHT sensor
                                pinMode(BUTTON1_PIN,INPUT_PULLUP);
                                pinMode(BUTTON2_PIN,INPUT_PULLUP);
                                pinMode(BUTTON3_PIN,INPUT_PULLUP);
                                pinMode(BUTTON4_PIN,INPUT_PULLUP);
                                enableInterrupt(BUTTON1_PIN,Button1,FALLING);
                                enableInterrupt(BUTTON2_PIN,Button2,FALLING);
                                enableInterrupt(BUTTON3_PIN,Button3,FALLING);
                                enableInterrupt(BUTTON4_PIN,Button4,FALLING);
                              void Button1() {
                                B1Int++;
                                _wokeUpByInterrupt = 0xFE; // Dirty hack to get out of MySensors sleep loop
                              void Button2() {
                                B2Int++;
                              void Button3() {
                                B3Int++;
                              void Button4() {
                                B4Int++;
                                _wokeUpByInterrupt = INVALID_INTERRUPT_NUM;
                                // Power up the DHT sensor
                                // Process buttons
                                if(B1Int > 0) {
                                  send(msgButtons.set(1));
                                  B1Int = 0;
                                } else if(B2Int > 0) {
                                  send(msgButtons.set(2));
                                  B2Int = 0;
                                } else if(B3Int > 0) {
                                  send(msgButtons.set(3));
                                  B3Int = 0;
                                } else if(B4Int > 0) {
                                  send(msgButtons.set(4));
                                  B4Int = 0;
                                // Wait for the DHT sensor to init
                                sleep(2000);
                                dht.readSensor(true);
                                if (isnan(temperature)) {
                                  lastTemp = temperature;
                                  // Reset no updates counter
                                  nNoUpdatesTemp = 0;
                                  #ifdef MY_DEBUG
                                  Serial.print("T: ");
                                  nNoUpdatesTemp++;
                                byte humidity = (byte)dht.getHumidity();
                                if (humidity != lastHum || nNoUpdatesHum == FORCE_UPDATE_N_READS) {
                                  lastHum = humidity;
                                  nNoUpdatesHum = 0;
                                  #ifdef MY_DEBUG
                                  Serial.print("H: ");
                                  Serial.println(humidity);
                                  nNoUpdatesHum++;
                                if (cycleCount >= BAT_UPDATE_INTERVAL) {
                                  cycleCount = 0;
                                  int BatV = readVCC();
                                  #ifdef MY_DEBUG
                                  Serial.print("BatVR: ");
                                  Serial.println(BatV);
                                  float BatVolts = BatV / 1000.0;
                                  #ifdef MY_DEBUG
                                  Serial.print("BatV: ");
                                  Serial.println(BatVolts);
                                  send(msgBattV.set(BatVolts, 2));
                                  float BatPercent = (BatVolts - 2.8) / 0.6 * 100;
                                  if(BatPercent > 100) BatPercent = 100;
                                  #ifdef MY_DEBUG
                                  Serial.print("Bat%: ");
                                  Serial.println(BatPercent);
                                  sendBatteryLevel((int)BatPercent);
                                cycleCount++;
                                // Power down the DHT sensor
                                digitalWrite(9, LOW);
                                sleep(UPDATE_INTERVAL);
                              int readVCC() {
                                wait(2); // Wait for Vref to settle
                                int result = (high<<8) | low;
                                #ifdef MY_DEBUG
                                Serial.print("R: ");
                                Serial.println(result);
                                result = VCC_CAL / result; // Calculate Vcc (in mV); 1125300 = 1.1*1023*1000
                              dbemowskD gohanG 2 Replies Last reply
                              • CarywinC Carywin
                                // Buttons
                                // Node 5: 1128953L
                                // Node 6: 1125300L
                                float lastTemp;
                                float lastHum;
                                uint32_t now;
                                DHT dht;
                                  pinMode(6, OUTPUT);
                                  pinMode(7, OUTPUT);
                                  pinMode(9, OUTPUT);
                                  sleep(2000);
                                void Button1() {
                                  B1Int++;
                                void Button2() {
                                  B2Int++;
                                void Button3() {
                                  B3Int++;
                                void Button4() {
                                  B4Int++;
                                  // Process buttons
                                  if(B1Int > 0) {
                                    B1Int = 0;
                                    B2Int = 0;
                                    B3Int = 0;
                                    B4Int = 0;
                                  sleep(2000);
                                    nNoUpdatesTemp = 0;
                                    #ifdef MY_DEBUG
                                    nNoUpdatesTemp++;
                                    lastHum = humidity;
                                    nNoUpdatesHum = 0;
                                    #ifdef MY_DEBUG
                                    nNoUpdatesHum++;
                                    cycleCount = 0;
                                    #ifdef MY_DEBUG
                                    #ifdef MY_DEBUG
                                    #ifdef MY_DEBUG
                                  cycleCount++;
                                int readVCC() {
                                  #ifdef MY_DEBUG
                                dbemowskD
                                dbemowskD
                                @carywin Certain arduinos such as the pro minis can ONLY do interrupts on pins 2 or 3 from my understanding.
                                NeverDieN CarywinC 2 Replies Last reply
                                • CarywinC Carywin
                                  // Buttons
                                  // Node 5: 1128953L
                                  // Node 6: 1125300L
                                  float lastTemp;
                                  float lastHum;
                                  uint32_t now;
                                  DHT dht;
                                    pinMode(6, OUTPUT);
                                    pinMode(7, OUTPUT);
                                    pinMode(9, OUTPUT);
                                    sleep(2000);
                                  void Button1() {
                                    B1Int++;
                                  void Button2() {
                                    B2Int++;
                                  void Button3() {
                                    B3Int++;
                                  void Button4() {
                                    B4Int++;
                                    // Process buttons
                                    if(B1Int > 0) {
                                      B1Int = 0;
                                      B2Int = 0;
                                      B3Int = 0;
                                      B4Int = 0;
                                    sleep(2000);
                                      nNoUpdatesTemp = 0;
                                      #ifdef MY_DEBUG
                                      nNoUpdatesTemp++;
                                      lastHum = humidity;
                                      nNoUpdatesHum = 0;
                                      #ifdef MY_DEBUG
                                      nNoUpdatesHum++;
                                      cycleCount = 0;
                                      #ifdef MY_DEBUG
                                      #ifdef MY_DEBUG
                                      #ifdef MY_DEBUG
                                    cycleCount++;
                                  int readVCC() {
                                    #ifdef MY_DEBUG
                                  @carywin what is the sleep current of your node with this "interrupt hack"?
                                  CarywinC 1 Reply Last reply
                                    Here's the PCB I made for the matrix keypad:
                                    The whole thing fits on a single sided PCB. :)
                                    • dbemowskD dbemowsk
                                      @dbemowsk said in 6/8 Buttons battery remote node:
                                      IIRC, you can do interrupts from other pins too, but each is tied to a separate bank of pins, so you have to do additional testing to determine which specific pin triggered the interrupt. In the case of the voltage divider keypad, that should be no problem.
                                        #38
                                        Here's the link: https://playground.arduino.cc/Main/PinChangeInterrupt
                                        So, in this scenario, it would be:
                                        ISR (PCINT1_vect) pin change interrupt for A0 to A5
                                          Here's a revision of the earlier code so that it uses ONLY ONE PIN (namely, A0) on the Arduino. And yes, this does work on a pro mini too, because that's what I tested it on. :)
                                          //  Description:
                                          //  Use just A0 to process the 12 button keypad.
                                          //  Button press is detected by interrupt set on A0.
                                          //  Which button was pressed is determined by an analog read of A0.
                                          // Note: sleep code borrows from Nick Gammon's Schedule J
                                          // Interrupt code borrows from https://playground.arduino.cc/Main/PinChangeInterrupt
                                          void pciSetup(byte pin)
                                              *digitalPinToPCMSK(pin) |= bit (digitalPinToPCMSKbit(pin));  // enable pin
                                              PCIFR  |= bit (digitalPinToPCICRbit(pin)); // clear any outstanding interrupt
                                              PCICR  |= bit (digitalPinToPCICRbit(pin)); // enable interrupt for the group
                                          ISR (PCINT1_vect) // handle pin change interrupt for A0 to A5 here
                                               //no need to do anything beyond just waking up.
                                            pinMode(A0,INPUT);
                                            pciSetup(A0);
                                            Serial.flush();
                                            uint16_t voltage;
                                            sleep_enable();
                                            noInterrupts ();
                                            pciSetup(A0);
                                            MCUCR = bit (BODS);
                                            delay(20);  //debounce the button
                                            voltage=analogRead(A0);  //throw out this first result
                                            if (voltage>700) {
                                              Serial.flush();
