  3. Vera plugin and actuator node inclusion problem
9 Posts 3 Posters 3.2k Views 1 Watching
  • ferpandoF Offline
    ferpandoF Offline
    ferpando
    I have my sistem setup with Vera Lite and a few arduinos working.
    Today I added an actuator node. It installed the light plugin on the vera and even the relay turns on and of by the button on the vera interface.
    The problem is that even clicking on the ON buttton, it didn't show it was on. Same for the off state. It turns off the relay but doesn't show.
    If it does not showm then I assume I can't get the status in Lua code.
    Then I decided to delete the node and the light switch and add them back.
    But they never got discovered again.
    Should I reset the cmos on the node?
    And about the other problem, any one having this issue?
    Thanks in advance for any help.
    hekH 1 Reply Last reply
    • ferpandoF ferpando
      hekH Offline
      hekH Offline
      @ferpando
      The signal from your gateway is reaching actuator, but reply never reaches gateway. Are you using amplified/antenna version on gateway and vanilla radio on actuator?
      ferpandoF 1 Reply Last reply
        @ferpando
        ferpandoF Offline
        ferpandoF Offline
        ferpando
        wrote on last edited by ferpando
        @hek I', using vanilla version on both.
        Both nodes are about 50cm away.
        The fact the actuator switches on and off and the node is discovered by vera means signal is getting through.
        • hekH Offline
          hekH Offline
          Try to restart vera (not only reload) and include it again. It seems Vera remembers deleted devices even if they don't show in gui. After reset they are gone.
          • B Offline
            B Offline
            BulldogLowell
            I see from time to time that a change on the device (pushbutton) isn't updated on the vera GUI.
            I have the same problem from time to time with other devices. I am using Safari and attributed the behaviour to that, but I'm not sure since parallel to that, the pushbutton demonstrates on my VeraMate app similarly to the Safari GUI.
            Since gw.sendVariable is ack'ed (right?) could it be a gateway><vera issue?
            likewise from time to time I get the erroneous action in the other direction; setting the switch in Vera produces no status change on the sensor.
            minor but happens from time to time.
            these devices are not sleeping, FYI.
              ferpandoF Offline
              ferpandoF Offline
              ferpando
              @hek, after rebooting the light switch was discovered but not the sensor node. Now I have a working switch without a node. Wired.
              I'll try sometime to clear the cmos and reprogram.
              • B BulldogLowell
                ferpandoF Offline
                ferpandoF Offline
                ferpando
                @BulldogLowell, I also have the same problem with my veraMate app.
                I tried adding a decoupling capacitor to both radios with no change in behaviour.
                • ferpandoF Offline
                  ferpandoF Offline
                  ferpando
                  I activated debug info and this is what log looks like on the node:
                  Started sensor.
                   Relay=0, distance=1
                   Radio id stored in EEPROM was: 3
                   Relaying message back to gateway.
                   Tx: fr=3,to=0,la=3,ne=0,ci=255,mt=0,ty=17,cr=115: 1.3b3 (4b18f9f)
                   Ack: receive timeout
                   Tx: fr=3,to=0,la=3,ne=0,ci=255,mt=4,ty=7,cr=115: 0
                   Tx: fr=3,to=0,la=3,ne=0,ci=255,mt=4,ty=14,cr=202: Relay
                   Tx: fr=3,to=0,la=3,ne=0,ci=255,mt=4,ty=15,cr=248: 1.0
                   Tx: fr=3,to=0,la=3,ne=0,ci=3,mt=0,ty=3,cr=122: 1.3b3 (4b18f9f)
                   Ack: received OK
                   Tx: fr=3,to=0,la=3,ne=0,ci=3,mt=2,ty=2,cr=13:
                   Ack: received OK
                   Message available on pipe 1
                   Sent ack msg to 0
                   Rx: fr=0,to=3,la=0,ci=3,mt=3,t=2,cr=134(ok): 0
                   Message addressed for this node.
                   Sent ack msg to 0
                   Rx: fr=0,to=3,la=0,ci=3,mt=1,t=2,cr=55(ok): 1
                   Tx: fr=3,to=0,la=3,ne=0,ci=3,mt=1,ty=2,cr=28: 1
                   Incoming change for relay on pin:3, New status: 1
                   Sent ack msg to 0
                   Rx: fr=0,to=3,la=0,ci=3,mt=1,t=2,cr=80(ok): 0
                   Tx: fr=3,to=0,la=3,ne=0,ci=3,mt=1,ty=2,cr=123: 0
                   Ack: received OK
                   Incoming change for relay on pin:3, New status: 0
                   Sent ack msg to 0
                   Sent ack msg to 0
                  It seams some ack are not reaching... what can I do to fix it?
                  • ferpandoF Offline
                    ferpandoF Offline
                    ferpando
                    Hello again,
                    My sensor node had the radio module too close to the arduino so I thought it might cause interference.
                    I modified it a bit putting the radio 3-4cm away and with the antenna up and it started working like a charm.
                    The problem I have now is that I don't have a node module on vera's interface. I have only the lightswitch.
                    Ack: received OK
                    Sent ack msg to 0
                    Sent ack msg to 0
                    Ack: received OK
                    Sent ack msg to 0
                    Ack: received OK
