  3. Home Assistant
  4. Suddenly communication between gw & nodes stopped , rebooting pi sometimes solves it
36 Posts 5 Posters 6.9k Views 5 Watching
  • Richard van der PlasR
    wrote on last edited by Richard van der Plas
    Hi there, the last few days suddenly all communication stopped between the GW and nodes.
    Only thing changed is the update of Home Assistant (should not interfere with the GW in my opinion)
    after a reboot it seems that receives work correctly, but sends fail suddenly.
    using a Pi3 as GW attached is the log file of what happens.
    what could be the problem suddenly?
    https://hastebin.com/osofixubog.swift
    running version: MySensors Library v2.2.0-beta
      what radio are you using? Also you can update to the stable 2.2
        its a nrf24 PA, ill try to update to stable 2.2
        and maybey add another 4.7u, i saw in a previous post you have 2 on them
        gohanG 1 Reply Last reply
          • Richard van der PlasR Richard van der Plas
            @richard-van-der-plas are you using a 3.3v voltage regulator from the 5V pins?
              yes, we had that discussion in another post already, seems to be running now, except 1 node gives me a headache (the newly created 3.3v arduino as discussed earlier)
                the arduino side:
                53 TSF:MSG:SEND,8-8-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                2062 !TSM:FPAR:NO REPLY
                2064 TSM:FPAR
                2101 TSF:MSG:SEND,8-8-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                4108 !TSM:FPAR:NO REPLY
                4110 TSM:FPAR
                4147 TSF:MSG:SEND,8-8-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                6154 !TSM:FPAR:NO REPLY
                6156 TSM:FPAR
                6193 TSF:MSG:SEND,8-8-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                8200 !TSM:FPAR:FAIL
                8202 TSM:FAIL:CNT=1
                8204 TSM:FAIL:PDT
                the gateway side:
                TSF:MSG:READ,8-8-255,s=255,c=3,t=7,pt=0,l=0,sg=0:
                TSF:MSG:BC
                TSF:MSG:FPAR REQ,ID=8
                TSF:PNG:SEND,TO=0
                TSF:CKU:OK
                TSF:MSG:GWL OK
                !TSF:MSG:SEND,0-0-8-8,s=255,c=3,t=8,pt=1,l=1,sg=0,ft=0,st=NACK:0
                TSF:MSG:READ,4-4-0,s=255,c=3,t=24,pt=1,l=1,sg=0:1
                TSF:MSG:PINGED,ID=4,HP=1
                TSF:MSG:SEND,0-0-4-4,s=255,c=3,t=25,pt=1,l=1,sg=0,ft=0,st=OK:1
                TSF:MSG:READ,3-3-0,s=255,c=3,t=24,pt=1,l=1,sg=0:1
                TSF:MSG:PINGED,ID=3,HP=1
                TSF:MSG:SEND,0-0-3-3,s=255,c=3,t=25,pt=1,l=1,sg=0,ft=0,st=OK:1
                TSF:MSG:BC
                TSF:CKU:OK,FCTRL
                TSF:MSG:GWL OK
                  The node is not receiving the reply from the gateway. Try moving it closer to gateway, or use the lower TX power settings
                  Richard van der PlasR 1 Reply Last reply
                    @gohan weird distance is 3 meters in clear air , it was working :(
                    is has do do something with power and capacitors, connected a 3.3u one, and using a 2xaaa power supply with a DCDC stepup to 3.3 volt as in the manuals.
                    what capacitors would you advice ?
                      Try with fully charged alkaline batteries without the booster and see if it works better.
                        @gohan looks alot better indeed, powered the radio directly from the AAA batteries, and seems to work now, next step is why my voltage reading of the battery is way off :)
                          Try using a ceramic cap on the booster output. I used 10uF without issues. As an alternative get the LiFePO4 batteries, get rid of booster and use vcc library to read battery voltage
                            @gohan Small update, still weird things, everything works after a reboot, but after a short time, when toggling a switch in HA, nothing is send through the gateway?
                            receives though work fine..
                            snippet of the log, where the first sends are working, but then dead the send commands.
                            Feb  6 22:01:53 raspberrypi mysgw: TSF:MSG:READ,3-3-0,s=255,c=3,t=24,pt=1,l=1,sg=0:1
                            Feb  6 22:01:53 raspberrypi mysgw: TSF:MSG:PINGED,ID=3,HP=1
                            Feb  6 22:01:53 raspberrypi mysgw: TSF:MSG:SEND,0-0-3-3,s=255,c=3,t=25,pt=1,l=1,sg=0,ft=0,st=OK:1
                            Feb  6 22:01:55 raspberrypi mysgw: TSF:MSG:READ,5-3-0,s=255,c=3,t=24,pt=1,l=1,sg=0:2
                            Feb  6 22:01:55 raspberrypi mysgw: TSF:MSG:PINGED,ID=5,HP=2
                            Feb  6 22:01:55 raspberrypi mysgw: TSF:MSG:SEND,0-0-3-5,s=255,c=3,t=25,pt=1,l=1,sg=0,ft=0,st=OK:1
                            Feb  6 22:02:02 raspberrypi mysgw: GWT:RFC:C=0,MSG=0;255;3;0;2;
                            Feb  6 22:02:02 raspberrypi mysgw: GWT:RFC:C=0,MSG=5;2;1;0;2;0
                            Feb  6 22:02:02 raspberrypi mysgw: TSF:MSG:SEND,0-0-3-5,s=2,c=1,t=2,pt=0,l=1,sg=0,ft=0,st=OK:0
                            Feb  6 22:02:02 raspberrypi mysgw: TSF:MSG:READ,5-3-0,s=2,c=1,t=2,pt=1,l=1,sg=0:0
                            Feb  6 22:02:10 raspberrypi mysgw: TSF:MSG:READ,2-2-0,s=2,c=1,t=16,pt=0,l=1,sg=0:1
                            Feb  6 22:02:12 raspberrypi mysgw: GWT:RFC:C=0,MSG=0;255;3;0;2;
                            Feb  6 22:02:18 raspberrypi mysgw: TSF:MSG:READ,2-2-0,s=2,c=1,t=16,pt=0,l=1,sg=0:0
                            Feb  6 22:02:22 raspberrypi mysgw: GWT:RFC:C=0,MSG=0;255;3;0;2;
                            Feb  6 22:02:32 raspberrypi mysgw: GWT:RFC:C=0,MSG=0;255;3;0;2;
                            Feb  6 22:02:35 raspberrypi mysgw: TSF:MSG:READ,2-2-0,s=2,c=1,t=16,pt=0,l=1,sg=0:1
                            Feb  6 22:02:42 raspberrypi mysgw: GWT:RFC:C=0,MSG=0;255;3;0;2;
                            Feb  6 22:02:46 raspberrypi mysgw: TSF:MSG:READ,2-2-0,s=2,c=1,t=16,pt=0,l=1,sg=0:0
                            Feb  6 22:02:52 raspberrypi mysgw: GWT:RFC:C=0,MSG=0;255;3;0;2;
                            Feb  6 22:02:54 raspberrypi mysgw: TSF:MSG:READ,2-2-0,s=2,c=1,t=16,pt=0,l=1,sg=0:1
                            Feb  6 22:03:02 raspberrypi mysgw: GWT:RFC:C=0,MSG=0;255;3;0;2;
                            Feb  6 22:03:03 raspberrypi mysgw: TSF:MSG:READ,2-2-0,s=2,c=1,t=16,pt=0,l=1,sg=0:0
                            Feb  6 22:03:06 raspberrypi mysgw: TSF:MSG:READ,2-2-0,s=2,c=1,t=16,pt=0,l=1,sg=0:1
                            Feb  6 22:03:12 raspberrypi mysgw: GWT:RFC:C=0,MSG=0;255;3;0;2;
                            Feb  6 22:03:21 raspberrypi mysgw: TSF:MSG:READ,2-2-0,s=2,c=1,t=16,pt=0,l=1,sg=0:0
                            Feb  6 22:03:22 raspberrypi mysgw: GWT:RFC:C=0,MSG=0;255;3;0;2;
                            Feb  6 22:03:25 raspberrypi mysgw: TSF:MSG:READ,2-2-0,s=2,c=1,t=16,pt=0,l=1,sg=0:1
                            Feb  6 22:03:32 raspberrypi mysgw: GWT:RFC:C=0,MSG=0;255;3;0;2;
                            Feb  6 22:03:32 raspberrypi mysgw: TSF:MSG:READ,2-2-0,s=2,c=1,t=16,pt=0,l=1,sg=0:0
                            Feb  6 22:03:38 raspberrypi mysgw: TSF:MSG:READ,2-2-0,s=2,c=1,t=16,pt=0,l=1,sg=0:1
                            Feb  6 22:03:42 raspberrypi mysgw: GWT:RFC:C=0,MSG=0;255;3;0;2;
                            Feb  6 22:03:45 raspberrypi mysgw: TSF:MSG:READ,5-3-0,s=1,c=1,t=0,pt=7,l=5,sg=0:-3.06
                            Feb  6 22:03:45 raspberrypi mysgw: TSF:MSG:READ,5-3-0,s=0,c=1,t=16,pt=1,l=1,sg=0:0
                            Feb  6 22:03:52 raspberrypi mysgw: GWT:RFC:C=0,MSG=0;255;3;0;2;
                            Feb  6 22:03:53 raspberrypi mysgw: TSF:MSG:READ,2-2-0,s=2,c=1,t=16,pt=0,l=1,sg=0:0
                            Feb  6 22:03:57 raspberrypi mysgw: TSF:MSG:READ,2-2-0,s=2,c=1,t=16,pt=0,l=1,sg=0:1
                            Feb  6 22:03:58 raspberrypi mysgw: TSF:MSG:READ,3-3-0,s=3,c=1,t=0,pt=7,l=5,sg=0:1.0
                              Are you sure it's not a controller problem? Try using something else like mycontroller or myscontroller and send something to the gateway
                                @gohan is there a light weigth application to test this? or do i have to install a complete suite ?
                                wouldt be handy if there's just a way to do a SEND command on the gateway
                                  With myscontroller it is just a windows app where you can send anything you want to the gateway. Mycontroller it is just a Java program where you just launch the start script and configure a few simple parameters, nothing fancy but it is useful to have for multiple purposes.
                                    @gohan said in Suddenly communication between gw & nodes stopped , rebooting pi sometimes solves it:
                                    myscontroller
                                    yes Mycontroller works as expected :), the issue lies in HA
                                      myscontroller
                                      @gohan what i see is that the mysensors.json isnt updated with values of the different sensors on the node ?
                                      log shows:
                                      child_id 3 already exists in children of node 11, cannot add child
                                      3:26 PM /srv/homeassistant/lib/python3.5/site-packages/mysensors/__init__.py (WARNING)
                                      child_id 2 already exists in children of node 11, cannot add child
                                      child_id 1 already exists in children of node 11, cannot add child
                                      Node 11 is unknown
                                      3:25 PM /srv/homeassistant/lib/python3.5/site-packages/mysensors/__init__.py (WARNING)
                                      Small update, using the 2.1 library issues are not there so much
                                        I moved it to the home assistant section. Let's hope somebody could help you out, I'm not HA expert
                                        Richard van der PlasR Sergio RiusS 2 Replies Last reply
                                          @gohan ty
