  2. Announcements
  3. 💬 Soil Moisture Sensor
99 Posts 33 Posters 51.3k Views 32 Watching
  • M manutremo
    @dbemowsk the convention in these breadboards is that the blue rail is Gnd. You may either connect the two sides or use a Mb102 module to feed both sides at the same time. You may also choose other options.
    The capture is not showing the power feed part since it's clear enough and because what it is mainly trying to describe is the moisture measurement part which is the part seemingly causing confusion and the origin of the thread.
    dbemowskD
    dbemowskD
    @manutremo said in 💬 Soil Moisture Sensor:
    I get that, but if someone were to build that as you have diagrammed with a standard breadboard, it would not work.
    You, me and other people in here may understand that, but a newbie most likely wouldn't. When I made the comment, I was assuming that that is what you meant, but had to be sure for the newbies.
    • dbemowskD dbemowsk
      manutremo
      My posting clearly states:
      the capacitor between the middle point of the voltage divider and GND
      @dbemowsk said in 💬 Soil Moisture Sensor:
      It is not clear, at least to me, if that is to VCC or GND.
      There's only one cap in the diagram so it should be quite clear.
      @dbemowsk
      I tend to think it wouldn't work with the jumper either if built as diagrammed, since the power source would still be missing.
      Don't you think that jumper could possibly lead newbies to confusion into thinking that the power supply needs to be done in a certain way? Or would it be better to avoid overloading the diagram with information irrelevant to the concept being illustrated and just focus on the important part? Certainly a personal decision. I might be wrong but I chose "less is more".
      Even newbies getting into electronics understand that diagrams may not always show all the components specially when they are focused and intended to illustrate a specific part of the circuit. even newbies into electronics understand that a power source is always necessary even though it may not appear in the diagram. Almost anyone using a breadboard knows what those rails are, what do the colors mean and that the way to pòwer them is mostly irrelevant as long as they get the proper voltage and current. And for the newbies and the few that may not , the community here will be happy to clarify.
      I appreciate your contribution but still fail to see why the diagram is confusing and I still think it responds to its original purpose. Feel free to improve it at your convenience.
      • UL7AAjrU
        UL7AAjrU
        UL7AAjr
        Try to never try resistive sensors. It is reaaly wrong way. I try to bult few resistive. No way.
        I try to buld some inductive. Yes, it's possible, but lot of analog parts, difficult to calibrate. No way too.
        Capacitive senors is most reliable and has a simple digital schematics.
        Good luck you on your way)
        PS: here is my own sensor http://vegimatics.com/products/current/
        want do discuss - wellcome)
        raptorjrR 1 Reply Last reply
        • UL7AAjrU UL7AAjr
          raptorjrR
          raptorjrR
          raptorjr
          @ul7aajr The link isn’t working for me.
          • raptorjrR raptorjr
            @raptorjr Worked for me.
              raptorjrR
              raptorjrR
              raptorjr
              @neverdie Yes. Works today. Yesterday I got a 404 error.
              • alowhumA
                alowhumA
                alowhum
                @ul7aajr said in 💬 Soil Moisture Sensor:
                I'm currently building a sensor that uses the Chirp devices. I want to chain them together. You can get them for 4 dollars each.
                NeverDieN UL7AAjrU 2 Replies Last reply
                • alowhumA alowhum
                  @alowhum What do you mean by "chain them together"?
                  alowhumA 1 Reply Last reply
                    alowhumA
                    alowhumA
                    alowhum
                    @neverdie They support I2C. So in theory you can connect a whole bunch to a pin. I'm trying to figure out if I can detect all of them and then automatically give each a unique ID.
                    dbemowskD 1 Reply Last reply
                    • alowhumA alowhum
                      dbemowskD
                      dbemowskD
                      @alowhum I amm not sure how easy it is to change the I2C address on devices like this.
                        alowhumA
                        alowhumA
                        alowhum
                        #46
                        @dbemowsk Changing the Chirp's I2C address is very easy actually.
                        #include <I2CSoilMoistureSensor.h>
                        I2CSoilMoistureSensor sensor(0x20);
                        // connect the reset pin (5) of the Chirp to a pin on your Arduino. It will create a small reset signal. This tells the chirp it should not be a stand-alone ensor, but an I2C connected one. If it receives I1C data shortyl after a reset (few seconds), then it will understand.
                        int resetPin = 4;
                          pinMode(resetPin, OUTPUT);
                          delay(1000);
                          digitalWrite(resetPin, HIGH);       // sets the digital pin 13 on
                          delay(100);                  // waits for a second
                          digitalWrite(resetPin, LOW);        // sets the digital pin 13 off
                          delay(1000);
                          Wire.begin();
                          Serial.begin(9600);
                          sensor.begin(); // reset sensor
                          delay(1000); // give some time to boot up
                          Serial.print("I2C Soil Moisture Sensor Address: ");
                          Serial.println(sensor.getAddress(),HEX);
                          Serial.print("Sensor Firmware version: ");
                          Serial.println(sensor.getVersion(),HEX);
                          Serial.println();
                          Serial.print("Change address to 0x21 ...");
                          if (sensor.setAddress(0x21,true)) // set Sensor Address to 0x21 and reset
                            Serial.println("... DONE");
                            Serial.println("... ERROR");
                          Serial.println();
                        /*loop scans I2C bus and displays foud addresses*/
                          byte error, address;
                          int nDevices;
                          Serial.println("Scanning...");
                          nDevices = 0;
                          for(address = 1; address < 127; address++ ) {
                            // The i2c_scanner uses the return value of
                            // the Write.endTransmisstion to see if
                            // a device did acknowledge to the address.
                            Wire.beginTransmission(address);
                            error = Wire.endTransmission();
                            if (error == 0) {
                              Serial.print("I2C device found at address 0x");
                              if (address<16)
                                Serial.print("0");
                              Serial.print(address,HEX);
                              Serial.println("  !");
                              nDevices++;
                            else if (error==4) {
                              Serial.print("Unknow error at address 0x");
                              if (address<16)
                                Serial.print("0");
                              Serial.println(address,HEX);
                          if (nDevices == 0)
                            Serial.println("No I2C devices found\n");
                            Serial.println("done\n");
                          delay(3000);           // wait 5 seconds for next scan
                        The default address is 0x20. So my idea is to just keep scanning, and if I find a 0x20 Chirp, then I change its I2C address to 0x21 and higher. Repeat as necessary until all 0x20 devices are gone.
                        The only thing I'm not sure about is if this is possible. If I can pick them off one by one this way.
                        • alowhumA alowhum
                          int resetPin = 4;
                            delay(1000);
                            delay(1000);
                            Wire.begin();
                            Serial.begin(9600);
                            Serial.println();
                            Serial.println();
                            int nDevices;
                            nDevices = 0;
                              if (error == 0) {
                                if (address<16)
                                  Serial.print("0");
                                nDevices++;
                                if (address<16)
                                  Serial.print("0");
                            if (nDevices == 0)
                          dbemowskD
                          dbemowskD
                          @alowhum That is nice. Some I2C devices have it hard coded and do not allow this from my understanding.
                            alowhumA
                            alowhumA
                            alowhum
                            @dbemowsk True. But it's another reason why I think the Chirp devices are pretty great soil sensors.
                            • alowhumA alowhum
                              dbemowskD
                              dbemowskD
                              @alowhum :+1:
                              • alowhumA alowhum
                                UL7AAjrU
                                UL7AAjrU
                                UL7AAjr
                                @alowhum
                                Not sure I2C is a good idea excepting case all sensors inside one room. It can be used just for testing to make it easy. As usual RS485 used to connect any sensors to nework. And there is Modbus protocol over RS485 that enable to use not only custom sensors, but kind of devices can be usefull in automatic systems. For example pump controllers, valve controllers....
                                So.. no good perspecrives to go
                                • alowhumA
                                  alowhumA
                                  alowhum
                                  Well, the Chirp doesn't support that protocol, so..
                                  It does have a mini arduino inside. Perhaps you could reprogram it. Then I will happily have a look ;-)
                                  https://wemakethings.net/chirp/
                                  • UL7AAjrU
                                    UL7AAjrU
                                    UL7AAjr
                                    No reason to reprogramm. There is I2C wired outside of sensor instead of UART. And some IC necessary to drive RS485.
                                    Would be easy to use custom adapter over the sensor with only two IC on board, some MCU and MAX485 (or analog).
                                    • alowhumA
                                      alowhumA
                                      alowhum
                                      I found another, simpler sensor on Aliexpress.
                                      https://www.aliexpress.com/item/NEW-Capacitive-soil-moisture-sensor-not-easy-to-corrode-wide-voltage-wire-for-arduino/32832538686.html
                                      • R RobKuipers
                                        My two cents. A soil moisture sensor that requires no extra hardware (not counting electric wire). Highly inspired by everything I've read in this thread. Comments welcome.
                                        Excuse the long post.
                                         Created:	5/25/2017 1:04:35 PM
                                         Author:	Rob
                                         Soil moisture measuring by using stainless steel rods (or any other conductor).
                                         Probably the simplest project ever, since only a MySensors-node and some wire is needed to set things up.
                                         The sketch alternates current during measuring to prevent corrosion of the rods due to electrolyses.
                                         Odd readings may occur when starting (eg. increasing soil moisture for no apparent reason), please just allow the electrodes to settle down in the soil.
                                         No extra hardware needed.
                                         I use an Arduino Mini 3V3, powered on two AA cells. It is suggested you set the fuses for a lower Brown Out Detection (BOD). But anything goes.
                                         Just tie D4 and A0 together to one rod, and D5 and A1 to another rod. This is sensor one.
                                         For the second sensor tie D6 and A2 together to one rod, and D7 and A3 to another rod.
                                         Connect a pushbutton between GND and D3 if you need a button that makes the node report immediately (can be omitted)
                                         Measurement are taken every minute and send to the gateway if different from the previous reading.
                                         In case of no changes, the node reports itself every four hours.
                                         The output is between 0 (dry) and 100 (wet).
                                         Can also be used as a depth moisture sensor with three sensor zones; in that case use one (common) long rod and three smaller sensors along
                                         the height of the rod and configure the sketch accordingly.
                                        	 sensors[0] = { 4, A0, 5, A1, -1, false };
                                        	 sensors[1] = { 4, A0, 6, A2, -1, false };
                                        	 sensors[2] = { 4, A0, 7, A3, -1, false };
                                        #include "Header.h"
                                        // Enable debug Serial.prints to serial monitor
                                        #if defined MY_DEBUG
                                        #define Sprintln(a) (Serial.println(a))
                                        #define Sprint(a) (Serial.print(a))
                                        #define Sprintln(a)
                                        #define Sprint(a)
                                        #define MY_RADIO_RFM69
                                        #define MY_RFM69_FREQUENCY RF69_868MHZ
                                        #define MY_IS_RFM69HW
                                        // Use PA_LOW for RF24+PA (Power Amplifier)
                                        //#define MY_RF24_PA_LEVEL RF24_PA_MAX
                                        #define MY_NODE_ID 4
                                        #define ACK 0        // = false
                                        #define CHILD_ID 1
                                        #define REPORTNOWSWITCH_PIN 3    // Arduino Digital I/O pin for button/reed switch (must be an interrupt pin!)
                                        #define NUM_MOISTURE_SENSORS 2
                                        #define CHILD_ID_TEMPERATURE (CHILD_ID+NUM_MOISTURE_SENSORS+1)
                                        #define SENSOR1_ROD1_DIGITAL 4
                                        #define SENSOR1_ROD1_ANALOG A0
                                        #define SENSOR1_ROD2_DIGITAL 5
                                        #define SENSOR1_ROD2_ANALOG A1
                                        #define SENSOR2_ROD1_DIGITAL 6
                                        #define SENSOR2_ROD1_ANALOG A2
                                        #define SENSOR2_ROD2_DIGITAL 7
                                        #define SENSOR2_ROD2_ANALOG A3
                                        #define SLEEP_IN_MS 60000		// every minute a new measurement
                                        #define EVERY_15_MINUTES (3600000/4/SLEEP_IN_MS)
                                        #define EVERY_4_HOURS (3600000*4/SLEEP_IN_MS)
                                        #define NUM_READS (int)10		// Number of sensor reads for filtering
                                        int countLoops;
                                        int8_t interruptedBy = -1;
                                        int oldBatLevel;
                                        float oldTemperature;
                                        int output_value;
                                        /// Included in Header.h:
                                        //typedef struct {
                                        //	int digital_input_a;
                                        //	int analog_input_a;
                                        //	int digital_input_b;
                                        //	int analog_input_b;
                                        //	int level;
                                        //	bool connected;
                                        //} sensorWiring;
                                        sensorWiring sensors[NUM_MOISTURE_SENSORS];
                                        MyMessage msgMoistureSensor(CHILD_ID, V_LEVEL);
                                        MyMessage msgChipTemp(CHILD_ID_TEMPERATURE, V_TEMP);
                                        void before()
                                        	// All buttons as input-pullup as per ATMEGA recommendation to use less power (and more safety)
                                        	// (http://electronics.stackexchange.com/questions/43460/how-should-unused-i-o-pins-be-configured-on-atmega328p-for-lowest-power-consumpt)
                                        	for (int i = 1; i <= 8; i++)
                                        		pinMode(i, INPUT_PULLUP);
                                        	// Now explicity set pins as needed
                                        	// Setup report-now switch, activate internal pull-up
                                        	pinMode(REPORTNOWSWITCH_PIN, INPUT_PULLUP);
                                        	// Initialize sensor variables
                                        	// Connect Digital pin 4 to Analog input A0 and a metal rod
                                        	// Connect Digital pin 5 to Analog input A1 and another metal rod.
                                        	sensors[0] = { SENSOR1_ROD1_DIGITAL, SENSOR1_ROD1_ANALOG, SENSOR1_ROD2_DIGITAL, SENSOR1_ROD2_ANALOG, -1, false };
                                        	// Connect Digital pin 6 to Analog input A2 and a metal rod
                                        	// Connect Digital pin 7 to Analog input A3 and another metal rod.
                                        	sensors[1] = { SENSOR2_ROD1_DIGITAL, SENSOR2_ROD1_ANALOG, SENSOR2_ROD2_DIGITAL, SENSOR2_ROD2_ANALOG, -1, false };
                                        	for  (int i = 0; i<NUM_MOISTURE_SENSORS; i++)
                                        		sensors[i].connected = testSensorConnections(sensors[i]);
                                        	sendSketchInfo("Moisture Sensor", "1.1", ACK);
                                        	for (int i = 0; i < NUM_MOISTURE_SENSORS; i++)
                                        		if (sensors[i].connected) present(CHILD_ID+i, S_MOISTURE, ACK);
                                        	present(CHILD_ID_TEMPERATURE, S_TEMP);
                                        	bool reportNow = (interruptedBy == digitalPinToInterrupt(REPORTNOWSWITCH_PIN));
                                        	if (reportNow)
                                        		// Little trick for debouncing the switch
                                        		attachInterrupt(digitalPinToInterrupt(REPORTNOWSWITCH_PIN), debounce, RISING);
                                        		wait(500);
                                        		Sprintln(F("Report now switch pressed"));
                                        		countLoops = 0;
                                        			output_value = measure(sensors[i]);
                                        			if ((sensors[i].level != output_value) || reportNow)
                                        				sensors[i].level = output_value;
                                        				send(msgMoistureSensor.setSensor(CHILD_ID+i).set(output_value), ACK);
                                        	// Every fifteen minutes; poll temperature
                                        	if (countLoops%EVERY_15_MINUTES==0 || reportNow)
                                        		float newTemp = readTemp();
                                        		if (oldTemperature != newTemp || reportNow)
                                        			send(msgChipTemp.set(newTemp, 1), ACK);
                                        			oldTemperature = newTemp;
                                        		int batLevel = getBatteryLevel();
                                        		if ((oldBatLevel != batLevel) || reportNow) // ...but only when changed, or when button is pressed;
                                        			sendBatteryLevel(batLevel, ACK);
                                        			oldBatLevel = batLevel;
                                        	// So you know I'm alive
                                        	if (countLoops == EVERY_4_HOURS)
                                        		sendHeartbeat(ACK);
                                        		countLoops = 0;
                                        	countLoops++;
                                        	interruptedBy = sleep(digitalPinToInterrupt(REPORTNOWSWITCH_PIN), FALLING, SLEEP_IN_MS);
                                        // Connect Digital pin 'digital_input_a' to Analog input 'analog_input_a' and a metal rod,
                                        // do the same for b
                                        long measure(sensorWiring sensor)
                                        	long total = 0;
                                        	int reading_a = 0;
                                        	int reading_b = 0;
                                        	for (int i = 0; i<NUM_READS; i++) {
                                        		// Left to right
                                        		reading_a = measureOneDirection(sensor.digital_input_a, sensor.digital_input_b, sensor.analog_input_a);
                                        		// Right to left
                                        		reading_b = measureOneDirection(sensor.digital_input_b, sensor.digital_input_a, sensor.analog_input_b);
                                        		total += reading_a + reading_b;
                                        	return map(total / (2 * NUM_READS), 1023, 0, 0, 100);
                                        long measureOneDirection(int digital_input_1, int digital_input_2, int analog_input_1)
                                        	pinMode(digital_input_2, OUTPUT);
                                        	digitalWrite(digital_input_2, LOW);
                                        	pinMode(digital_input_1, INPUT_PULLUP);
                                        	delayMicroseconds(100);
                                        	long reading = analogRead(analog_input_1);
                                        	//delayMicroseconds(25);
                                        	pinMode(digital_input_1, INPUT);     // High impedance
                                        	pinMode(digital_input_2, INPUT);     // High impedance
                                        	delay(1);
                                        	Sprint(F("measureOneDirection - Reading "));
                                        	Sprintln(reading);
                                        	return reading;
                                        // test the connections of both rods of a sensor
                                        boolean testSensorConnections(sensorWiring moistureSensor)
                                        	return (testSensorConnection(moistureSensor.digital_input_a, moistureSensor.analog_input_a) && testSensorConnection(moistureSensor.digital_input_b, moistureSensor.analog_input_b));
                                        //  test if digital pin is connected to correct analog pin
                                        boolean testSensorConnection(int digital_input, int analog_input)
                                        	pinMode(digital_input, OUTPUT);
                                        	digitalWrite(digital_input, HIGH);
                                        	long reading_1 = analogRead(analog_input);
                                        	digitalWrite(digital_input, LOW);
                                        	long reading_2 = analogRead(analog_input);
                                        	pinMode(digital_input, INPUT);     // High impedance
                                        	delay(1);
                                        	Sprint(F("testSensorConnection - Reading1 "));
                                        	Sprintln(reading_1);
                                        	Sprint(F("testSensorConnection - Reading2 "));
                                        	Sprintln(reading_2);
                                        	bool correct = ((reading_1 == 1023) && (reading_2 == 0));
                                        	return correct;
                                        float readTemp()
                                        #if defined (xxMY_RADIO_RFM69) && !defined(MY_RFM69_NEW_DRIVER)
                                        	return _radio.readTemperature(-3);
                                        	// Read 1.1V reference against MUX3
                                        	return (readMUX(_BV(REFS1) | _BV(REFS0) | _BV(MUX3)) - 125) * 0.1075f;
                                        long readMUX(uint8_t aControl)
                                        	long result;
                                        	ADMUX = aControl;
                                        	delay(20); // Wait for Vref to settle
                                        	noInterrupts();
                                        	// start the conversion
                                        	ADCSRA |= _BV(ADSC) | _BV(ADIE);
                                        	set_sleep_mode(SLEEP_MODE_ADC);    // sleep during sample
                                        	interrupts();
                                        	sleep_mode();
                                        	// reading should be done, but better make sure
                                        	// maybe the timer interrupt fired
                                        	while (bit_is_set(ADCSRA, ADSC));
                                        	// Reading register "ADCW" takes care of how to read ADCL and ADCH.
                                        	result = ADCW;
                                        	return result;
                                        // Battery measure
                                        int getBatteryLevel()
                                        	int results = (readVcc() - 2000) / 10;
                                        	if (results > 100)
                                        		results = 100;
                                        	if (results < 0)
                                        		results = 0;
                                        	return results;
                                        } // end of getBandgap
                                        // when ADC completed, take an interrupt
                                        EMPTY_INTERRUPT(ADC_vect);
                                        long readVcc() {
                                        	long result;
                                        	result = readMUX(_BV(REFS0) | _BV(MUX3) | _BV(MUX2) | _BV(MUX1));
                                        	result = 1126400L / result; // Back-calculate AVcc in mV (1024 steps times 1100 mV (1.1V) = 1126400L)
                                        	return result;
                                        // Utter nonsense, but needed for attaching an interrupt to...
                                        void debounce() {
                                        ร
                                        ร
                                        รอเรือ
                                        wrote on last edited by รอเรือ
                                        #54
                                        @robkuipers
                                        Your code will fail compiling in Arduino 1.8.5 (mysensors 2.2.0) with the following errors:
                                        /mnt/data/Dropbox/UTV/Arduino/SoilMoisture/SoilMoisture.ino: In function 'void before()':
                                        /mnt/data/Dropbox/UTV/Arduino/SoilMoisture/SoilMoisture.ino:112:114: warning: extended initializer lists only available with -std=c++11 or -std=gnu++11
                                        /mnt/data/Dropbox/UTV/Arduino/SoilMoisture/SoilMoisture.ino:112:14: warning: extended initializer lists only available with -std=c++11 or -std=gnu++11
                                        /mnt/data/Dropbox/UTV/Arduino/SoilMoisture/SoilMoisture.ino:116:114: warning: extended initializer lists only available with -std=c++11 or -std=gnu++11
                                        /mnt/data/Dropbox/UTV/Arduino/SoilMoisture/SoilMoisture.ino:116:14: warning: extended initializer lists only available with -std=c++11 or -std=gnu++11
                                        So the following code need tobe changed to something valid
                                        I'm not a c++ guy so I can't tell what needs to be done. Maybe you or someone else would like to help out?
                                        Cheers!
                                        EDIT: After removing the file platform.txt for solving another problem (as suggested here) The problem above vanished. So strange. But it works now so... :sunglasses: :sunglasses: :sunglasses:
                                        • ร
                                          ร
                                          รอเรือ
                                          I've found that measuring soil moisture by the electrical resistance is not a trivial task.
                                          If the probe is put into compact soil containing no mold, you'll typically get a high reading even at very low moisture levels. It will most likely always stay within the span of 90-100%.
                                          However if the probe is put into pure mold, the readings will range between 0% to 100%.
                                          My conclusion is that measuring directly in the soil is very unpredictable. A better solution might be to surround the probe with some material that adapts the ambient humidity from whatever kind of soil it's put into.
