  3. CNC PCB milling
CNC PCB milling
933 Posts 28 Posters 809.5k Views 27 Watching
  • dbemowskD dbemowsk
    @neverdie I just printed them in PLA and they seem to slide pretty smoothly on the rods, but someone told me that printing them in nylon is better.
    #576
    It would seem so: http://www.craftechind.com/top-5-materials-for-plastic-bearings-used-on-metal-surfaces/
    If you had a multi-filament printer, I wonder if you could print the nylon bearing within another plastic piece (e.g. the part that holds the spindle to the z-axis)? That would would be pretty cool and would also save assembly time.
    dbemowskD 1 Reply Last reply
      dbemowskD
      dbemowskD
      @neverdie the way i have it designed, the printed bearings get sandwiched by a rear plate that holds the bearings and coupler nut that goes on the threaded rod to drive the assembly up and down.
      • dbemowskD
        dbemowskD
        I wasn't home before to get a pic, but here is the layout.
          #579
          Anyone tried Trinamic drivers, such as the TMC2130? They seem to produce superior 3D prints, and so I would guess they would yield some improvement for CNC as well.
          So far I've only found two boards that appear to be made for them, a ramps and a rumba:
          https://www.aliexpress.com/item/MKS-Gen-V1-4-control-board-5PCS-TMC2130-V1-0-And-Heatsink-stepper-motor-compatible-with/32836389832.html?spm=2114.search0204.3.2.3e5a8105IWdaWH&ws_ab_test=searchweb0_0,searchweb201602_5_10152_5711320_10151_10065_10344_10068_10130_10324_10342_10547_10325_10343_10546_10340_10548_10341_10545_10084_10083_10618_10630_10307_5711220_5722320_10313_10059_10534_100031_10103_10627_10626_10624_10623_10622_10621_10620_10142,searchweb201603_2,ppcSwitch_5_ppcChannel&algo_expid=875aa997-05fe-4eda-9d76-0aaefcaeff83-0&algo_pvid=875aa997-05fe-4eda-9d76-0aaefcaeff83&priceBeautifyAB=0
          https://www.aliexpress.com/item/3D-Printer-Rumba-Board-With-6pcs-TMC2130-Stepper-Driver-6pcs-Heatsink-High-Quality-3D-Printer-Parts/32839321651.html?spm=2114.search0204.3.49.3e5a8105IWdaWH&ws_ab_test=searchweb0_0,searchweb201602_5_10152_5711320_10151_10065_10344_10068_10130_10324_10342_10547_10325_10343_10546_10340_10548_10341_10545_10084_10083_10618_10630_10307_5711220_5722320_10313_10059_10534_100031_10103_10627_10626_10624_10623_10622_10621_10620_10142,searchweb201603_2,ppcSwitch_5_ppcChannel&algo_expid=875aa997-05fe-4eda-9d76-0aaefcaeff83-7&algo_pvid=875aa997-05fe-4eda-9d76-0aaefcaeff83&priceBeautifyAB=0
          I have no experience with either board, so I don't know if either would be desirable.
          The pinout of the TMC2130 is different than the A4988 driver currently used in my Woodpecker. However, I could perhaps make an adapter board to re-route the pins so as to be compatible. In that case, maybe I could plug them into my Woodpecker board. A video by Sanladerer seems to imply that might actually work:
          https://www.youtube.com/watch?v=sPvTB3irCxQ
          Note: from what I've read, the v1.1 TMC2130 modules are much better for adapting than the v1.0 modules.
            #580
            I'm unsure what kind of firmware runs on the Woodpecker board, so I have doubts whether it could exploit the Trinamic features. Anyone here know?
            So.... I'm looking at a Smoothieboard as perhaps one possibility, although I'm not sure yet as to whether Chillipepr will talkto it.
            https://www.panucatt.com/azteeg_X5_mini_reprap_3d_printer_controller_p/ax5mini.htm
              dbemowskD
              dbemowskD
              Are you looking at this for a 3D printer or for your CNC? If you are looking at it for a 3D printer, have you looked at the RAMPS 1.4 boards? I like their modular design over a fully integrated board for the simple fact that if a part dies, you are only replacing the one part and not an entire board. This make repairs cheaper if something goes wrong.
              • dbemowskD
                dbemowskD
                @NeverDie I have one more question of measurements on your CNC. If you look at the pic, can you tell me the measurements of the red and blue arrows on your machine? I have some idea of how tall I want my bracket for the red arrow area, but you were mentioning that you wish you had more travel in that area and I am curious if I have enough room.
                  @dbemowsk
                  red: 100mm
                  blue: 53mm
                  RFM69R 1 Reply Last reply
                    @dbemowsk
                    red: 100mm
                    blue: 53mm
                    RFM69R
                    RFM69R
                    RFM69
                    wrote on last edited by RFM69
                    #584
                    Perhaps slightly off topic but I wanted to share very interesting youtube channel of FRANK from Germany link text who's been working on a PCB pick and place module along with a CNC tool changer in the video above.
                    Very inginious, and clever work if you've not come accross his videos and work yet.! alt text
                    scalzS NeverDieN 3 Replies Last reply
                    • RFM69R RFM69
                      #585
                      @rfm69 said in CNC PCB milling:
                      Imho, it's certainly a fun project.. but I think you can go faster by hand ;)
                      Only a thousands more expensive machine will be faster for assembling, and they are more precise, have a lot more features (cam driven features, more feeders etc.).
                      Pick And Place is not plug and play at all :) there is lot of calibration, preparation. So it's useful and save time, only if you plan volume production. This is why there is often fees when you ask for a pcba, they spend time for calibrating each new board, parts in database etc.
                      There are multiple different diy pnp, most of them are slow, not enough precise for <0402 etc..
                      If it's for 0603 size with some dfn, low volume, you don't need this kind of investments I think.. but if you want to tinker it's fun I imagine.
                      For example, if I remember well, someone said he can assemble an easypcb in 30mn, trhough hole. Good but that's the time I need to get assembled&soldered one of my compact smd multisensors boards, no PNP, no handsoldering..
                      PNP is just for placing, it won't fix test, soldering shorts etc, that still need some agility :)
                      No need of a solder paster dispenser, I use stencils. I like freedom for placing parts, but you can also build a simple manual pick&place in case you shake when placing (no shaking here). With a good magnifier, easy! (I have a big one like dentists, + another one with a cam). Finally, the reflow oven cook it. When I need a repair/reflow -> flux + hot air or fine solder tip. Well organized, you're faster like that. Not the same, if you want to assemble 50 boards, agreed.
                      So, I've no real xp on PNP, but I'm not new at assembling smd boards. Saying this because I already digged in forums, diy builds, reviews, as I need to invest in a cnc router, and PNP this year. and I'm lucky I can talk with local professionals.. I always "try" to get a good ratio between the need/time/ROI . I'll build the cnc router, but I'll buy the PNP. there are a few interesting but it's still a few thousands dollars.
                      • RFM69R RFM69
                        @rfm69 Thanks! I've already learned something potentially very useful: instead of doing his etching with an etching bit, he uses a V spiral endmill 30 degrees. Unfortunately, he didn't say the diameter. :(
                        Interestingly, he didn't even bother with autoleveling.
                        https://www.youtube.com/watch?v=KeY3bZJbtm0
                        • RFM69R RFM69
                          @rfm69 Yes, a tool changer would be very nice to have.
                            Are you sure? What's happening from 3:25 then?
                            • YveauxY Yveaux
                              @yveaux said in CNC PCB milling:
                              You're right. I guess he edited most of it out, or else he did just a partial.
                                Looks as though StepCraft makes a tool changer that you can buy:
                                https://youtu.be/pCMdPF39Uts
                                • scalzS scalz
                                  RFM69R
                                  RFM69R
                                  RFM69
                                  @scalz Agreed... the P&P is beyond my knowledge level, but what I found fascinating in what and how he was doing the project to make something himself, how he evolved the project was very interesting.
                                  He's got something similar for a tool changer on a 3d printer which is very nicely designed... along with the software and controllers.
                                    RFM69R
                                    RFM69R
                                    RFM69
                                    @neverdie I saw this stepcraft automatic tool changer, its nice, but the design aproach of Franks is really novel, and way cheapper, simple ingenious. But my skill level is much lower, so I could be wrong :)
                                    • RFM69R RFM69
                                      @rfm69 Does he describe in detail somewhere how to make one? I mean, I get the concept, but he did a lot of work on both the hardware and the software to make it functional.
                                        RFM69R
                                        RFM69R
                                        RFM69
                                        @neverdie you mean the tool changer, yes he has a blog and git pages where he shares. Its neccessary to speed control with current limiting breaking the spindle, which he's done via cheap ebay motor controller and arduino. Same goes for the spindle locking mechanism powered by a servo. and the CNC software..
                                        Heres the git link text
                                        Heres the blog link text
                                        Its not step by step, perhaps he'll get their but I know he'll be happy if people copy, or chime in :), or add
                                          #595
                                          I noticed that Frank is apparently using carbon fiber tubing on his 3D printer. It turns out that carbon fiber tubing is an easy upgrade, if what you have already is aluminum rod:
                                          https://youtu.be/0Pg-L1pQ6qU
                                          However, its Young's modulus appears to be about 10% less than steel, which I interpret to mean that it is a bit less rigid than steel (cf https://www.christinedemerchant.com/youngmodulus.html).
                                          For the printer in the video that I linked, I can see how reduced weight may be worth the tradeoff.
                                          However, since weight isn't really much of a factor in the 2418 CNC, I think it makes sense to stick with hardened steel rods.
                                          Am I missing something? Opinions?
                                          RFM69R zboblamontZ 2 Replies Last reply
