  3. CNC PCB milling
CNC PCB milling
933 Posts 28 Posters 809.5k Views 27 Watching
  • dbemowskD
    dbemowskD
    @NeverDie I have one more question of measurements on your CNC. If you look at the pic, can you tell me the measurements of the red and blue arrows on your machine? I have some idea of how tall I want my bracket for the red arrow area, but you were mentioning that you wish you had more travel in that area and I am curious if I have enough room.
    • dbemowskD dbemowsk
      @dbemowsk
      red: 100mm
      blue: 53mm
      RFM69R 1 Reply Last reply
        @dbemowsk
        red: 100mm
        blue: 53mm
        RFM69R
        RFM69R
        RFM69
        wrote on last edited by RFM69
        #584
        Perhaps slightly off topic but I wanted to share very interesting youtube channel of FRANK from Germany link text who's been working on a PCB pick and place module along with a CNC tool changer in the video above.
        Very inginious, and clever work if you've not come accross his videos and work yet.! alt text
        scalzS NeverDieN 3 Replies Last reply
        • RFM69R RFM69
          #585
          @rfm69 said in CNC PCB milling:
          Imho, it's certainly a fun project.. but I think you can go faster by hand ;)
          Only a thousands more expensive machine will be faster for assembling, and they are more precise, have a lot more features (cam driven features, more feeders etc.).
          Pick And Place is not plug and play at all :) there is lot of calibration, preparation. So it's useful and save time, only if you plan volume production. This is why there is often fees when you ask for a pcba, they spend time for calibrating each new board, parts in database etc.
          There are multiple different diy pnp, most of them are slow, not enough precise for <0402 etc..
          If it's for 0603 size with some dfn, low volume, you don't need this kind of investments I think.. but if you want to tinker it's fun I imagine.
          For example, if I remember well, someone said he can assemble an easypcb in 30mn, trhough hole. Good but that's the time I need to get assembled&soldered one of my compact smd multisensors boards, no PNP, no handsoldering..
          PNP is just for placing, it won't fix test, soldering shorts etc, that still need some agility :)
          No need of a solder paster dispenser, I use stencils. I like freedom for placing parts, but you can also build a simple manual pick&place in case you shake when placing (no shaking here). With a good magnifier, easy! (I have a big one like dentists, + another one with a cam). Finally, the reflow oven cook it. When I need a repair/reflow -> flux + hot air or fine solder tip. Well organized, you're faster like that. Not the same, if you want to assemble 50 boards, agreed.
          So, I've no real xp on PNP, but I'm not new at assembling smd boards. Saying this because I already digged in forums, diy builds, reviews, as I need to invest in a cnc router, and PNP this year. and I'm lucky I can talk with local professionals.. I always "try" to get a good ratio between the need/time/ROI . I'll build the cnc router, but I'll buy the PNP. there are a few interesting but it's still a few thousands dollars.
          • RFM69R RFM69
            @rfm69 Thanks! I've already learned something potentially very useful: instead of doing his etching with an etching bit, he uses a V spiral endmill 30 degrees. Unfortunately, he didn't say the diameter. :(
            Interestingly, he didn't even bother with autoleveling.
            https://www.youtube.com/watch?v=KeY3bZJbtm0
            • RFM69R RFM69
              @rfm69 Yes, a tool changer would be very nice to have.
                Are you sure? What's happening from 3:25 then?
                • YveauxY Yveaux
                  @yveaux said in CNC PCB milling:
                  You're right. I guess he edited most of it out, or else he did just a partial.
                    Looks as though StepCraft makes a tool changer that you can buy:
                    https://youtu.be/pCMdPF39Uts
                    • scalzS scalz
                      RFM69R
                      RFM69R
                      RFM69
                      @scalz Agreed... the P&P is beyond my knowledge level, but what I found fascinating in what and how he was doing the project to make something himself, how he evolved the project was very interesting.
                      He's got something similar for a tool changer on a 3d printer which is very nicely designed... along with the software and controllers.
                        RFM69R
                        RFM69R
                        RFM69
                        @neverdie I saw this stepcraft automatic tool changer, its nice, but the design aproach of Franks is really novel, and way cheapper, simple ingenious. But my skill level is much lower, so I could be wrong :)
                        • RFM69R RFM69
                          @rfm69 Does he describe in detail somewhere how to make one? I mean, I get the concept, but he did a lot of work on both the hardware and the software to make it functional.
                            RFM69R
                            RFM69R
                            RFM69
                            @neverdie you mean the tool changer, yes he has a blog and git pages where he shares. Its neccessary to speed control with current limiting breaking the spindle, which he's done via cheap ebay motor controller and arduino. Same goes for the spindle locking mechanism powered by a servo. and the CNC software..
                            Heres the git link text
                            Heres the blog link text
                            Its not step by step, perhaps he'll get their but I know he'll be happy if people copy, or chime in :), or add
                              #595
                              I noticed that Frank is apparently using carbon fiber tubing on his 3D printer. It turns out that carbon fiber tubing is an easy upgrade, if what you have already is aluminum rod:
                              https://youtu.be/0Pg-L1pQ6qU
                              However, its Young's modulus appears to be about 10% less than steel, which I interpret to mean that it is a bit less rigid than steel (cf https://www.christinedemerchant.com/youngmodulus.html).
                              For the printer in the video that I linked, I can see how reduced weight may be worth the tradeoff.
                              However, since weight isn't really much of a factor in the 2418 CNC, I think it makes sense to stick with hardened steel rods.
                              Am I missing something? Opinions?
                              RFM69R zboblamontZ 2 Replies Last reply
                              • andrewA andrew
                                @neverdie once the assembly is done, you should adjust the stepper drivers' current limiting as well.
                                then, it is always good idea to have the basic settings exported from the board, just in case... you can do it by "$$" command sent from the g code sender gui or directly from the serial terminal.
                                currently I use the following settings, the machine might be able to create nice results with higher feed rates, but I did not have enough time to test it and I sticked to the current working config.
                                isolation routing with 2001 bits:
                                • z cut: -0.05mm
                                • feed rate: 200
                                you can calculate the V carving bit's tool width for the given milling depth with the following formula:
                                tan(bit angle/2) * milling depth * 2 + bit's end width
                                for excel formula the bit angle should be provided in radians, so it should look like this
                                tan(radians(bit angle/2)) * milling depth * 2 + bit's end width
                                edge cut or hole milling with the 0.8mm endmill:
                                • feed rate: 170
                                • z cut: -1.7mm
                                • multi depth, depth/pass: 0.2mm
                                drilling:
                                • feed rate: 130
                                • z cut: -1.8
                                the spindle should be 1000 everywhere.
                                most probably your board will not have a bootloader, so it will not be possible to update the firmware via usb serial connection (with avrdude), but it is worth to try it. for me it did not work, so I traced back the MCU pins to the pin rows and used ISP to upgrade the firmware to grbl v1.1f (the board will come with 0.9j if I remember correctly). do not forget to export the gerber settings before you upgrade the firmware, as it will loose those, and you have to re-assign the given values again, after the update.
                                the ISP pinout (from the pin row's top left corner):
                                Reset -> pin 2
                                SCK -> pin 3
                                MISO -> pin 12
                                MOSI -> pin 13
                                5v -> pin1
                                gnd-> bottom row(!) e.g. pin 1
                                B
                                B
                                bodof1981
                                @andrew Hy my name is Ferenc please help me.
                                i update the grbl cnc 2418 firmware but dont read settings.
                                From where I can download it and how I can write it ?
                                My machine does not function properly now unfortunately. Please help thank you.
                                  I'm noticing that the tips on 0.1mm etching bits last well enough if the PCB substrate if bakelite, but not very long at all if it's FR4. 0.2mm bit tips on FR4 seems to last much better.
                                    RFM69R
                                    RFM69R
                                    RFM69
                                    @neverdie I'm gathering parts to make the same 3d printer with the carbon rods. I understood the weight reduction on the moving parts with carbon rods was the reason to go for them. And with the light 3d printer head that model can print much faster because of the stability and lightness. Which perhaps dosn't apply for the 2418 cnc ?
                                      zboblamontZ
                                      zboblamontZ
                                      zboblamont
                                      @neverdie Wall thickness as well as the material characteristics determine tube stiffness, comparison on the modulus alone is misleading.
                                      As well as carrying the load, the section must also support it's own weight, one aspect where carbon fibre will out-perform steel.
                                        What's the best way to check the RPM on my spindle? From looking at similar spindles on-line, I think it might be as low as 6000RPM at 24v.
                                        So.... if I upgraded to a spindle that could go, say, 12000RPM, could I simply increase my feedrate by 2x and be done twice as fast?
                                        • zboblamontZ zboblamont
                                          #601
                                          Granted. What's a better way to compare them based on the available info?
