  3. Best CNC for milling/routing wood?
39 Posts 8 Posters 11.8k Views 8 Watching
    I bet that diameter of unsupported tube would be a fail, based on what we saw in the earlier videos.
    However, if you were to fill those flimsy tubes with self-leveling mortar/concrete, maybe even with a piece of re-bar running down the center of it, I bet they'd become a lot more rigid.... Maybe then you could keep the same size.
    Also, would box tubing be more rigid? Seems like the same design idea could be adapted to that. I can imagine that a box geometry might even stabilize the spindle more (keep it from going ring-around-the-rosie like maybe it would on a circular tube).
    RFM69R
    RFM69R
    RFM69
    @neverdie They've already answered the concrete idea, many people consider that, but a simple center support I think solves the problem. They have nice forums over at the vicious.com link I shared.
      @rfm69 Is this it?
      Hmmm. That does look clever. I suppose one could scale it to use whatever bigger/stronger pipe might be needed to make it rigid enough. Pipe/tubing is usually plenty cheap, so I guess it might even be affordable.
      If needed, you could maybe even replace the plastic joinery with Kee Klamps or similar: https://www.simplifiedbuilding.com/pipe-fittings/kee-klamp
      When will you be done making yours? I'd love to hear how well you like it.
      RFM69R
      RFM69R
      RFM69
      @neverdie The same web site has a few other designs for larger machines.
      • RFM69R RFM69
        #22
        @rfm69
        Ah, OK, that makes sense for the side supports:
        The rods that move, though, remain unsupported, especially in the middle. What about those?
        RFM69R 1 Reply Last reply
        • RFM69R RFM69
          #23
          @rfm69 said in Best CNC for milling/routing wood?:
          Hmm.. That Low Rider MPCNC does looks interesting. They're using just two stainless steel tubes for that. Should be relatively cheap to make, and it can handle large formats. :)
          !alt text
            @rfm69
            RFM69R
            RFM69R
            RFM69
            @neverdie Generally I get the feeling from reading other peoples experience that its a mistake to quickly make the machine too big because of rigidity. But people do make mods to address this issue or to add heavier spindles.
            Heres one mod i/d like to do link text
            But to change the size just need to get new pipes which even if you use SS they are they cheapest part.
              #25
              same here, a while I'm looking at the MPCNC. It's a nice and affordable project when you want to build a cnc.
              Unfortunately never jumped into, because I have different requirements, need something more "powerful" for my job, not only for wood or thin sheets.
              I don't think it's comparable with the others machine above (strength, speed, raw material that can be machined..). But if you don't need so much power, it might be pretty cool, you can make lot of things with it :)
              RFM69R NeverDieN 2 Replies Last reply
              • scalzS scalz
                RFM69R
                RFM69R
                RFM69
                @scalz Agreed, It might be anough for me, but a good cheap learning platform :)
                • scalzS scalz
                  @scalz Do you have a CNC? If so, which one did you pick?
                  scalzS 1 Reply Last reply
                    @neverdie
                    no, I haven't yet. still studying :) because i'll built mine, custom I think (inspired from multiple builds), for my job I need stronger than mpcnc (so far asking local subcontractor when I need it).
                    if it would be for personal use, low cost, for soft materials, no speed concern, maybe I would pick the MPCNC as I already have a 3dprinter for printing parts (I think i've maybe just a few missing parts to build one though).
                      #29
                      This guy took a very different approach, yet he took deflection into account and has supported rails. For its size, it may be the least expensive:
                      https://www.ebay.com/itm/BobsCNC-E3-CNC-Router-Engraver-Kit-includes-the-DeWalt-DW660-Router/222859180982?epid=530593462&hash=item33e3713bb6:g:HjsAAOSwJvpalajY
                      https://www.youtube.com/watch?v=v-e2IVQUh1k
                      Also, the Y-axis is easily extensible:
                      https://www.youtube.com/watch?v=k44hWAIadjc
                      • bjornhallbergB
                        bjornhallbergB
                        bjornhallberg
                        Yes but can he do this? ;-)
                        https://youtu.be/Nz8k2MSAasI?t=47s
                        NeverDieN YveauxY RFM69R 3 Replies Last reply
                          #31
                          @bjornhallberg I'm sold! ... except I'm not, because they won't sell a kit to anyone in the United States. Go figure. I don't understand why.
                            @bjornhallberg said in Best CNC for milling/routing wood?:
                            Something tells me that machine needs some big red E-Stops...
                              RFM69R
                              RFM69R
                              RFM69
                              @bjornhallberg Any estimate on the cost of mechanical parts ?
                                • RFM69R RFM69
                                  bjornhallbergB
                                  bjornhallbergB
                                  bjornhallberg
                                  @rfm69 I think the mechanical stuff is ~$1400 and then ~$600 for steppers and spindle and a few other things.
                                  Of course the machine we're building at the makerspace is the biggest suggested model. Working area ~100x150cm with steel reinforced Y and X and with laser cut steel plates instead of aluminum. So I don't think he ever sold that as a kit internationally because of weight and size. A smaller machine would be much cheaper obviously.
                                  @neverdie Yeah the guy behind the RawCNC has been a bit difficult. This is sort of his side project and he keeps changing his mind on how to proceed. He actually rolled back some of the features to make the machines lighter and easier to ship. But then he didn't sell internationally anyway. At least not for long.
                                    RFM69R
                                    RFM69R
                                    RFM69
                                    @bjornhallberg Thanks for the info, I got a bit frustrated trying to find this on the rawcnc website... i was in some loop, very frustrating.
                                    I'm going to learn with the mpcnc and then posisble upgrade if I can justify it, or feel more flush. But thanks for the info...
                                    This shipping costs, can be a big factor, so I do understand, but the openness and transparency or generally communicating well, which you don't get at all from most china suppliers, and some closer is just as important.
                                      Seems like a very good price for the rigidity and such a large format, at least compared to other offerings.
                                        The MPCNC is a smart project but I would assume it would struggle with a bigger motor.
                                        The 2.2kW we are going to use weighs A LOT. Around 5kg at least I'd guess. The 1.5kW is not much better. With a smaller spindle, or router like a Kress things would be different. Still I'm glad to have the extra power, and standard ER20 collets up to 13mm. Plus these chinese spindles are really quiet compared to a regular router. And the speed can be set and spindle can be started from the control panel or from the computer. The downside is the low quality VFD I guess, but if it works it works. And you can always use shielded cables everywhere.
                                        Muhammad IbrahimM
                                        Muhammad IbrahimM
                                        Muhammad Ibrahim
                                        Thankyou for sharing. i was looking for best cnc router i got alot of information here
                                        • Muhammad IbrahimM Muhammad Ibrahim
                                          #39
                                          @Muhammad-Ibrahim I suggest you look into PrintNC, which didn't even exist 4 years ago when this thread began. I'm aware of a number of people who have recently "upgraded" (their words) from MPCNC to PrintNC.
