  3. Best CNC for milling/routing wood?
39 Posts 8 Posters 11.8k Views 8 Watching
    #25
    same here, a while I'm looking at the MPCNC. It's a nice and affordable project when you want to build a cnc.
    Unfortunately never jumped into, because I have different requirements, need something more "powerful" for my job, not only for wood or thin sheets.
    I don't think it's comparable with the others machine above (strength, speed, raw material that can be machined..). But if you don't need so much power, it might be pretty cool, you can make lot of things with it :)
    RFM69R NeverDieN 2 Replies Last reply
    • scalzS scalz
      RFM69R
      RFM69R
      RFM69
      @scalz Agreed, It might be anough for me, but a good cheap learning platform :)
      • scalzS scalz
        @scalz Do you have a CNC? If so, which one did you pick?
        scalzS 1 Reply Last reply
          @neverdie
          no, I haven't yet. still studying :) because i'll built mine, custom I think (inspired from multiple builds), for my job I need stronger than mpcnc (so far asking local subcontractor when I need it).
          if it would be for personal use, low cost, for soft materials, no speed concern, maybe I would pick the MPCNC as I already have a 3dprinter for printing parts (I think i've maybe just a few missing parts to build one though).
            #29
            This guy took a very different approach, yet he took deflection into account and has supported rails. For its size, it may be the least expensive:
            https://www.ebay.com/itm/BobsCNC-E3-CNC-Router-Engraver-Kit-includes-the-DeWalt-DW660-Router/222859180982?epid=530593462&hash=item33e3713bb6:g:HjsAAOSwJvpalajY
            https://www.youtube.com/watch?v=v-e2IVQUh1k
            Also, the Y-axis is easily extensible:
            https://www.youtube.com/watch?v=k44hWAIadjc
            • bjornhallbergB
              bjornhallbergB
              bjornhallberg
              Yes but can he do this? ;-)
              https://youtu.be/Nz8k2MSAasI?t=47s
              NeverDieN YveauxY RFM69R 3 Replies Last reply
                #31
                @bjornhallberg I'm sold! ... except I'm not, because they won't sell a kit to anyone in the United States. Go figure. I don't understand why.
                  @bjornhallberg said in Best CNC for milling/routing wood?:
                  Something tells me that machine needs some big red E-Stops...
                    RFM69R
                    RFM69R
                    RFM69
                    @bjornhallberg Any estimate on the cost of mechanical parts ?
                      • RFM69R RFM69
                        bjornhallbergB
                        bjornhallbergB
                        bjornhallberg
                        @rfm69 I think the mechanical stuff is ~$1400 and then ~$600 for steppers and spindle and a few other things.
                        Of course the machine we're building at the makerspace is the biggest suggested model. Working area ~100x150cm with steel reinforced Y and X and with laser cut steel plates instead of aluminum. So I don't think he ever sold that as a kit internationally because of weight and size. A smaller machine would be much cheaper obviously.
                        @neverdie Yeah the guy behind the RawCNC has been a bit difficult. This is sort of his side project and he keeps changing his mind on how to proceed. He actually rolled back some of the features to make the machines lighter and easier to ship. But then he didn't sell internationally anyway. At least not for long.
                          RFM69R
                          RFM69R
                          RFM69
                          @bjornhallberg Thanks for the info, I got a bit frustrated trying to find this on the rawcnc website... i was in some loop, very frustrating.
                          I'm going to learn with the mpcnc and then posisble upgrade if I can justify it, or feel more flush. But thanks for the info...
                          This shipping costs, can be a big factor, so I do understand, but the openness and transparency or generally communicating well, which you don't get at all from most china suppliers, and some closer is just as important.
                            Seems like a very good price for the rigidity and such a large format, at least compared to other offerings.
                              The MPCNC is a smart project but I would assume it would struggle with a bigger motor.
                              The 2.2kW we are going to use weighs A LOT. Around 5kg at least I'd guess. The 1.5kW is not much better. With a smaller spindle, or router like a Kress things would be different. Still I'm glad to have the extra power, and standard ER20 collets up to 13mm. Plus these chinese spindles are really quiet compared to a regular router. And the speed can be set and spindle can be started from the control panel or from the computer. The downside is the low quality VFD I guess, but if it works it works. And you can always use shielded cables everywhere.
                              Muhammad IbrahimM
                              Muhammad IbrahimM
                              Muhammad Ibrahim
                              Thankyou for sharing. i was looking for best cnc router i got alot of information here
                              • Muhammad IbrahimM Muhammad Ibrahim
                                #39
                                @Muhammad-Ibrahim I suggest you look into PrintNC, which didn't even exist 4 years ago when this thread began. I'm aware of a number of people who have recently "upgraded" (their words) from MPCNC to PrintNC.
