  3. Barometric Pressure Sensor Using MS5637
23 Posts 4 Posters 11.0k Views 1 Watching
  • M Offline
    M Offline
    Myles L
    Hello
    Very new to Arduino and MySensors so please excuse any novice mistakes. I am trying to get the Pressure Sensor sketch to work with a different pressure sensor http://www.freetronics.com.au/collections/modules/products/barometric-pressure-sensor-module#.VLSnlNH9mUk
    I have modified the code (included below) but when I try to add it to Vera (VeraLite, UI7, Ethernet Gateway, and yes it does work with other sensors surprisingly!) no new device is included and when I open a serial monitor no response is available. I have confirmed the pressure sensor itself is working using a different sketch. Any suggestions would be appreciated.
    #include <BaroSensor.h>
    #define BARO_CHILD 0
    #define TEMP_CHILD 1
    unsigned long SLEEP_TIME = 60000; // Sleep time between reads (in seconds)
    BaroSensorClass bmp = BaroSensorClass(); // Digital Pressure Sensor
    float lastPressure = -1;
    float lastTemp = -1;
    int lastForecast = -1;
    char *weather[] = {"stable","sunny","cloudy","unstable","thunderstorm","unknown"};
    int minutes;
    float pressureSamples[180];
    int minuteCount = 0;
    bool firstRound = true;
    float pressureAvg[7];
    float dP_dt;
    boolean metric;
    MyMessage forecastMsg(BARO_CHILD, V_FORECAST);
    gw.begin();
    gw.sendSketchInfo("Pressure Sensor", "1.0");
    bmp.begin();
    // Serial.println("Could not find a valid sensor, check wiring!");
    //while (1) { }
    // Register sensors to gw (they will be created as child devices)
    gw.present(BARO_CHILD, S_BARO);
    gw.present(TEMP_CHILD, S_TEMP);
    float pressure = bmp.getPressure(); //(205)/100; // 205 meters above sealevel
    float temperature = bmp.getTemperature();
    if (!metric) {
    // Convert to fahrenheit
    temperature = temperature * 9.0 / 5.0 + 32.0;
    int forecast = sample(pressure);
    Serial.print("Temperature = ");
    Serial.print(temperature);
    Serial.println(metric?" *C":" *F");
    Serial.print("Pressure = ");
    Serial.print(pressure);
    Serial.println(" Pa");
    if (temperature != lastTemp) {
    gw.send(tempMsg.set(temperature,1));
    lastTemp = temperature;
    if (pressure != lastPressure) {
    gw.send(pressureMsg.set(pressure, 0));
    lastPressure = pressure;
    if (forecast != lastForecast) {
    gw.send(forecastMsg.set(weather[forecast]));
    lastForecast = forecast;
    DP/Dt explanation
    0 = "Stable Weather Pattern"
    1 = "Slowly rising Good Weather", "Clear/Sunny "
    2 = "Slowly falling L-Pressure ", "Cloudy/Rain "
    3 = "Quickly rising H-Press", "Not Stable"
    4 = "Quickly falling L-Press", "Thunderstorm"
    5 = "Unknown (More Time needed)
    gw.sleep(SLEEP_TIME);
    int sample(float pressure) {
    // Algorithm found here
    if (minuteCount == 180)
    minuteCount = 5;
    pressureSamples[minuteCount] = pressure;
    minuteCount++;
    if (minuteCount == 5) {
    	// Avg pressure in first 5 min, value averaged from 0 to 5 min.
    	pressureAvg[0] = ((pressureSamples[0] + pressureSamples[1]
    			+ pressureSamples[2] + pressureSamples[3] + pressureSamples[4])
    			/ 5);
    } else if (minuteCount == 35) {
    	// Avg pressure in 30 min, value averaged from 0 to 5 min.
    	pressureAvg[1] = ((pressureSamples[30] + pressureSamples[31]
    			+ pressureSamples[32] + pressureSamples[33]
    			+ pressureSamples[34]) / 5);
    	float change = (pressureAvg[1] - pressureAvg[0]);
    		dP_dt = ((65.0 / 1023.0) * 2 * change); // note this is for t = 0.5hour
    		dP_dt = (((65.0 / 1023.0) * change) / 1.5); // divide by 1.5 as this is the difference in time from 0 value.
    } else if (minuteCount == 60) {
    	// Avg pressure at end of the hour, value averaged from 0 to 5 min.
    	pressureAvg[2] = ((pressureSamples[55] + pressureSamples[56]
    			+ pressureSamples[57] + pressureSamples[58]
    			+ pressureSamples[59]) / 5);
    	float change = (pressureAvg[2] - pressureAvg[0]);
    		dP_dt = ((65.0 / 1023.0) * change); //note this is for t = 1 hour
    		dP_dt = (((65.0 / 1023.0) * change) / 2); //divide by 2 as this is the difference in time from 0 value
    } else if (minuteCount == 95) {
    	pressureAvg[3] = ((pressureSamples[90] + pressureSamples[91]
    			+ pressureSamples[92] + pressureSamples[93]
    			+ pressureSamples[94]) / 5);
    	float change = (pressureAvg[3] - pressureAvg[0]);
    		dP_dt = (((65.0 / 1023.0) * change) / 1.5); // note this is for t = 1.5 hour
    		dP_dt = (((65.0 / 1023.0) * change) / 2.5); // divide by 2.5 as this is the difference in time from 0 value
    } else if (minuteCount == 120) {
    	pressureAvg[4] = ((pressureSamples[115] + pressureSamples[116]
    			+ pressureSamples[117] + pressureSamples[118]
    			+ pressureSamples[119]) / 5);
    	float change = (pressureAvg[4] - pressureAvg[0]);
    		dP_dt = (((65.0 / 1023.0) * change) / 2); // note this is for t = 2 hour
    		dP_dt = (((65.0 / 1023.0) * change) / 3); // divide by 3 as this is the difference in time from 0 value
    } else if (minuteCount == 155) {
    	pressureAvg[5] = ((pressureSamples[150] + pressureSamples[151]
    			+ pressureSamples[152] + pressureSamples[153]
    			+ pressureSamples[154]) / 5);
    	float change = (pressureAvg[5] - pressureAvg[0]);
    		dP_dt = (((65.0 / 1023.0) * change) / 2.5); // note this is for t = 2.5 hour
    		dP_dt = (((65.0 / 1023.0) * change) / 3.5); // divide by 3.5 as this is the difference in time from 0 value
    } else if (minuteCount == 180) {
    	pressureAvg[6] = ((pressureSamples[175] + pressureSamples[176]
    			+ pressureSamples[177] + pressureSamples[178]
    			+ pressureSamples[179]) / 5);
    	float change = (pressureAvg[6] - pressureAvg[0]);
    		dP_dt = (((65.0 / 1023.0) * change) / 3); // note this is for t = 3 hour
    		dP_dt = (((65.0 / 1023.0) * change) / 4); // divide by 4 as this is the difference in time from 0 value
    	pressureAvg[0] = pressureAvg[5]; // Equating the pressure at 0 to the pressure at 2 hour after 3 hours have past.
    	return 5; // Unknown, more time needed
    else if (dP_dt < (-0.25))
    	return 4; // Quickly falling LP, Thunderstorm, not stable
    else if (dP_dt > 0.25)
    	return 3; // Quickly rising HP, not stable weather
    	return 2; // Slowly falling Low Pressure System, stable rainy weather
    	return 1; // Slowly rising HP stable good weather
    else if ((dP_dt > (-0.05)) && (dP_dt < 0.05))
    	return 0; // Stable weather
    • hekH Offline
      hekH Offline
      Sorry, we aren't machines that easily do diffs in our heads... :)
      What exactly did you change and why?
      • M Offline
        M Offline
        Myles L
        Sorry about that, I changed
        #include <Adafruit_BMP085.h> changed to #include <BaroSensor.h> (Alternate library files for different baro sensor)
        Adafruit_BMP085 bmp = Adafruit_BMP085(); changed to BaroSensorClass bmp = BaroSensorClass(); (BaroSensorClass is referenced in the library files)
        float pressure = bmp.readSealevelPressure(205)/100; **changed to ** float pressure = bmp.getPressure(); (also referenced in the library)
        float temperature = bmp.readTemperature(); changed to float temperature = bmp.getTemperature(); (same reason)
        if (!bmp.begin()) {
        Serial.println("Could not find a valid BMP085 sensor, check wiring!");
        while (1) { } **changed to ** bmp.begin(); (Could not get the sketch to compile using the original so changed to just start the baro sensor)
        Thanks again.
        • hekH Offline
          hekH Offline
          If you get no output in the Serial Monitor there could be a out of (stack) memory situation.
          Try adding debug prints to see where it fails.
          • M Offline
            M Offline
            Myles L
            Thanks, I added debug prints after each line but still get nothing on the serial monitor. Does that mean I can assume that the problem is in the initial setup section (the code before void setup(){)?
            I couldn't find a way to add debug prints to that section but any suggestions on how to are welcome.
            • K Offline
              K Offline
              korttoma
              Did you try something like this:
              delay(1000);
              Serial.println("Serial begin ");
              gw.begin
              Edit: newermind, I don't think you can get anything from the section before setup()
              • Tomas
              • B Offline
                B Offline
                BulldogLowell
                maybe i missed it, but did you have a sketch that worked (with the appropriate libraries) at least outputting the sensor data to the serial monitor?
                If you have that, post it. It will be easy to add to that the 'stuff' you need for MySensors, I believe.
                • M Offline
                  M Offline
                  Myles L
                  Yes, I have that. It is just a really a really basic sketch that prints the sensor data to a serial output. I am also very interested in the weather forecast part of the MySensors sketch which is why I was trying to mod it.
                  Serial.begin(9600);
                  BaroSensor.begin();
                  if(!BaroSensor.isOK()) {
                  Serial.print("Sensor not Found/OK. Error: ");
                  Serial.println(BaroSensor.getError());
                  BaroSensor.begin(); // Try to reinitialise the sensor if we can
                  else {
                  Serial.print("Temperature: ");
                  Serial.println(BaroSensor.getTemperature());
                  Serial.print("Pressure: ");
                  Serial.println(BaroSensor.getPressure());
                  delay(1000);
                  B 1 Reply Last reply
                  • M Myles L
                    Serial.begin(9600);
                    BaroSensor.begin();
                    else {
                    delay(1000);
                    B Offline
                    B Offline
                    BulldogLowell
                    @Myles-L
                    this compiles, but I could not test it:
                    int minutes;
                    float dP_dt;
                    boolean metric;
                      gw.begin();
                      BaroSensor.begin();
                      float pressure = BaroSensor.getPressure()/100;
                      float temperature = BaroSensor.getTemperature();
                      if (!metric)
                       DP/Dt explanation
                    	if (minuteCount > 180)
                    		minuteCount = 6;
                    	minuteCount++;
                    		pressureAvg[0] = ((pressureSamples[1] + pressureSamples[2]
                    				+ pressureSamples[3] + pressureSamples[4] + pressureSamples[5])
                    				/ 5);
                    • B BulldogLowell
                      @Myles-L
                      int minutes;
                      float dP_dt;
                      boolean metric;
                        gw.begin();
                        BaroSensor.begin();
                        if (!metric)
                         DP/Dt explanation
                      		minuteCount = 6;
                      	minuteCount++;
                      				/ 5);
                      M Offline
                      M Offline
                      Myles L
                      Thank you so much, it is so close. Code compiles, uploads and there is output from the serial monitor but when adding the device to Vera only a repeater node gets added and not the actual pressure sensor.
                      The additional pressure sensor files have been uploaded to Vera.
                      • M Myles L
                        B Offline
                        B Offline
                        BulldogLowell
                        put some delays in here... especially if you do not have the caps on the radio!!!
                        BaroSensor.begin();
                        delay(250);
                        delay(250);
                        delay(250);
                        if that isn't enough, you can try to add a little more time to the delays....
                        • M Offline
                          M Offline
                          Myles L
                          Tried delays right up to 5000 and also added a few others but unfortunately it still only presents the repeater node to Vera
                          • M Myles L
                            B Offline
                            B Offline
                            BulldogLowell
                            @Myles-L
                            Try deleting the devices it created and starting over. Give it a new device number and try it without it being a repeating node:
                            change:
                            gw.begin();
                            to:
                            gw.begin(NULL, DEVICE_ID, false);
                            where you defined (added) in the header of the sketch:
                            #define DEVICE_ID 10
                            or some other number that is non-zero and not greater than 254
                            • M Offline
                              M Offline
                              Myles L
                              By adding those changes it went back to not outputting to the serial interface. I was able to get it to output again by removing the DEFINE DEVICE ID and the DEVICE ID section (not sure why that made a difference) but then it goes back to only adding a node to Vera.
                              Really appreciate your determination to solve this and I am learning lots along the way!
                              • M Myles L
                                B Offline
                                B Offline
                                BulldogLowell
                                @Myles-L
                                you mind posting the code you tried last?
                                Can you confirm that you have deleted the Vera devices that were created (I believe you said it was a relay)
                                • M Offline
                                  M Offline
                                  Myles L
                                  I have deleted the Vera devices and I have also tried removing and re-adding the MySensors plugin in Vera. When I add the pressure sensor now it still adds as a node. Code is below:
                                  int minutes;
                                  float dP_dt;
                                  boolean metric;
                                  gw.begin(NULL, false);
                                  delay(1000);
                                  BaroSensor.begin();
                                  delay(1000);
                                  delay(1000);
                                  delay(1000);
                                  if (!metric)
                                  DP/Dt explanation
                                  minuteCount = 6;
                                  minuteCount++;
                                              / 5);
                                  • B Offline
                                    B Offline
                                    BulldogLowell
                                    @BulldogLowell said:
                                    Try this, and tell me what the serial output looks like.
                                    Have you added a capacitor to the radio? It could be electronic...
                                    #define DEVICE_ID 99
                                    int minutes;
                                    float dP_dt;
                                    boolean metric;
                                      delay(1000);
                                      Serial.println("Got to GW.Begin");
                                      Serial.println("Sketch data Presented");
                                      delay(1000);
                                      BaroSensor.begin();
                                      Serial.println("Brometer Sensor started...");
                                      delay(1000);
                                      Serial.println("presenting Barometer");
                                      delay(1000);
                                      Serial.println("presenting Thermometer");
                                      delay(1000);
                                      Serial.println("requesting Metric");
                                      delay(1000);
                                      Serial.println("Setup Complete");
                                    • M Offline
                                      M Offline
                                      Myles L
                                      The Sensor and Ethernet gateway both have 4.7uf electrolytic capacitors across the power input of the radio's (I cant get much distance out of them, maybe <10 metres, but they do work for the relay sensor).
                                      The serial output looks like this: ��Ah���Y5����������i��`q!���J�����
                                      • M Offline
                                        M Offline
                                        Myles L
                                        Using that sketch I was able to add it to Vera, it just does not report pressure or forecast (obviously as there is no data being presented to it)
                                        • B Offline
                                          B Offline
                                          BulldogLowell
                                          Great, now just plug the loop() back into the sketch, flash your arduino, and you should be good to go
                                          oh... and add a Serial.begin(yourDesiredBaudRate) to setup() ;)
