  3. Barometric Pressure Sensor Using MS5637
23 Posts 4 Posters 11.2k Views 1 Watching
    Sorry, we aren't machines that easily do diffs in our heads... :)
    What exactly did you change and why?
      Myles L
      Sorry about that, I changed
      #include <Adafruit_BMP085.h> changed to #include <BaroSensor.h> (Alternate library files for different baro sensor)
      Adafruit_BMP085 bmp = Adafruit_BMP085(); changed to BaroSensorClass bmp = BaroSensorClass(); (BaroSensorClass is referenced in the library files)
      float pressure = bmp.readSealevelPressure(205)/100; **changed to ** float pressure = bmp.getPressure(); (also referenced in the library)
      float temperature = bmp.readTemperature(); changed to float temperature = bmp.getTemperature(); (same reason)
      if (!bmp.begin()) {
      Serial.println("Could not find a valid BMP085 sensor, check wiring!");
      while (1) { } **changed to ** bmp.begin(); (Could not get the sketch to compile using the original so changed to just start the baro sensor)
      Thanks again.
        If you get no output in the Serial Monitor there could be a out of (stack) memory situation.
        Try adding debug prints to see where it fails.
          Myles L
          Thanks, I added debug prints after each line but still get nothing on the serial monitor. Does that mean I can assume that the problem is in the initial setup section (the code before void setup(){)?
          I couldn't find a way to add debug prints to that section but any suggestions on how to are welcome.
          • korttomaK
            korttomaK
            korttoma
            Did you try something like this:
            delay(1000);
            Serial.println("Serial begin ");
            gw.begin
            Edit: newermind, I don't think you can get anything from the section before setup()
            • Tomas
            • BulldogLowellB
              BulldogLowellB
              BulldogLowell
              maybe i missed it, but did you have a sketch that worked (with the appropriate libraries) at least outputting the sensor data to the serial monitor?
              If you have that, post it. It will be easy to add to that the 'stuff' you need for MySensors, I believe.
                Myles L
                Yes, I have that. It is just a really a really basic sketch that prints the sensor data to a serial output. I am also very interested in the weather forecast part of the MySensors sketch which is why I was trying to mod it.
                Serial.begin(9600);
                BaroSensor.begin();
                if(!BaroSensor.isOK()) {
                Serial.print("Sensor not Found/OK. Error: ");
                Serial.println(BaroSensor.getError());
                BaroSensor.begin(); // Try to reinitialise the sensor if we can
                else {
                Serial.print("Temperature: ");
                Serial.println(BaroSensor.getTemperature());
                Serial.print("Pressure: ");
                Serial.println(BaroSensor.getPressure());
                delay(1000);
                • M Myles L
                  Serial.begin(9600);
                  BaroSensor.begin();
                  else {
                  delay(1000);
                  BulldogLowellB
                  BulldogLowellB
                  BulldogLowell
                  @Myles-L
                  this compiles, but I could not test it:
                  #define BARO_CHILD 0
                  #define TEMP_CHILD 1
                  unsigned long SLEEP_TIME = 60000; // Sleep time between reads (in seconds)
                  float lastPressure = -1;
                  float lastTemp = -1;
                  int lastForecast = -1;
                  int minutes;
                  float pressureSamples[180];
                  int minuteCount = 0;
                  bool firstRound = true;
                  float pressureAvg[7];
                  float dP_dt;
                  boolean metric;
                  MyMessage forecastMsg(BARO_CHILD, V_FORECAST);
                    gw.begin();
                    gw.sendSketchInfo("Pressure Sensor", "1.0");
                    BaroSensor.begin();
                    // Register sensors to gw (they will be created as child devices)
                    gw.present(BARO_CHILD, S_BARO);
                    gw.present(TEMP_CHILD, S_TEMP);
                    metric =  gw.getConfig().isMetric;
                    float pressure = BaroSensor.getPressure()/100;
                    float temperature = BaroSensor.getTemperature();
                    if (!metric)
                      // Convert to fahrenheit
                      temperature = temperature * 9.0 / 5.0 + 32.0;
                    int forecast = sample(pressure);
                    Serial.print("Temperature = ");
                    Serial.print(temperature);
                    Serial.println(metric?" *C":" *F");
                    Serial.print("Pressure = ");
                    Serial.print(pressure);
                    Serial.println(" Pa");
                    if (temperature != lastTemp) {
                      gw.send(tempMsg.set(temperature,1));
                      lastTemp = temperature;
                    if (pressure != lastPressure) {
                      gw.send(pressureMsg.set(pressure, 0));
                      lastPressure = pressure;
                    if (forecast != lastForecast)
                      gw.send(forecastMsg.set(weather[forecast]));
                      lastForecast = forecast;
                     DP/Dt explanation
                     0 = "Stable Weather Pattern"
                     1 = "Slowly rising Good Weather", "Clear/Sunny "
                     2 = "Slowly falling L-Pressure ", "Cloudy/Rain "
                     3 = "Quickly rising H-Press",     "Not Stable"
                     4 = "Quickly falling L-Press",    "Thunderstorm"
                     5 = "Unknown (More Time needed)
                    gw.sleep(SLEEP_TIME);
                  int sample(float pressure) {
                  	// Algorithm found here
                  	if (minuteCount > 180)
                  		minuteCount = 6;
                  	pressureSamples[minuteCount] = pressure;
                  	minuteCount++;
                  	if (minuteCount == 5) {
                  		// Avg pressure in first 5 min, value averaged from 0 to 5 min.
                  		pressureAvg[0] = ((pressureSamples[1] + pressureSamples[2]
                  				+ pressureSamples[3] + pressureSamples[4] + pressureSamples[5])
                  				/ 5);
                  	} else if (minuteCount == 35) {
                  		// Avg pressure in 30 min, value averaged from 0 to 5 min.
                  		pressureAvg[1] = ((pressureSamples[30] + pressureSamples[31]
                  				+ pressureSamples[32] + pressureSamples[33]
                  				+ pressureSamples[34]) / 5);
                  		float change = (pressureAvg[1] - pressureAvg[0]);
                  			dP_dt = ((65.0 / 1023.0) * 2 * change); // note this is for t = 0.5hour
                  			dP_dt = (((65.0 / 1023.0) * change) / 1.5); // divide by 1.5 as this is the difference in time from 0 value.
                  	} else if (minuteCount == 60) {
                  		// Avg pressure at end of the hour, value averaged from 0 to 5 min.
                  		pressureAvg[2] = ((pressureSamples[55] + pressureSamples[56]
                  				+ pressureSamples[57] + pressureSamples[58]
                  				+ pressureSamples[59]) / 5);
                  		float change = (pressureAvg[2] - pressureAvg[0]);
                  			dP_dt = ((65.0 / 1023.0) * change); //note this is for t = 1 hour
                  			dP_dt = (((65.0 / 1023.0) * change) / 2); //divide by 2 as this is the difference in time from 0 value
                  	} else if (minuteCount == 95) {
                  		pressureAvg[3] = ((pressureSamples[90] + pressureSamples[91]
                  				+ pressureSamples[92] + pressureSamples[93]
                  				+ pressureSamples[94]) / 5);
                  		float change = (pressureAvg[3] - pressureAvg[0]);
                  			dP_dt = (((65.0 / 1023.0) * change) / 1.5); // note this is for t = 1.5 hour
                  			dP_dt = (((65.0 / 1023.0) * change) / 2.5); // divide by 2.5 as this is the difference in time from 0 value
                  	} else if (minuteCount == 120) {
                  		pressureAvg[4] = ((pressureSamples[115] + pressureSamples[116]
                  				+ pressureSamples[117] + pressureSamples[118]
                  				+ pressureSamples[119]) / 5);
                  		float change = (pressureAvg[4] - pressureAvg[0]);
                  			dP_dt = (((65.0 / 1023.0) * change) / 2); // note this is for t = 2 hour
                  			dP_dt = (((65.0 / 1023.0) * change) / 3); // divide by 3 as this is the difference in time from 0 value
                  	} else if (minuteCount == 155) {
                  		pressureAvg[5] = ((pressureSamples[150] + pressureSamples[151]
                  				+ pressureSamples[152] + pressureSamples[153]
                  				+ pressureSamples[154]) / 5);
                  		float change = (pressureAvg[5] - pressureAvg[0]);
                  			dP_dt = (((65.0 / 1023.0) * change) / 2.5); // note this is for t = 2.5 hour
                  			dP_dt = (((65.0 / 1023.0) * change) / 3.5); // divide by 3.5 as this is the difference in time from 0 value
                  	} else if (minuteCount == 180) {
                  		pressureAvg[6] = ((pressureSamples[175] + pressureSamples[176]
                  				+ pressureSamples[177] + pressureSamples[178]
                  				+ pressureSamples[179]) / 5);
                  		float change = (pressureAvg[6] - pressureAvg[0]);
                  			dP_dt = (((65.0 / 1023.0) * change) / 3); // note this is for t = 3 hour
                  			dP_dt = (((65.0 / 1023.0) * change) / 4); // divide by 4 as this is the difference in time from 0 value
                  		pressureAvg[0] = pressureAvg[5]; // Equating the pressure at 0 to the pressure at 2 hour after 3 hours have past.
                  		return 5; // Unknown, more time needed
                  	else if (dP_dt < (-0.25))
                  		return 4; // Quickly falling LP, Thunderstorm, not stable
                  	else if (dP_dt > 0.25)
                  		return 3; // Quickly rising HP, not stable weather
                  		return 2; // Slowly falling Low Pressure System, stable rainy weather
                  		return 1; // Slowly rising HP stable good weather
                  	else if ((dP_dt > (-0.05)) && (dP_dt < 0.05))
                  		return 0; // Stable weather
                    @Myles-L
                    int minutes;
                    float dP_dt;
                    boolean metric;
                      gw.begin();
                      BaroSensor.begin();
                      if (!metric)
                       DP/Dt explanation
                    		minuteCount = 6;
                    	minuteCount++;
                    				/ 5);
                    Myles L
                    Thank you so much, it is so close. Code compiles, uploads and there is output from the serial monitor but when adding the device to Vera only a repeater node gets added and not the actual pressure sensor.
                    The additional pressure sensor files have been uploaded to Vera.
                    • M Myles L
                      BulldogLowellB
                      BulldogLowellB
                      BulldogLowell
                      put some delays in here... especially if you do not have the caps on the radio!!!
                      BaroSensor.begin();
                      delay(250);
                      delay(250);
                      delay(250);
                      if that isn't enough, you can try to add a little more time to the delays....
                        Myles L
                        Tried delays right up to 5000 and also added a few others but unfortunately it still only presents the repeater node to Vera
                        • M Myles L
                          BulldogLowellB
                          BulldogLowellB
                          BulldogLowell
                          @Myles-L
                          Try deleting the devices it created and starting over. Give it a new device number and try it without it being a repeating node:
                          change:
                          gw.begin();
                          to:
                          gw.begin(NULL, DEVICE_ID, false);
                          where you defined (added) in the header of the sketch:
                          #define DEVICE_ID 10
                          or some other number that is non-zero and not greater than 254
                            Myles L
                            By adding those changes it went back to not outputting to the serial interface. I was able to get it to output again by removing the DEFINE DEVICE ID and the DEVICE ID section (not sure why that made a difference) but then it goes back to only adding a node to Vera.
                            Really appreciate your determination to solve this and I am learning lots along the way!
                            • M Myles L
                              BulldogLowellB
                              BulldogLowellB
                              BulldogLowell
                              @Myles-L
                              you mind posting the code you tried last?
                              Can you confirm that you have deleted the Vera devices that were created (I believe you said it was a relay)
                                Myles L
                                I have deleted the Vera devices and I have also tried removing and re-adding the MySensors plugin in Vera. When I add the pressure sensor now it still adds as a node. Code is below:
                                int minutes;
                                float dP_dt;
                                boolean metric;
                                gw.begin(NULL, false);
                                delay(1000);
                                BaroSensor.begin();
                                delay(1000);
                                delay(1000);
                                delay(1000);
                                if (!metric)
                                DP/Dt explanation
                                minuteCount = 6;
                                minuteCount++;
                                            / 5);
                                • BulldogLowellB
                                  BulldogLowellB
                                  BulldogLowell
                                  @BulldogLowell said:
                                  Try this, and tell me what the serial output looks like.
                                  Have you added a capacitor to the radio? It could be electronic...
                                  #define DEVICE_ID 99
                                  int minutes;
                                  float dP_dt;
                                  boolean metric;
                                    delay(1000);
                                    Serial.println("Got to GW.Begin");
                                    Serial.println("Sketch data Presented");
                                    delay(1000);
                                    BaroSensor.begin();
                                    Serial.println("Brometer Sensor started...");
                                    delay(1000);
                                    Serial.println("presenting Barometer");
                                    delay(1000);
                                    Serial.println("presenting Thermometer");
                                    delay(1000);
                                    Serial.println("requesting Metric");
                                    delay(1000);
                                    Serial.println("Setup Complete");
                                    Myles L
                                    The Sensor and Ethernet gateway both have 4.7uf electrolytic capacitors across the power input of the radio's (I cant get much distance out of them, maybe <10 metres, but they do work for the relay sensor).
                                    The serial output looks like this: ��Ah���Y5����������i��`q!���J�����
                                      Myles L
                                      Using that sketch I was able to add it to Vera, it just does not report pressure or forecast (obviously as there is no data being presented to it)
                                      • BulldogLowellB
                                        BulldogLowellB
                                        BulldogLowell
                                        Great, now just plug the loop() back into the sketch, flash your arduino, and you should be good to go
                                        oh... and add a Serial.begin(yourDesiredBaudRate) to setup() ;)
                                          Myles L
                                          Ok, so close! Adding back the rest I get and endless string of � in the serial monitor and nothing adds to Vera.
                                          I don't actually need the temp (tried commenting it out but could not get it to compile) if that makes it easier?
                                          Here is what I have:
                                          int minutes;
                                          float dP_dt;
                                          boolean metric;
                                          Serial.begin(9600);
                                          delay(1000);
                                          delay(1000);
                                          BaroSensor.begin();
                                          delay(1000);
                                          delay(1000);
                                          delay(1000);
                                          delay(1000);
                                          if (!metric)
                                          Serial.println(metric?" C":" F");
                                          DP/Dt explanation
                                          minuteCount = 6;
                                          minuteCount++;
                                          / 5);
