  3. My 1AA battery sensor
prototypepoweredbatterylow
23 Posts 9 Posters 26.9k Views 6 Watching
  • tbowmoT
    tbowmoT
    tbowmo
    @klim
    What is the range of this unit? (ie. how far away from the GW can you put it). The reason I ask, is that you have put the stepup converter very close to the antenna area for the nrf module.
    And also a battery (made of metal) is close to the antenna, which also could impact drastic on the antenna performance
    • klimK
      klimK
      klim
      Hi, at the time i've just tested a few meter, sorry to be not more specific, i've not measured it. Because of the NRF module has a gnd shield on the bottom side and the StepUp too, so they have their gnd sided very close to each other, i hope to not get any signal losses.
      • T
        that0n3guy
        @klim Hows the battery life looking?
        • klimK
          klimK
          klim
          Hi, based on the results of my last measurement the sensor needs 90µA, while sleeping + consumption for transmitting, but this depends on the configuration.
          The theoretical battery life just for sleeping (without battery self discharge) should be:
          2500mAh/90µA=27777h
          27777h/24h=1157d
          1157d/365d/3,17a
          • daulagariD
            daulagariD
            daulagari
            @klim : Nice idea and thanks for documenting it here!
            Following @tbowmo I am wondering what is the effect of the stepup converter very close to the antenna; although the converter will work in the kHz range, it harmonics can be in the 2.4 GHz range and quite loud, so it could be that some channels are worse than others. Also the coil can induct currents in the traces of the NRF24L01 board.
            I am not so worried about the metal of the battery, that will impact the antenna pattern and maybe the impedance but the overall energy transmitted will be largely the same.
            But, that is all theory would be good to know if you see any drawback.
            I do not see a capacitor on the NRF24L01 board between the 3.3V and GND. Looks like you have one on the board but I think you can improve things by adding a low-ESR capacitor on the NRF24L01 board see http://www.mysensors.org/build/connect_radio
            • klimK klim
              2500mAh/90µA=27777h
              27777h/24h=1157d
              1157d/365d/3,17a
              that0n3guy
              2500mAh/90µA=27777h
              27777h/24h=1157d
              1157d/365d/3,17a
              I'm basically asking because everyone states that the step-up pulls like 1ma even arduino is in sleep. Your saying yours is not doing that?
              • klimK
                klimK
                klim
                @daulagari:
                I'm aware of that it is not the best option to mount them close to each other, but as it is just a prototype nearly everything is allowed :-)
                I did a quick test with success on a distance of 5m through a cement-wall of 20cm width.
                A capacitor for NRF24l01 is already on board, it's the grey one with a capacity of 4µ7. I know it's just an ordinary aluminium capacitor and not low-ESR, but i had nothing other at home.
                @that0n3guy:
                Again tested at battery side: 90µA @ 1.5V --> 135µW. Take a look here:
                upload-851de198-37be-40aa-9307-f087de7faa52
                • m26872M
                  m26872M
                  m26872
                  wrote on last edited by m26872
                  @klim If you press the yellow button you'll see 1mAac. It will not imply real power, but impair battery life, Question is how much?
                  • klimK
                    klimK
                    klim
                    @m26872: Why should i measure a dc current in ac mode? I did it anyway, the result was 0.87mA when sleeping. Please enlighten me.
                    • tbowmoT
                      tbowmoT
                      tbowmo
                      @klim
                      As the stepup converter functions, by chopping the supply up with a squarewave (in the order of 100-400kHz) it will not be a dc current. It will be more like an AC current
                      see comment below.
                      • klimK
                        klimK
                        klim
                        Thanks a lot for clarifying, i didn't thought about that before. This means the power consumption is not as good as it seems.
                        • tbowmoT
                          tbowmoT
                          tbowmo
                          Tried to search google to back up my theory, but I failed at it :sa:
                          So I turned to a group of fellow electronic nerds, asking them how to measure things.. The conclusion from their responses is:
                          Use DC current measurement, if your multimeter is good at averaging things. Otherwise, use a oscilloscope with a series resistor, and use integral maths to calculate the real current usage..
                          So I was wrong in my assumptions.. Sorry :)
                          • klimK
                            klimK
                            klim
                            Thanks for your info. That was my toughts too, to use an oscilloscope and integrating the current over time, but first i need a good digital oscilloscope to do that.
                            • T
                              therik
                              This was also my method (using an oscilloscope to integrate the current), but...I found it difficult to measure the very low currents...µA range with an oscilloscope (these are very high quality Tectronics units, we have many at work, but there is some DC offset even though I calibrated the probe, yada yada yada). So, on some more recent measurements I used a Keithley bench multimeter with averaging. I guess the final test is to see how long the batteries (or battery) actually last.
                              • klimK
                                klimK
                                klim
                                wrote on last edited by klim
                                I know about the problems and accuracy for very low current measurements without special instruments. Therefore i want to buy a µCurrent Gold adapter soon, it is a very cost effective way to measure very low currents. This adapter with the combination of a digital oscilloscope with math is what we need here. But at the end as therik already said: the final test is to see how long the battery actually last
                                tbowmoT 1 Reply Last reply
                                • klimK klim
                                  tbowmoT
                                  tbowmoT
                                  tbowmo
                                  Only problem is, that this is going to take a very long time to check..
                                  • klimK
                                    klimK
                                    klim
                                    That's the reason, we must use instruments and methods to give predictions, instead of waiting for real results ;-)
                                    • T
                                      therik
                                      The longer it takes to find out, the better, right? ;)
                                      RJ_MakeR 1 Reply Last reply
                                      • T therik
                                        RJ_MakeR
                                        RJ_MakeR
                                        RJ_Make
                                        @therik Yes, but then any corrections also take longer to test.. :-)
                                        RJ_Make
                                        • T
                                          that0n3guy
                                          Well, if its pulling ~1mA, then it should only last about a month or two. (right?)
                                          You could also pull battery voltages to see the battery "level" as well.
