  3. My 1AA battery sensor
prototypepoweredbatterylow
23 Posts 9 Posters 26.5k Views 6 Watching
  • K Offline
    K Offline
    klim
    wrote on last edited by klim
    Hi, i want to present you my working but not really sexy looking single cell AA battery sensor. It is as it is - under development and was just made to get some experience about power consumption and physical size.
    I thought a lot about the type of battery to choose, but at the end i desisted to use an ordinary AA cell. I know about the advantages and disadvantages of different battery chemistry and types, but in the aspect of price/mA the AA battery is still the winner. Self discharge of a few years is acceptable for that type of battery.
    Another aspect i followed is, just to use buy-able and assembled modules, as i don't have enough time to build my own arduino board, or battery management (step up), etc. .....
    The core of the sensor is the battery itself. The components are mounted around the battery. The sensor can be completely disassembled in a few seconds, as the modules are just connected with pin headers.
    The power consumption for sleep is around 90µA, if i can believe my Fluke 175. The power consumption of normal operation and transmit i don't post here, because of two reasons:
    1. I was not able to get a good measurement result with a multimeter. I should integrate the consumption over time to get a real result.
    2. The lifetime of a sensor is dominated by the sleep consumption, not by the operating consumption (if transmission time is just a few times per hour)
    There are still some improvements to do, but ehh, this is just a prototype.
    Used components:
    -Arduino pro mini 3.3V @ 8Mhz (mcu board)
    -NRF24L01 (wireless board)
    -3.3V StepUp (0.8V-3.3V from Canton electronic an ebay product link)
    Modifications:
    -Arduino board: Cut LED
    -Arduino board: Cut LDO
    -StepUp board: Cut LED
    Physical dimensions (without pin headers):
    65mm x 22mm x 25mm
    Which values the sensor can send?
    In general this is just a battery monitor, as i want to get some experience of power consumption, but the pin header is able to work with various types of sensors. I use a simple DS18B20 temperature sensor on the header pins.
    Here are some pictures:
    Overall view1
    upload-55448569-77ab-4346-80ce-0fbb859991ea
    Overall view2
    upload-47cc27d8-c72c-47f6-8219-ed2668202c61
    Overall view3
    upload-ec04de50-8172-4891-914f-413dafa86824
    Overall view4
    upload-10334a15-91fb-4171-bda9-92e976e95de7
    Unused space over battery, but i didn't had the correct pin headers at home "mea culpa"
    upload-3e47d133-e3e2-46e0-8fc1-c3d667439ece
    Disassembled view1
    upload-fce77d46-7b45-4388-920d-f74055c0a75e
    Disassembled view2
    upload-6278a2b6-a1ce-41a1-a788-146209c0ab04
    Assemble view1
    upload-aba7428f-b2b4-40c3-a727-c4923e15f347
    Assemble view2
    upload-46644d8c-9537-431b-8bc2-eeaace130e79
    Assemble view3
    upload-2dd25b83-45e6-4861-9934-9fb3288185ef
    Assemble view4
    upload-d954cb15-453d-4817-bc0c-cb589acdf69d
    Assemble view5
    upload-ea78b989-eeb8-4d9d-be4d-846bf6b3e8d1
    Bottom view (remember - just a prototype)
    upload-62b434cd-c8d5-48dd-b959-d897f8de4224
    I hope i could give you some potential ideas for your own project.
    Questions, suggestions, feedback, all is welcome.
    • T Offline
      T Offline
      tbowmo
      @klim
      What is the range of this unit? (ie. how far away from the GW can you put it). The reason I ask, is that you have put the stepup converter very close to the antenna area for the nrf module.
      And also a battery (made of metal) is close to the antenna, which also could impact drastic on the antenna performance
      • K Offline
        K Offline
        klim
        Hi, at the time i've just tested a few meter, sorry to be not more specific, i've not measured it. Because of the NRF module has a gnd shield on the bottom side and the StepUp too, so they have their gnd sided very close to each other, i hope to not get any signal losses.
        • T Offline
          T Offline
          that0n3guy
          @klim Hows the battery life looking?
          • K Offline
            K Offline
            klim
            Hi, based on the results of my last measurement the sensor needs 90µA, while sleeping + consumption for transmitting, but this depends on the configuration.
            The theoretical battery life just for sleeping (without battery self discharge) should be:
            2500mAh/90µA=27777h
            27777h/24h=1157d
            1157d/365d/3,17a
            • D Offline
              daulagari
              @klim : Nice idea and thanks for documenting it here!
              Following @tbowmo I am wondering what is the effect of the stepup converter very close to the antenna; although the converter will work in the kHz range, it harmonics can be in the 2.4 GHz range and quite loud, so it could be that some channels are worse than others. Also the coil can induct currents in the traces of the NRF24L01 board.
              I am not so worried about the metal of the battery, that will impact the antenna pattern and maybe the impedance but the overall energy transmitted will be largely the same.
              But, that is all theory would be good to know if you see any drawback.
              I do not see a capacitor on the NRF24L01 board between the 3.3V and GND. Looks like you have one on the board but I think you can improve things by adding a low-ESR capacitor on the NRF24L01 board see http://www.mysensors.org/build/connect_radio
              • K klim
                2500mAh/90µA=27777h
                27777h/24h=1157d
                1157d/365d/3,17a
                T Offline
                T Offline
                that0n3guy
                2500mAh/90µA=27777h
                27777h/24h=1157d
                1157d/365d/3,17a
                I'm basically asking because everyone states that the step-up pulls like 1ma even arduino is in sleep. Your saying yours is not doing that?
                • K Offline
                  K Offline
                  klim
                  @daulagari:
                  I'm aware of that it is not the best option to mount them close to each other, but as it is just a prototype nearly everything is allowed :-)
                  I did a quick test with success on a distance of 5m through a cement-wall of 20cm width.
                  A capacitor for NRF24l01 is already on board, it's the grey one with a capacity of 4µ7. I know it's just an ordinary aluminium capacitor and not low-ESR, but i had nothing other at home.
                  @that0n3guy:
                  Again tested at battery side: 90µA @ 1.5V --> 135µW. Take a look here:
                  upload-851de198-37be-40aa-9307-f087de7faa52
                  • M Offline
                    M Offline
                    m26872
                    wrote on last edited by m26872
                    @klim If you press the yellow button you'll see 1mAac. It will not imply real power, but impair battery life, Question is how much?
                    • K Offline
                      K Offline
                      klim
                      @m26872: Why should i measure a dc current in ac mode? I did it anyway, the result was 0.87mA when sleeping. Please enlighten me.
                      • T Offline
                        T Offline
                        tbowmo
                        @klim
                        As the stepup converter functions, by chopping the supply up with a squarewave (in the order of 100-400kHz) it will not be a dc current. It will be more like an AC current
                        see comment below.
                        • K Offline
                          K Offline
                          klim
                          Thanks a lot for clarifying, i didn't thought about that before. This means the power consumption is not as good as it seems.
                          • T Offline
                            T Offline
                            tbowmo
                            Tried to search google to back up my theory, but I failed at it :sa:
                            So I turned to a group of fellow electronic nerds, asking them how to measure things.. The conclusion from their responses is:
                            Use DC current measurement, if your multimeter is good at averaging things. Otherwise, use a oscilloscope with a series resistor, and use integral maths to calculate the real current usage..
                            So I was wrong in my assumptions.. Sorry :)
                            • K Offline
                              K Offline
                              klim
                              Thanks for your info. That was my toughts too, to use an oscilloscope and integrating the current over time, but first i need a good digital oscilloscope to do that.
                              • T Offline
                                T Offline
                                therik
                                This was also my method (using an oscilloscope to integrate the current), but...I found it difficult to measure the very low currents...µA range with an oscilloscope (these are very high quality Tectronics units, we have many at work, but there is some DC offset even though I calibrated the probe, yada yada yada). So, on some more recent measurements I used a Keithley bench multimeter with averaging. I guess the final test is to see how long the batteries (or battery) actually last.
                                • K Offline
                                  K Offline
                                  klim
                                  I know about the problems and accuracy for very low current measurements without special instruments. Therefore i want to buy a µCurrent Gold adapter soon, it is a very cost effective way to measure very low currents. This adapter with the combination of a digital oscilloscope with math is what we need here. But at the end as therik already said: the final test is to see how long the battery actually last
                                  • K klim
                                    T Offline
                                    T Offline
                                    tbowmo
                                    Only problem is, that this is going to take a very long time to check..
                                    • K Offline
                                      K Offline
                                      klim
                                      That's the reason, we must use instruments and methods to give predictions, instead of waiting for real results ;-)
                                      • T Offline
                                        T Offline
                                        therik
                                        The longer it takes to find out, the better, right? ;)
                                        R 1 Reply Last reply
                                        • T therik
                                          R Offline
                                          R Offline
                                          RJ_Make
                                          @therik Yes, but then any corrections also take longer to test.. :-)
                                          RJ_Make
                                          12.2k
