  3. Pro Mini issues
Pro Mini issues
12 Posts 6 Posters 3.0k Views 6 Watching
  • dpconsD
    dpconsD
    dpcons
    Hi All.
    I'm using a 3V Pro Mini and having issues loading the BinarySwitchSleepSensor2 app straight from web site. Sketch fails after a few seconds of loading.
    Details:
    Sketch uses 12768 bytes (41%) of program storage space. Maximum is 30720 bytes.
    Global variables use 446 bytes (21%) of dynamic memory, leaving 1602 bytes for local variables. Maximum is 2048 bytes.
    avrdude: verification error, first mismatch at byte 0x1c55
    0x7f != 0x5f
    The Pro Mini loads and runs Blink app and others but fails with this. The nRF24L01 radio is hooked up as shown in Guide, although this doesn't matter. Won't load without the radio attached either.
    The app loads and runs just fine on the ESP8266. Has anyone else had issues with the pro mini?
    Dan
    dbemowskD mfalkviddM 2 Replies Last reply
    • dpconsD dpcons
      Hi All.
      Details:
      0x7f != 0x5f
      Dan
      dbemowskD
      dbemowskD
      @dpcons Are you using the Arduino IDE as your programmer? Did you select the correct arduino and com port? When I program my pro minis, I have to watch when I compile and send. As soon as it gets done compiling and gets ready to send, I hit the reset button on the pro mini. Sounds like you may already know all of that, but I just mentioned it in case you didn't. One other thing that you may not know is that you NEED to have your FTDI adapter set to 3.3v and NOT 5v. Depending how you had it wired with your nRF24 radio, if you tried programming at 5v, you may have fried the radio.
      Can you show a pic of how you have this wired?
        Did you check if you selected the right arduino mcu? It is easy to select the 16mhz at 5v instead of the 8mhz 3.3v
        • dpconsD dpcons
          Hi All.
          Details:
          0x7f != 0x5f
          Dan
          Welcome to the community @dpcons
          See if changing usb cables helps.
          • dpconsD
            dpconsD
            dpcons
            Hey Guys,
            Thanks for the response. I've uploaded a jpg to show the connections. Yes, it's a 3V device. Before I use the minis I put 5V on RAW and check VCC. I've also selected the correct 328 configuration in the Arduino IDE. I've checked DTR with a scope and it's working fine, but I've held the reset button before programming, just to be safe. I've also used different Hub ports and cables as well as different FTDI programmers and Pro Mini boards. I even went back to the old version of the Arduino AVR Library. That's the reason for the posting. I've just started using the mysensors library, so I wasn't sure if all the examples worked on all devices and I didn't want to dig in the code. If you're telling me the Mini works with this code, then I can continue to look into other areas. Again, thanks to all! I appreciate your interest.
            Dan
            dbemowskD 1 Reply Last reply
            • dpconsD dpcons
              Hey Guys,
              Dan
              dbemowskD
              dbemowskD
              @dpcons Not that it matters too much to this situation, but when programming the pro minis, all that is needed is GND, VCC, RX and TX. Because you need to do a manual reset when programming, the DTR line is not necessary.
              bgunnarbB 1 Reply Last reply
                personally I leave the pro mini without headers on the programming side and just stick the FTDI headers in the pcb holes and incline it to make a stronger connection. :)
                • dbemowskD dbemowsk
                  bgunnarbB
                  bgunnarbB
                  bgunnarb
                  @dbemowsk Strange! I have never made a manual reset when programming my Pro Minis.
                  I have never been so busy since I retired!
                  dbemowskD ThucarT 2 Replies Last reply
                  • bgunnarbB bgunnarb
                    dbemowskD
                    dbemowskD
                    @bgunnarb That is the way I have done it for years and it has worked. I will have to try the DTR line.
                      ThucarT
                      ThucarT
                      Thucar
                      @bgunnarb said in Pro Mini issues:
                      I need to manually reset all my chinese Arduino clones as well. I either press the reset button right after the IDE finishes compiling the sketch and shows “uploading” or if I miss that mment, I’ll have to reset the *duino couple times while the IDE retries uploading.
                      Controller: Node-Red
                      Gateway: SerialGateway & GSMMQTTGateway
                      MySensors: 2.2.0
                        With dtr pin connected there is no need to reset.
                        • dpconsD
                          dpconsD
                          dpcons
                          This problem has been resolved. It appears my ANKER 10 port USB Hub is the problem. It's associated with the lower 4 ports of the hub. The remaining 6 are OK. I'm not sure what the actual problem is yet. The hub has a 60W power supply attached so I doubt it's a power issue...maybe noise? I now have a 10 port Amazon Hub which works well. As for the DTR signal, I've always used it and have seldom used the reset buttons. Also, I think most of the Arduinos and clones have it implemented through the serial convertor chip as well. It's also on all the ESP32 and ESP 8266 clones I've used. Again, thanks everyone for your comments and suggestions.
