  3. 💬 Easy/Newbie PCB (RFM69 HW/W edition) for MySensors
mysensoreasynewbiepcbmysx
106 Posts 20 Posters 57.0k Views 19 Watching
  • sundberg84S sundberg84
    Everything is going fine so im taking this to the next level... from test to produktion.
    This sensor might be my most important summer sensor from now on ;)
    A couple of days ago I had some friends over which gave me a beer cooler, garden edition.
    Its pretty much a barrel in the ground which cools the beer down... (a bit atleast).
    I must say Im very impressed with the RFM69 so far... except the price, there has been no trouble at all. No repeaters, no capacitors, no fine tuning... nothing. Pretty much solder 'n' play!
    This node is burried in the far end on the garden (25m) and has to penetrate 3 concrete + 1brick wall to reach the GW in the celler... no problems, first try and bang!
    So far... the temperature in the cooler isnt very impressive, and I have only tried the first layer. I was afraid I would loose radio coverage if I put the sensors far down... but I will try.
    Cheers mates!
    Mr_sensor
    @sundberg84 said in 💬 Easy/Newbie PCB (RFM69 HW/W edition) for MySensors:
    Cheers mates!
    Hi, nice set-up. I have been reading this and havong a "newbie" question. I have a Newbie PCB build with the Nrf24l01+ which seems to give (me) a poor range.
    So would that improve having a rfm69 instead? Or will just adding an antenna improve the reach (I have more or less the same outside distance and concrete wall/ flooring I'd liek to cross). Now I just have a reach for approx 8 meters and one concrete floor (inside the house)? Which is not very good (even my z-wave devices are preforming much better - outside at 20 mtr from the house.
    Can the nrf240 be improved or do I need teh rfm69 (or even using a LORA ?).
      wrote on last edited by gohan
      #68
      I would get better quality nrf24 modules and using a PA LNA one on the gateway may also help. Sure the rfm69 at 433MHz can have a better wall penetration, but I think you can do with better radios. Look for CDEByte store on aliexpress, they have good radio modules. Also a poor quality power supply can reduce the effective range.
      If you want to try the RFM69 radios, you can "convert" the ones you have with this https://www.mysensors.org/hardware/nrf2rfm69
        Mr_sensor
        @gohan said in 💬 Easy/Newbie PCB (RFM69 HW/W edition) for MySensors:
        So these would be better?
        https://nl.aliexpress.com/item/E01-ML01DP5-Ebyte-2-4GHz-20dBm-2100m-nRF24L01-SPI-Wireless-transceiver-module/32638720689.html?spm=a2g0s.13010208.99999999.336.T3AfNk
        https://nl.aliexpress.com/item/CDEBYTE-2PCS-Lot-E01-ML01D-Wireless-Transceiver-For-Arduino-nRF24L01-2-4GHz-Antenna-Module-For-Microcontroll/32803704874.html?spm=a2g0s.13010208.99999999.333.T3AfNk
        https://nl.aliexpress.com/item/CDEBYTE-2PCS-Lot-Special-promotions-1800-meter-long-distance-nRF24L01-PA-LNA-wireless-modules-with-PCB/32803720600.html?spm=a2g0s.13010208.99999999.330.T3AfNk
        If I use one with PA_LNA on my Gateway are the pin-out the same as for the nrf24l+ as in the mysensors gatweay example?
        Also there are models with nrf24l+PA what is the difference with the nrf24l+ ones?
          Yes those. Pa stands for power amplifier, lna stands for low noise amplifier and it is used to amplify incoming signal to boost low signals. For gateway it is better to use these with the higher gain antenna, on the node it is up to you according to the size constraints you may have.
          • M Mr_sensor
            sundberg84S
            sundberg84S
            #71
            @mr_sensor I have the same experience. A good gateway radio is important. I also use a amplified version. Sometimes it has been poor radio clones that make the bad range as well. Even if you don't have a amplified radio 8m+ 1 wall should be possible.
              Mr_sensor
              @sundberg84 @gohan Ok thanks for the input I will order some of the extended ones :) and see if thing s will improve.
              • M Mr_sensor
                Mr_sensor
                @mr_sensor said in 💬 Easy/Newbie PCB (RFM69 HW/W edition) for MySensors:
                The parts mentioned above arrived. I thought just swapping the radio's and see if there is any improvement. But it seems my devices are not happy with there new radio :) ? So are these new devices coming with the same pin-out and are they using the same library as the non amplified radio"s ? Or do I need to alter my sketches or wiring for it to work?
                • M Mr_sensor
                  sundberg84S
                  sundberg84S
                  #74
                  @mr_sensor i think it should be the same pin out. Gohan might now better on the amplified version. As I said I don't use those much.
                  What kind of error do you have now?
                    they both work fine for me, just define in code wether is HW version
                      Mr_sensor
                      wrote on last edited by Mr_sensor
                      #76
                      @gohan Ok, what do you mean by "define HW" in code" ? This in my code:
                        but this is RFM69 radio pcb not NRF24
                          Mr_sensor
                          I know but I am using the nrf24 pcb.
                          Do I need to add something like this when using the AP version?
                          Or just #define MY_RADIO_NRF24
                          • M Mr_sensor
                            sundberg84S
                            sundberg84S
                            @mr_sensor correct. As I said I'm no expert with the amplified version but that looks ok. I suggest you try it out. If it's wrong you will get an error and you can post that .
                              You should be able to swap a regular nrf24 with a PA version without changing code, given you have a stable 3.3v supply that can handle extra power
                              • sundberg84S
                                sundberg84S
                                This has now been updated to rev. 10. There are still some images left to change.
                                The gerbers has been updated and sent to manufacturer but it will take some days before they update.
                                Make sure it says rev5 before ordering.
                                P 1 Reply Last reply
                                  P
                                  P
                                  Prakhar Birla
                                  Thanks for creating these PCBs, it's great to have a stable base to work upon!
                                  I want to make a daughter board using the MYSX connector but the pin choices are a little inconvenient. Like A0 is used by the battery voltage measure circuit, D2 is used by the RFM69 radio. Could you share your reasons for using these pins and whethe it is possible to use different pins?
                                  Finally, I couldn't find instructions for adding the flash memory. That is a great addition to this board!
                                  Cheers,
                                  Birla
                                  • P Prakhar Birla
                                    Cheers,
                                    Birla
                                    sundberg84S
                                    sundberg84S
                                    @prakhar-birla Hi!
                                    The reason is that MysX is a fixed connector. This way you can make daughterboards. If the pins would be inconsistent it would not work. You can use these pins (A0 + D2) if you dont use it for radio or battery measurment.
                                    I havent had time to make instructions for the flash memory, but there are several others on this site which have made that. Look around for @scalz work for example on openhardware.io
                                      @prakhar-birla Hi!
                                      P
                                      P
                                      Prakhar Birla
                                      Hey @sundberg84,
                                      Thanks for the clarification! I checked the spec docs for the MYSX connectors but they didn't mention any fixed pins, just the purpose/pin type. Anyway, for different MCU it will inevitably be different pins. On Arduino Pro Mini since there are only two external interrupts there's no escaping D2, the analog pin on the other hand in an easy fix either use a different pin for battery measurement (A6/A7 is only a via away) or a different pinout on the MYSX.
                                      I couldn't find any instructions for the flash memory, please share a link when you can. Also is it possible to add it without the footprint on the PCB?
                                      PS. I just ordered a set of 10 PCBs through Open Hardware :)
                                      • P Prakhar Birla
                                        Hey @sundberg84,
                                        sundberg84S
                                        sundberg84S
                                        @prakhar-birla - well the idea with MysX is that the pin-order is fixed so you can attach any daugherboard to it. If you start mixing the pins around you will not be able to transfer a daugherboard from one motherboard to another since they will be different. Im not sure how MysX would translate to other MCU but other have digital and analog pins as well - so it would be most possible to connect MysX to other mcu.
                                        About the external interrupt you are right, there are 2 on the atmega328. On my Nrf24l01+ version you can use D2 as an interrupt but since the RFM69 radio uses this pin you can not on this version. D3 is your only choise and if you need more you might have to create an external circuit.
                                        As I said, I havent had time to look over SPI flash instructions yet. I havent even tried it - this is a user request from this forum. You can search this forum for more information - like this: https://forum.mysensors.org/topic/3160/ota-flash-types-for-mysensors/
                                        • ferroF
                                          ferroF
                                          ferro
                                          Hi @sundberg84, on Easy/Newbie PCB rfm69 version PIN3 of MysX connector is connected to 3.3V resp. to the output from voltage regulator. When I compare with Easy/Newbie PCB nrf24l01 version, MysX PIN3 is connected to input of voltage regulator (to 5V). Is this a mistake in design of Easy/PCB rfm69 version?
