  3. 💬 Easy/Newbie PCB (RFM69 HW/W edition) for MySensors
mysensoreasynewbiepcbmysx
106 Posts 20 Posters 57.0k Views 19 Watching
  • M Mr_sensor
    @sundberg84 @gohan Ok thanks for the input I will order some of the extended ones :) and see if thing s will improve.
    Mr_sensor
    @mr_sensor said in 💬 Easy/Newbie PCB (RFM69 HW/W edition) for MySensors:
    The parts mentioned above arrived. I thought just swapping the radio's and see if there is any improvement. But it seems my devices are not happy with there new radio :) ? So are these new devices coming with the same pin-out and are they using the same library as the non amplified radio"s ? Or do I need to alter my sketches or wiring for it to work?
    • M Mr_sensor
      sundberg84S
      sundberg84S
      #74
      @mr_sensor i think it should be the same pin out. Gohan might now better on the amplified version. As I said I don't use those much.
      What kind of error do you have now?
        they both work fine for me, just define in code wether is HW version
          Mr_sensor
          wrote on last edited by Mr_sensor
          #76
          @gohan Ok, what do you mean by "define HW" in code" ? This in my code:
            but this is RFM69 radio pcb not NRF24
              Mr_sensor
              @gohan said in 💬 Easy/Newbie PCB (RFM69 HW/W edition) for MySensors:
              I know but I am using the nrf24 pcb.
              Do I need to add something like this when using the AP version?
              Or just #define MY_RADIO_NRF24
              • M Mr_sensor
                sundberg84S
                sundberg84S
                @mr_sensor correct. As I said I'm no expert with the amplified version but that looks ok. I suggest you try it out. If it's wrong you will get an error and you can post that .
                  You should be able to swap a regular nrf24 with a PA version without changing code, given you have a stable 3.3v supply that can handle extra power
                  • sundberg84S
                    sundberg84S
                    This has now been updated to rev. 10. There are still some images left to change.
                    The gerbers has been updated and sent to manufacturer but it will take some days before they update.
                    Make sure it says rev5 before ordering.
                    P 1 Reply Last reply
                    • sundberg84S sundberg84
                      P
                      P
                      Prakhar Birla
                      @sundberg84 said in 💬 Easy/Newbie PCB (RFM69 HW/W edition) for MySensors:
                      Thanks for creating these PCBs, it's great to have a stable base to work upon!
                      I want to make a daughter board using the MYSX connector but the pin choices are a little inconvenient. Like A0 is used by the battery voltage measure circuit, D2 is used by the RFM69 radio. Could you share your reasons for using these pins and whethe it is possible to use different pins?
                      Finally, I couldn't find instructions for adding the flash memory. That is a great addition to this board!
                      Cheers,
                      Birla
                      • P Prakhar Birla
                        Cheers,
                        Birla
                        sundberg84S
                        sundberg84S
                        @prakhar-birla Hi!
                        The reason is that MysX is a fixed connector. This way you can make daughterboards. If the pins would be inconsistent it would not work. You can use these pins (A0 + D2) if you dont use it for radio or battery measurment.
                        I havent had time to make instructions for the flash memory, but there are several others on this site which have made that. Look around for @scalz work for example on openhardware.io
                          @prakhar-birla Hi!
                          P
                          P
                          Prakhar Birla
                          Hey @sundberg84,
                          Thanks for the clarification! I checked the spec docs for the MYSX connectors but they didn't mention any fixed pins, just the purpose/pin type. Anyway, for different MCU it will inevitably be different pins. On Arduino Pro Mini since there are only two external interrupts there's no escaping D2, the analog pin on the other hand in an easy fix either use a different pin for battery measurement (A6/A7 is only a via away) or a different pinout on the MYSX.
                          I couldn't find any instructions for the flash memory, please share a link when you can. Also is it possible to add it without the footprint on the PCB?
                          PS. I just ordered a set of 10 PCBs through Open Hardware :)
                          • P Prakhar Birla
                            Hey @sundberg84,
                            sundberg84S
                            sundberg84S
                            @prakhar-birla - well the idea with MysX is that the pin-order is fixed so you can attach any daugherboard to it. If you start mixing the pins around you will not be able to transfer a daugherboard from one motherboard to another since they will be different. Im not sure how MysX would translate to other MCU but other have digital and analog pins as well - so it would be most possible to connect MysX to other mcu.
                            About the external interrupt you are right, there are 2 on the atmega328. On my Nrf24l01+ version you can use D2 as an interrupt but since the RFM69 radio uses this pin you can not on this version. D3 is your only choise and if you need more you might have to create an external circuit.
                            As I said, I havent had time to look over SPI flash instructions yet. I havent even tried it - this is a user request from this forum. You can search this forum for more information - like this: https://forum.mysensors.org/topic/3160/ota-flash-types-for-mysensors/
                            • ferroF
                              ferroF
                              ferro
                              Hi @sundberg84, on Easy/Newbie PCB rfm69 version PIN3 of MysX connector is connected to 3.3V resp. to the output from voltage regulator. When I compare with Easy/Newbie PCB nrf24l01 version, MysX PIN3 is connected to input of voltage regulator (to 5V). Is this a mistake in design of Easy/PCB rfm69 version?
                              • ferroF ferro
                                sundberg84S
                                sundberg84S
                                @ferro - Hi no - the RFM version is 3.3v only. nrf24 data pins are 5v tolerant but the rfm radio isnt so thats why.
                                ferroF 1 Reply Last reply
                                  ferroF
                                  ferroF
                                  ferro
                                  @sundberg84 - ok thanks, it makes sense ;). I was asking because I connected your Dimmable Led Strip daughterboard via MysX to this Easy PCB. Dimmer daughterboard is providing 5V on PIN3 (when LM2940CT voltage regulator is used on it). This would bring 5V to output of voltage regulator on Easy PCB so I disconnected PIN3 connection between dimmer daughterboard and Easy PCB. I connected PIN3 from dimmer board by wire to >3.3V power input of Easy PCB instead. Other option I'm thinking of would be not using voltage regulator on dimmer daughterboard at all but use its 12V raw voltage provided by dimmer board via MysX PIN1 (+ raw jumper on Easy PSB) and use voltage regulator (LE33) on Easy PCB only.
                                  • N
                                    N
                                    Nigel31
                                    Schematic rfm69 version.
                                    Needs updating, as it shows nrf radio.
                                    • N Nigel31
                                      sundberg84S
                                      sundberg84S
                                      @njwyborn - you are correct, thanks for noticing! Its been corrected!
                                      • E
                                        E
                                        eMdzeJ
                                        Hi, I've lipo battery pack with 4,2v maximum voltage (3,6v nominal). Can I safely use it with this board? Do I need any modifications?
                                        • E eMdzeJ
                                          sundberg84S
                                          sundberg84S
                                          @emdzej - I'm not sure but it's designed for 3.3v. you have to check the rfm radio for Max input voltage on VCC and io. I think it's 3.3v so you might have to regulate down your lipo battery to this.
