  3. Recommendation for motorized roller blinds solution (actual motor, like somfy, rollertrol, ebay...)
37 Posts 10 Posters 13.8k Views 10 Watching
  • J jacikaas
    Hello. I also thinking of my roller blinds automation and i was found this on thingiverse https://www.thingiverse.com/thing:2392856
    Its very cheap project for 5-10€/window. With 28BYJ-48 stepper motor you at least need 9v psu, it's even better with 12v.
    I also saw, that someone was already discusing in mysensors forum about how to start this motor and there is a code. Of course if you want to use percentage for open blinds, you should modify code and add some typen of encoder on mechanics. https://forum.mysensors.org/topic/3394/curtain-control-node/31
    @jacikaas Nice find!
    However, I think this thread is about outdoor roller blinds, like:
    Which require a lot more power to be operated.
    J 1 Reply Last reply
    • YveauxY Yveaux
      J
      J
      jacikaas
      @Yveaux
      Yes, that outdoor blinds need a lot more power :)
      Nca78N 1 Reply Last reply
      • J jacikaas
        @Yveaux
        @jacikaas said in Recommendation for motorized roller blinds solution (actual motor, like somfy, rollertrol, ebay...):
        @Yveaux
        Some indoor blinds too, I will try the solution in your link but I don't think it will work for me as I have a lot of height (> 2m) and up to 1,8m width, it gets pretty heavy.
        NeverDieN J 2 Replies Last reply
        • Nca78N Nca78
          @Yveaux
          @nca78 Maybe just a regular low RPM, high torque motor would work best for you?
            @neverdie said in Recommendation for motorized roller blinds solution (actual motor, like somfy, rollertrol, ebay...):
            Yes there are 220V motors you put inside the tube (same concept than the link given in the first post).
            • K
              K
              krejcarek
              Hello, let me shortly give you my 5 cents about this topic.
              I have since 1.5 years a roller blind solution up and running. The logic is based upon the solution of @scalz.
              It uses standard Becker (similar quality as Somfy) motors 4 wired, that normally has an indoor switch unit. I chose this since significantly cheaper than any radio controlled solution, and absolutely robust. Definitely a plus for something firmly built into the walls.
              For control I have hubs for 4 windows each. They include mysensors, Arduino, and an 8 pcs relay board. Enabling of setting individual positioning by counting time. The total run time is adjustable through mysensors commands. This proved to be for me a simple but very reliable method. I can set any percentage, or even stop, and then it reports actual state. The complete ecosystem is within an openHAB controller, thus I can set automated rules, e.g. go down at the local dusk time, or gently wake up just by go up a bit.
              Code is here available: https://github.com/krejcarek/mysensors
              Overal very happy with the setup. Two issues I experienced:
              • some struggle with range, and unreliable transfer in mesh
              • the units are in the attic. In winter I experience some unreliable operation, some units "freeze". Can be literally, or due to some solder quality issues, not sure yet what is causing it.
              • Nca78N Nca78
                @Yveaux
                J
                J
                jacikaas
                @nca78
                Yes, thats quite heavy. Need to check it practically. I started to test the motor (now only on the desk), but my 28BYJ-48 motor is shaking with AccelStepper library. With some simple code without included any library - working fine, so I will look why thats happening.
                • D dakipro
                  I would like to have motorized blinds that can report current state and can be controlled from several sources (manually via button, remotely via mqtt etc) and also be "percentage" controllable, meaning shut only 30% or so.
                  I can fix pretty much all with mysensors, but motor itself is a tricky part, I would like it to be robust and "properly" done (easiest is with commercial products).
                  I leave in Norway, Europe and I have not yet ordered any motor, still checking out options. I saw recommendations about Somfy motors (I also like that they can run on batteries). But from what I have understood the motor needs to have 3 wires (neutral and up and down) for arduino to determine current percentage? or is it?
                  They are also natively 433mhz, and I have rfLink for 433 comunication but again there is issue of keep state synchronized with multiple inputs (physical remote, mqtt, etc...)
                  I was considering something from ebay as well, but again, two vs three wires for mysensors, can that work somehow?
                  f.eks. https://www.ebay.com/itm/DC-24V-30RPM-DIY-Electric-Roller-Blind-Shade-Tubular-Motor-Holder-Kit/253225599792
                  Open to suggestions about any solution, if it helps I have rflink for 433 communication, I do have z-wave, xiaomi controllers if some of these can do it easier.
                  Would like hear what people would recommend for blinds?
                  parachutesjP
                  parachutesjP
                  parachutesj
                  wrote on last edited by parachutesj
                  #27
                  @dakipro I do have somfy motors wired to the control panels everywhere. The motors itself are very good. There are also newer ones I think which can be controlled wireless in case you do not have the wires yet or would need to wire it. then it only needs power at the window.
                  For controlling, I used to have mysensors, but never had very reliable results. Potentially my bad electronic skills and switched to comercial solution lately (Homematic).
                  for controlling, you might need to look into this:
                  https://github.com/marvinroger/arduino-shutters
                  • D
                    dakipro
                    wrote on last edited by dakipro
                    #28
                    At the end I purchased and installed z-wave roller blinds from Swedish company m.nu .
                    So far so good, and if all is great, I will order three more motors (and two knobs/switches) for living room and terrace doors (which should also automatically keep the shades open if doors er open, to prevent damage).
                    Made a basic node-red flow that uses xiaomi lux sensor to get them down, but ultimate goal is to have them understand when the light is very bright and when it is "cozy", perhaps even knowing to get the blinds just low enough. Found one good explanation on the internet, will check it out (perhaps use multiple lux sensors strategically placed around the room to determine sun position and strength). Any tips and tricks?
                    (gif of the action, cannot upload gif to the forum https://media.giphy.com/media/5aY6vSwVn1hsdYC6nd/giphy.gif gif is twice the speed)
                    gohanG parachutesjP 2 Replies Last reply
                    • wallyllamaW
                      wallyllamaW
                      wallyllama
                      • D dakipro
                        @dakipro what did you use as remote controller?
                        • D
                          dakipro
                          It is a Smart Color Button - Philio, got it as a package with the motor itself, from m.nu
                          https://www.m.nu/rullgardin/motorisera-rullgardin-1-motor-z-wave-24v?nosto=productcategory-nosto-3
                          It is wireless, gyroscope based "button" that works directly with motor itself. They say battery lasts for 6months, but it is usb rechargeable, so not a biggie. It reports battery level to the controller so that is a plus.
                          As far as WAF goes, it is wireless and looks nice so that is a plus, but to use it it is a bit, well.. different to operate as it is just held by magnet on the holder/wall and has no rotation limitats, so it is not 100% intuitive for first time use as you just turn it and then nothing happens, then you have to wait almost 2s for it to settle and send new position to the shades, and one cannot change direction (at least I didn't find how) so "left" might be counter intuitive as if shades are open or closed, so it is a bit fiddly to operate. Also it has a tolerance rotation, meaning that fine adjustments for the shades are a bit hit and miss, so...
                          But I am hoping that blinds will mostly work automatically so that would not matter that much. And I didn't find some much better remote dimmer-like controllers for the blinds, so.. it will work for now. Easy to replace I think
                          • D dakipro
                            parachutesjP
                            parachutesjP
                            parachutesj
                            @dakipro why bother with individual sensors at the windows? You can calculate the sun position (azimuth and elevation) any time during the day and check if it would be possible for the sun to shine into the room. And in second step you only need to know if sun is shining or it is cloudy. Simplest way is using an online weather service. However I noted that this is not very reliable. My solution is based on MySensors:
                            It is a weather station with some sensors (rain, temp, pressure). I've started with a light sensor but found it very unreliable also protection from environment is difficult.
                            So at the end my sun senors is quite simple. One dallas sensor exposed to the sun and a second one in the shade. If the difference is high enough, sun is shining. Depending on your geographical location and preferences values might vary but for me (Zurich, CH) 10 degree celsius seems to be a good value.
                            • parachutesjP parachutesj
                              #33
                              @parachutesj said in Recommendation for motorized roller blinds solution (actual motor, like somfy, rollertrol, ebay...):
                              Clever! Which library or algorithm do you recommend for that?
                              parachutesjP 1 Reply Last reply
                                parachutesjP
                                parachutesjP
                                parachutesj
                                @neverdie I am not that smart, just using the library from my controller: the astro binding for openHAB. It returns any time of the day the sun position based on your location. So what I do is basically check for any window* in the house if azimuth is between two values and if true checking in addition if sun is shining and when both are true, the rollershutter will go down. When sun stops shining or the sun has moved away, it will go up again.
                                Elevation is no big deal in my case, only on the western side in late afternoon during winter months but for a start, I would recommend working with azimuth only.
                                Also the inputs for down and up should have different values (e.g. going down > 10 degree; going up < 8 degree) otherwise they might constantly go down/up when reaching the peaks.
                                And to make it more complicated, I also added conditions if someone is present, if it is raining, wind is too strong etc.
                                Elevation is mainly used to trigger sunrise and sunset events (open in the morning, close in the evening)
                                *for practical reasons I have groups based on the side of the house, but then doing different things.
                                • D
                                  dakipro
                                  thanks @parachutesj , I was thinking of something similar as well, sounds much simpler then my initial thought to have several sensors in a line to determine position of the shade in the room... I also like your temperature sensor solution, as that is actually what we would mostly like to react to, especially on the winter.
                                  I have quickly found one solution on the internet, using luminosity sensor http://www.instructables.com/id/A-solar-tracking-automatic-motorized-window-blind-/
                                  I must also deal with "manual override" but I have seen some design patterns for it already, using the "dead switches" / proxy items. And a door that should prevent blinds to go down if doors are open. Should be possible to program in node-red.
                                  And according to my wife, I must fix it all very soon :)
                                  Thanks again, will look more into it.
                                  • D dakipro
                                    parachutesjP
                                    parachutesjP
                                    parachutesj
                                    @dakipro well WAF is important. Mine complained a lot when things didn't work but as it is quite stable she enjoys it but would never state that ;-)
                                    A perfect solution is always very difficult to achieve. However when looking at my office where all blinds are triggered at the same time on any side of the building, it never works well and just annoyes anyone.
                                    Here at home, it works in most cases but you could always tune a bit. That is what I meant with "starting with azimuth and forget about elevation". There are cases in early morning during bright winter days when sun rises there is sun shining and blinding us at the dining room table. temperature difference is too low and it would not react. Two possibilities:
                                    a) manually trigger or
                                    b) build an even more complex rule (which I did).
                                    But these are cosmetics. And one could not predict all cases over 365 days in all possible weather situations.
                                    Regarding dead switch:
                                    I do not have any logic in my actuators. Fullstop!
                                    All comes from openHAB.
                                    First of all I do have one master switch, this kills everything. No actuator can be triggered automatically (sometimes important for WAF).
                                    Second there are certain conditions which cannot be overruled: e.g. if it starts raining, the roof windows close also when the wind speed is above trigger, rollershutters go up. These are mainly in order to prevent damage (except when master switch - rule 1 - is off).
                                    And then the rest could be easily achieved. If done with MySensors, just send an additional fake state back to the controller when you manually trigger something and then check in your rules:
                                    //light goes on
                                    send( myLightSwitch.set(1) );
                                    send( myManualStatus.set(1) );
                                    Then check in your rules if that value for myManualStatus is 1 or 0.
                                    I work for example with my rollershutters like this: when it goes down automatically, it goes to 85%. If it shall go up, I also check if it is at 85% - if not, then someone set it manually and I do not move it. Chances are pretty high, that if it is triggered manually it is not at 85% and rather at 84 or 86 or even something completely different.
                                    But then when sun sets, it overrides again and automatic kicks in again.
                                    gohanG 1 Reply Last reply
                                      //light goes on
                                      @parachutesj that sound a reasonable approach
