  3. Node running on supercaps and a solar panel.
59 Posts 5 Posters 11.2k Views 6 Watching
  • N Offline
    N Offline
    #34
    Try running with your fuses set to xFF xDA xC2, That way your BOD will be turned off, you'll be running from the internal 8mhz resonator, and you'll be waking from sleep in <4uSec.
    alexsh1A 1 Reply Last reply
    • N NeverDie
      alexsh1A Offline
      alexsh1A Offline
      alexsh1
      #35
      @neverdie I have already all that. I am using this node https://www.openhardware.io/view/76/Stamp-size-MySensor-node
      Let's see when I have final results. I have this supercap AVX 30F with ESR = 0.02ohm (vs Vishay 15F ESR=1.8Ohm used with Moteino and BQ25570 at lowpowerlab)
      EDIT: Another point is signing/encryption. This would affect supercap charge as the node would be transmitting more data to GW.
      N 1 Reply Last reply
      • alexsh1A alexsh1
        @gohan However, in the nutshell you are right. With a small solar battery (53mm x 30mm, 5V 0.15W), this is what I get:
        and today is an extremely cloudy day (no sun at all). Harvesting works really well.
        I implemented a voltage divider yesterday with 1.8M / 470k resistors. Now I can monitor voltage in Domoticz:
        voltage at 22:00 yesterday - 4.797V
        voltage at 12:00 today - 4.887V
        @alexsh1 I use a total of 20F 5.5V supercaps and they discharge much more during night most likely because the buck/boost converter is not very low power and supercaps are chinese quality, but as far as I can get 36/48h of runtime without solar charge I should be fine
          alexsh1A Offline
          alexsh1A Offline
          alexsh1
          #37
          @gohan As you may see from the graph above my self discharge + sleep/tx consumption during the night dropped voltage from 4.851V at 21:00 (I charged supercaps initially) to 4.549V at 08:00. This is the rate of about 0.3V per 12 hours, I estimate that I have around 10 days without any charging before I run out of energy.
          It took 4h 25mins on a cloudy day (see another graph) to get 2x10F in series supercaps fully charged to 5.047V
            You are using a very efficient circuit and good quality supercaps, I loose about 1V in 12 hours
              alexsh1A Offline
              alexsh1A Offline
              alexsh1
              @gohan Did you try to measure your sleeping current?
              • alexsh1A alexsh1
                N Offline
                N Offline
                @alexsh1 said in Node running on supercaps and a solar panel.:
                If anything, you should have an advantage, since the nRF24L01 transmits at a faster bitrate, and using significantly less Tx power also.
                • N Offline
                  N Offline
                  Are you using the passive mode option for mysensors? If not, that could be part of what's draining you.
                  • N NeverDie
                    alexsh1A Offline
                    alexsh1A Offline
                    alexsh1
                    #42
                    @neverdie said in Node running on supercaps and a solar panel.:
                    I did notice there is an option:
                    #define MY_PASSIVE_NODE
                    What is the passive node option please?
                    I am not using it and yet I do not have any problems with draining
                    EDIT: I see now
                        All transport-related checks and safety-mechanisms are disabled.
                        Requires that MY_NODE_ID is set, MY_PARENT_NODE_ID and MY_PARENT_NODE_IS_STATIC are optional.
                        Singing, registration, and OTA FW update are disabled.
                    • alexsh1A alexsh1
                      EDIT: I see now
                      alexsh1A Offline
                      alexsh1A Offline
                      alexsh1
                      In my view disabling transport related checks is not an option.
                      Singing, registration, and OTA FW do take a lot of power. Especially OTA. It is slow and takes a lot of up time.
                      • N Offline
                        N Offline
                        It sounds like you're happy already. Good luck!
                          If I remeber well, passive node is used when you have a very tiny node, with low memory that only send data one way, like RF433
                            alexsh1A Offline
                            alexsh1A Offline
                            alexsh1
                            @gohan OK, but I think the key here is to get consumption down to something meaningful - 5uA or something. The only down side when not using a passive node is that if GW is disconnected, node would not go to sleep, but will be trying to connect to GW. define MY_TRANSPORT_UPLINK_CHECK_DISABLED would disable the node sending more than MY_TRANSPORT_STATE_RETRIES times message
                              even if it drains the battery when the GW is dead, it is no big deal as you just have to wait for some sunlight
                                alexsh1A Offline
                                alexsh1A Offline
                                alexsh1
                                @gohan True! I was more talking about super small nodes working on CR1632. I have a few of these.
                                • alexsh1A Offline
                                  alexsh1A Offline
                                  alexsh1
                                  Another interesting set of graphs (voltage scale is wrong - please ignore):
                                  This is with signing:
                                  This is without signing:
                                    It looks a little irregular to me, doesn't it?
                                      alexsh1A Offline
                                      alexsh1A Offline
                                      alexsh1
                                      @gohan Well, the point is that signing does take more tx time. Therefore, voltage does drop upto 0.2-0.3V.
                                      I am not sure about irregularities though
                                        Maybe it has to do with the harvesting chip. My graph looks like a sawtooth from day to day.
                                        • N Offline
                                          N Offline
                                          For this type of comparison, I think you're better off charging up the supercap in a standardized way and then running with the solar panel disconnected. Otherwise, how recently and how long the supercap was charged to full capacity can affect the rate of discharge.
