  3. Node running on supercaps and a solar panel.
59 Posts 5 Posters 11.2k Views 6 Watching
    even if it drains the battery when the GW is dead, it is no big deal as you just have to wait for some sunlight
    alexsh1A Offline
    alexsh1A Offline
    alexsh1
    @gohan True! I was more talking about super small nodes working on CR1632. I have a few of these.
    • alexsh1A Offline
      alexsh1A Offline
      alexsh1
      Another interesting set of graphs (voltage scale is wrong - please ignore):
      This is with signing:
      This is without signing:
        It looks a little irregular to me, doesn't it?
        alexsh1A 1 Reply Last reply
          alexsh1A Offline
          alexsh1A Offline
          alexsh1
          @gohan Well, the point is that signing does take more tx time. Therefore, voltage does drop upto 0.2-0.3V.
          I am not sure about irregularities though
            Maybe it has to do with the harvesting chip. My graph looks like a sawtooth from day to day.
            • N Offline
              N Offline
              For this type of comparison, I think you're better off charging up the supercap in a standardized way and then running with the solar panel disconnected. Otherwise, how recently and how long the supercap was charged to full capacity can affect the rate of discharge.
                alexsh1A Offline
                alexsh1A Offline
                alexsh1
                @gohan there is no harversting - this is just 30F cap connected to a node.
                I have two setups:
                1. BQ25570 + 2x10F supercaps in series and a small solar panel connected to a node. This is an excellent setup which can last for days without recharging
                2. 30F cap connected directly (initially I tried it via mcp1640) to a different node. The above graphs are from this setup.
                  I am re-measuring it them right now as the code was wrong.
                • alexsh1A alexsh1
                  A Offline
                  A Offline
                  Anticimex
                  @alexsh1 with signing you also get message bursts. Not only is the max size data transmitted for every signed message, two more messages are exchanged; a nonce request (small) and a nonce (big).
                  • A Anticimex
                    alexsh1A Offline
                    alexsh1A Offline
                    alexsh1
                    @anticimex said in Node running on supercaps and a solar panel.:
                    That's clearly visible on the graph.
                    • alexsh1A alexsh1
                      I have got my hands on 30F 2.7V supercapacitor.
                      With it was charged for the first time, it only lasted sending 2583 times (1 time a minute voltage and an 20ms LED pulse and then sleeping; sleeping consumption is 4-5uA). The number is a bit disappointing. It is however connected via boost MCP1640 to provide the node with a stable 3.3V. I may try to get the supercapacitor connected directly to the node to see if I can extract more packets.
                      alexsh1A Offline
                      alexsh1A Offline
                      alexsh1
                      #57
                      @alexsh1 said in Node running on supercaps and a solar panel.:
                      Supercap connected directly to the node stopped working at 2V.
                      I got about 8949 packets (10ms LED and sent voltage every minute. No signing). It has been running about 6 days.
                        basically you got 3 times packets sent without the booster?
                          alexsh1A Offline
                          alexsh1A Offline
                          alexsh1
                          @gohan That's correct and I am sure the result is not final
