  3. 💬 Single board computer UPS
arduinoraspberrydc-dcupsbattery
22 Posts 7 Posters 9.2k Views 6 Watching
  • openhardware.ioO
    openhardware.ioO
    openhardware.io
    https://www.openhardware.io/view/570/Single-board-computer-UPS
      Why the 2 batteries?
      kalinaK 1 Reply Last reply
        kalinaK
        kalinaK
        kalina
        @gohan said in 💬 Raspberry UPS (external):
        Because each battery has own advantages and disadvantages. I see the next picture:
        I think that UPS must support both battery types.
        mfalkviddM gohanG 2 Replies Last reply
        • kalinaK kalina
          @kalina does it support connecting both batteries at the same time, giving the lipo priority since it is rechargeable? or does the user choose to connect only one of the batteries?
            kalinaK
            kalinaK
            kalina
            @mfalkvidd said in 💬 Raspberry UPS (external):
            Yes, both batteries can be connected at the same time. This is allowed by circuit design - separate channels with MOSFET (see pic below).
            One of the tasks is develop the algorithm of functioning (priority and so on ..)
            • kalinaK kalina
              @kalina I have missed the big one wasn't rechargeable
              • kalinaK
                kalinaK
                kalina
                Today I have received a holder for DIN rail and i am trying to apply it for my enclosure now.
                G 1 Reply Last reply
                • kalinaK kalina
                  G
                  G
                  giltesa
                  Hello @kalina
                  It looks very good, but why do not I use a DIN rail box?
                  For example:
                  https://www.aliexpress.com/item/1-piece-87-60-52mm-din-rail-plastic-box-enclosure-junction-box-electronics-plastic-control-housing/32848666230.html
                  • G giltesa
                    Hello @kalina
                    For example:
                    kalinaK
                    kalinaK
                    kalina
                    Hello @giltesa
                    I have been looking for an enclosure for this device long time. But i didn't find suitable DIN rail enclosure. At first looks like that this one is suitable, but later one of the sizes does not fit.
                    • kalinaK
                      kalinaK
                      kalina
                      I have received pcb from PCBWAY today. 11 pcs were in the box instead 10 :grinning:
                      As always, quality is excellent for little money! In a few days I'll assembly the boards.
                      • alexsh1A
                        alexsh1A
                        alexsh1
                        Interesting.
                        I am using one of these
                        http://pimodules.com/
                        It is an internal UPS (Hat on), very advanced, very small with multiple settings battery options.
                        • alexsh1A alexsh1
                          Interesting.
                          kalinaK
                          kalinaK
                          kalina
                          @alexsh1
                          You share really great UPS! But in my case I need UPS for outdoor usage. I am going to use this UPS on temperature -20 C and lower. As for multiple settings, I put Atmega328p inside, so this UPS will be Arduino compatible and will have multiple settings too.
                          • kalinaK
                            kalinaK
                            kalina
                            Some photos of soldered device...
                            5_1525528221710_UPS_06.jpg 4_1525528221710_UPS_05.jpg 3_1525528221709_UPS_04.jpg 2_1525528221709_UPS_03.jpg 1_1525528221709_UPS_02.jpg 0_1525528221708_UPS_01.jpg
                              did you hand soldered all those smd components?
                                kalinaK
                                kalinaK
                                kalina
                                @gohan Yes. This first board was soldered manually. But I use the services of soldering in general.
                                • kalinaK kalina
                                  G
                                  G
                                  giltesa
                                  wrote on last edited by giltesa
                                  @kalina
                                  The PCB looks very good.
                                  I thought you soldered the PCBs manually. Where do you order the assembly of PCBs? Price?
                                  • G giltesa
                                    @kalina
                                    kalinaK
                                    kalinaK
                                    kalina
                                    @giltesa I order boards assembly in Ukraine. This is a small company that develops and small-scale production of electronics. The price is very different and depends on many factors, such as quantity and size of components, number of devices, etc. All questions are discussed individually.
                                    • kalinaK
                                      kalinaK
                                      kalina
                                      I tested this device yesterday and found some issues. Now, I want to share results.
                                      1. The analog comparator circuit must be modified. AIN0 should left floating (unconnected) and to this pin need connect the internal 1.1V bandgap reference. The 5V_Fail signal must be connected to AIN1 pin.
                                      2. VD7 must be removed and DC-DC will be works all time except power save mode.
                                      3. Need to add the MOSFET for manage LiPo charger, because this IC interrupts accumulator detecting signal (this signal always near 4..5 volts).
                                      4. Need to add the 5V (external) detecting signal to the microcontroller .
                                      5. Many of the components values should be revised.
                                      All these remarks will be taken into account in the new revision.
                                      Everything else works perfectly!
                                      For the first revision of the device, I'm completely satisfied with the result.
                                      • kalinaK
                                        kalinaK
                                        kalina
                                        The second revision of "Raspberry UPS" which now called "Single borad computer UPS" was received yesterday from PCBWAY.com
                                        berkseoB 1 Reply Last reply
                                        • kalinaK kalina
                                          berkseoB
                                          berkseoB
                                          berkseo
                                          @kalina
                                          Privet :)
                                          Great work, I want it (rev2).
