  3. 💬 Single board computer UPS
arduinoraspberrydc-dcupsbattery
22 Posts 7 Posters 9.2k Views 6 Watching
  • kalinaK kalina
    Today I have received a holder for DIN rail and i am trying to apply it for my enclosure now.
    G
    G
    giltesa
    Hello @kalina
    It looks very good, but why do not I use a DIN rail box?
    For example:
    https://www.aliexpress.com/item/1-piece-87-60-52mm-din-rail-plastic-box-enclosure-junction-box-electronics-plastic-control-housing/32848666230.html
    kalinaK 1 Reply Last reply
    • G giltesa
      Hello @kalina
      For example:
      kalinaK
      kalinaK
      kalina
      Hello @giltesa
      I have been looking for an enclosure for this device long time. But i didn't find suitable DIN rail enclosure. At first looks like that this one is suitable, but later one of the sizes does not fit.
      • kalinaK
        kalinaK
        kalina
        I have received pcb from PCBWAY today. 11 pcs were in the box instead 10 :grinning:
        As always, quality is excellent for little money! In a few days I'll assembly the boards.
        • alexsh1A
          alexsh1A
          alexsh1
          Interesting.
          I am using one of these
          http://pimodules.com/
          It is an internal UPS (Hat on), very advanced, very small with multiple settings battery options.
          • alexsh1A alexsh1
            Interesting.
            kalinaK
            kalinaK
            kalina
            @alexsh1
            You share really great UPS! But in my case I need UPS for outdoor usage. I am going to use this UPS on temperature -20 C and lower. As for multiple settings, I put Atmega328p inside, so this UPS will be Arduino compatible and will have multiple settings too.
            • kalinaK
              kalinaK
              kalina
              Some photos of soldered device...
              5_1525528221710_UPS_06.jpg 4_1525528221710_UPS_05.jpg 3_1525528221709_UPS_04.jpg 2_1525528221709_UPS_03.jpg 1_1525528221709_UPS_02.jpg 0_1525528221708_UPS_01.jpg
                did you hand soldered all those smd components?
                  kalinaK
                  kalinaK
                  kalina
                  @gohan Yes. This first board was soldered manually. But I use the services of soldering in general.
                  G 1 Reply Last reply
                  • kalinaK kalina
                    G
                    G
                    giltesa
                    wrote on last edited by giltesa
                    @kalina
                    The PCB looks very good.
                    I thought you soldered the PCBs manually. Where do you order the assembly of PCBs? Price?
                    • G giltesa
                      @kalina
                      kalinaK
                      kalinaK
                      kalina
                      @giltesa I order boards assembly in Ukraine. This is a small company that develops and small-scale production of electronics. The price is very different and depends on many factors, such as quantity and size of components, number of devices, etc. All questions are discussed individually.
                      • kalinaK
                        kalinaK
                        kalina
                        I tested this device yesterday and found some issues. Now, I want to share results.
                        1. The analog comparator circuit must be modified. AIN0 should left floating (unconnected) and to this pin need connect the internal 1.1V bandgap reference. The 5V_Fail signal must be connected to AIN1 pin.
                        2. VD7 must be removed and DC-DC will be works all time except power save mode.
                        3. Need to add the MOSFET for manage LiPo charger, because this IC interrupts accumulator detecting signal (this signal always near 4..5 volts).
                        4. Need to add the 5V (external) detecting signal to the microcontroller .
                        5. Many of the components values should be revised.
                        All these remarks will be taken into account in the new revision.
                        Everything else works perfectly!
                        For the first revision of the device, I'm completely satisfied with the result.
                        • kalinaK
                          kalinaK
                          kalina
                          The second revision of "Raspberry UPS" which now called "Single borad computer UPS" was received yesterday from PCBWAY.com
                          berkseoB 1 Reply Last reply
                          • kalinaK kalina
                            berkseoB
                            berkseoB
                            berkseo
                            @kalina
                            Privet :)
                            Great work, I want it (rev2).
                            • berkseoB berkseo
                              @kalina
                              Privet :)
                              kalinaK
                              kalinaK
                              kalina
                              @berkseo Hello,
                              First of all I have to check hardware part, and then i am going to develop software. In my opinion, production will be start in a month. I'll share photos of the soldered device tomorrow.
                              • kalinaK
                                kalinaK
                                kalina
                                #22
                                First soldered device:
                                And a small test:
