  3. 💬 Single board computer UPS
arduinoraspberrydc-dcupsbattery
22 Posts 7 Posters 9.2k Views 6 Watching
    Why the 2 batteries?
    kalinaK
    kalinaK
    kalina
    @gohan said in 💬 Raspberry UPS (external):
    Because each battery has own advantages and disadvantages. I see the next picture:
    I think that UPS must support both battery types.
    mfalkviddM gohanG 2 Replies Last reply
    • kalinaK kalina
      @kalina does it support connecting both batteries at the same time, giving the lipo priority since it is rechargeable? or does the user choose to connect only one of the batteries?
      kalinaK 1 Reply Last reply
        kalinaK
        kalinaK
        kalina
        @mfalkvidd said in 💬 Raspberry UPS (external):
        Yes, both batteries can be connected at the same time. This is allowed by circuit design - separate channels with MOSFET (see pic below).
        One of the tasks is develop the algorithm of functioning (priority and so on ..)
        • kalinaK kalina
          @kalina I have missed the big one wasn't rechargeable
          • kalinaK
            kalinaK
            kalina
            Today I have received a holder for DIN rail and i am trying to apply it for my enclosure now.
            G 1 Reply Last reply
            • kalinaK kalina
              G
              G
              giltesa
              Hello @kalina
              It looks very good, but why do not I use a DIN rail box?
              For example:
              https://www.aliexpress.com/item/1-piece-87-60-52mm-din-rail-plastic-box-enclosure-junction-box-electronics-plastic-control-housing/32848666230.html
              • G giltesa
                Hello @kalina
                For example:
                kalinaK
                kalinaK
                kalina
                Hello @giltesa
                I have been looking for an enclosure for this device long time. But i didn't find suitable DIN rail enclosure. At first looks like that this one is suitable, but later one of the sizes does not fit.
                • kalinaK
                  kalinaK
                  kalina
                  I have received pcb from PCBWAY today. 11 pcs were in the box instead 10 :grinning:
                  As always, quality is excellent for little money! In a few days I'll assembly the boards.
                  • alexsh1A
                    alexsh1A
                    alexsh1
                    Interesting.
                    I am using one of these
                    http://pimodules.com/
                    It is an internal UPS (Hat on), very advanced, very small with multiple settings battery options.
                    • alexsh1A alexsh1
                      Interesting.
                      kalinaK
                      kalinaK
                      kalina
                      @alexsh1
                      You share really great UPS! But in my case I need UPS for outdoor usage. I am going to use this UPS on temperature -20 C and lower. As for multiple settings, I put Atmega328p inside, so this UPS will be Arduino compatible and will have multiple settings too.
                      • kalinaK
                        kalinaK
                        kalina
                        Some photos of soldered device...
                        5_1525528221710_UPS_06.jpg 4_1525528221710_UPS_05.jpg 3_1525528221709_UPS_04.jpg 2_1525528221709_UPS_03.jpg 1_1525528221709_UPS_02.jpg 0_1525528221708_UPS_01.jpg
                          did you hand soldered all those smd components?
                            kalinaK
                            kalinaK
                            kalina
                            @gohan Yes. This first board was soldered manually. But I use the services of soldering in general.
                            • kalinaK kalina
                              G
                              G
                              giltesa
                              wrote on last edited by giltesa
                              @kalina
                              The PCB looks very good.
                              I thought you soldered the PCBs manually. Where do you order the assembly of PCBs? Price?
                              • G giltesa
                                @kalina
                                kalinaK
                                kalinaK
                                kalina
                                @giltesa I order boards assembly in Ukraine. This is a small company that develops and small-scale production of electronics. The price is very different and depends on many factors, such as quantity and size of components, number of devices, etc. All questions are discussed individually.
                                • kalinaK
                                  kalinaK
                                  kalina
                                  I tested this device yesterday and found some issues. Now, I want to share results.
                                  1. The analog comparator circuit must be modified. AIN0 should left floating (unconnected) and to this pin need connect the internal 1.1V bandgap reference. The 5V_Fail signal must be connected to AIN1 pin.
                                  2. VD7 must be removed and DC-DC will be works all time except power save mode.
                                  3. Need to add the MOSFET for manage LiPo charger, because this IC interrupts accumulator detecting signal (this signal always near 4..5 volts).
                                  4. Need to add the 5V (external) detecting signal to the microcontroller .
                                  5. Many of the components values should be revised.
                                  All these remarks will be taken into account in the new revision.
                                  Everything else works perfectly!
                                  For the first revision of the device, I'm completely satisfied with the result.
                                  • kalinaK
                                    kalinaK
                                    kalina
                                    The second revision of "Raspberry UPS" which now called "Single borad computer UPS" was received yesterday from PCBWAY.com
                                    berkseoB 1 Reply Last reply
                                    • kalinaK kalina
                                      berkseoB
                                      berkseoB
                                      berkseo
                                      @kalina
                                      Privet :)
                                      Great work, I want it (rev2).
                                      • berkseoB berkseo
                                        @kalina
                                        Privet :)
                                        kalinaK
                                        kalinaK
                                        kalina
                                        @berkseo Hello,
                                        First of all I have to check hardware part, and then i am going to develop software. In my opinion, production will be start in a month. I'll share photos of the soldered device tomorrow.
                                        • kalinaK
                                          kalinaK
                                          kalina
                                          #22
                                          First soldered device:
                                          And a small test:
