  2. Announcements
  • MasMatM MasMat
    @anticimex I've built a new node, DHT11 that sends temp&hum data. I reconfigured Rpi with this:
    sudo ./configure --my-transport=nrf24 --my-rf24-irq-pin=15 --my-signing-debug --my-signing=password --my-signing-password=XXXXXX --my-gateway=mqtt --my-controller-ip-address=127.0.0.1 --my-mqtt-user=YYYY --my-mqtt-password=ZZZZZ --my-mqtt-publish-topic-prefix=mysensors-out --my-mqtt-subscribe-topic-prefix=mysensors-in --my-mqtt-client-id=mygateway1 --my-leds-err-pin=12 --my-leds-rx-pin=16 --my-leds-tx-pin=18
    This is what I get in gw syslog:
    Apr  2 22:53:11 DietPi mysgw: Starting gateway...
    Apr  2 22:53:11 DietPi mysgw: Protocol version - 2.2.0
    Apr  2 22:53:11 DietPi mysgw: MCO:BGN:INIT GW,CP=RNNGLSQX,VER=2.2.0
    Apr  2 22:53:11 DietPi mysgw: !SGN:BND:PWD<8
    Apr  2 22:53:11 DietPi mysgw: !SGN:INI:BND FAIL
    Apr  2 22:53:11 DietPi mysgw: TSF:LRT:OK
    Apr  2 22:53:11 DietPi mysgw: TSM:INIT
    Apr  2 22:53:11 DietPi mysgw: TSF:WUR:MS=0
    Apr  2 22:53:11 DietPi mysgw: TSM:INIT:TSP OK
    Apr  2 22:53:11 DietPi mysgw: TSM:INIT:GW MODE
    Apr  2 22:53:11 DietPi mysgw: TSM:READY:ID=0,PAR=0,DIS=0
    Apr  2 22:53:11 DietPi mysgw: MCO:REG:NOT NEEDED
    Apr  2 22:53:11 DietPi mysgw: MCO:BGN:STP
    Apr  2 22:53:11 DietPi mysgw: MCO:BGN:INIT OK,TSP=1
    Apr  2 22:53:11 DietPi mysgw: GWT:RMQ:MQTT RECONNECT
    Apr  2 22:53:11 DietPi mysgw: connected to 127.0.0.1
    Apr  2 22:53:11 DietPi mysgw: GWT:RMQ:MQTT CONNECTED
    Apr  2 22:53:11 DietPi mysgw: GWT:TPS:TOPIC=mysensors-out/0/255/0/0/18,MSG SENT
    Apr  2 22:53:23 DietPi mysgw: TSF:MSG:READ,99-99-255,s=255,c=3,t=7,pt=0,l=0,sg=0:
    Apr  2 22:53:23 DietPi mysgw: TSF:MSG:BC
    Apr  2 22:53:23 DietPi mysgw: TSF:MSG:FPAR REQ,ID=99
    Apr  2 22:53:23 DietPi mysgw: TSF:PNG:SEND,TO=0
    Apr  2 22:53:23 DietPi mysgw: TSF:CKU:OK
    Apr  2 22:53:23 DietPi mysgw: TSF:MSG:GWL OK
    Apr  2 22:53:23 DietPi mysgw: SGN:SKP:MSG CMD=3,TYPE=8
    Apr  2 22:53:23 DietPi mysgw: TSF:MSG:SEND,0-0-99-99,s=255,c=3,t=8,pt=1,l=1,sg=0,ft=0,st=OK:0
    Apr  2 22:53:25 DietPi mysgw: TSF:MSG:READ,99-99-0,s=255,c=3,t=24,pt=1,l=1,sg=0:1
    Apr  2 22:53:25 DietPi mysgw: SGN:SKP:MSG CMD=3,TYPE=24
    Apr  2 22:53:25 DietPi mysgw: TSF:MSG:PINGED,ID=99,HP=1
    Apr  2 22:53:25 DietPi mysgw: SGN:SKP:MSG CMD=3,TYPE=25
    Apr  2 22:53:25 DietPi mysgw: TSF:MSG:SEND,0-0-99-99,s=255,c=3,t=25,pt=1,l=1,sg=0,ft=0,st=OK:1
    Apr  2 22:54:18 DietPi mysgw: TSF:MSG:READ,99-99-0,s=1,c=3,t=16,pt=0,l=0,sg=0:
    Apr  2 22:54:18 DietPi mysgw: SGN:SKP:MSG CMD=3,TYPE=16
    Apr  2 22:54:18 DietPi mysgw: !SGN:NCE:GEN
    Apr  2 22:54:23 DietPi mysgw: TSF:MSG:READ,99-99-0,s=0,c=3,t=16,pt=0,l=0,sg=0:
    Apr  2 22:54:23 DietPi mysgw: SGN:SKP:MSG CMD=3,TYPE=16
    Apr  2 22:54:23 DietPi mysgw: !SGN:NCE:GEN
    This is kicking my butt... I cant understand that last part about the nonce :(
    I will add the code from the node as soon as possible.
    @masmat according to the log parser
    means the password is too short.
    MasMatM 1 Reply Last reply
    • MasMatM MasMat
      AnticimexA
      AnticimexA
      Anticimex
      @masmat and this
      !SGN:INI:BND FAIL
      Means the signing backend failed to initialize. So you need to make the password longer.
        MasMatM
        MasMatM
        MasMat
        @mfalkvidd Made the password 10 characters. From looks of the logs, it's working now.
        I cant believe I skipped the step of making the password longer... Just got too fixated on the password I came up with.
        AnticimexA 1 Reply Last reply
        • MasMatM MasMat
          AnticimexA
          AnticimexA
          Anticimex
          @masmat the nonce failures is because the backend never initialized so basically any call to the backend that can fail will fail.
          • alowhumA
            alowhumA
            alowhum
            I just discovered these USB-to-NRF24 devices. Would it be possible to use that instead of connecting to the GPIO pins?
            https://www.aliexpress.com/item/USB-wireless-serial-module-serial-to-nRF24L01-digital-communication-remote-control-acquisition-module-nRF2401/32722937957.html
            • alowhumA alowhum
              #901
              @alowhum not with the existing code. Is there a datasheet that describes how these modules work?
              One of the reviews says "have no idea wath software to use with this" so documentation might be hard to come by.
                sineverba
                wrote on last edited by sineverba
                #902
                Background: I use signing software on some nodes + whitelisting on a node (of course only PI serial is on the whitelist).
                With current --development branch (I think 2.3.0alpha) I cannot anymore set my previous personalized flags on gateway RPI3.
                In detail, with current master (2.2.0) I can do:
                sudo mysgw --set-soft-hmac-key=F618D4848992B
                sudo mysgw --set-soft-serial-key=26[...]9
                sudo mysgw --set-aes-key=EC7[...]CEB4
                WIth development I did see only the --get[...] flags and cannot set anymore. Can you confirm?
                How can I set my previous values for signing?
                • S sineverba
                  AnticimexA
                  AnticimexA
                  Anticimex
                  #903
                  @sineverba I believe this change alters how rPi port handles signing related personalisation: https://github.com/mysensors/MySensors/commit/3c0b2727a56907277d4d04c985fd72b14e4a483c
                  And, as usual, the documentation is a good place to start ;) https://www.mysensors.org/apidocs-beta/group__MySigninggrpPub.html#MySigninggrphowuse
                  • joaoabsJ
                    joaoabsJ
                    joaoabs
                    wrote on last edited by joaoabs
                    #904
                    I'm currently compiling the code for connecting the NRF24l01+ directly to the Raspberry PI. Since I'm running the controller (on this case OpenHab) on the same Raspberry PI, would it be recommended the Ethernet or the serial flavor of it?
                    In the case of ethernet, can I place the own machine IP (127.0.0.1)? This way, if I need to change the IP address of the PI it wouldn't affect the communication between the controller and the MySensors code, right?
                    --my-gateway=ethernet --my-controller-url-address=127.0.0.1
                    And by the way, for the signing configuration, it is mentioned in the documentation "Update the gateway config file with the generated keys/valeus", what file is that (name, path)?
                    I should be able to re-use the keys I have defined before, right? So I just go to step 2 (no need to generate new keys).
                    I'm refering to this link.
                      --my-controller-url-address=127.0.0.1 is not needed for ethernet
                      • joaoabsJ
                        joaoabsJ
                        joaoabs
                        #906
                        I found that the configuration file is /etc/mysensors.conf but " The first time you start the gateway the configuration file will be created if it does not already exist.", so that's why I wasn't finding it.
                        Anyway, the file states that:
                        "Note: The gateway must have been built with signing support to use the options below."
                        What flags should I include to have signing support?
                        OK, found it: just run ./configure -h and there is a list of options. Leaving it here just for future reference
                        gohanG AnticimexA 2 Replies Last reply
                        • joaoabsJ joaoabs
                          @joaoabs said in 💬 Building a Raspberry Pi Gateway:
                          it is already written in the article
                          • joaoabsJ joaoabs
                            AnticimexA
                            AnticimexA
                            Anticimex
                            @joaoabs
                            Release: https://www.mysensors.org/apidocs/group__RaspberryPiGateway.html
                            Beta/development: https://www.mysensors.org/apidocs-beta/group__RaspberryPiGateway.html
                            • joaoabsJ
                              joaoabsJ
                              joaoabs
                              Thanks for the replies.
                              I've changed the PI from a PI1 to a PI3 and was able to make it working with signing. Its running smoothly, I guess the GW is chosen :).
                              I'll now focus on the nodes, specially the SenseBender micros that are 2xAA battery powered and are consuming ~3% bat per day, but that will be for another post...
                              Joaoabs
                              • D
                                Damian
                                Hi, is there any way to check the current gateway operating parameters? My purpose is to check the radio channel and power level set before compilation but I would be glad if I could check other configurable parameters. I looked at Makefile.inc and found some flags set, but not the information I was looking for (does it mean that the default values are set)? Debug logs neither provide these informations.
                                  What radio are you using?
                                  D 1 Reply Last reply
                                    Damian
                                    @gohan nrf24, one deployment pa+lna version with external antenna and the other standard with build-in "zig-zag" antenna.
                                      I always set gw to max power if the radio is shielded
                                      • joaoabsJ
                                        joaoabsJ
                                        joaoabs
                                        #914
                                        Is it normal to have frequently these errors in the RPI GW?
                                        May 11 00:43:54 nettemp mysgw: RF24: Recovered from a bad interrupt trigger.
                                        May 11 00:43:56 nettemp mysgw: RF24: Recovered from a bad interrupt trigger.
                                        May 11 00:43:58 nettemp mysgw: RF24: Recovered from a bad interrupt trigger.
                                        May 11 00:44:00 nettemp mysgw: RF24: Recovered from a bad interrupt trigger.
                                          Damian
                                          @gohan Well, that is not an answer to my question apparently :) I suppose that max power lever is the default setting according to the configure script's help.
